Go Back   HeliFreak > R/C Helicopter Support > Gas Powered Thoughts
Gas Powered Thoughts Advice for Gas Helicopter Success from Carey Shurley
Old 04-18-2013, 10:11 PM   #1 (permalink)
Default Build Thread - Leviathan Goblin 700 Conversion
History
Back in December 2012 I saw a posting about a gas conversion for a Goblin G700 helicopter. I was quite intrigued by this as the Goblin is currently a very popular helicopter and its design is pretty straightforward so its easy to build.
Eventually I was able to be introduced to the designer, Joey Chan. Joey is a partner in a company called Leviathan Designs, they design/manufacture industrial robots.
Seems that Joey likes gas helicopters!!
So he went about designing a conversion that could be used to transform a Goblin G700 or G630 into a gas helicopter. His knowledge of engineering, design, materials and manufacturing combined with his actually flying model helicopters turned out to be a good fit for something like this.
So four months later, here it is. Keep in mind this is a pre-production conversion its not yet available for sale. But I think you'll agree that after looking at it, everything in it is very high quality and it LOOKS like production kit quality
So lets get going here
Overview
Like any conversion, you need a donor model as the basis for the conversion. This one requires a Goblin 700 (or 630) as its donor
Here you can see what I'm using, its a current spec G700 using the HPS rotor head.
SAB Goblin G700 Donor Model
I'm using Futaba BLS255HV servos as well as the GY750 using the latest R1.31 firmware. Obviously no electric motor, esc, bec or main batteries are needed
Standard G700 Electronics
Here's the contents of the kit I received. All of the composite/routed parts are G10 which has a black semi-gloss finish.
Conversion Kit Parts
A couple of drawings are included to help with bolt placement
Kit Composite Parts
and this one shows where to install the various bolts/washers, etc
Kit Bolt Map
The conversion is largely complete so only a couple additional things are needed
Required Parts:
  • Throttle Servo - I'm using a Futaba BLS255HV
  • Air system battery - I'm using a Gens Ace 4000 LiPo
Required Parts for Conversion
Of course its a gas helicopter so you need a gasoline power system. The kit is designed to use the Zenoah RC format motor and clutch system.
You have several choices for motors, 23, 26 or 29cc stock or modified. Currently the major modifiers of RC motors are TRM Power and BH Hanson. I'm going to use a TRM Power VX270TT motor
You also need an exhaust system, you have many choices here. I'm going to use a Hatori SB12-R3, which is the latest gas muffler from Hatori, it uses their isolation mount system
You need a 14 oz dubro fuel tank, and of course fuel tubing
Power System Components:
  • Motor - TRM VX270TT
  • Muffler - Hatori SB12-R3
  • Clutch - Zenoah RC clutch
  • Deflector - Hostile TR880x
  • Tank - Dubro 414 tank + gas proof stopper Dubro 400
  • Tygon fuel tubing
Power System Parts
And as is typical for me, I'll be using some additional optional parts to "enhance the model".
  • Stator Gator GGS23-RC - to use as an RPM sensor for both governor and telemetry use
  • Sullivan 478 Aluminum tank stopper - I hate the plastic caps
  • Sullivan 476 fuel nipple - overflow and vent
  • Walbro 125-527 filtered clunk
  • Stens 610-079 tank vent
  • Futaba SBS-01RM Telemetry RPM sensor
  • Futaba SBS-01T Telemetry Temp sensor
  • KDE Landing Gear Supports
  • Fromeco - battery connector splitter (2 way)
Optional Parts
The main drive came pre-assembled. You can see here that it uses three bearing blocks. The drive assembly is basically a box made of the bearing blocks and a set of G10 plates to support the bearing blocks. This assembly will replace the motor plate on the donor model
This is setup very much like the Whiplash in that you can use both the pull starter and spin start it from the top BUT also uses the Zenoah clutch.
If you wanted, you can flip the OWB around in the starter yoke and use it to drive a generator
Main Drive - Side View
Here you can see the custom drive pulley mounted on the vented clutch
Main Drive - Front View
There are a few machined delrin parts.
First, two blocks which mount beneath the std landing gear supports. These support the lower motor mount plate.
Of interest is that these are slotted so that you can use the stronger KDE landing gear supports
The triangular parts replace the stock skid bumpers. In the conversion, you double up the landing gear so these have to be wider to support the double plates.
Delrin parts
As I indicated earlier you can leave the pull start in place if you desire. OR you can replace it with this custom made fan cover for a weight savings and just use the top spin start. This would preclude the use of a generator however since they commonly use the start shaft as a driver
Fan Cover - Pull Start Replacement
Finally, there's a bag of various bolts required to assemble the parts. Rather than go over these here I'll indicate them during the assembly
Included Hardware
Video Overview
Next Step:
Prepare Sub Assemblies
carey shurley is offline        Reply With Quote Quick reply to this message
Old 04-18-2013, 10:11 PM   #2 (permalink)
Default Build Thread - Leviathan Goblin 700 Conversion - Sub Assemblies
Sub Assemblies
This conversion is pretty straight-forward but it can be simplified even more by doing some prep work on some components that can be prepared in advance.
So I'll get those built first
Fuel Tank
This conversion uses a std Dubro 14oz fuel tank. Those include some brass tubing, fuel pickup, cap, etc. If you've followed my builds you know that I never use them. Instead I have some common parts that I usually use
here you can see the fuel tank parts needed
If you bought the optional Fuel Tank Kit, it will include everything you need
  • tank
  • cap
  • fittings
  • pickup
  • pickup tube
  • pickup fitting
The part numbers were listed in the options parts list
Fuel Tank Parts
first off build the fuel pickup line. Cut a 6" piece of the fuel tubing that comes with Zenoah RC motors. Its very flexible and it is NOT neoprene. Assemble as shown.
Fuel Pickup Line
BEFORE YOU DRILL THESE HOLES MEASURE THE FITTINGS TO MAKE SURE THEY WILL FIT
You'll need to drill holes for the vent/return lines, with the Sullivan fittings these are .244" or about 1/4". The exact position isn't that critical
Holes for Vent/Return Fittings
This hole is for the fuel pickup fitting, this is an MA#0403 fitting but any similar fitting can be used. This hole is .185" or about 3/16"
Again test check the fit on something else before you drill the tank!!!
Holes for Fuel Feed
here you can see the fittings for the tank vent/return lines installed and tightened
Vent/Return fittings installed
now insert the fuel clunk in the tank and work the threaded end of the fuel fitting through the previously drilled hole on the front of the tank
Insert assembled fuel pickup line
and tighten it fully
Fuel pickup installed
Install the fuel tank cap, make sure none of the stopper holes are exposed.
Fuel tank cap installed
The fuel tank is now complete, set it aside for now
Engine
You'll be using a Zenoah RC format motor. I'm using a TRM Power VX270TT motor, there are many choices out there. Here you can see the parts needed to prepare it for installation
The parts are:
  • Zenoah engine
  • Engine mount and bolts
  • Zenoah RC clutch/washers
  • Hostle RC deflector
  • Clutch start yoke
  • Special clutch mount bolts
  • Fan cover
  • Throttle control ball
Parts to complete engine
The conversion includes a fan cover that replaces the pull starter. If you plan on using a generator, you won't be able to save the weight of the pull starter as it will be the only way to start the motor. Otherwise I suggest you remove the pull starter, install this plate and spin start the motor as you would any other liquid fuel helicopter
Fan cover parts
and here you can see the fan cover installed
Fan cover installed
Before any clutch assembly the engine mount must be installed. If your engine has the clutch mount plate installed, you'll need to remove it first using a puller.
The production kit includes an alignment nose ring. This is ONLY for the RC2xx/RC300 engines. It is not needed for the RC320
Engine Mount parts
the nose ring has a protruding ring. This protrusion will face downward and be inserted into the engine mount
Engine nose ring design
here you can see the ring installed in the mount and bolted in with the included bolts
Engine nose ring installed - top view
you can see on the bottom that the bottom of the nose ring will be flush with the bottom of the engine mount if you have installed it in the correct orientation
Engine nose ring installed - bottom view
The nose ring is only used for the RC2xx-RC300 engines. It is not needed (and won't fit) the RC320 engine. If you intend to mount the RC320 engine you will need to acquire the optional RC320 Engine Plate Spacers
Engine Mount position on RC2xx-RC300
Here you can see the mount on an RC320. Note that the nose ring is not needed or installed
Engine Mount position on RC320
Mount and tighten the engine mount as shown using the supplied M5 bolts. Use thread lock and fully tighten. The engine mount is symmetrical so it can be installed in either direction
Engine Mount installed
Now the clutch can be be installed on the motor. Start with the clutch mount plate as shown and set the flat washers on it as shown.
Clutch Flat Washers placed
Set the clutch shoes on top of the washers. Make sure the arrow stamped in the shoes is visible on the top of the clutch. Set the spring washers on top of the clutch shoes as shown
Clutch shoes/spring washers
Now the clutch start yoke sets on top of the spring washers. In the prototype, this is an MA part however in the production conversion it may or may not be. The clutch assembly is held together by the special shouldered M5 bolts included with the conversion. These can be fully tightened using thread lock
OWB Starter yoke positioned
Insert the shouldered clutch mount bolts using thread lock. These can be fully tightened. Be careful that it fits properly through the washers and parts
Clutch mount bolts inserted
Next the air deflector will be installed. This is a part made by Hostile R/C, typically used on RC cars. It installs on the the engine fan shroud using the bolt shown here as removed
Deflector mount bolt removed
The fan deflector installs as shown using the previously removed bolt
G]Air Deflector Installed
If this is a new motor, the carb arm will be installed in the improper position.
Stock throttle arm position
Remove it by loosening the retaining bolt. Grab the arm with a tool before removing the retaining bolt, down just twist against the closed throttle. You can damage the carb butterfly
Carburetor arm removed
Install a control ball. This can be from any manufacturer for which you have a matching link. I used an SAB control ball std for this kit using thread lock. Note the orientation of the mount slots in the arm
Throttle arm ball installed
Now reinstall the carb arm positioned as shown with the carb butterfly closed. Use thread lock
Carb arm re-installed
This completes the engine pre-assembly. Set it aside for now
Completed engine
Landing Gear
Now the revised landing gear can be assembled.
The parts needed are:
  • Additional landing gear plates
  • New landing skid blocks/bolts
  • Optional KDE landing gear plates
First remove the standard landing gear plates from the donor model. If you are going to use the original landing gear plates, remove them as well
Removing landing gear
The stock landing gear uses doublers on the stop of the plates and some U shaped sliders on the bottom of each plate. These should be removed
Landing Gear removed
When done, here's what you have. You will need the two landing gear plates and related mount bolts only
Landing gear disassembled
The small doublers on the original landing gear will be replaced with the additional landing gear plates included in the Required parts list. They stack together as shown and assemble using the original mount bolts
Landing gear plates stacked
The conversion includes a new set of wider sliders for the bottom of the landing gear along with longer bolts. These assemble over the stacked landing gear plates and are bolted on using the included longer bolts. Use CA on the bolts. Note that the mount holes on the skid blocks are bigger on the outside just as with the original blocks
New Landing Gear parts
I'm using the reinforced KDE landing gear plates for this conversion. If you chose to do this, you'll need to drill two holes in the reinforcement bar on the bottom of each plate. This will be necessary to bolt on the lower motor plate mounts in a later step. These should be at least 2.6mm in diameter
KDE Landing Gear Plate Mods Required
Here you can see the completed landing gear which will be assembled to the new chassis in a later step
Completed landing gear
Main Drive Mount
Although this was delivered in the prototype assembled, it may or may not in the actual kit so we'll go through the assembly
These are all the parts required to assemble the main drive. They are all included in the conversion kit or are on the required parts list. You'll also need the drive belt from the donor model
The quality and finish on the parts is very nice and it all fits together as expected
Clutch Drive Mount Parts
BEFORE YOU BUILD THIS READ HERE: httpss://www.helifreak.com/showpost....&postcount=296
The clutch bell includes two flange bearings for the start shaft, the upper one is visible here. First drop the lower clutch bell bearing block over the clutch bell shaft and seat it against the bell. Note its orientation
Lower clutch support block installed
There is a spacer that slips over the shaft at this point and seats against the lower bearing
Thick Spacer installed
To account for minor variations in manufacturing tolerances, the kit includes shims. These will determine the position of the drive pulley so that the drive belt runs in the center of the rear pulley. It will require some trial and error to get the right number installed in the right position. These slip over the clutch bell shaft and are a tight fit but they can go below the bottom pulley flange or on top of the top pulley flange as needed.
Spacer shims positioned
Next the lower flange for the drive pulley is installed. The flange has a shoulder on one side this faces downwards against the previously installed shims
Lower Pulley Flange installed
Now the main drive pulley goes on the shaft. The shaft has a flat on it and the pulley has a set screw hole. Make sure to align these two so the set screw will mount against the shaft flat. The pulley is a very tight fit, you may want to heat the pulley with a heat gun or cool the clutch bell shaft to make this fit easier
Drive Pulley positioned
Now fix the pulley position using the included set screw against the flat on the shaft. Install with thread lock and tighten well
Pulley Set Screw
The upper flange for the pulley installs next, this time the shoulder will face upwards as shown
Pulley upper flange installed
Now the upper bearing block can fit over the clutch bell shaft. Seat it against the upper main pulley flange
Upper mount block positioned
The clutch bell shaft is threaded so use the included nut to tighten this assembly together. Use thread lock on the nut and tighten so that the assembly fits snugly with no vertical play. You can in fact crank down on this because of the way the bearing stack is designed but its really not necessary.
Clutch bell retaining nut installed
The start shaft can be inserted as shown from inside the clutch bell. Set it against the bearing on the inside of the clutch bell
NOTE - there is a small brass spacer slipped over the shaft (found in the top start option kit). This spacer is required to be there for proper spacing.
Start shaft inserted
The other end of the start shaft has a flat on it, this should be exposed as shown on the top of the clutch bell stack
Starter shaft flat exposed
Install the starter coupler over the start shaft and make sure one of the set screw holes aligns over the flat on the start shaft. Tighten the two set screws with thread lock on the coupler so that one seats against the flat.
Starter coupler installed
Select the drive belt from the donor model as shown
Install drive belt
Slip the drive belt over the clutch bell and main drive pulley as shown
Drive Belt Installed
The side plates for this assembly will install as shown. All of the bolts are the same length except the two rear bolts on the upper bearing block. These are shorter so they can't hit and possibly damage the drive belt
Side plate mount layout
Install the left clutch block support plate as shown using thread lock
Left clutch block mount plate installed
Now install the right clutch block support plate as shown using thread lock
Right clutch block mount plate installed
At this point the clutch block assembly is complete and can be set aside for the next step
Clutch Drive System completed
This completes the sub assemblies for the conversion
Video Narrative
Next Step
Main Frame Assembly
Old 04-18-2013, 10:12 PM   #3 (permalink)
Default Build Thread - Leviathan Goblin 700 Conversion - Main Frame Assembly
Main Frame Assembly
This step will build the conversion main frame assembly around the main drive plate from the donor model.
First we'll need to take a few more parts off the donor model
Prepare donor chassis
We've already removed the landing gear in an earlier step, here we'll strip the chassis down to the main drive plate
Goblin Donor Chassis
remove the tail boom and set it aside. note the belt orientation for reassembly in a later step
Tail Boom removed
remove the bolts/canopy mounts across the top of the side frames that secure them to the main drive plate. The frame assembly can be removed as a unit
Frames Removed
Disassemble the frames, we'll need these landing gear plates, pinion guard and frame spacers for the conversion. NOTE - If you use the KDE landing gear plates, you won't need the original ones
Parts needed from donor frames
Remove the motor plate from the main drive plate and then remove the mount studs. You may need to heat these to get them out
Motor Plate removed
that completes the prep for the main drive plate, so we can start the assembly process
Install Main Drive
take the motor plate studs previously removed and install them in the new upper bearing plate on the main drive assembly as shown. Thread them until they are flush with the bottom of the block and use green or red thread lock. let it dry before proceeding
Install main drive plate studs
The conversion has NOT been designed to use the belt tension springs but for you to instead set the belt tension. If you want to use the springs, pilot holes have been put into place, you can drill them to 3.2mm and then drop the two belt tension springs into their holes on the new upper bearing plate as shown
Install tension springs
Now insert the new drive assembly into the main drive plate EXACTLY as you would the original motor plate. Because the belt has to be preinstalled on the main drive assembly, it will not fit over the main pulley just yet
Insert main drive assembly into chassis plate
push the main drive assembly inwards towards the mainshaft until you can thread the main drive belt over the main drive pulley as shown
Belt threaded onto main drive pulley
on the top of the main drive assembly install the washers and locknuts if you haven't already and make sure they are sitting as shown
Note position of drive mount nuts/washers
The drive belt needs to be relatively tight. A good indication is to ensure that the main drive assembly interfaces with the main drive plate as shown. You can achieve this by just pulling on the main drive assembly while pushing against the main drive assembly, its not that hard to do
Set Belt Tension
while holding the belt tense, tighten the two locknuts that retain the main drive assembly. Make sure they are tight!
Tighten drive mount nuts
Remember back when we put the main drive assembly I talked about some shims that can go under or above the drive pulley? They can be used to position the main drive pulley slightly higher or lower. The reason for that is to ensure that the drive belt rides in the proper place on the main drive pulley
The belt should be flush with the top or bottom of the main drive pulley or centered on it but it should NOT "hang off" the top or bottom of the pulley or rub on anything.
If the belt doesn't ride true on the main drive pulley, you'll need to remove the main drive assembly and reorder the pulley shims until the belt rides in the proper position
Ensure true belt runout
Here are the parts needed to build the conversion lower frames. Note you'll need the additional frame spacers from the required parts list
Conversion Frame parts
First we'll build the radio tray and pinion guard. Use the parts shown and assemble with thread lock
Conversion tray parts
here is the battery tray and pinion guard assembled- NOTE There is a running change to the radio tray, the holes are not countersunk. I would suggest using 3mm button head bolts on this
Trays assembled
now the tank isolators can be installed. Select the two rubber isolators and cut them to the proper length which will be approximately 335mm. Cut it a little longer and you can trim it as you install it
Tank isolators cut to size
Start installing the isolators on the bottom of the frame as shown
Start tank isolator install here
you'll need to work the rubber isolators around the tank cutouts. I used a heat gun to help soften the rubber. The isolators don't have to fit perfectly
Tank isolators installed
now install the two frame doublers to the lower outside portion of each frame using the M3 x 8 button head bolts
Frame doublers installed
a washer and locknut secure these on the frame inside
Frame doubler lock nuts
install the remaining frame spacers in the holes shown. Use an M3 x 12 bolt through the frame doubler. The other bolt is an M3 x 8. Use thread lock and tighten
Frame Spacers installed
here's where the battery tray goes. Note the tabs on the tray and the slots they install into on the inside of the left frame. Also note the orientation of the slot in the battery tray which is towards the rear of the model
Battery tray position
install the battery tray using M3 x 8 bolts and thread lock. These mount holes are slotted so you can make minor positioning changes
Battery tray installed
The tab on the pinion guard will be pushed through the rear slot on the battery tray
Pinion guard position
Bolt the pinion guard to the left frame using an M3 x 8 bolt and thread lock
Pinion guard installed
Select the fuel tank assembled earlier and place it on the left frame as shown. For now it will need to just sit in place
Fuel tank positioned
Select what was the original pinion guard from the donor model and install its tabs into the slots at the rear of the left frame, they are the ones just above the servo cutout
Rear frame tray installed
Now the right frame can be assembled to combine the frame halves. Position it as shown
Right frame position
Install the right frame using the bolts specifed on the frame bolt map in the initial build post in this thread. Don't tighten the bolts on the front of the frame as you'll need to spread them to install the upper plate shortly
Right frame installed
Once the frames are bolted together, the fuel tank is captured as shown
Fuel Tank installed
Select the upper frame plate from the original model that the main drive was installed earlier. Its going to install between the frame plates as shown. You'll need to slightly spread them for the bolts on the main drive plate to slip through
Upper plate positioned
once the upper plate is in place, use the original bolts/canopy mounts from the donor model to install. Fully tighten with thread lock. Also tighten the other bolts on the frame that were left loose previously to allow the main drive plate to slip between the frames
Upper plate installed
This completes the basic frame assembly
Video Narrative
Next Step
Install Motor
Carey Shurley
Proprietor - Gas Powered Helicopters
Old 04-18-2013, 10:12 PM   #4 (permalink)
Default Build Thread - Leviathan Goblin 700 Conversion - Install Motor
Motor Installation
The final new part needed to install the motor is the motor plate. Select the parts shown from the conversion kit as well as the landing gear assembly previously built
Motor plate parts
the two motor plate spacers are positioned on the landing gear blocks as shown. If you're using the stock landing gear plates, position the blocks as shown. If you're using the KDE landing gear plates, the motor plate spacers are slotted to allow them to slip over the reinforcement on the bottom of the plate
Motor plate spacer installed
Install the motor plate using the bolts specified on the frame bolt map in the first build step. Don't fully tighten these at this time. Set this aside for now
Motor plate installed
Select the motor previously prepared in an earlier step. Remove the four M5 bolts from the fan shroud on the bottom of the motor. You'll need these next
Also note you'll need the M3 x 8 and M3 x 12 bolts from the conversion as well as the large frame washers from the required parts list
Parts to install motor
The motor will drop into the motor plate previously attached to the landing gear as shown. Reinstall the four M5 bolts with thread lock and fully tighten the motor to the motor plate
Motor Installed - bottom view
At this point the motor is read to install into the frames. Note the exact position of the clutch shoes, they will need to be in this position to fit into the upper frames
Motor installed - side view
Before installing the motor, depending on where you installed your fuel inlet you may want to install the fuel inlet tubing to simplify its installation. For this fuel inlet fitting position, the correct length of the tubing is 6"
Fuel inlet line optional install
The previously assembled upper frames will mate to the motor assembly as shown
Upper/Lower frame mate positioning
install the motor to the upper frames. Use the bolts specified in the bolt map in the original build thread post. Don't fully tighten any of the mount bolts just yet
Motor installed - Right view
Here you can see the chassis from a left view
Motor installed - Left view
This completes the basic motor installation
Video Narrative
Next Step
Complete electronics
Old 04-18-2013, 10:12 PM   #5 (permalink)
Default Build Thread - Leviathan Goblin 700 Conversion - Complete Electronics
Complete Electronics Installation
In this step we'll complete the electronics install. There is a bit more to install than on the std Goblin, a battery is needed to power the on board systems and an additional servo is needed for the throttle control
Also need to build a power transfer cable to get the power from the front of the model to the electronics in the back of the model
Finally I've included an optional electronic component, the Stator Gator. If you're not familiar with it, its a simple device that makes it easy to read the ignition pulse from the engine and send it to a governor if you're using one of the compatible versions.
Components to complete electronics install
First I'm gonna hook up the Stator Gator, it replaces the kill switch on the RC motor so first its removed
SG - Remove kill switch
connect the SG sensor according to its instructions
SG - sensor connected
once completed the SG sensor pickup is barely noticeable
SG - sensor installed
Install the throttle servo as shown. Note that it installs from the inside of the frame. You can just use Align servo nuts/plates/screws it isn't critical. This needs to connect to your governor/Rx
Install the push rod from the required parts, the approximate length of this is 94mm from link center to link center. That will vary a little depending on your servo or whether you are running differential setups.
The on board battery goes onto the battery tray on the front of the model. Make sure its well secured with velcro or other retainers
Battery installed
Since the battery is in the front of the model and the Rx/FBL system installs in the rear of the model its required to create a cable to transfer the power. The exact length of this will depend on your setup and how you like wire your model. Its important to make sure it can't get into any of the drive train
Power extension cable
As noted earlier, there is a lot of wiring to put into a very small place. Since I'm including telemetry as well it add some wiring as well. Because of the way the Goblin canopy is shaped there is room in the open space behind the radio area to let the wiring expand but still be captured by the canopy. Here's the left view of my wiring
Wiring completed - left
and here's what it looks like from the right side of the model. The FBL sensor is underneath the main frame tray. Note that I've used clips on EVERY connector related to the control system. This will account for any additional vibration
Wiring completed - right
There is some room inside the frames from some of the wiring as well, here you can see what I've put there. This needs to be kept away from the drive belt. You can also see the Stator Gator sensor installed on the cross plate just below the throttle servo
Wiring completed - inside
Once all the other wiring is done, put the tail boom back on. This installs just like it did on the donor model. No modifications are involved
Tail boom installed
once the tail boom is installed then connect the T/R servo. Once again I used a clip to ensure the servo doesnt' get disconnected
T/R servo connected
With the electronics installed, its time to finish the model!
Video Narrative
Next Step
Complete Model
Carey Shurley
Old 04-18-2013, 10:12 PM   #6 (permalink)
Default Build Thread - Leviathan Goblin 700 Conversion - Complete Model
Complete Chassis
Just a few more parts needed to finish the model
You'll need a muffler of some sort. New Zenoah RC motors come with a steel canister muffler but its quite loud. There are a number of mufflers on the market that work well. I'm using the Hatori SAB-12R2
You'll also need some fuel tubing to complete the plumbing as well as make a tank vent
Finally you need the main blades
Parts to complete model
I'm using the Hatori SAB12-R2, this is a two piece muffler that uses the Hatori soft mount system. With this muffler first you install its mount on the motor
Install Hatori muffler mount
And then you install the muffler. This muffler is VERY quiet and at 12oz is one of the lightest mufflers available.
Hatori muffler installed
Remember back in the pre-assembly we installed a tank vent and overflow fitting. Time to plumb those. I'm going to use a coiled tube as a vent. This simply routes to the bottom of the model. The overflow routes back to the carburetor
Complete tank plumbing
The overflow tube from the tank goes to the primer fitting on the carburetor. By using the coiled vent we can just put a T fitting in the primer return line and fill the tank from there. You can defuel from it though
Complete carburetor plumbing
Complete Canopy
The 700 Standard canopy requires some modifications to fit the model properly. Its necessary to:
  • cut frame clearance slots on the bottom
  • cut throttle servo clearance on the left
  • cut air deflector clearance on the right
IF YOU ARE CONVERTING A 630, 700 Competition or 770 you will need to re-evaluate these changes
Here's how to measure for the cuts on the bottom
[I]Canopy cutouts - bottom/I]
After the canopy bottom is cut, you can fit the canopy and find the locations for the remaining cutouts if you want or just use these directions
here is how to find the location for the throttle servo cutout on the left side of the canopy
Location for throttle servo cutout
and here is its shape
Shape for throttle servo cutout
here is how to locate the cutout for the heat deflector on the right side of the canopy
Location for heat deflector cutout
Shape for heat deflector cutout
Here I've marked my canopy bottom to be cut
Canopy bottom marked
here is the left side marked
Canopy Left Marked
and the right side marked
Canopy right marked
Complete Model
Once the canopy has been cut, its ready to install on the model. It installs in the same way as it did on the original donor model
Canopy Installed
Install the main blades of your choice
Main blades installed
AND, the model is completed and ready for setup
Model completed
I'm not going to go into detail about how to set up the model as there is a lot of personal preference here. Next will be a summary of the model
Video Narrative
Next Step
Model Summary
Carey Shurley
Old 04-18-2013, 10:12 PM   #7 (permalink)
Default Build Thread - Leviathan Goblin 700 Conversion - Summary
Overview
Here are a few photos of the completed conversion
Old 04-18-2013, 10:13 PM   #8 (permalink)
Default Flying
Here are a few flying photos
Old 04-18-2013, 10:13 PM   #9 (permalink)
Default Gas Goblin Flies
The gas goblin flies!
thanks to Jordan Martin
Carey Shurley
Old 05-08-2013, 06:52 AM   #10 (permalink)
Added video for pre-assembly step
Carey Shurley
Old 05-08-2013, 07:22 AM   #11 (permalink)
I have a question. Are the side frames predrilled for generator use? And are the stock landing skids tall enough for the pull starter?
This design is very nice.
Thanks.
Suat
Trex 700 Gasser
FBL | HeliBug HB7-RC 17T | Silverline V-Bar| TRM VX290TT | SG | RJX Gas muffler (modded)
Trex 600 Gasser FBL | HeliXHeli conv. | OS GT15HZ | iKon | Homemade onboard generator
Azalin is offline        Reply With Quote Quick reply to this message
Old 05-08-2013, 10:52 AM   #12 (permalink)
Hey Suat, it still requires the "generator platform" to be installed, as the side frames on the model don't extend above the main "plate". The top bearing mount is drilled and tapped so its setup for a generator install. Since I don't currently use any generator system I don't know exactly how it would mount here.
but other than that its just like the Whiplash, flip the OWB in the starter yoke and use the start shaft to connect the generator driver adapter.
In terms of pull start clearance I'll have to measure the actual distance but its at least as good as the whiplash with the tuff-strut package installed.
Carey Shurley
Old 05-08-2013, 10:59 AM   #13 (permalink)
Default Technically speaking
Pull starter clearance is not "necessary". Even if the model sits with the starter bottom on the ground, you can make it removable and just take if off after the 1 to 2 pulls to start the engine.
-=>Raja.
MA 1005, Hanson 280, 4260 flights, Spectra-g, Hanson 270, 3375 flights
Whiplash-g V1-2, Hanson 300, 1737 flights, Whiplash-g V2, Hanson 300, 635 flights
Jewel on-board Generators, Miniature Aircraft Team Manager
rbort is offline        Reply With Quote Quick reply to this message
Old 05-08-2013, 08:12 PM   #14 (permalink)
Hey Guys,
Should be plenty of clearance for pull start, see attached ; )
jc23cl is offline        Reply With Quote Quick reply to this message
Old 05-10-2013, 05:42 AM   #15 (permalink)
What an awesome build! Glad I wandered over here from the "normal" SAB forum!
Silverline V-bar, Vbar Control
#205
rebeltrousers is offline        Reply With Quote Quick reply to this message
Old 05-10-2013, 09:11 AM   #16 (permalink)
tell your friends in the other forums. The next couple of steps are gonna be pretty interesting
Carey Shurley
Old 05-15-2013, 10:03 PM   #17 (permalink)
Default Goblin gasser
How do I become a beta tester? Awesome build!
squeely531 is offline        Reply With Quote Quick reply to this message
Old 05-16-2013, 06:15 AM   #18 (permalink)
added video for engine installation
Carey Shurley
Old 05-17-2013, 10:22 PM   #19 (permalink)
added video for frame assembly
Carey Shurley
Old 05-19-2013, 04:23 PM   #20 (permalink)
Default 700
Hi Carey, Nice job on the build as always. When will you have a vid of it flying and do they have a price on the kit yet? like to build one. Keep up the good work.
Loren
foreignloren is offline        Reply With Quote Quick reply to this message
