Old 12-13-2007, 07:51 PM   #1 (permalink)
Default Graphic 430 motor bearing replacement
Materials and tools
1.NEW R2-5ZZ Bearing *2
2. screw lock adhisive
3. Homemade wrench set.
4. bended main spindle of 450
5. Toothpicks 1
6. Hammer .
7. table pliers
ID:	33100   Click image for larger version
ID:	33101   Click image for larger version
ID:	33102   Click image for larger version
ID:	33103   Click image for larger version
ID:	33105   Click image for larger version
ID:	33106   Click image for larger version
When one day you can manage hover,the sky is your home!
iceman33 is offline        Reply With Quote Quick reply to this message
Old 12-13-2007, 09:05 PM   #2 (permalink)
I like the idea of your homemade wrench set.
0636 is offline        Reply With Quote Quick reply to this message
Old 12-13-2007, 09:25 PM   #3 (permalink)
Nice job iceman33.
I just wanted to throw in for those looking for bearing if you have a hard time finding them as RZ-522, that they are non metric, or standard, 1/8 x 5/16 x 5/32" which if you just have to spec them in metric is 7.93 x 3.17 x 3.57mm
You should be able to get them at any bearing supply or Boca has them.
Gary JP4 is offline        Reply With Quote Quick reply to this message
Old 12-13-2007, 10:57 PM   #4 (permalink)
go on.
ID:	32785   Click image for larger version
ID:	32786   Click image for larger version
ID:	32787   Click image for larger version
ID:	32788   Click image for larger version
ID:	32794   Click image for larger version
ID:	32795   Click image for larger version
Old 12-14-2007, 08:26 AM   #5 (permalink)
COOL. I have a locked up 430L I would like to take apart, but I had no idea how to get it apart.
Time to make some tools.
Terry
AMA#47402, IRCHA # 3395
Pinecone is offline        Reply With Quote Quick reply to this message
Old 12-16-2007, 09:42 PM   #6 (permalink)
Got my motor fixed. A few things:
I used a piece of 2" metal strap with holes I had laying around (Home Depot). It had been cut off at one end across the edge of one of the holes. This worked great for the shaft end.
4mm socket head machine screw heads fit the motor holes perfectly.
The holes for the machine screws should be 18mm apart on the tools.
Now only one end comes off. On mine it was the shaft exit end, but this was enough for me.
Pulling my motor apart I would a washer inside. This was what locked it up. I think I may have dropped it in during the build. If so I got something like 60 or so flights before it locked up.
So now I have a spare motor.
Terry
Old 12-16-2007, 11:29 PM   #7 (permalink)
Team Taco VP
This is GREAT INFO! Thank you.... If you all agree I want to STICK this post....
You all agree it's worthy?
Bob
Old 12-16-2007, 11:45 PM   #8 (permalink)
Yes
Old 12-17-2007, 10:04 AM   #9 (permalink)
Bob
there are some photo need edit.
Old 12-17-2007, 10:18 AM   #10 (permalink)
yeah defo worth a sticky Finless, very useful!
Tom Burgess is offline        Reply With Quote Quick reply to this message
Old 12-17-2007, 01:37 PM   #11 (permalink)
I like it! Sticky!
First time I have seen the inside of an align motor!
I'm still rocking my 430L!
gagi is offline        Reply With Quote Quick reply to this message
Old 12-17-2007, 08:57 PM   #12 (permalink)
part 3
ID:	33108   Click image for larger version
ID:	33109   Click image for larger version
ID:	33110   Click image for larger version
ID:	33111   Click image for larger version
ID:	33113   Click image for larger version
ID:	33114   Click image for larger version
Old 12-17-2007, 09:06 PM   #13 (permalink)
final
ID:	33116   Click image for larger version
ID:	33117   Click image for larger version
Old 12-17-2007, 09:09 PM   #14 (permalink)
Bob
Awesome!!!!
Helifarns is offline        Reply With Quote Quick reply to this message
Old 12-29-2007, 01:08 AM   #15 (permalink)
Talking
Iceman
Thanks for the info, this now gives me a spare motor
rwmcknight is offline        Reply With Quote Quick reply to this message
Old 02-04-2008, 07:53 AM   #16 (permalink)
Salute !!! seems I can try on my Align 600L and update my blog
http://drtungym.blogspot.com/2008/01...brushless.html
tungym is offline        Reply With Quote Quick reply to this message
Old 02-27-2008, 11:02 PM   #17 (permalink)
What have people used for adhesive during reassembly?
jhat is offline        Reply With Quote Quick reply to this message
Old 02-28-2008, 08:54 AM   #18 (permalink)
I used nothing as it took the tools to put it back together. You could use some blue Loctite.
Terry
Old 03-03-2008, 12:54 AM   #19 (permalink)
Originally Posted by outhouse
i just got the align rce-bl35x for the -8 and hope it works fine. ive seen one of the pros using the align 35 so what the heck
Outhouse,
I have that exact set up with No Braking, High Timing, Mid Batt. cut off, Heli 2 mode w/ Soft start/ Gov mode, and lastly with Quick Throttle response. I was just wondering what head speed your getting. Cause I have 2221-8 v1 w/ 13T and with my last ESC the Align BL35G which gave me 3200 HS easy at 100% but I have noticed that when I hit idle up 1 or even 2 I could usual hear it jump up and the head speed would really jump to 3200 but with this "New" BL35X (6v) ESC it will only hit 3000 HS tops and it would not jump at all or increase at all when I hit Idle up hear are my TC's
Flight Mode - 0,INH,80,INH,100
Idle Up 1 - 100,INH,90,INH,100
Idle Up 2 - 100,100,100,100,100
I have the DX-7 radio and I didn't know if you or anyone would know what to do to get my HS back up to normal with Gov mode if that's possible
Thanx
Blake
600dreamer is offline        Reply With Quote Quick reply to this message
Old 04-23-2008, 02:27 AM   #20 (permalink)
IDK so correct me if I'm wrong, but wouldn't locktight just liquify from the heat the motor makes? Maybe CA instead? BTW what happens if you do touch the coils...with like a screw or something? Is there a way to fix it then?
Thanks,
~Marty
See my artwork: http://martins819.deviantart.com
MartinS819 is offline        Reply With Quote Quick reply to this message
