Old 02-24-2013, 06:18 PM   #21 (permalink)
Default Mounting
All three motors take the std 3mm screws.
EDIT: Note! The Turnigy has two 2,5mm holes and two 3mm holes, so make sure you use the right ones!
Micro: XK K110, Mini: Gaui X2 Formula
Medium: 330X 6S, G380
Big: G500, Align 700E
DX8, Phoenix
Old 02-26-2013, 04:36 AM   #22 (permalink)
Default Mounting part II
Now, as already discovered by sn00p, you can't really use the 3mm screws for the Turnigy. The problem is that the screw holes sit too far apart to fit the motour mount. You'd have to dremel away too much material, leaving no support for the screw heads.
So you need to find a couple of 2,5 mm screws for the Turnigy. Those holes are closer to the center, and fit the 300X motor mount:
The 2,5 mm holes line up with the mount
3mm vs 2,5 mm screws
I used a "sleeve" that often comes with servos to keep the 2,5mm screws in place in the motor mount. Just needed to dremel away the lip.
Then I put on a large washer, an "exploding" washer, finally the sleeve.
You need to really bend the wires in order to pry it into place. And you need to open the frame a bit in the front in order to get the mount in or out.
Turnigy mounted and ready to go!
For the Wicked it was much easier. You mount it exactly like the stock motor, with 3mm screws.
As to the pinons - on both the Turnigy and Wicked, push it as far in as it goes, then secure. It should be approx 12,1 mm from the top of the pinion down to the motor itself.
Btw I did test at the same time some alu aftermarket parts. The MH head doesen't seem to run 100% true, anyone else experienced this? This is with a new 100% straight main shaft. I'm a bit sceptical as to that "clamp solution" where the follower arms are mounted - can you kinda adjust here as to the straightness of the alu head?
The MH alu main blade grips need smaller dia thrust bearing, which was missing in the pack Anyone else tried these?
And OMG that main gear... it's just HORRIBLE how badly cast those are! I really REALLY hope we can get some decent CNC machined gears SOON!!! Gear mesh is super tight on one side, and way too loose on the other side
ID:	398140   Click image for larger version
ID:	398141   Click image for larger version
ID:	398142   Click image for larger version
ID:	398143   Click image for larger version
DX8, Phoenix
Old 02-26-2013, 07:20 AM   #23 (permalink)
Default 300X - motor and ESC alternatives?
Originally Posted by Dylwad View Post
10 tooth, HiModel Cool 33a blheli 9.4, default settings. Approx 3400 rpm. Sab main blades.
Sent from tapatalk
Can you post the links to the parts? What are your flight times like with the stock battery? If you're not using the stock battery, which battery are you using and what r ur flight times on it?
Thnx
sohor1 is offline        Reply With Quote Quick reply to this message
Old 02-26-2013, 09:58 AM   #24 (permalink)
Ive fitted my wicked motor and paired it with a align RCE-BL35P. I have the esc set to low timing as per the little note in the motor box and govener on with soft start. what voltage can I set the esc bec to. I have a choice of 5,5.5 and 6v. I am running the standard cyclic servos and a align ds425 tail servo. I know the ds425 can be safely run at 6v but what about the eflight cyclic servos?
master65 is offline        Reply With Quote Quick reply to this message
Old 02-26-2013, 11:31 AM   #25 (permalink)
4.8 - 6.0 V
http://www.bladehelis.com/Products/D...rodID=EFLRDS76
DX8, Phoenix
Old 02-26-2013, 12:08 PM   #26 (permalink)
Originally Posted by SHYguy View Post
Many thanks, just wasn't sure 6v wouldn't kill the cyclic servos.
Old 02-26-2013, 01:30 PM   #27 (permalink)
So with the 3mm screw holes, even if you move one to the furthest forward in one motor mounting plate slot and the other on the furthest rearward in the other slot they're still too far apart?
Old 02-26-2013, 01:32 PM   #28 (permalink)
Love your home-made frame braces. I was thinking something similar before coming across your pic here.
Old 02-26-2013, 04:27 PM   #29 (permalink)
Thx man! Works wonders! Even better is a dab of hot glue between the two rear servos, that really stiffen things up!
I'll check out that diagonal idea! Why didn't I think of that!
DX8, Phoenix
Old 02-26-2013, 04:58 PM   #30 (permalink)
My wicked motor and cool33a esc should be installed tonight. I have good weather tomorrow. Can't wait to give it a try. The cool33 looks tiny compared to the eflight esc. I'll have to weigh them tonight.
kpod is offline        Reply With Quote Quick reply to this message
Old 02-26-2013, 05:00 PM   #31 (permalink)
Sent from tapatalk
http://helidirect.com/sab-redwhitebl...ht-p-21188.hdx
Are these the sab blades you are running?
Old 02-26-2013, 05:02 PM   #32 (permalink)
Default Re: 300X - motor and ESC alternatives?
Those are the ones
Sent from tapatalk
Dylan ~ www.AstroidDesigns.com
Dylwad is offline        Reply With Quote Quick reply to this message
Old 02-26-2013, 05:28 PM   #33 (permalink)
D, how do they feel compared to the Blade carbons?
DX8, Phoenix
Old 02-26-2013, 05:50 PM   #34 (permalink)
When will the Wicked motor be in stock again? Where can I find the ESC for it? Will the stock ESC work just fine or?
Old 02-26-2013, 10:42 PM   #35 (permalink)
Those are the ones
Sent from tapatalk
Am I missing something? I've got it all hooked up and the ESC is as apparently already armed. When I go to arm, it starts spooling up. I'm on blheli 9.4 with stock settings.
Old 02-26-2013, 11:31 PM   #36 (permalink)
Read the instructions for 9.xx, blheli arms just like any other esc with ppm input, you only have to arm it with some throttle on an mcpx or the like with pwm input so it can learn the signal.
Ppm is always putting out a signal, so the esc Learns it right away and arms if it sees 0 throttle signal, pwm puts out no signal of any kind at 0 throttle.
All is normal im running 75%flat on idle 2.
Sent from tapatalk
Old 02-26-2013, 11:34 PM   #37 (permalink)
I have never flown the blade carbons, I like the sabs better than the MH carbons. They are smoother, and have a little less pop, but are more precise.
Sent from tapatalk
Old 02-27-2013, 12:13 AM   #38 (permalink)
Are you running stock dampeners? I should be getting lynx dampeners tomorrow.
I was able to do a test hover and a few pitch pumps. It seems to be running smooth. I do have a slight tail kick to the right on pitch pumps that I need to get dialed out. I put a tarot radial bearing hub on it so I think my tail kick is due to that.
Old 02-27-2013, 12:50 AM   #39 (permalink)
Completely stock head and swash. I had to dial the collective down a bit with the wicked/10 tooth, and adjusted the tail comp or whatever it's called on the beastx. None of my beastx settings are default.
Sent from tapatalk
Old 02-27-2013, 10:15 AM   #40 (permalink)
I've got some time and good weather today to try and get the beast dialed in and start playing with the esc. I think I'm also going to try cutting some weight off tonight to see how light I can get it. The cool 33a esc is tiny compared to the stock esc. I couldn't find my scales last night to weigh it before installing but it has to be lighter. I would think the weight saved on the esc may offset the weight added by the wicked motor.
Adding the 255 blades should add around 50 square inches of disc area. Cutting down weight and adding the sab 255 blades with this motor esc combo should make the 300x act like I want it to.
