Old 06-22-2015, 07:45 AM   #141 (permalink)
Default Spektrum Telemetry Log File Viewer
Hello All,
I am new to the sight and trying to get the Export KML file to work. In the file menu everything is active except KML. Any ideas what I am doing wrong?
Thanks Darryl
Darrylhj is offline        Reply With Quote Quick reply to this message
Old 06-22-2015, 11:40 AM   #142 (permalink)
you need to have the gps data selected in the tabs for the export kml file to be active.
Trex 600N Pro with Vibe 50 Head and YS91RS motor, Vibe 50 VBar FBL, Trex744 VBar FBL MW44 Turbine, Logo 800 XXTreme, Logo 600 12s, Logo 500SE, Vario UH-1D (Building), Scratch built 625mm Quad.
kevinww is offline        Reply With Quote Quick reply to this message
Old 08-09-2015, 01:24 PM   #143 (permalink)
Default TLM with ESC and Flight Pack Data
Hi Kevin,
in case you are still looking for TLM files with the new sensors, I can offer you this one with ESC and Flight Pack Data submitted from a JLog2.6 module.
https://dl.dropboxusercontent.com/u/...-JLog-Jive.TLM
I also tried running the Mac version of Telemetry Viewer on OSX 10.10 but hit a wall as I only have 64-Bit Java available. Is there anything more recent (or a how-to) available for us OSX'ers?
Cheers,
Martin
klickmich is offline        Reply With Quote Quick reply to this message
Old 08-10-2015, 05:38 PM   #144 (permalink)
See post 120
https://www.helifreak.com/showpost.p...&postcount=120
Old 10-03-2015, 11:07 AM   #145 (permalink)
two flights today with Spektrum mah sensor
| Kraken 700 : Neo | Atom 6HV : Neo | Align 500X : Neo | vbct : | DX8g2 |
ragge1 is offline        Reply With Quote Quick reply to this message
Old 10-03-2015, 12:03 PM   #146 (permalink)
Thanks Ragge, they look fine. Still got a couple issues to resolve with ESC sensor graphing and then I'll do a new version. Time is still at a premium my end so will be at least a couple of weeks to a month.
Old 10-03-2015, 04:51 PM   #147 (permalink)
It seems like maybe the capacity should start out "full" and then go down.. like opposite as that graph does above. Maybe?
Maybe it would seem like it is getting "used up", instead of "growing" if the line started out high on the left and then ended up low on the right.
Just an idea. Or maybe that could just be an option in the way the graph is presented, since you obviously can't know the final outcome at the start of the file.
BWX_ is offline        Reply With Quote Quick reply to this message
Old 10-08-2015, 02:40 PM   #148 (permalink)
I,
With OSX 10.11 (El Capitan) the soft freeze on TLM file load.
Cordialy
Jc
godjc is offline        Reply With Quote Quick reply to this message
Old 10-10-2015, 01:09 PM   #149 (permalink)
Default A note of apreciation
Kevin,
Thanks so much for your work on this software. I am a new telemetry user and your software has allowed me to review the data graphically as well as exporting it to an Excel compatible format.
I am seeing some strange data and will be working on a resolution.
redytorace is offline        Reply With Quote Quick reply to this message
Old 10-22-2015, 07:27 PM   #150 (permalink)
Default Sensor Tabs
Hi All, just curious, but is it possible to disable or hide tabs for sensors that are not installed?
Thanks,
Bob
DOANRM is offline        Reply With Quote Quick reply to this message
Old 10-22-2015, 09:17 PM   #151 (permalink)
Thanks,
Bob
You can do it in the "custom" section.. but then every time you re-load the program, it all goes back to the way it was before, nothing ever saves, I mean the changes you can make to the views or the changes you make to the color of the lines or thickness of the lines in the graph, etc. it all goes back to default upon each restart unfortunately. It is possible to get a screen without those extra things though.
(uploaded a pic as example of a custom view)
-edit- what the heck? HF shrinks pics and sets quality to - crap. :-/
Name:	radian first thermal 2015-4-12-15-1.jpg
Old 10-23-2015, 05:47 PM   #152 (permalink)
You should only get tabs for the sensors you have configured in the radio or which the radio receives.
BWX, not sure why you think changes you make to the graph colors, line thickness etc are not saved they should be.
Old 10-23-2015, 05:57 PM   #153 (permalink)
Originally Posted by godjc View Post
I,
Cordialy
Jc
Thats going to be a difficult one to see what is going on as its developed on a Windows platform and then built to run on Mac, so no development tools on mac to analyse what has changed.
Old 10-23-2015, 06:09 PM   #154 (permalink)
They reset after each restart, everything always does, I even have to set it to standard (not metric) every time. The program has no "memory" at all for me, and never has AFAIK.
My PC is up to date.. Win 7 64 Ultimate.
This is what it says in that "error.log file" (using v4.2)
Code:
Config file not found, using default values.
Invalid or No preferences file found, using defaults.
java.lang.NullPointerException
	at com.kw.telemetry.ConfigParameters.saveFile(ConfigParameters.java:131)
	at com.kw.telemetry.app.TelemetryAppWindow.open(TelemetryAppWindow.java:129)
	at com.kw.telemetry.app.TelemetryAppWindow$1.run(TelemetryAppWindow.java:101)
	at org.eclipse.core.databinding.observable.Realm.runWithDefault(Realm.java:332)
	at com.kw.telemetry.app.TelemetryAppWindow.main(TelemetryAppWindow.java:97)
	at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
	at sun.reflect.NativeMethodAccessorImpl.invoke(Unknown Source)
	at sun.reflect.DelegatingMethodAccessorImpl.invoke(Unknown Source)
	at java.lang.reflect.Method.invoke(Unknown Source)
	at com.exe4j.runtime.LauncherEngine.launch(Unknown Source)
	at com.exe4j.runtime.WinLauncher.main(Unknown Source)
In TelemetryApp.cfg file:
Code:
         G:\downloads\Spektrum DX9\flight logs\up to april 13 2-015
TelemetryAppPreference.cfg
Code:
com.kw.telemetry.sensors.CustomTelemetry
Custom Telemetry;0;0;0
TemperatureM
Temperature;255;0;0;NONE;1;0;SOLID_LINE;Celcius;150;150;150
Pack Voltage
Pack Voltage;128;0;255;NONE;1;0;SOLID_LINE;Voltage;0;255;0
AirspeedI
Airspeed;0;0;255;NONE;1;0;SOLID_LINE;Airspeed MPH;255;128;0
A
A;0;255;255;NONE;1;0;SOLID_LINE;Fades;0;255;255
B
B;0;0;0;NONE;1;0;SOLID_LINE;Fades;0;255;255
L
L;200;200;200;NONE;1;0;SOLID_LINE;Fades;0;255;255
TemperatureI
Temperature;255;0;0;NONE;2;0;SOLID_LINE;Farenheit;150;150;150
Max Y
Max Y;200;200;200;NONE;1;0;SOLID_LINE;G Force;0;0;255
Max X
Max X;153;186;243;NONE;1;0;SOLID_LINE;G Force;0;0;255
VarAltitudeM
Altitude;153;186;243;NONE;2;0;SOLID_LINE;Metres;153;186;243
Max Z
Max Z;255;0;0;NONE;1;0;SOLID_LINE;G Force;0;0;255
VarAltitudeI
Altitude;153;186;243;NONE;2;0;SOLID_LINE;Feet;153;186;243
R
R;255;0;255;NONE;1;0;SOLID_LINE;Fades;0;255;255
Voltage
Voltage;0;255;0;NONE;2;0;SOLID_LINE;Volts;200;200;200
AirspeedM
Airspeed;0;0;255;NONE;1;0;SOLID_LINE;Airspeed KPH;255;128;0
Frame
Frame;0;255;0;NONE;1;0;SOLID_LINE;Frame/Loss Count;255;0;0
Y
Y;0;255;0;NONE;1;0;SOLID_LINE;G Force;0;0;255
X
X;0;255;255;NONE;1;0;SOLID_LINE;G Force;0;0;255
GPSAltitudeI
Altitude;255;128;0;NONE;1;0;SOLID_LINE;GPS Feet;255;128;0
Z
Z;128;0;255;NONE;1;0;SOLID_LINE;G Force;0;0;255
Current
Current;0;0;255;NONE;1;0;SOLID_LINE;Amps;153;186;243
DeltaM
Delta;255;128;0;NONE;1;0;SOLID_LINE;Metres/s;255;128;0
Mah 2
Mah 2;255;0;0;NONE;1;0;SOLID_LINE;Mah;255;128;0
DeltaI
Delta;255;128;0;NONE;1;0;SOLID_LINE;Feet/s;255;128;0
Mah 1
Mah 1;255;128;0;NONE;1;0;SOLID_LINE;Mah;150;150;150
Holds
Holds;255;0;0;NONE;1;0;SOLID_LINE;Frame/Loss Count;255;0;0
GPSAltitudeM
Altitude;255;128;0;NONE;1;0;SOLID_LINE;GPS Metres;255;128;0
Pump Volotage
Pump Volotage;0;255;0;NONE;1;0;SOLID_LINE;Voltage;0;255;0
Min Z
Min Z;255;0;255;NONE;1;0;SOLID_LINE;G Force;0;0;255
AltitudeI
Altitude;153;186;243;NONE;1;0;SOLID_LINE;Feet;153;186;243
EGTM
EGT;255;0;0;NONE;1;0;SOLID_LINE;Celcius;255;0;0
Throttle %
Throttle %;0;0;255;NONE;1;0;SOLID_LINE;Throttle %;0;0;255
RX Volts
RX Volts;0;0;255;NONE;1;0;SOLID_LINE;RX Voltage;0;255;0
AltitudeM
Altitude;153;186;243;NONE;1;0;SOLID_LINE;Metres;153;186;243
SpeedM
Speed;153;186;243;NONE;1;0;SOLID_LINE;GPS Kph;153;186;243
Turbine RPM
Turbine RPM;0;0;0;NONE;1;0;SOLID_LINE;Turbine RPM;0;0;0
Max AltitudeM
Max Altitude;255;0;0;NONE;1;0;SOLID_LINE;Metres;153;186;243
RPM
RPM;0;0;255;NONE;2;0;SOLID_LINE;RPM;0;0;0
Volts 2
Volts 2;153;186;243;NONE;1;0;SOLID_LINE;Volts;150;150;150
EGTI
EGT;255;0;0;NONE;1;0;SOLID_LINE;Farenfeit;255;0;0
SpeedI
Speed;153;186;243;NONE;1;0;SOLID_LINE;GPS Mph;153;186;243
Volts 1
Volts 1;0;0;255;NONE;1;0;SOLID_LINE;Volts;150;150;150
Max AltitudeI
Max Altitude;255;0;0;NONE;1;0;SOLID_LINE;Feet;153;186;243
End
com.kw.telemetry.sensors.VarioSensorTelemetry
Vario Telemetry;0;0;0
VarAltitudeM
DeltaM
VarAltitudeI
DeltaI
End
com.kw.telemetry.sensors.StdSensorTelemetry
Standard Telemetry;0;0;0
TemperatureM
Voltage
RPM
TemperatureI
End
com.kw.telemetry.sensors.PowerBoxSensorTelemetry
GPS Telemetry;0;0;0
Mah 2
Mah 1
Volts 2
Volts 1
End
com.kw.telemetry.sensors.CurrentSensorTelemetry
Current Telemetry;0;0;0
Current
End
com.kw.telemetry.sensors.RXSensorTelemetry
RX Telemetry;0;0;0
A
A;0;255;255;NONE;2;0;SOLID_LINE;Fades;0;255;255
B
B;0;0;0;NONE;2;0;SOLID_LINE;Fades;0;255;255
Holds
Holds;255;0;0;NONE;2;0;SOLID_LINE;Frame/Loss Count;255;0;0
R
R;255;0;255;NONE;2;0;SOLID_LINE;Fades;0;255;255
RX Volts
RX Volts;0;0;255;NONE;2;0;SOLID_LINE;RX Voltage;0;255;0
L
L;200;200;200;NONE;2;0;SOLID_LINE;Fades;0;255;255
Frame
Frame;0;255;0;NONE;2;0;SOLID_LINE;Frame/Loss Count;255;0;0
End
com.kw.telemetry.sensors.SpeedSensorTelemetry
Speed Telemetry;0;0;0
AirspeedI
AirspeedM
End
com.kw.telemetry.sensors.GForceSensorTelemetry
GForce Telemetry;0;0;0
Max Y
Max X
Max Z
Y
X
Min Z
Z
End
com.kw.telemetry.sensors.JetCatSensorTelemetry
JetCat Telemetry;0;0;0
Pack Voltage
EGTM
Throttle %
Turbine RPM
EGTI
Pump Volotage
End
com.kw.telemetry.sensors.GPSSensorTelemetry
GPS Telemetry;0;0;0
SpeedM
GPSAltitudeM
SpeedI
GPSAltitudeI
End
com.kw.telemetry.sensors.AltitudeSensorTelemetry
Altitude Telemetry;0;0;0
AltitudeI
AltitudeM
Max AltitudeM
Max AltitudeI
End
TelemetryReader.vmoptions :
Code:
-Xmx256m
-Xms32m
Same thing with all versions too. I dunno?
Old 10-23-2015, 06:20 PM   #155 (permalink)
Maybe program expects to find that cfg file somewhere else or something. All files are in the same folder, the one that got made when I unzipped the program.
edit- Just for the heck of it I opened it up again and tried it and all those lines and stuff seem to be the same as I set them (thicker, different colors, etc).. So that's new.
Strange that it all "stuck" from last time I opened the program, about a month ago now.
In the "custom" tab, all the boxes are checked each time, I have to go in and uncheck them still. I guess that's what the post was about in the first place though. Those views cannot be saved.
Old 10-23-2015, 06:33 PM   #156 (permalink)
Seems like you have resolved it.
Old 10-30-2015, 02:44 AM   #157 (permalink)
Hello,
after upgrading my DX9 to 1.08 firmware version, the TLM files became crazy :
http://home.nordnet.fr/davy/RAVE.TLM
Revert to 1.07 resolved my issue.
Do you have same problem ? Thank you.
zzzdavy is offline        Reply With Quote Quick reply to this message
Old 10-30-2015, 03:15 AM   #158 (permalink)
That's not good, either the telemetry format has been changed by spektrum or the new update is buggy or your file is corrupted somehow. My guess is they have changed the format slightly but I can't check as I cant open the file you posted. Can you attach it to your post instead.
Old 10-30-2015, 03:17 AM   #159 (permalink)
Here is the file. Thank you.
Old 10-30-2015, 04:26 AM   #160 (permalink)
It looks like there have been some subtle changes to the file format that is causing the problem. As I'm not privvy to the format of the file and have to work it out myself, I'll have to do a bit more analysis as to what's changed.
If spektrum have changed the format slightly, which is their prerogative as its their file, it becomes a very large task to work out what they have done and time is at a premium on my side, also I no longer use Spektrum radios, which may mean that I have to evaluate whether I withdraw support for the app as it will become unsustainable if future Airware updates can change the telemetry data.
