Old 02-22-2013, 09:39 PM   #1 (permalink)
Default So I just programmed my Jive 120+
I set Heli Mode 4 and I went to Mode 7 to reverse the motor rotation. Is that the mode you guys are using with a VBAR or are you using 8 and letting the VBAR do the governor?
I also notice that they are calling for us to use the second (Slave) BEC channel to allow additional copper for servo currents above 2A. Second ring and the whole works. You guys doing that? I wish I would have read that prior to doing the rest of my wiring.
Rick
Helifreak, the place to be!
rdlohr is offline        Reply With Quote Quick reply to this message
Old 02-22-2013, 10:38 PM   #2 (permalink)
I haven't set my Jive up yet, but I am not using the internal BEC. I am using a 2S pack and Scorpion BUG.
Bryan AMA# 982814
"No-Neck R/C"
backburner1955 is offline        Reply With Quote Quick reply to this message
Old 02-22-2013, 10:49 PM   #3 (permalink)
OK. I'm using the Jive and a bug.
Rick
Old 02-22-2013, 11:04 PM   #4 (permalink)
Rick, mode 4 over here, 2200 RPM and LOVING IT!!!!
Rush 700 * Trex 700N x 2 * Trex 600Pro * Goblin 570 * 450L Dominator - V-Bar on all
AMA #934662
caralmar is offline        Reply With Quote Quick reply to this message
Old 02-23-2013, 08:41 AM   #5 (permalink)
Cool, thanks. Did you use the second Slave BEC wire?
Rick
Old 02-23-2013, 09:33 AM   #6 (permalink)
Rick, you can just plug the slave BEC wire into the V-Bar for a little power redundancy.
onlyfinehelis.com
mmickels is offline        Reply With Quote Quick reply to this message
Old 02-23-2013, 09:39 AM   #7 (permalink)
Rick
I don't use the built-in BEC at all. I removed the red pin from the throttle lead and just use my WR BEC and the Scorpion Backup guard.
AMA #934662
Old 02-23-2013, 09:42 AM   #8 (permalink)
Yep, that's what I am planning. I was just wondering if anyone else was doing it.
OK, thanks.
Rick
Old 02-23-2013, 09:45 AM   #9 (permalink)
Sorry, to answer your question, Yes, they suggest that you use a slave cable for redundancy and added current support for the BEC. I was going to use teh BEC, and originally I had both master and slave cables on my ESC, but now that I am running a 2S and BUG, there are 3 points of power on my FBL controller. (1) from the BUG and (2) from the LiPo using this...
Bryan AMA# 982814
"No-Neck R/C"
Old 02-23-2013, 11:34 AM   #10 (permalink)
OK, thanks. That makes sense. Regardless of the source, to get current above 2A, it makes sense to use more cables to get more copper into the equation. Thanks much!
Rick
Old 02-23-2013, 01:57 PM   #11 (permalink)
I use something similar that I made up myself. It provides power into 4 of my free Vbar servo connections. Wanted to be on the safe side with my HV servos
Down in the bottom right corner...
Jacob
Rush 700, Synergy N5c tt, MA Fury 55, Trex 450 pro, Blade 130X
jmdanna is offline        Reply With Quote Quick reply to this message
Old 02-23-2013, 02:30 PM   #12 (permalink)
The lightest setup you can use is the internal BEC with a small 800 mAh 4.8V Eneloop buffer pack. I've been using it for hundreds of flights. The pack is 1/2 the weight of the Scorp BUG, and you save the 80g of an external BEC.
Yes, use the slave cable. If you are using a miniV and sBus, you can plug it into the RX if you have to. I always remove the rings. On my last build I got different shorter heavier gauge male-male cables instead of using the Kontronik ones... works awesome as always. The copper isn't the weak/resistive point... it's the plugs. Doubling up cuts the plug resistance in half. A single plug will MELT at 4 amps continuous.
JIVE is a bulletproof setup, and the buffer pack decreases the BEC current spikes significantly (per JLog readings) so the Kon BEC lives a very easy life. Plus... you never have to charge the buffer.
I don't get why someone would spend the extra $$$ for a JIVE and not use the BEC, but then again I don't get the HV servo craze either. Convenient on a nitro where you must have a RX pack, but performance/feel differences seem negligible. I'll only go HV when I'm forced to.
1 - Diabolo 1 stuffed with, well, see below
2 - Diabolo 2 stuffed with testosterone, jittery sweat, and rippling flanks
OverTemp is offline        Reply With Quote Quick reply to this message
Old 02-23-2013, 06:00 PM   #13 (permalink)
I asked two buddies who fly Kontroniks about this and both advised me that they had shutdowns when using the internal BEC. I like being able to power up my electronics without having any power to the ESC so I can work on the heli while on the bench and not feel like an accident could ruin my day.
For these reasons, I choose to use a BEC and a backup guard. The backup guard is tiny and weighs next to nothing... weight isn't an issue on such a powerful beast of a heli.
AMA #934662
Old 02-23-2013, 07:13 PM   #14 (permalink)
Theoretically, there is no reason for an internal BEC to be any less dependable than an external BEC assuming it is a quality design. That's why I have often paid the premium to get Kontronics ESCs. I've run a lot of hours on Kony BECs and never had a problem. Is this unique to the 120+? I have no experience on this BEC.
Old 02-23-2013, 07:25 PM   #15 (permalink)
They both run the 120+. Once I heard "shutdown" I ran the other way!
AMA #934662
Old 02-23-2013, 07:43 PM   #16 (permalink)
OK. Did they use the extra slave cable?
Old 02-23-2013, 07:47 PM   #17 (permalink)
I don't know. I'll ask one of them tomorrow when I see him at the field.
AMA #934662
Old 02-23-2013, 07:50 PM   #18 (permalink)
Thanks Carlos. This is the first time I ever heard of a Kony BEC having problems. Good thing I have the BUG.
Rick
Old 02-23-2013, 11:27 PM   #19 (permalink)
Ask them what model number of servos they were using. There were certain servos (JR I think) that had some feedback/back EMF issues that were causing the JIVE to shut down.
I insist on Futaba brushless servos for their long life and very low current draw and have never had a problem
Old 02-24-2013, 09:45 AM   #20 (permalink)
Great I have JR 8717s.
