2.4G Spektrum Radios Spektrum 2.4 Gigahertz Radios and Technology |
#62 (permalink) |
![]() Nice app…thanks for making this available.
#63 (permalink) |
![]() Can't use the latest version. Symantec is saying TelemetryReader.exe has security risk Suspicious.Cloud.2. So it doesn't like something in the new code.
DX9, Mostro 700N 120SRX, HD Cell 500, Blade 450xl 6S, 180 CFX and 130x. |
#64 (permalink) |
![]() Join Date: Nov 2008
![]() As per previous posts, code is virus scanned before upload and after download and is clean. You are getting a false positive from Symantec which seems quite common for Suspicious Cloud 2.
Trex 600N Pro with Vibe 50 Head and YS91RS motor, Vibe 50 VBar FBL, Trex744 VBar FBL MW44 Turbine, Logo 800 XXTreme, Logo 600 12s, Logo 500SE, Vario UH-1D (Building), Scratch built 625mm Quad. |
#65 (permalink) |
![]() HI Kevin,
I have been using previous versions of your software with much success for some time. I have just installed version 3.0. I really wanted to be able to choose what info I show on a particular graph and not have it separated in to RX Telem, Standard Telem etc so this a great new feature. Unfortunately I now get a mis-match between the colour of the scale for a particular variable, and its actual and legend line colour. It make sit rather confusing when looking at the graphs !! I hope you can fix it for the next release. Thanks, Jeremy |
#66 (permalink) |
![]() If you tell me which one it is I'll have a look as I've had to try as best I can to match them, but may have missed a couple.
The other problem is that to implement the combined graph I've had to force each individual graph to be overlaid on a single graph, so the colours in the combined graph are those that are used in the individual graphs and i can't change them on the combined graph, so you may get some clashes. Also you need to clarify where the mismatch is as the line colour very rarely matches the scale colour, the scale colour for each line is indicated by the coloured box that surrounds each legend.
#67 (permalink) |
![]() Version 3.1 Available
This version is a minor uppdate to fix a couple issues. Updates New Functionality None Fixes 1. Fixes an issue that can occur with model names that populate the whole model name field causing app to terminate. 2. Fixes graph filtering when large chunks of telemetry data are missing from the file, for example when a model has gone out of telemetry range and then comes back into range. Windows Version :- http://boxhillheliclub.co.uk/wp-cont...etryReader.zip MAC Version :- http://boxhillheliclub.co.uk/wp-cont...eader.dmg_.zip Kevin
#68 (permalink) | |
![]() Quote:
"Suspicious.Cloud.2" found in TelemetryReader.exe - file removed ![]() Symantec for the VirusTotal: "WS.Reputation.1" ![]() but the file is clear by the remaining sources for the VirusTotal ![]()
vjj TRex 700L Dominator TOP 3+3 Speed TRex 600EFL PRO DFC BL750MX w/Performance Booster Last edited by vojta; 06-04-2014 at 10:28 AM.. |
#69 (permalink) |
![]() False positives, check back in the thread its a Norton issue.
#70 (permalink) |
![]() I have a version dated back in 12/15/13. I have no idea what version it is because the files aren't labeled with software versions and neither are the zip files. But that one works. The newest version from April 2014 trips Norton anti-virus. False positive or not, that means that the software is the problem as far as I'm concerned.
#71 (permalink) |
![]() does this work with DX9 telemetry? Had no issues with DX8 but it won't load the DX9 file. I have the latest v 3.1.
#72 (permalink) |
![]() Should be no problems with DX9. If you attach the file, I'll have a look. No other problems with DX9 have been reported, so could be a corrupted file, which I've seen in one other case.
#73 (permalink) |
![]() File too large for attachment so sharing on google drive.
If it is corrupt, you recall how it was fixed? I removed the file from sd card so it starts new. https://drive.google.com/file/d/0B61...it?usp=sharing
#74 (permalink) |
![]() File looks corrupted, most of the data in it is whole blocks of -1 values. Same as I saw in the other case, I suspect that there is some mechanism whereby the file is not terminated correctly. Cant fix that file, try and generate a new file and see if the problem persists.
#75 (permalink) |
![]() Turns out it was the sd card that came with dx9. Replaced it and now telem log works.
Sent from my SCH-I545 using Tapatalk
#76 (permalink) |
![]() Hello
is it possible to save the program settings? It is very troublesome turn off all unnecessary check after every start. It is also laborious to adjust all the colors of the lines after each program restart. Greeting Werner |
#77 (permalink) |
![]() Its on the list of future enhancements to be looked at.
#78 (permalink) |
![]() Just downloaded...works perfectly! Thank you, thank you!!
James (Jamie) Deavers MD6_Spartan Vortex_Futaba14sgh_AMA 1083246_Citizen 676 |
#79 (permalink) |
![]() Just wanted to add my request to the list of people wanting to be able to save custom trace color schemes instead of being forced to change them each time I open a new file or even change sessions in one file. One other request is to be able to adjust the 'filter' parameters. It seems that the filter only removes really spurious points. I would like to be able to change the time averaging of the trace to really smooth the traces. The preference would be to adjust per trace and not just the whole session. Thanks for a great app, keep up the great work. BTW, do you accept money for your efforts? I feel compelled to compensate people for good work.
Blade mCPx, Blade 130x, Blade 180 CFX T-Rex 250 DFC 3GX V3.1, T-Rex 450 Pro V2 3GX T-Rex 550E DFC, AR7200BX, Talon 90,TM1000 Goblin 500, IKON, Edge 100, TM1000 |
#80 (permalink) |
![]() Excellent software - just used it for the Mac. 3 things very much needed, however. First, could you have a display of the maximums and minimums for each graphed y-axis value? Second, the ability to mouseover the graph and display the current y-axis values. Third, the ability to tick and untick a y-axis box display on the Custom tab without resetting the zoom if the data has been zoomed in. The Castle Creations and also Eagle Tree software both do this and it's very helpful.
