Old 04-19-2013, 07:18 PM   #1 (permalink)
Default how to limit my cyclic pitch
please help me
how can i limit my cyclic picth on my heli
on a setup menu there ins't any menu to limit the travel of cyclic,
there you go.. after finish through the menu on the bench i found that my cyclic around 14deg. binding anywhere except low collective.
i am using futaba 8fgs.
lev.
Trex 700e Vbar 5.3pro,Goblin700c Vbar
JR260Z gasser dji ace one, Trex 450 pro flybar, Futaba 8FGS.
levpardede is offline        Reply With Quote Quick reply to this message
Old 04-20-2013, 01:56 AM   #2 (permalink)
Swash setup click expert blue hat and cyclic ring is the setting you change
helicraze is online now        Reply With Quote Quick reply to this message
Old 04-22-2013, 07:29 PM   #3 (permalink)
thank you sir
but seems it is for pro software, mine is express.
so i went to limit on my tx at swash ring menu at 85
still binding at full collective
but i guess it won't travel that much during flight
am i correct...
Old 04-23-2013, 02:28 AM   #4 (permalink)
TdB
Swash ring in your TX won't have any effect.
The V-bar will use as much cyclic pitch as needed to achieve a certain roll/flip rate.
So it can still bind.
T
Certified Flight Instructor
TdB is offline        Reply With Quote Quick reply to this message
Old 04-23-2013, 02:47 AM   #5 (permalink)
you need to upgrade to pro software
Old 04-23-2013, 06:08 PM   #6 (permalink)
tim & helicraze
thank's for your respon.
i read similar thread about this, if swash pitch move that much on the bench
doesn't always did the same in the air.
i will try that setup later and see what happen
just a bit scare if my ball link pop up because of it..
Old 04-23-2013, 07:46 PM   #7 (permalink)
Originally Posted by levpardede View Post
please help me
lev.
You mention you're getting 14* cyclic. Are you checking this outside of setup? If you are you can't go by that.
Even if you have Pro, when you go to adjust your cyclic ring you do it in setup after getting your 8* cyclic pitch and checking for binding.
Never bother checking pitch values outside of setup mode. It will drive you nuts.
#nodroneshere - 104
Old 04-23-2013, 09:30 PM   #8 (permalink)
yess
it is outside setup menu cyclic pitch is around 14*
the mini has pro software now and more tweaking on a hat tab,
let see what i can do and might need some help here..
just order hobbywing rpm sensor from ebay
for governing setup i may want to start a new thread.
thanks
lev
Old 04-24-2013, 12:34 AM   #9 (permalink)
Yeah I thought it might have been out of setup. Ignore that measurement. Just make sure you have the 8* on the cyclic setup page and then go back to the Swash tab in setup and check for binding. Adjust cyclic ring there (in the pro settings) if needed.
#nodroneshere - 104
