Anyone else waiting to hear about a brushless master cp to go into Production - HeliFreak
Go Back   HeliFreak > R/C Helicopter Support > Walkera Helicopters > Master CP
Master CP Walkera Master CP Helicopter Support
Old 02-01-2013, 03:26 PM   #1 (permalink)
Default Anyone else waiting to hear about a brushless master cp to go into Production
I just don't want to buy the Master CP and then convert it to brushless.
panamacitymustang is offline        Reply With Quote Quick reply to this message
Old 02-01-2013, 04:09 PM   #2 (permalink)
I'm waiting for Walkera to fix the throttle hold delay and fixed ID issues. Converting to brushless is cheap enough and it's a good flyer with the oversized brushed motors anyway.
If you want better 3D performance and BL, go for the V120D02S (on sale for $140 at Wow.)
V120D02S x 2 :: Mini Protos x 2 :: Align Trex150 :: Proto X nano quad
Devo 6 with Deviation flies them all!
Jazzjohn is offline        Reply With Quote Quick reply to this message
Old 02-01-2013, 05:18 PM   #3 (permalink)
That's not bad at all I just wanted something a little bigger I already have a mini cp
Old 02-01-2013, 05:55 PM   #4 (permalink)
Except for the servos, the Master is more forgiving. The V120 has a driven tail which doesn't survive crashes as well. But after a while, you'll get faster at repairing it.
I think the choice would depend on your flying skills and goals.
Old 02-01-2013, 06:48 PM   #5 (permalink)
Well I'm still learning and really haven't crashed much lately. I'm just flying around nothing advanced yet. Has anyone tried the new metal servos they been offering.
Old 02-03-2013, 12:38 AM   #6 (permalink)
I put the metal servos on mine. Only had a few easy flights so far but they seem fine.
Old 02-03-2013, 01:33 AM   #7 (permalink)
Default Master CP MEtal Servo Replacement and Set Up
Hi
Just replaced all 3 servos on my CP to the metal ones. My question is I cant seem to set the pitch on the blades correctly. The default setting on normal mode is -15 at PL, +25 at PM and +55 at PH. My swash is level or seems to be at 0 throttle. However at mid throttle each blade has a different pitch using a pitch gauge. I have set the servo arms to 90 or as close to it but cant seem to get this issue corrected. Any help would be appreciated.
Benrile is offline        Reply With Quote Quick reply to this message
Old 02-03-2013, 01:30 PM   #8 (permalink)
Where on wow??
minidan is offline        Reply With Quote Quick reply to this message
Old 02-03-2013, 02:27 PM   #9 (permalink)
Originally Posted by Benrile View Post
Hi
Throttle stick at mid position arms at 90 and 0 pitch ? If not reset arms and adjust untill you have these set correctly . Also make sure you have a linear pitch curve before you try to set up head .
5488fletcher is offline        Reply With Quote Quick reply to this message
Old 02-03-2013, 03:13 PM   #10 (permalink)
Thanks for the advice. I have the arms at 90 mid throttle and 0 pitch after playing around with it. What should the pitch be at 0 and full throttle respectively? Is it -2 and +9 or 10?
Old 02-03-2013, 03:26 PM   #11 (permalink)
(low stick - 2 deg ) ( mid stick 0 deg ) (high stick +10 deg ) These numbers will give you a very calm collective feel in normal mode .
Old 02-03-2013, 05:59 PM   #12 (permalink)
I'm not 100% sure but if its like most helicopters it should be set -12 to +12
Old 02-03-2013, 07:46 PM   #13 (permalink)
Depends on the heli . On my trex 450pro they say 9-11 deg . 10 deg both ways of center is a good number for beginners . When i stated i ran about -2 at low stick , +4 deg at mid stick and 10 deg at high stick . I dont recommend running +4 at mid though because the transition to idle ups will cause heli to drop when going from normal to idle up modes . You can run higher pitch numbers if your motor will do it without bogging and you don't have binding issues in the head .
Old 02-04-2013, 11:42 AM   #14 (permalink)
Originally Posted by minidan View Post
Where on wow??
It's the "other" Wow, which I didn't realize at the time...
http://www.hobbywow.com/en-walkera-n...id=18283950120
Old 02-06-2013, 05:14 PM   #15 (permalink)
Does anyone think walkera would put a brushless master cp on the market.
Old 02-06-2013, 05:35 PM   #16 (permalink)
pitch is somewhat subjective.....with a heavy heli like the master cp +10 to -10 will probably feel like it doesn't want to take off unless you give it a bunch of throttle. Mine is set at +14.5 to -14.5 there's a little slop in the head so i can't get a perfect measurement but that's pretty close. You just don't want to put so much pitch that the blades slow down significantly at full throttle.
pmerritt is offline        Reply With Quote Quick reply to this message
Old 02-08-2013, 12:47 PM   #17 (permalink)
Where to buy the master cp with the new metal servo gears.
Old 02-09-2013, 05:11 AM   #18 (permalink)
I would guess that you can get a better deal at helircstore don't you think?
Intheway is offline        Reply With Quote Quick reply to this message
Old 02-10-2013, 10:03 AM   #19 (permalink)
$199 there:
http://helircstore.com/walkera-hm-v1...ody-only-green
Old 01-30-2018, 12:58 AM   #20 (permalink)
That was the best answer I've heard come out of this thread, and that's what I did a few years ago, the little 120 is a hand-full to keep up with. I also bought the new 450 series and they are sort of fun as well. We can all dream of what the MCP could have been, but there are options, as you have pointed out.
Andy Sitton is offline        Reply With Quote Quick reply to this message
Human Verification
