Old 11-19-2007, 10:09 PM   #1 (permalink)
Default suggestion for best blades for 600e
I am looking for suggestions for the best fit for blades for a 600e that I am setting up for AP. I would like good stable lift etc etc
I have had a look at the TST V blades and have sent them an email with a similar question without reply
Hitchingbar is offline        Reply With Quote Quick reply to this message
Old 11-19-2007, 10:55 PM   #2 (permalink)
radix are efficent and probably one of the better blades for ap.
TREX 600 CF, TREX 600 MF, JR X9303/XP9303.
MAAC# 76893
simarRC is offline        Reply With Quote Quick reply to this message
Old 11-19-2007, 11:39 PM   #3 (permalink)
SAB 620mm on 10s or 12s
misio is offline        Reply With Quote Quick reply to this message
Old 11-20-2007, 12:23 AM   #4 (permalink)
What does ap means?
Manol is offline        Reply With Quote Quick reply to this message
Old 11-20-2007, 01:19 AM   #5 (permalink)
Originally Posted by Manol View Post
What does ap means?
Aerial Photography
Like this
BTW, I'm using NHP razor 620 pros on 10s
I want to try the Radix also because of its ultra wide chord.
T-Rex 600 HFE-stretched to 700, 10s, Tango 45-08, Jazz 55, JR7703D/S8900G, DJ Vegh nose cam mount.
T-Rex 600 HFX-stretched to 700, 10s, Orbit 30-12, Jazz 55, GY611/S9256, Askman 360 mount.
JR X9303.
bullaculla is offline        Reply With Quote Quick reply to this message
Old 11-20-2007, 02:43 PM   #6 (permalink)
Why wouldn't you use flat bottom semi-symetrical blades for AP? The shape gives better lift when upright. Just don't go inverted with them .
StatiC is offline        Reply With Quote Quick reply to this message
Old 11-20-2007, 02:59 PM   #7 (permalink)
Balloons in the wind. a slight gust will pop the heli up, and if the wind dies, it will fall out of the air. I do have semi symms, but only use them when its really calm, or steady wind.
AND, just try finding flat or even semi symm blades in 600-620mm size
JR X9303.
Old 11-20-2007, 03:04 PM   #8 (permalink)
bullaculla, Good info. I didn't know about the ballooning issue with semi-symetrical blades.
Old 11-20-2007, 03:12 PM   #9 (permalink)
If you really need more lift, I got my semi symms from heli world. the rotortech 610s.
Also, they will pull less amps in a hover compared to symmetrical blades.
they are very nice! I even use them to fly sport sometime with my play 600. can hover inverted no problem
JR X9303.
Old 11-20-2007, 03:18 PM   #10 (permalink)
If you hover at +5 pitch with semi-symetrical blades, where do you think you hover inverted (-7 or maybe more)? I wonder how much pitch it takes to make up for the flat bottom when inverted.
Old 11-20-2007, 04:39 PM   #11 (permalink)
Thanks guys that is some great info. I am glad to see that there are some people using the 600e for 'Ariel Photography'
I would also be interested in the motor gearing setup that is used.
thanks
Old 11-20-2007, 08:15 PM   #12 (permalink)
Not sure, but the semi symms are so close to symmetrical that its hard to tell the difference in profile between top and bottom. I dont think there are any flat bottom blades for anything larger than a 450. and actually, the semis create so much lift at high HS that a stock trex600 can hover at 2-3 degrees pitch.
thanks
Actually, there are quite a few people using totally stock trex600s for AP. you should check out our AP section.
JR X9303.
Old 11-21-2007, 12:16 AM   #13 (permalink)
I run 600mm Radix on main and 95mm radix on the thrusted tail. Helical spur & 11 tooth pinion. Stock 1650kv motor, Stock ESC, Flightpower 6S 4900's & 5000's. Works great for AP & when I take off the camera mount they perform well for play.
Conway V
Scene From Above Photography
www.scenefromabove.ca
Gaui X7 Cameraship
SFACV is offline        Reply With Quote Quick reply to this message
Old 11-21-2007, 07:36 AM   #14 (permalink)
Originally Posted by bullaculla View Post
Aerial Photography
Like this
every time i see your bird I shivver in envy i want a ap setup
Ginvent is offline        Reply With Quote Quick reply to this message
Old 11-21-2007, 11:17 PM   #15 (permalink)
That pic is old. You should see it now
Looks pretty much the same, but I did some high vis mods, and it has the tango and new light swash, plus the X9303
Now that I have more channels, i have my AP2000i dialed in and have a slider for gain adjustment.
Also, I have all the parts to stretch to 690s, and that will get the power jazz
JR X9303.
Old 11-22-2007, 08:52 PM   #16 (permalink)
I shoudl report you you evil son of a
Old 11-30-2007, 07:32 PM   #17 (permalink)
#4 AP = Aerial Photography
pfatz is offline        Reply With Quote Quick reply to this message
Old 11-30-2007, 07:39 PM   #18 (permalink)
Hitchingbar, I never get an answer from anyone except xtrema who made my charger/wattmeter. Super service. The Online Hobby Stores don't care if we have a question.......take it down the road is the attitude!
Old 12-25-2007, 02:10 PM   #19 (permalink)
Question
Unless you want to take sky photos, you really don't need to go inverted.. LOL
I'm hesitating between the semi symmetrical Rotortech 610 mm (CN266175C) and the semi symmetrical from Carbon Tech 610 mm H6175C. Bird is Thunder Tiger E-620.
Any ideas more than welcome.
Happy flying.
E-620: Kasama head and tail, Phoenix HV120 ICE2, Lipo 10S, custom CF frames, Z-50A 600 V.2. Gyro: DS-760. Servos: BLS451 BLS251.
henrik04 is offline        Reply With Quote Quick reply to this message
