Old 10-15-2014, 04:13 AM   #101 (permalink)
Can you indicate platform you are running on as i don't see these issues. Ok looks like a bug in the vario data
Trex 600N Pro with Vibe 50 Head and YS91RS motor, Vibe 50 VBar FBL, Trex744 VBar FBL MW44 Turbine, Logo 800 XXTreme, Logo 600 12s, Logo 500SE, Vario UH-1D (Building), Scratch built 625mm Quad.
kevinww is offline        Reply With Quote Quick reply to this message
Old 10-15-2014, 04:28 AM   #102 (permalink)
Thanks for the update.
I have a small problem with it however.
If I open a tlm file, click the custom tab, and then untick a choice at the bottom (eg "L") the program closes.
I attach an example tlm file. Windows 7.
DX9, Align Trex 450 Pro DFC, Blade 180cfx, Blade Nano cpx, Blade Msrx
venton is offline        Reply With Quote Quick reply to this message
Old 10-15-2014, 04:48 AM   #103 (permalink)
There is a problem with files containing vario data in the Custom view, i'm looking at it.
Old 10-15-2014, 04:49 AM   #104 (permalink)
Yup it is windows 7 ultimate 64bit.
I cleaned up my previous post, something happened when I edited it and it got messed up before.
BWX_ is offline        Reply With Quote Quick reply to this message
Old 10-15-2014, 08:18 AM   #105 (permalink)
Default Version 4.1 Available
Version 4.1 has been removed as a number of issues have been found.
Version 3.2 is still available here :-
https://www.helifreak.com/showpost.p...4&postcount=82
Kevin
Old 10-15-2014, 08:47 AM   #106 (permalink)
Well those sames things don't make it crash.. but I found out another one that does.
On main screen on standard tab, I hit the temperature box, and the programmed crash, but that was the first run. I started it again and exited properly, then restarted, then I tried same thing again and it did not chase the program. I think it was because there was no file to write to yet? Not sure.
Also, on custom tab, I cannot get checked box settings to stick, are they supposed to?
Thanks!
-edit-
Well I spoke too some.. i just went back to program after it sat for a bit, went to custom tab and clicked on the one of the boxes below, I think it was "A", and program crashed. hmmm
I'll upload the files I am using..
Old 10-15-2014, 08:51 AM   #107 (permalink)
Check boxes are not sticky as what's there depends on what other data present. I'll have a look at the standard telemetry
Old 10-15-2014, 08:55 AM   #108 (permalink)
Oh ok.
I uploaded the file above but I had to make it a zip file because it was too big, then it wouldn't let me upload a zip file, so I renamed it to a TLM file.
Just change it to a .zip file and then unzip it. It will create a 3,824kb .TLM file.
Old 10-15-2014, 08:59 AM   #109 (permalink)
Oh ok..
What I am trying to accomplish is to get altitude and battery flight pack voltage together, and sticky on the custom tab (or any tab). (with sticky settings for color ad line thickness... and possibly to overlay temperature and other stuff if needed).
Name:	custom setup.jpg
Old 10-15-2014, 09:16 AM   #110 (permalink)
It works the other way, you get all graphs overlayed in custom and then you switch off what you don't want to see. You cannot do what you trying to do and creat a new type of graph.
Old 10-15-2014, 09:36 AM   #111 (permalink)
Yeah that is what that is though.. just a custom telem tab..
Would be awesome if you gave option to be able to sticky those boxes ticked or not ticked somehow though.. Maybe with warning that if you tick a box that isn't part of current telem. file that it will mess things up? Not sure if that is the problem or not though. (I don't know what the limitation is, is what I meant)
Name:	custom telem tab.jpg
Old 10-16-2014, 11:34 AM   #112 (permalink)
It might be good to show the version number in the "About" box.
4_Props is offline        Reply With Quote Quick reply to this message
Old 10-16-2014, 01:19 PM   #113 (permalink)
Version number should be in the about box.
Old 10-17-2014, 09:09 AM   #114 (permalink)
Nope, maybe it's the screen resolution I run at 1920x1200. I can't drag and resize the box either.
Name:	Screenshot - 10_17_2014 , 9_54_40 AM.gif
Old 10-17-2014, 04:33 PM   #115 (permalink)
Defiantly there, you can see the start of the 3, looks like you are using large fonts, I'll increase the size of the field so its visible in your case.
Old 10-17-2014, 11:12 PM   #116 (permalink)
Old 10-20-2014, 03:17 AM   #117 (permalink)
Default Version 4.2 Available
This version is a major update to improve the graphing of data. The graphing code has had a complete overhaul so that any customizations made to Y axis properties such as colors names etc are now saved.
I've tested as much as i can with the files i have on hand, but odds are that there may be some anomalies, if you find any let me know.
Updates
New Functionality
1. Customizations to Y axis properties in graphs are now saved.
2. Changing the Y Axis selection filters on a graph no longer forces a complete graph redraw, so that all zooms etc are maintained.
Fixes
1. Fixes an issue where some selection filters could be missing in the custom graph.
Windows Version :-
http://boxhillheliclub.co.uk/wp-cont...etryReader.zip
MAC Version :-
http://boxhillheliclub.co.uk/wp-cont...eader.dmg_.zip
For install instructions see post #44
https://www.helifreak.com/showpost.p...9&postcount=44
Kevin
Old 10-20-2014, 03:32 AM   #118 (permalink)
Thanks for update! I see no crashes and the settings seem to be remembered.
Old 10-21-2014, 06:36 AM   #119 (permalink)
I,
I have a problem with OSX Yosemite. JRE 7 isn't compatible with Yosemite and your soft is not compatible with JRE 8.
Many thanks.
Jc
godjc is offline        Reply With Quote Quick reply to this message
Old 10-21-2014, 06:44 AM   #120 (permalink)
Its virtually impossible for me to cover every possibility, you could try JRE 6 as thats the lowest supported version of my code.
JRE 8 only supports 64 bit JRE on OSX whereas the code needs 32 bit JRE due to some native libraries used in the graphing, so it would require a separate build and test process for a 64 bit version, but I'll have a look.
After working with godjc on this issue, it turns out its an issue with java and Yosemite and Apple have released an updated JRE here :- http://support.apple.com/kb/DL1572?v...S&locale=en_US that resolves the problem.
