Old 11-26-2013, 04:26 AM   #21 (permalink)
Default Version 2.4
Version 2.4 Available here :-
http://boxhillheliclub.co.uk/wp-cont...etryReader.zip
Updates
Previous version introduced an issue with kml file generation if you fly well above sea level.
New Functionality
None
Fixes
1. Fixes to kml file generation introduced by filtering in 2.3 if you are flying a lot higher than sea level.
Kevin
Trex 600N Pro with Vibe 50 Head and YS91RS motor, Vibe 50 VBar FBL, Trex744 VBar FBL MW44 Turbine, Logo 800 XXTreme, Logo 600 12s, Logo 500SE, Vario UH-1D (Building), Scratch built 625mm Quad.
kevinww is offline        Reply With Quote Quick reply to this message
Old 11-27-2013, 06:48 AM   #22 (permalink)
Thanks Kevin. We all appreciate your dedication
Oxy 2X-VertWarp 360Blade 450XBlade 450X NightflyerGoblin 500 ♦ 2 X mCPX v2 ♦ night fly mQXLadyMQXnano QXnano QX FPVInductrixDX8 G1
Coco66 is offline        Reply With Quote Quick reply to this message
Old 12-02-2013, 06:14 PM   #23 (permalink)
Default Version 2.5
Version 2.5 Available here :-
Updates
Major performance improvements when loading TLM files, Files should now load upto 5 times faster.
New Functionality
None
Fixes
1. Fixes a problem when saving Model Sessions from DX9 TLM files which subsequently causes them to fail when re-loaded.
Kevin
Old 12-03-2013, 01:27 AM   #24 (permalink)
You are on a roll. I can't wait to try the performance improvements not that it really felt slow before. Your work is appreciated.
Trex 550e V2 (flybar) - Nano CP X - Concept 30 DX
Previous: HeliMax MX400 (junk) - Trex 450 (many flavors all flybar) - Trex 600 (flybar) - 700e F3C V2 (flybar) - Trex 500e (flybar) - MCP X BL
DLGs: Solar DLG - Binary IV DLG - TopSky Mini DLG
xStatiCa is offline        Reply With Quote Quick reply to this message
Old 12-24-2013, 07:38 AM   #25 (permalink)
Default Version 2.6 Available
Version 2.6 Available here :-
Updates
No major updates, Just a bit of tidying up.
1. Minor changes to interface to aid ports to other platforms.
2. A new Icon that looks like a DX9/18 radio.
3. Minor changes to improve some of the filtering.
4. Added flight time to end of model name in drop down list.
New Functionality
None
Fixes
None
Kevin
Old 12-24-2013, 08:05 AM   #26 (permalink)
As hinted in the above notes, I've built versions of the app from a single code base for other platforms and tested them on my own machines, however, I'm looking for a couple of guinea pigs for each platform to test installation in the wild, as I already have the required Java runtimes installed and need to see how each platform behaves if the runtime is not available and how much hassle it is to install if its not available.
The native versions that I need testing are
MacOS
Tested on MacOS 10.7.4 locally
Linux
Currently tested on Ubuntu 12.4
Note these versions will require you to install a 1.6 or later Java runtime on your machine as its not included in the package as per the windows version.
If anyone would like to be a tester for either of these platforms let me know by PM.
Depending on how the testing goes, I may make these generally available in addition to the Windows version if there aren't too many issues encountered.
Kevin
Old 01-01-2014, 12:46 PM   #27 (permalink)
I just installed the latest Windows version. When I clicked on the application Norton 360 analyzed it and deleted the program. It said it was unsafe!
Anyone else have this problem? Not really interested in running an "unsafe" program.
Don
T-500 V-Bar, T-450 Pro Skookum, T-250 V-Bar, Blade 130x, Blade 300x
Don McCullough is offline        Reply With Quote Quick reply to this message
Old 01-01-2014, 01:29 PM   #28 (permalink)
Don
Norton is the problem, not the program.
Well, actually Windoze is the problem; but that's another story.
Align: Trex 550 Pro DFC, Trex 500 Pro DFC, Trex 450 Pro DFC, Trex 250 Pro DFC, Trex 150 DFC, Blade: CX2, mSR X, 120 SR, Nano QX, 300X. Spektrum: DX6i, DX8, DX9
DWill is offline        Reply With Quote Quick reply to this message
Old 01-01-2014, 03:42 PM   #29 (permalink)
The app is always virus scanned before upload and then a test download is carried out and a further scan completed after download, prior to it being announced. Both scans show it to be clean and no one else has reported an issue, so it sounds like Norton is reporting a false positive on your machine.
Old 01-06-2014, 04:30 PM   #30 (permalink)
All I get is "Failed to load [...] SPEKTRUM.TLM"
700E Pro DFC, 550SX v2, 450 Pro DFC, mCPX BL, DX8
Crowbar is offline        Reply With Quote Quick reply to this message
Old 01-06-2014, 05:34 PM   #31 (permalink)
Post the file and I'll have a look, but i suspect the file is corrupted. You'll probably have to rename it as a .txt file to post it as an attachement.
Old 01-07-2014, 02:22 PM   #32 (permalink)
If you are looking for MAC testers I can help out.
fjoe is offline        Reply With Quote Quick reply to this message
Old 01-09-2014, 08:44 PM   #33 (permalink)
I see some weird things in my log, frame loss jumps to 255. At the same time B and R, which are normally NC(AR8000 with SAT) have values. Are these just glitchs? Frame loss is never anything but zero at the end of the file.
Old 01-10-2014, 02:38 AM   #34 (permalink)
They are range warnings and are quite normal, indicating that telemetry is going out of range or TX is having a problem receiving telemetry data.
Old 01-10-2014, 06:31 AM   #35 (permalink)
Thanks!
Old 01-30-2014, 11:25 AM   #36 (permalink)
Thanks for update.
One thing I would find really useful is to have voltage and altitude on same graph. Don't know if that's possible.
DX9, Align Trex 450 Pro DFC, Blade 180cfx, Blade Nano cpx, Blade Msrx
venton is offline        Reply With Quote Quick reply to this message
Old 01-31-2014, 02:48 AM   #37 (permalink)
Not currently as each sensor is implemented as an object that only knows how to draw its own data.
Old 01-31-2014, 02:54 AM   #38 (permalink)
Default Re: Spektrum Telemetry Log Viewer
Hey guys. How do I moniter my rx and main pack volts seperatly on the dx8 also is all those sensor writes 2 needed. .... im just wondering will I have time to even look to see the voltage except maybe with rx packs in between batteries
Rc Zombie is offline        Reply With Quote Quick reply to this message
Old 02-09-2014, 08:17 AM   #39 (permalink)
This is a really great app! Nice to see the community step in and do something Spektrum should have done themselves.
Let me know if you need a Mac tester. I'm running Mavericks w/ Java 1.6.0_65
06graphite is offline        Reply With Quote Quick reply to this message
Old 02-09-2014, 04:30 PM   #40 (permalink)
Default Mac OSX
Where can I find the OSX version?
ecard is offline        Reply With Quote Quick reply to this message
