Old 12-28-2014, 05:34 PM   #121 (permalink)
Default Thanks
Thanks a lot Kevin for this application. It is very useful.
Ben_M is offline        Reply With Quote Quick reply to this message
Old 12-31-2014, 06:49 PM   #122 (permalink)
Default Problem with 'Custom' display settings
This software is a terrific tool ........... Thank you. I have encountered a problem using the 'Custom' graph setting. If I try and un-tick any of the parameters using the tick boxes at the bottom of the screen it closes the application. It does not seem to matter which one I pick. This does not happen when I use the other tab selections such as 'Speed' or 'GPS' for example.
Appreciate your advice ....... Ross
Macchiaust is offline        Reply With Quote Quick reply to this message
Old 01-01-2015, 04:12 AM   #123 (permalink)
if you can attach the TLM file I can have a look and see what's going on. A work around for now would be to untick them on the individual graph and then go to the custom graph where they should remain unticked.
Trex 600N Pro with Vibe 50 Head and YS91RS motor, Vibe 50 VBar FBL, Trex744 VBar FBL MW44 Turbine, Logo 800 XXTreme, Logo 600 12s, Logo 500SE, Vario UH-1D (Building), Scratch built 625mm Quad.
kevinww is offline        Reply With Quote Quick reply to this message
Old 02-28-2015, 12:29 PM   #124 (permalink)
Default Flight Pack Capacity
hi Kevin , is it possible to update the software so that you can add Flight Pack Capacity , I updated my mah sensor with the new firmware , and now I don't get readings on the powerbox but the flight pack menu works
flight pack sensor (3 min 8 sec)
| Kraken 700 : Neo | Atom 6HV : Neo | Align 500X : Neo | vbct : | DX8g2 |
ragge1 is offline        Reply With Quote Quick reply to this message
Old 03-02-2015, 04:12 AM   #125 (permalink)
I'm in the process of updating it to support the 3 new sensor types, but will need tlm files for testing, so i'll have a look at the file you've posted, but if anyone else has any tlm files with the Flight Pack sensor, RX Pack sensor and ESC sensors, it will help.
Old 03-02-2015, 10:05 AM   #126 (permalink)
flight pack sensor - YouTube
What sensor are you using? AFAIK at least here in the US they are still preorder.
ESC appears in the Telemetry menus but we arent clear exactly what its capabilities are yet.
Too many helis & Too many planks
Lots of DX radios & A couple Futaba 72mhz radios
AMA member & Full scale plank driver
HELIFREAK !!!
aerocal is offline        Reply With Quote Quick reply to this message
Old 03-02-2015, 11:55 AM   #127 (permalink)
So looks like there's one that monitors flight pack voltage and one that monitors receiver pack voltage- like for a motor-less sailplane I presume? There was another one that I think is listed as discontinued.
Aircraft Telemetry Flight Pack Batt Energy Sensor (SPMA9605)
http://www.horizonhobby.com/radios/t...ensor-spma9605
Key Features
  • Measure mAh (coulombs) – Monitors the level of mAh used in a single flight pack battery
  • Compact Design – Small footprint allows for virtually unlimited applications
  • Easy Set Up – No calibration or programming of the unit itself is required
  • EC3 Connectors – Uses standard EC3 battery connectors to easily connect between the battery and ESC
Aircraft Telemetry Receiver Batt Energy Sensor (SPMA9604)
http://www.horizonhobby.com/radios/t...ensor-spma9604
Key Features
  • Reset Switch – Allows the user to reset the data of the battery status after recharging the battery pack
  • Measure mAh (coulombs) – Monitors the level of mAh used in a single receiver battery pack
  • Measure Voltage – User will be able to monitor the voltage condition of the batteryin use
  • Compact Design – Small footprint will allow for virtually unlimited applications
  • Z Connector – Uses the conventional servo connector to connect to the receiver making it compatible with all Spektrum telemetry compatible receivers
This one listed as discontinued:
Aircraft Telemetry High-Current Sensor (SPMA9590)
http://www.horizonhobby.com/aircraft...ensor-spma9590
Key Features
  • Measure the current from 10-150A
  • Can be used on high-voltage applications up to 60V
  • Easy installation in most any aircraft
  • Spektrum™ TM1000 module-compatible for use with aircraft telemetry systems
  • 11-bit resolution with 146mA/bit for precise data measurement
BWX_ is offline        Reply With Quote Quick reply to this message
Old 03-02-2015, 12:48 PM   #128 (permalink)
as you know Spektrum have been late or didn't have the intress in making a mah sensor while other companies did , so a German guy made a home-made sensor for the spektrum radios and was honoured to try/buy some , here is a tread I made in the Swedish board back in sep. 2013 : http://www.helisweden.se/showthread....light=rctronix
might need google translate
I had the V2 version that I could read the mah and current in the powerbox menu , but after I updated to V3 - so that includes the new radio update '' Flight pack capacity '' I can't read the values anymore on the powerbox ,
here an old file with the sensor on V2
will get the Spectrum sensor and test as well when they come out ( may I believe )
Old 03-02-2015, 12:59 PM   #129 (permalink)
suprising the sun came out today , managed one flight , hade the alarm set at 2200mah and status raport on 60s
really cool every minute you get the info on how much mah is used
Kevin file on the flight today
ID:	572782   Click image for larger version
Old 03-22-2015, 08:21 PM   #130 (permalink)
I have 1 of those sensors I bought it from Christian aka chla1 here on Helifreak. I am very happy with it.
001~1 Heli.TLM
Lynx Team Test Pilot
Heli's :, Gaui X3, Logo 480,
Vbar Control
Lu523 is offline        Reply With Quote Quick reply to this message
Old 03-23-2015, 02:08 AM   #131 (permalink)
Attachment 575500
Attachment 575493
have you upgraded your sensor to v3 ,
Old 03-23-2015, 12:14 PM   #132 (permalink)
It is just like I bought it. I don'y even know how to update it. Maybe something I need to check into.
Vbar Control
Old 04-09-2015, 09:18 PM   #133 (permalink)
Kevin,
Do you have source out on GitHub or another site? I'd love to play around with the app. Possibly work on a Linux or Android version.
Thanks,
Mike G.
mikejr83 is offline        Reply With Quote Quick reply to this message
Old 04-12-2015, 05:57 PM   #134 (permalink)
Sorry no, I have a Linux version, but have not made it available due to the support overhead it will generate. Won't work on Android as the graphing library used is not available.
Old 04-12-2015, 06:15 PM   #135 (permalink)
So, not open source then? Was at least hoping to see how you're working with the files. I opened up one of the files in Bless to see if I could make anything from hex -> ascii and aside from the model name wasn't able to get anything usable.
My end goal was basically to have some sort of alt graph readout in an Android app.
Old 04-21-2015, 03:28 AM   #136 (permalink)
Hi Kevin!
I've got the same problem like ragge1. I'm using this brilliant sensor: http://www.rctronix.de/wp/?p=368
In the latest Version with firmware V3 it supports flight pack capacity metering. Now it is possible to use it for example with the DX6 radio which doesn't support the powerbox. It works fine and I'm able to configure alarms and check the used mAh's directly on the screen of my radio.
Actually I can't upload any file - because I'm a new user, I guess?
cfblades is offline        Reply With Quote Quick reply to this message
Old 04-21-2015, 08:09 AM   #137 (permalink)
As per previous reply to ragge1, the new sensors types are a work in progress, but until I can test with data from all the various sensors that support these formats and not just the functionality that your currently using via the powerbox, I'm restricted in what I can do, as currently time is at premium on my side so I don't want to release something that works sometimes and not others and then have to do a fix later. I'd rather get it right first time.
Old 04-21-2015, 10:04 AM   #138 (permalink)
Ok, this sounds plausible, thanks for your quick response.
If I can help with tlm-files, let me know.
Old 06-21-2015, 10:16 AM   #139 (permalink)
Hi Kevin,
you making progress with the flight Pack integration.
I'm so impatient because my power box no longer works with the new Kapasensor software.
papads is offline        Reply With Quote Quick reply to this message
Old 06-21-2015, 05:34 PM   #140 (permalink)
See post #137 above, coding is complete, but spektrum sensors not widely available yet to complete testing.
