Like Tree5Likes
Old 05-11-2013, 10:08 PM   #1 (permalink)
Default Using the DS-16 with a sim
I want to use my DS-16,when it arrives, with Phoenix sim. What type of trainer connector does the Jeti have? I will be honest. I own a copy of Phoenix but the USB dongle got destroyed because it got caught in a door and crushed. Since I already own the dongle I wasn't going to pay full price for another copy of Phoenix so i got one of the 9-in-1 things from Chinese Ebay. I have all of the connectors that came with it, so i imagine I have what I need, but i can't be sure. I also wanted to make sure that a SimStick isn't required because the Jeti has a weird plug or something like that. Any help would be greatly appreciated. Thanks
Protos Max 700 Vbar, Synergy E7se Vbar, Rush 750 Vbar, Gaui X5 Vbar, Gaui X4II Vbar, Protos 500 Vbar, Compass Warp 360 Vbar, Gaui X3 Robird
Controlled by: Jeti DS-16
Clay333 is offline        Reply With Quote Quick reply to this message
Old 05-12-2013, 07:37 AM   #2 (permalink)
Clay,
Most people are now using a Simstick Pro with a R6i receiver. The R5 receiver is now available, but I haven't had a chance to try it.
Simstick Pros are now out of stock at most retailers, and I know that a few of us are waiting for a new shipment for a while so it shouldn't be much longer.
You can buy the combination of a Simstick pro and R6i for $124.00 from www.circlecityhelis.com
Lou
Vector 550 Quad/Octo Multirotors
DJI WooKong Multirotor Controllers
Twin Bergen 44 Magnum Turbines - KERO Start FBL
lperagallo is offline        Reply With Quote Quick reply to this message
Old 05-12-2013, 11:06 AM   #3 (permalink)
The DS-16 doesn't have a trainer port because Jeti buddy boxing is wireless. As Lou said you can use the PPM out on a Rx, otherwise you would have to remove the back of the radio and use the PPM jack.
BustedRaptor77 is offline        Reply With Quote Quick reply to this message
Old 05-12-2013, 11:13 AM   #4 (permalink)
BTW you shouldn't need the sim stick with Jeti on Phoenix. Just change the plug on the Phoenix jack to a servo connector and plug it into a Jeti RX.
Old 05-12-2013, 12:08 PM   #5 (permalink)
Or any system for that matter. (Great idea!)
Team - "Self Interests" -
Old 05-12-2013, 01:21 PM   #6 (permalink)
Including a DX7 SE?
Minicopter Diabolo 800+ - Minicopter Triabolo - Srimok FAIFA
Jeti DS-16
tribe3 is offline        Reply With Quote Quick reply to this message
Old 05-12-2013, 01:22 PM   #7 (permalink)
Wow, that sucks. I definitely didn't anticipate having to spend another $125 just to use the sim. I really don't mind having a wire when I'm simming. What do I have to have if I removed the back cover? What about the USB port..... Is there a way to make it work somehow?
Old 05-12-2013, 01:47 PM   #8 (permalink)
Come again?
I want to do this (I've already got two simsticks and a simstick pro, and dont want to have to buy more)
So what are the pin-outs for the phoenix-jack to servo connector?
And why does simstick exist if this can be done so easily with just an adaptor?
Groucho_ is offline        Reply With Quote Quick reply to this message
Old 05-12-2013, 02:42 PM   #9 (permalink)
I haven't done it yet, but in theory it should work.
Why does sim stick exist? So you don't have to cut any wires.
I use a Futaba adapter currently. I also have a spare adapter. Will just need to cut the adapter and then ensure that the power and signal wires are mapped correctly to a standard servo connector. Servo connector goes to the receiver as normal. If for some reason the USB power isn't enough for the rx, then I'll just use a small receiver pack.
I can't think of any reason why it wouldn't work.
Old 05-12-2013, 03:30 PM   #10 (permalink)
Update:
Only two wires in the Futaba adapter. The connector to the radio has 6 pins but only two interface the actual sim chord.
Haven't done the servo lead yet, but I think a separate battery will be required. This may be the advantage of a sim stick as it probably captures the required voltage to run the rx.
Old 05-12-2013, 06:26 PM   #11 (permalink)
Originally Posted by Groucho_ View Post
Come again?
Phoenix is simply looking for a PPM input. For example to use my 8FG it is pin 1 and ground. So since Jeti Rxs output PPM you just make an adapter that has a universal servo plug on it on one end and the Phoenix female jack on the other. You could just cut the wire off too instead of using an adapter, but you would no longer be able to use any other transmitter with Phoenix. I haven't bothered doing it yet because I am still waiting for my radio. The only part I don't know about yet is if the Phoenix adapter will output a high enough voltage to power the Rx. If not I'll just use an old Rx pack or something.
Old 05-12-2013, 06:32 PM   #12 (permalink)
Do you know what the pin-outs from the Phoenix jack to the Servo connector are?
Old 05-12-2013, 08:29 PM   #13 (permalink)
At some point it just isn't worth the effort. I think I'll be happy with a wireless simstick solution using my kitty chewed R7 receiver.
Mark
mkovalcson is online now        Reply With Quote Quick reply to this message
Old 05-12-2013, 08:33 PM   #14 (permalink)
The tip is the PPM signal.
Old 05-12-2013, 08:40 PM   #15 (permalink)
I don't have a sim stick so a $4 radio shack solution instead of a $60 sim stick seems like it is worth the drive to radio shack and about 5 minutes to build.
Old 05-12-2013, 09:31 PM   #16 (permalink)
+1
No simstick but I have the rest.
Old 05-12-2013, 10:28 PM   #17 (permalink)
This may not work after all. At least with Futaba, I can get it to recognize that it is connected, but it will not output any channels from the SBus port.
Old 05-12-2013, 10:35 PM   #18 (permalink)
because s-bus is different to PPM. So it will work with PPM.
im4711 is offline        Reply With Quote Quick reply to this message
Old 05-13-2013, 12:14 AM   #19 (permalink)
Originally Posted by tribe3 View Post
Including a DX7 SE?
No, since there are no Spektrum RXs that output PPM, same goes for futaba AFAIK.
Most of the other radio manufacturers have PPM outputs so it would work for them.
-DX8
desertstalker is offline        Reply With Quote Quick reply to this message
Old 05-13-2013, 12:17 AM   #20 (permalink)
Not giving up. Will try again whenever my DS-16 is in my hands.
