Go Back   HeliFreak > R/C Helicopter Support > Compass Helicopters > Warp 360
Warp 360 Compass Warp 360 Model Helicopter Discussion
Old 04-13-2013, 03:31 PM   #1 (permalink)
Exclamation New Compass motor can may not work with Koby 55
I got the new motor can this Thursday and I was flying today.
After the second flight I got smoke signs...
I was hovering at this point and did nothing fancy before.
Luckily I still had power on the servo so I could auto here down and had no damage.
Here are the pictures. I will contact Mike and Kontronik about this and report back
Logo 600 - Warp 360 - Blade 130X
TeamHeliProz.com
falke398 is offline        Reply With Quote Quick reply to this message
Old 04-13-2013, 04:35 PM   #2 (permalink)
Default kontronik
those kontronik burn as much as the old castle creations at only twice the price, what a deal.
frito169 is offline        Reply With Quote Quick reply to this message
Old 04-13-2013, 05:43 PM   #3 (permalink)
I wouldn't be so quick to blame it on the motor not working with that ESC. Can you pull the can and investigate? The motor could have shorted out internally. I have had this happen to a few motors in the past, the latest being a scorpion 4025-550 last June.
Are you sure you did not accidentally nick the windings when you re-built the motor?
And, are you sure that its not possible that a screw or other debris could have been in the can when you installed it?
Just things to look for, I'm not saying it is your fault... it could have been a defect, or it could be the ESC as you stated.
~SAB~ Goblin 700 ~Compass~ Warp 360 ~Blade~ mCP X (BL)
AMA# 977012
**Team BOCA Bearings**
BaconRaygun is offline        Reply With Quote Quick reply to this message
Old 04-13-2013, 05:57 PM   #4 (permalink)
I have not investigate the motor yet. But will do so and report back.
I am a very careful builder and I am 100% certain that there was no mechanical flaw one could catch during the build.
When I exchanged the can I looked at the motor for any kind of wear or anything out of the ordinary...
I used this motor with the old can and the resonances for about 60 flights but my vbar did not like it during take off.
There is always a change of this having nothing to do with the ESC motor combo... but there is a trend...
TeamHeliProz.com
Old 04-13-2013, 08:16 PM   #5 (permalink)
Hey man, I hope it didn't sound like I was knocking your build skills, as that was not my intention!
I'm curious to hear if anybody else is running this combo. I know many are running the yep as well as yeg and some CC ice and ice lite 50's (I'm using an ice 50 lite and a scorpion 2025-1360, but I have not re-built after my failed maiden).
Just suggesting other variables, that's all.
Hope you get her flying soon my friend.
AMA# 977012
Old 04-13-2013, 09:08 PM   #6 (permalink)
I hate to see something like this at least your bird is ok. On the first flight it didn't seem hot or anything? I would also say the wires touched outside the can where they sit or possibly even inside the can from seeing similar instances in my ventures. I haven't seen a Compass motor fail but I am certain none are truly immune. It's scary how little enamel there is on the wires to be able to wind these things how we need but it doesn't take much to cause an initial point of failure. A good thorough investigation of the motor should be enlightening at least we know where the fire started. I certainly am not qualified to rule out an incompatibility after all I am not even running that esc.
r/c helis lifestyle
HeliSmith is offline        Reply With Quote Quick reply to this message
Old 04-13-2013, 11:22 PM   #7 (permalink)
The temps of the first pack were hand warm. Temps way below 50C of the ESC and Motor.
No problem. I am looking for input and other people having similar experiences. Or let people know that there is a risk...
TeamHeliProz.com
Old 04-14-2013, 05:05 PM   #8 (permalink)
Default Update on the motor.
I pulled the motor off and inspected it...
All 2 windings are burned equally which indicated that the current went through the whole wire and that there was no short circuit.
I could not measure a resistance between the burned windings. Most likely the start point where all 3 winding meet has no connection anymore.
I could measure a resistance between the winding which were ok and one of the burned ones.
50mV @ 1A => 50mOhm which seems to be a good value. (HK-2520-1360 has 38mOhm)
Before I took the motor off the mount I measured the resistance between the mount and the windings... no connection. So no screw punctured the wires.
TeamHeliProz.com
Old 04-14-2013, 08:40 PM   #9 (permalink)
Default New Compass motor can may not work with Koby 55
Definitely report the issue to Kontronik to see what they say. I was able to locate other compatibility issues using Google. I didn't believe it could possibly be the esc at first but I stand corrected. It might be good to document your setup with this failure also. Pwm, timing, were you on the governor when it smoked and etc.. Thanks for looking out for others like this it's appreciated and let us know what else you learn
r/c helis lifestyle
Old 04-15-2013, 03:17 AM   #10 (permalink)
Also, although part of the only group that didnt burn, one of the teeth of the fiberglass board is missing =/
Andrew_ZA is offline        Reply With Quote Quick reply to this message
Old 04-15-2013, 05:35 AM   #11 (permalink)
Are you talking about your motor?
I see one missing also in Falke's motor.
XL Power 520, Warp 360 , Sport 360 NiTHeli
T500 AP
Luigi_tuga is offline        Reply With Quote Quick reply to this message
Old 04-15-2013, 06:49 AM   #12 (permalink)
Yes, I noticed this too. But it is on the one that is still OK... So my assumption is that it did not contribute to the incident. But one will never know.
TeamHeliProz.com
Old 04-15-2013, 09:12 AM   #13 (permalink)
Just noticed that. falke398, when you replaced the can, was it already like this? If you lost that in flight, that sure could have caused the problem.
AMA# 977012
Old 04-15-2013, 12:31 PM   #14 (permalink)
don't know
TeamHeliProz.com
Old 04-16-2013, 07:20 AM   #15 (permalink)
Kontronik has released the new FW 1.08 for the Koby which is supposed to fix the burnout-during-spoolup issue... Until now, it is only available on the german section of the HP. Any volunteers?
My warp now has about 10 perfect flights with the compass motor since I have upgraded the new can.
BTW, in my replacement can there were 1 grub screw and 1 clip sticking to the magnets inside. Fortunately, I spotted them before assembly...
Cheers, Daniel
shaman3 is offline        Reply With Quote Quick reply to this message
Old 04-16-2013, 08:55 AM   #16 (permalink)
Default brass spacer
I would add, make sure you don't forget the brass spacer that is in between the stator and the can.
Old 04-16-2013, 10:24 AM   #17 (permalink)
I got an answer from Kontronik saying execly this. 1.08 should solve the problem and that I should send thm my koby.
I also had a clip on the can... no screws...
Cheers, Daniel
Spacer was installed.
TeamHeliProz.com
Old 04-17-2013, 03:58 PM   #18 (permalink)
Did you do a mode 1 reset and re program mode 4 before using? I'm at a complete loss now after reading this. I'm using the 55 with the old compass motor, no problems and plenty of power, only with the silly start up sound. I've got a new can en route and a scorpion in a box.
Oxy 3 SK540 Minijazz 20 / WARP 360 SK540 Koby 55 / Goblin 500 SK540 jive 100 / 6HV ultimate Helijive120 SK540 / 7HV SK540 Kosmik200 / Futaba18mz / Skookum support rep
heathy is offline        Reply With Quote Quick reply to this message
Old 04-17-2013, 04:56 PM   #19 (permalink)
Yes I did.
Kontronik is aware of the problem and has a new firmware for the Kobys 1.08.
They offered to replace the controller.
Mike from Prostarhoppy is taking care of the exchange. He provides/d excellent service. I could not be happier.
Lets see when the new ESC arrives and who it likes the motor...
I'll report ones I got her back in the air.
TeamHeliProz.com
Old 04-17-2013, 05:09 PM   #20 (permalink)
Originally Posted by falke398 View Post
Yes I did.
Cool, till then I'm sticking on what works.
