Go Back   HeliFreak > R/C Helicopter Support > Gas Powered Thoughts
Gas Powered Thoughts Advice for Gas Helicopter Success from Carey Shurley
Old 08-10-2014, 08:36 PM   #41 (permalink)
Started assembling my kit tonight. How are you guys securing the servos? On my align the servo screws anchored into the servo trays and obviously that won't work for the Helix.
I've got a couple ideas, but wondering what has worked for others?
Whiplash Gasser l Goblin Gasser
in2deep is offline        Reply With Quote Quick reply to this message
Old 08-11-2014, 09:37 AM   #42 (permalink)
Originally Posted by george_4789 View Post
Oh...really? Got my frames already from Tin but have only limited time for the build so progress is very slow...thanks for your reply
I am not Tin, I am just a lucky dude that is getting to do some testing for him on this new design is all.
the original kit is a wonderful heli, you will enjoy it for a very long time.
Gasser Mike
Team KDE Direct, TRM Power, Byron Fuels, MKS Servos
LoveToFly1 is offline        Reply With Quote Quick reply to this message
Old 08-11-2014, 09:38 AM   #43 (permalink)
I used M3x8mm bolts and lock nuts. overkill, I know, but that's what I used.
Gasser Mike
Old 08-16-2014, 04:26 AM   #44 (permalink)
I used the W type servo nuts from hirobo
george_4789 is offline        Reply With Quote Quick reply to this message
Old 10-08-2014, 02:48 PM   #45 (permalink)
Does the fuel tank stopper need to be changed for gas operation?
Don S is offline        Reply With Quote Quick reply to this message
Old 10-08-2014, 03:53 PM   #46 (permalink)
the align tank stopper itself is fine in the gasoline. it is the fuel line that is the most important to change.
you will benefit from the quick-uk fuel tank blanking plug retainer that prevents the other stopper from leaking though.
http://www.quickuk.eu/products/3132/...r_tx7f-04.html
Gasser Mike
Old 10-09-2014, 07:12 AM   #47 (permalink)
I used M3x8mm bolts and lock nuts. overkill, I know, but that's what I used...
...I used the W type servo nuts from hirobo
I use the "PEM" nuts MA used to sell. I'll have to find another source once I'm out.
Team Miniature Aircraft
"I love the smell of Nitro/Gas in the morning!"
Citizen 654
rcnut is offline        Reply With Quote Quick reply to this message
Old 10-09-2014, 08:37 AM   #48 (permalink)
I fly gas airplanes, so I know about the fuel tubing thing. Thanks for the stopper tip. One more question, does the tank still suck in on these? I saw that other thread yesterday.
Old 10-09-2014, 08:44 AM   #49 (permalink)
if the tank is properly vented, it will not "suck in"
if you use a one way vent, if the tank sucks in the vent needs to be replaced
otherwise with the looped coil vent the only way this will happen is if the tube gets plugged somehow
Carey Shurley
Proprietor - Gas Powered Helicopters
carey shurley is offline        Reply With Quote Quick reply to this message
Old 10-09-2014, 08:54 AM   #50 (permalink)
thanks
Old 10-09-2014, 09:25 AM   #51 (permalink)
the tank doesnt suck in like Carey is talking about unless the vent it messed up.
but the tank does still do what they were talking about in that thread. over time, the tank will become a little more transparent, and a little softer. i really dont know why it does this either....but i have not had an issue with it. it got a little transparent, and a little softer, then stopped.....never got any worse. still working perfectly today.
Gasser Mike
Old 10-31-2014, 12:16 PM   #52 (permalink)
Can your donor 700 be an electric or does it have to be a nitro? Thanks
4 stroke flyer is offline        Reply With Quote Quick reply to this message
Old 10-31-2014, 02:04 PM   #53 (permalink)
the new one i am flying is for an electric. as far as the WEBSITE says, the older model is for a nitro conversion.
didnt you get everything you needed from me at IRCHA? if so, all you need is the nitro tail box, everything past that and the electric is the same. you got KDE bearing blocks, head and mainshaft, and the complete clutch assembly from me at IRCHA. so all you need is OWB hub, gears, and the tail box....that just dawned on me. sorry, i would have mentioned that in the PM if i had thought about it.....
Gasser Mike
Old 11-05-2014, 12:52 PM   #54 (permalink)
It depends on which parts you are looking for. I built up one of these kits by purchasing parts, instead of a donor. Most of the parts I bought were for an electric Trex. I can't remember which parts were Nitro specific. Fuel tank obviously... main bearing blocks maybe?
-Rob
Managing Director
NOVAerial Robotics Inc.
R_Lefebvre is offline        Reply With Quote Quick reply to this message
Old 11-11-2014, 07:49 AM   #55 (permalink)
I'm leaning towards getting this kit with a TRM VX-275 modified Zenoah engine. I can't seem to find a Gens Ace 3200mAh LiFe pack anywhere.
Any other good LiFe packs out there to recommended?
Anyone have video of their G700?
_________________________________
Trex 700N,600N,700e DFC, Fusion, Goblin500, Blade450x, Helix G700(in progress)
Frankcm1 is offline        Reply With Quote Quick reply to this message
Old 11-11-2014, 12:12 PM   #56 (permalink)
Here you go...
Badd Gass at The Southwest Heli Rodeo in Phoenix 11-8-2014 (5 min 0 sec)
doug
TRM Power - RC Racing Engines - - VP Racing / Powermaster Fuels
Aero Hobbies - Lewisville, TX (972) 420-1414
Doug Darby is offline        Reply With Quote Quick reply to this message
Old 11-24-2014, 04:23 PM   #57 (permalink)
Personally I dont use anything but the orignal:
http://hangtimes.com/a123_packs.html
Bit of a weight penalty over generic LiFe but they will take a beating none of the clones will.
-Jeremy | AMA L7278
MA Whiplash-Gas (G2 conversion), HelixHeli G700 TRex gasser, T-Rex 450 FBL conversion.
A bunch of elec, glow & gas airplanes
, Futaba 18SZ
jharkin is offline        Reply With Quote Quick reply to this message
Old 11-25-2014, 10:56 AM   #58 (permalink)
How dose the HelixHeli G700 compair to the goblin gasser? What's the average weight of the HelixHeli G700 without fuel in it?
joecass2 is offline        Reply With Quote Quick reply to this message
Old 12-02-2014, 06:58 PM   #59 (permalink)
Mine weighs 5kg without main blades or fuel (well there's a tiny bit of fuel in the tank). So depending on blades it will be 5.4kg ready to fly without fuel.
(This is with a 2200mah RX pack, SK540 FBL, G260RC engine)
2009 TDR, Kasama Dune and Faifa, Minicopter Triabolo 700, RMJ Raptor gasser,
Beam E4 and Avantgarde, JR E8 leggero, Suzi Laos, Shape S8, Compass Knight 3D, Robbe Futura SE and Dyna-X, Trex 500.
trillian is online now        Reply With Quote Quick reply to this message
Old 12-02-2014, 07:46 PM   #60 (permalink)
Thanks for the reply. So you will probly be around 12lbs with a full tank. That's realy light. Dose the 260RC Weigh the same as the TRM 300 RC?
Human Verification
