Airtronics Radios Airtronics Radios Support |
#1 (permalink) |
![]() Looking for help with my setup endpoints limits on my SD-10.
The beast seems to be working all direction but having too much cyclic. |
#2 (permalink) |
![]() Hello ,
When you say too much cyclic are you referring to binding? The best way to set up is to leave your endpoints at default. Adjust the cyclic and collective pitch limits with the beastx setup. Set up dual rates on the sd-10g and set them to about 60% to start out. Then adjust the rates to your liking. Mark |
#4 (permalink) | |
![]() Join Date: Sep 2011
![]() Quote:
I wash wondering about my aileron and elevator setting. I read and seen several ways of set up and was just asking. I set my pitch @10+ 11- on 1,2 and 10+ 6- N Ailerons are about 13 off my scale. Setting DR I had go go down to 20% to keep within 8 After bringing travel down I noticed operation was much slower. |
#5 (permalink) |
![]() I don't believe that you are setting the beastx up properly.With all of your radio settings at default values for end points and no D/R you should adjust the beastx to achieve the cyclic and collective pitch values that you require by using the rudder stick in steps K and L.. Ensure that you exit all the way out of the beastx menu after you complete those settings.
#6 (permalink) | |
![]() Quote:
You're setup is way off and that's why the Beast is acting the way it is. TM |
#7 (permalink) |
![]() Hello TMoore
Randy and I had been discussing his BeastX issues over the phone for a couple of weeks. We finally got together this past weekend at a local Fly-In. Upon reviewing his setup, He had setup and parameter issues. Looks like we have sorted this out. He has informed me that all seems well.
![]() Here, when wanted There, when needed Everywhere, when looked for |
#8 (permalink) |
![]() Thanks TM,
I sent you a PM |
#9 (permalink) |
![]() Thanks T Moore,
I sent you a PM yesterday. |
#10 (permalink) | |
![]() Quote:
TM |
