Go Back   HeliFreak > R/C Electronics Support > Spartan RC > Spartan Vortex
Spartan Vortex Spartan RC - Vortex VX1 Factory Support Forum
Old 05-29-2013, 02:05 PM   #21 (permalink)
Member
Originally Posted by the pond dweller View Post
Hi Bob and thanks for reply. The main issue is that the datapod is not toggling between flight modes when the tx switch is moved.
First your gyro menu, gov menu, whatever you're using to tell the DataPod/Vortex what channel to expect a gyro signal on, it must be tied to your flight mode switch in the transmitter. Only then will the DataPod/Vortex track the flight mode switch.
Old 05-29-2013, 04:30 PM   #22 (permalink)
Default flight mode sync to governor values
Hurrah!! checked through tx manual, (JR DSX9ii) and of course found that with a raw model set up, I needed to enter Gyro Sens (Gyro Gain Function) and set to auto mode. Now seeing flight mode numbers in datapod.
Thanks for advice so far.............more may be sought!!
the pond dweller is offline        Reply With Quote Quick reply to this message
Old 05-29-2013, 06:26 PM   #23 (permalink)
Member
Good to hear!!
BTW, if your radio is like mine, the Gyro menu will only allow for three different values, therefore you will end up one short.
If you have a governor menu, it could allow for four different values. That's why I used the Gov menu instead.
Old 05-29-2013, 06:31 PM   #24 (permalink)
Wink
Thanks Bob, my radio is the same and I'm using the governor menu like you. I also had to asign a different channel in the data pod to see the correct tx channel. All good now and working my way through the rest of your vids.....brilliant
Old 05-29-2013, 09:44 PM   #25 (permalink)
Member
Okay, glad to hear it's working now.
Also, the videos I made were before M3, so they don't cover some steps added afterward. Check this thread for a run-down on the additional steps for Swash Setup. You shouldn't have any problems with them.
https://www.helifreak.com/showpost.p...2&postcount=14
Old 05-30-2013, 06:02 PM   #26 (permalink)
Post
Thanks Bob,
Just staretd again tonight and find that in Swash menu, Ail/Elev 8 deg section, I can't get less than -9.0 deg and in either. Any advise please?
Old 05-31-2013, 10:30 AM   #27 (permalink)
A friend has suggested moving the futaba servo wheel balls in by one hole ( bls 451's), so will give that a go before proceeding.
Old 05-31-2013, 08:11 PM   #28 (permalink)
Member
Default Re: The Spartan DataPod thread w/ firmware update guides
Do you also have a very low value when setting your max collective? Moving the balls on your cyclic servos in one hole should help out both situations. Let us know how you make out with that.
Sent from my phone
Old 06-03-2013, 08:56 AM   #29 (permalink)
I have just ordered new flybarless servo wheels (Align for Futaba) with two hole spacing, which the guys at the field use on their 700n's and acheive all the correct values in the Vortex. Will be next week before I get back in this and will advise outcome.
Old 06-03-2013, 09:21 AM   #30 (permalink)
Member
Those must be the Align 3G wheels. The inner holes worked great before the DFC head came out. Some guys running the DFC head have had to use even narrower spacing than that (being the DFC head design provides so much more blade deflection).
Let us know how it goes.
Old 06-26-2013, 07:20 AM   #31 (permalink)
Bob,
Sorry, but I thought I had updated this earlier. New servo wheels fitted and all the numbers are now good and well within the required ranges. Just the governor set-up left to complete the basics and then test fly. Had good flying weather here recently and been away, so this has been on the back burner.
Regards
Charles
