Go Back   HeliFreak > R/C Simulators Support > Other R/C Flight Simulators
Other R/C Flight Simulators Other R/C Flight Simulators
Like Tree1Likes
Old 12-11-2007, 12:33 PM   #21 (permalink)
Considering that it's freeware v1.1 it's simply awesome!! I think this has the potential to become very popular. Keep up the good work!
Btw i'm using a dx7 with universal usb cable.
davidw is offline        Reply With Quote Quick reply to this message
Old 12-11-2007, 01:08 PM   #22 (permalink)
Works fine with Futaba 9c + cheapo FMS usb cable
DarkHeli is offline        Reply With Quote Quick reply to this message
Old 12-11-2007, 01:08 PM   #23 (permalink)
I don't know how many people that own Realflight G4 are going to be using Helisim, but the Interlink Elite works great. I assume the G3 interlink will work as well. You can even use the throttle hold, idle up, and reset switches. Mark, I sent you an e-mail with the calibration and mapping files.
I imagine it's not on your top priority, but I think Helisim would really benefit from some rudimentary sounds.
chinookmark is offline        Reply With Quote Quick reply to this message
Old 12-11-2007, 01:26 PM   #24 (permalink)
Nice work
I have an esky 0406 (6 channel) and a USB adapter and it works fine in clearview, but doesnt seem to go with helisim Only joystick installed.
jackosmeister is offline        Reply With Quote Quick reply to this message
Old 12-11-2007, 01:33 PM   #25 (permalink)
Guys, where can I buy a cheap round futaba sim cord? I would like to use it with this sim and FMS. Please help
Wii1 is offline        Reply With Quote Quick reply to this message
Old 12-11-2007, 01:42 PM   #26 (permalink)
Helismith;
I just have tried it for 5 minutes, but really like it. The feel is more realistic than Clearview, such as the inertia of the model. Clearview has a bunch of flying sites and helis, but if you have T-rex of MX-400, its great, pick one model and stick with it. Changing model is the worst thing you can do, inconsistent.
I am using a DX7 TX and the Milehighwings cable and it works without a hitch.
Will try it with a CX2 TX and also with VMware fusion in the next couple of days.
Again, great job Mark.
T-REX 450 SE, GY 401, 4x HS 65MG
T-REX 450 SE, Logictec 2100, 4x HS65
MX 400 PRO CCPM, Zoom Gyro, 4x HS65
MX 400 CF + CCPM, Copter-X head, GY 401, 4x HS65
Spektrum DX7
equisol is offline        Reply With Quote Quick reply to this message
Old 12-11-2007, 01:50 PM   #27 (permalink)
Interlink on g3 works, but I couldn't get the idle up or throttle hold to work, even when I chose the buttons for it. So I used the curves supplied in the sim and tweaked them to my liking. Had to increase the yaw control, piro rate wasn't fast enough at 1.00, so I went to 2.00, dropped to 5 on the expo all the way around and it is responsive. No sound does mess me up a little but it is pretty good. I probably won't use it much except as a standard for video among others, as I prefer g3.5. But I will definitely say it is real good for free.
The 3 things rc modeling has taught me:
Rotary tools are your friends.
You must be smarter than the object you are dealing with.
You can't buy ability.
trilerian is offline        Reply With Quote Quick reply to this message
Old 12-11-2007, 02:21 PM   #28 (permalink)
I put version 1.1 up today around lunch time (11 EST). It fixes the problem with expo rates off.
I have thought a lot about sound, and will do it at some point. I wanted to make this much available before I got into it though, because it'll take quite a while. Also, it seemed relatively unimportant to me, since I usually turn it off and listen to music!
Mark
Logo 600se, Scorpion 5020-450, mini-V, Jive 80HV
Trex 600 ESP FBL, Scorpion 4025-740, cgy750, CC85HV
Trex 450 Vx FBL, Scorpion 2221-10, RJX head, mini-V, Ice 50
markb is offline        Reply With Quote Quick reply to this message
Old 12-11-2007, 02:55 PM   #29 (permalink)
Cool work! Will try it out for fun.
cat5 is offline        Reply With Quote Quick reply to this message
Old 12-11-2007, 04:11 PM   #30 (permalink)
Default What happens when you call in sick from work
A pic of my Trex on Mars, and settings that feel like my real Trex.
ID:	32587   Click image for larger version
Old 12-11-2007, 04:13 PM   #31 (permalink)
It does work just fine on my MacBook Pro under W' XP and bootcamp
adamvangaalen is offline        Reply With Quote Quick reply to this message
Old 12-11-2007, 04:16 PM   #32 (permalink)
Originally Posted by Rogerdee View Post
Have an Esky 4 channel USB Tx at work and home.
Just tried it at work.Works fine.
Great sim.
Thanks for effort.
Roger
Strange, I have the same one and like I said before the elevator is the throttle?
Did yours work perfectly from the beginning or did it take some tweaking?
T-Rex 450 SA
V1 head / 430L / 35G / DS285s / GY401-HS56 / Hextronik D9 G3 2200mah / AR7000 / DX7 / Cheapie $12 CFs
Razor_Racer is offline        Reply With Quote Quick reply to this message
Old 12-11-2007, 08:43 PM   #33 (permalink)
Didn't work for me on my iMac in bootcamp. I mapped the controls and they calibrated fine. Calibration screen shows that the control signal is smooth and reading correctly but when I try to fly it it doesn't respond most of the time. Pumping the throttle I got it up in the air a few times but definitely something not working right. One weird thing I noticed was that I had no sound when I later went to fly in ClearView. Somehow the free sim turned off the audio in ClearView. I enabled audio in the ClearView setup screen and it was fine after that.
"DON'T STEAL, THE GOVERNMENT HATES COMPETITION." Congressman Ron Paul
PilotSmith is offline        Reply With Quote Quick reply to this message
Old 12-11-2007, 09:20 PM   #34 (permalink)
I have a xp6102. What piece of hardware would I need to get this to work for me. It would be nice as I don't have a sim and could really use one.
Ginvent is offline        Reply With Quote Quick reply to this message
Old 12-11-2007, 10:49 PM   #35 (permalink)
worked for me with the G3 controller. i didn't hear any sound. but, i didnt know it was supposed to have any, so i didnt muck with it. FYI, i'm using a macbook on bootcamp.
˙ʇı ʞɐǝɹq 'ǝʞoɹq ʇ,uıɐ ʇı ɟı
cudaboy_71 is offline        Reply With Quote Quick reply to this message
Old 12-11-2007, 11:41 PM   #36 (permalink)
I was using the Hitec USB cable with a Hitec radio. Same setup I use when I run ClearView on my Mac. Oh well.
Old 12-12-2007, 02:26 AM   #37 (permalink)
For Razor_racer
Some tweaking to get all the controls right.
Patience+Perseverance+Paypal=Fix+Fly+Fear
Rogerdee is offline        Reply With Quote Quick reply to this message
Old 12-12-2007, 08:56 AM   #38 (permalink)
There is no sound. I doubt that it was responsible for turning sound off, though anything is possible. But HeliSim doesn't contain any accesses to audio functions....
If you see smooth responses in the joystick mapping, but cannot take off: you may have throttle hold on. Or, the collective pitch may be mapped wrong, so you cant achieve any positive collective. The left most dial at the bottom of the screen is motor RPM. If it comes up to vertical or past, then you've got enough to fly, and its collective. If it wont move, you either have throttle mapped wrong, or throttle hold is on (red dot, upper right screen) If you're using a real RC tx, you may need to configure a simulator model setup... with linear throttle pitch curves.
Mark
Old 12-12-2007, 09:09 AM   #39 (permalink)
Originally Posted by 10karer View Post
WOW this is great. for all of the noobs out there with DX radios get smartpropo and PPjoy takes a little figuring to set up but well worth it.
Here is a link: http://www.geocities.com/shaul_ei/SmartPropoPlus.html
You need a JR trainer Cord or a Mono cord with 3.5mm jacks on both ends ( it has to be MONO Stereo wil not work) then go to the link above and follow the instructions.
Lift off is optional landing is mandatory
10karer is offline        Reply With Quote Quick reply to this message
Old 12-12-2007, 10:29 AM   #40 (permalink)
So the tx would plug into to headphone jack?
