Old 10-31-2007, 06:47 PM   #1 (permalink)
Default DX7 Antenna angle?
I read somewhere in one of the Futaba ADs, that most of the signal for a 2.4ghz radio comes out the side of the antenna. Does this mean that on your DX 7 it would be safer to fly with the antenna at 90 degrees? Is the knuckle only there so that it fits in flight boxes etc, or is it more important?
Thanks.
Zoobie is offline        Reply With Quote Quick reply to this message
Old 10-31-2007, 06:48 PM   #2 (permalink)
its more important.
We generally lock the antenna at about a 45 degree angle, and so far have had no range issues.
WayneBrown is offline        Reply With Quote Quick reply to this message
Old 11-01-2007, 01:25 PM   #3 (permalink)
Honestly, it really shouldn't matter at all which way you have it. To get the maximum signal strength between any receiving antenna and any transmitting antenna, the two antennas should be aligned along the same axis. That is, they should be pointing the same direction. We radio folks refer to this a s "polarization". If your antenna on your model is vertical, it will "hear" your transmitter best if the TX's antenna is also vertical. Likewise with a horizontally polarized antenna, but here we introduce another axis: azimuth (the direction the tip of the antenna is pointing).
If your antenna on the TX is horizontal, and pointing at, say 270 degrees (due West), then your receiver will hear it best when it's antenna is also horizontally polarized and pointing at 270 degrees. Signal strength is always lowest when the transmitting antenna and the receiving antenna are "cross-polarized" or put another way, perpendicular to each other.
The thing with antenna placement is, your model's position (and therefore, the antenna's position) is constantly changing as it moves and maneuvers through the air. Therefore, the orientation of one antenna to the other is constantly changing, and so the received signal strength at the model is constantly fluctuating. So, it really matters very little which direction your transmitting antenna is placed. The radios are engineered so that in a worst case scenario (i.e. TX and RX antennas perpendicular and model at outside edge of range) the radio signal strength will be sufficient to maintain control of the model.
Proper antenna / receiver placement in the model will have a much bigger effect on range and signal strength than whether or not your TX antenna is horizontal, vertical, or somewhere in between. Ensure that your antenna is as exposed as you can get it and keep it away from conductive surfaces that can block reception and you'll be fine.
RC Helicopter product reviews and general musings:
The HeliGeek's Blog
http://heligeek.com
jeffk is offline        Reply With Quote Quick reply to this message
Old 11-02-2007, 10:57 PM   #4 (permalink)
Dipole antennas (which is what we use, a quarter wave whip is half of a dipole with the ground acting as phantom second dipole element) do not radiate directly off the tip. So if you point the antenna tip directly at the model, you have the minimum signal going to the model.
But the radiation pattern of a dipole is like a fat donut, so even 3 - 5 degrees angle off the tip has a good signal strength.
Terry
AMA#47402, IRCHA # 3395
Pinecone is offline        Reply With Quote Quick reply to this message
Old 11-04-2007, 08:35 PM   #5 (permalink)
There seems to be two groups of people with regard to "bending" or "aiming" the antenna:
Those who read the internet and carefully set various angles into things.
Those who don't read the internet and just go fly with the antenna in whatever orientation.
After watching many, many, many people in both groups, they seem to get about equal results in the real world at the flying field.
Trex 700E - SuziHans,V-Bar,JR8717/BLS251,X-Era 4030/3Y-460,12S Rhino 4900; SH frames are ~1 Lb lighter than Align 700E kit
Trex 700N - 7100R/[email protected]/GY611
About a dozen more, including 2xTrex 500 - 1 V-Stabi/6S, 1 Flybar/5S,GY770/DS3400G
Danal Estes is offline        Reply With Quote Quick reply to this message
Old 11-05-2007, 05:14 AM   #6 (permalink)
Heres my validation, Watch someone fly. most folks face the machine, pretty common. Some folks use body english and twist and turn too. With Pinecone's description of a dipole antenna in mind, you are most likely one of the folks who FACES the model you are flying, directly in the weakest plane of signal. Crank the antenna at an angle, and you always have the antenna pointed elsewhere besides the model.
Back in the day of AM radios, you'd get by with pointing the antenna at a model for a couple hundred feet, and lose it. Rotate the tip 90* and regain control. Lessons learned then still apply in some respect to the newer technology.
Old 11-05-2007, 09:57 AM   #7 (permalink)
A 2.4 GHz antenna on a spektrum or futaba radio is not a dipole by any stretch of the imagination. Unless you're 3 inches tall, the ground is so far away from the antenna (electrically speaking) that there's no possible way it can act like the second leg of a dipole. If anything, it's using the circuitry in the radio, or even the carrying handle as a ground plane.
In any case, an antenna such as we have on our transceivers is so inefficient that we as average users couldn't possibly begin to plot the radiation pattern. With all the pattern interfering objects in the way (not the least of which is your body, which distorts e-fields at 2.4G quite effectively) you might as well give up on predicting where your signal strength is maximum. Also, you're very rarely pointing the tip of the antenna directly at the model. this is why I maintain that polarization would be the only real factor that you could do anything about, but even if you did, a moving model negates anything you CAN do.
If you're really in doubt, do a range test. Try the antenna in various positions, pointing at and perpendicular to the model. To simulate the relative antenna position, move your transmitter to different angles relative to the model. Turn the model around from all angles. This ought to give you a pretty good picture of what's going on.
The HeliGeek's Blog
http://heligeek.com
Old 06-25-2020, 04:46 AM   #8 (permalink)
I have done all the tests, following a crash for the firtst time in 15 years. Let me just say, and I will put it mildly, the results are not in favor of the statement that 'direction of the TX antenna doesn't matter'. The difference in range with european 100mW is more than 30%!!!. That equates to a mere 100-150 meters. Angled : 200 meters and more
Oostdam is offline        Reply With Quote Quick reply to this message
Old 06-25-2020, 07:07 AM   #9 (permalink)
Very true. The radio signal radiates "sideways" from the length of the antenna. There's hardly any signal coming from the tip, so if you spend most of the time flying with the tip of the antenna pointed at your aircraft, the signal is not going to be very good for the receiver in the aircraft.
Fast forward to 2020 (this is a pretty old thread), and now most of the newer Spektrum transmitters have antenna diversity, which means there's a second antenna in the handle of the transmitter that sends a signal in a direction that's perpendicular to the main antenna. Many receivers have dual antennas as well that you want to position pointing in two different directions. Between the two antennas in the transmitter and the two antennas on the receiver, signal should get through much better regardless of how the transmitter and the aircraft are positioned relative to each other.
flightengr is online now        Reply With Quote Quick reply to this message
Old 06-30-2020, 08:52 AM   #10 (permalink)
Hello,
My DX8G1 and Devo10 let me move the antenna 90 degree sideways.
I don't hold the transmitter in front of me in any weird angle (with a neckstrap or pult) that I would clearly point the antenna tip to the ground....like it was suggested by users for the DX10T.
Instead the TX is pointing levelled "forward" (even on the strap) in a normal way in front of the stomache.
Yeah, most.
The Dx6e and DX8e do not have diversity.
https://www.spektrumrc.com/Content/M...Comparison.pdf
Looking back:
I did not really understand why HorizonHobby came up only with a fixed perpendicular antenna design on the black DX6G2 (Super V2) and DX7(G2).
That fixed design won't allow us pilots to move the antenna 90 degree sideways like we usually do on our transmitters which do not have 1-2 internal patch antennas.
But the benefit of this of course is that you do not damage the plastic antenna on the inside (articulated joint) that quickly; I broke 2+ antennas on the DX8G1.
Now both these "older" (well not really) Spektrum transmitters are discontinued and are replaced by the DX6G3 and DX8G2.....which both have diversity.
I had opened a thread -- in October 2014 -- about that fixed "new" antenna design about the "DX6 Super V2" (with missing diversity) in a German RC forum but nobody from HorizonHobby bothered to answer:
HF Abstrahlung bei nur einer fix montiert senkrechten Sendeantenne
Instead they responded with the new diversity successors in the lower/mid entry range
What a coincidence!
Not that I would really think that a US company bothers to read through threads in a German RC forum :-)
I am still curious.
Q: Does anybody know for sure with a profound electrical engineering background how the HF exactly works with a "fixed antenna design" (Dx6G2/Super V2, Dx6e, black DX7, DX8e) -- without diversity -- when you do not point the transmitter with the tip to the ground (not only holding it in your hand with that angle but having a strap) but instead you follow the aircraft/heli?
I am happy for any interesting link.
Did the engineers change the HF module somehow? Is it using a different modulation? Adjusted firmware?
How can this be accomplished when there usually is no/not much radiation on the tip (apple principle)? What could be adjusted to make it work?
Best regards from Germany
Walkera Devo 10/DeviationTX (12CH DSMx & telemetry)...Ex-DX8...Blade 4503D...Walkera V120D02s...XK K110...Blade 200QX quad...Ex-NanoCPX...Ex-120SR...StrykerQ (LEDs, M2 tuning)...Ex-MPX EGP...PPZ P51-D...PZ Wildcat (searching fuselage-firewall)
Thomas.Heiss is offline        Reply With Quote Quick reply to this message
Old 06-30-2020, 11:36 AM   #11 (permalink)
On HF?? Probably not.
On RCG in the radio forum - absolutely. It seems like the entire Engineering staff from Spektrum / Horizon Hobby is on the forum answering user questions about everything.
But, they may not speak German.
"Those who can make you believe absurdities can make you commit atrocities." (Voltaire)
Watch out: There are a lot of absurdities being thrown around lately.
+ > RIP: John Lewis
