Go Back   HeliFreak > R/C Simulators Support > Phoenix Flight Sim
Phoenix Flight Sim Phoenix Flight Sim
Old 12-17-2007, 08:50 AM   #1 (permalink)
Default Phoenix Sim - Post your variant to share here!!!
Hi all, since this sim need some swap pages (like other sim), i think that user like me need some variant posted/shared from all of you.
Be the first, this is my variant of T600 nitro red;
This variant have "gear" related adjustment for better autos like gear friction setting, robustness and lowering CG to get something smooth slide movement in autos.
Please use winzip to extract this file to your documents folder like:
C:\Documents and Settings\"yourlogginname"\My Documents\PhoenixRC\Variants\helicopters\trex600ni tro_red_3Dreal.fly
or example for me; (in mine; with loggin as "DeVIN") to:
C:\Documents and Settings\DeVIN\My Documents\PhoenixRC\Variants\helicopters\trex600ni tro_red_3Dreal.fly
Sorry for my bad English. Just try to make some contribution for this community.
Cheers.
File Type: zip PhoenixRC_Variants_helicopters_trex600nitro_red_3Dreal.zip (984 Bytes, 1645 views)
devindh is offline        Reply With Quote Quick reply to this message
Old 12-17-2007, 09:05 AM   #2 (permalink)
Cool thanks! (Sticked post)
Dan Da Dawg - JR X9303
Hexa F550 on 3S + 6S TREX 500 + 6S TREX 600 + Blade mSR + Blade mCPx2 Brushless + 12S Rave FBL ENV
DebianDog is offline        Reply With Quote Quick reply to this message
Old 12-17-2007, 10:00 AM   #3 (permalink)
Thx Deb, can i call you like that??,....
And this for 2nd,...
Spark variant like Blade CP Pro heli, stock setup + headlock gyro,.... with skid tweak like superskid strength.
I hope you all like that.
File Type: zip PhoenixRC_Variants_helicopters_spark_Blade CP Pro.zip (955 Bytes, 853 views)
Old 12-19-2007, 11:06 AM   #4 (permalink)
Good news, got an email from Phoenix support team,..
Hi Devin
Thank you very much for your comments and suggestions.
We are intending to create a swap site for variants, recordings and eventually new paint schemes.
Reagrding the repainting the models, we are currently working very hard on a painting tool whch will allow you to repaint any Phoenix model in full 3D - more information on this will be on our website in the near future.
Best Regards
PhoenixRC Support
Old 12-20-2007, 11:29 PM   #5 (permalink)
Did you ask Phoenix if they are going to improve the sound effects for heli blades and wind etc.?
Crelum is offline        Reply With Quote Quick reply to this message
Old 12-20-2007, 11:44 PM   #6 (permalink)
Yap. they will,...
Cheers.
Old 12-27-2007, 03:11 AM   #7 (permalink)
Try to get 110% in cylic for my t600nitro_red variant now, for get better piroflip.
Someone here?? Please, post your setup.
Cheers.
Old 01-01-2008, 07:15 AM   #8 (permalink)
hey guys here's my trex 600n variant .fly file. Its saved as a .txt so will need renaming.
i've changed some of the numbers a fair bit, but I think it now flies pretty close to my 600n with metal grips, infinivation dampers and radix blades. my real one doesn't actually weigh 7 kg, but it seems to make it sit in a hover more like mine does! I haven't played with it in autorotations much, so i'm not sure if works very well there yet.
hope you like it
squareben is offline        Reply With Quote Quick reply to this message
Old 01-01-2008, 08:27 AM   #9 (permalink)
Hi Squareben. Nice. What is your simulation speed for this variants?? I feel it so twitchy, here in 100% speed.
Regards.
Old 01-01-2008, 12:55 PM   #10 (permalink)
How do you change it back to a .fly file?
raptor3dpilot is offline        Reply With Quote Quick reply to this message
Old 01-01-2008, 06:58 PM   #11 (permalink)
Hi, raptor3dpilot. Download the files to your computer. Use explorer and renaming *.txt to *.fly and put it to eg;in mine - "C:\Documents and Settings\DeVIN\My Documents\PhoenixRC\Variants\helicopters\ trex600nitro_red_squareben.fly"
PS; DeVIN is my login name; must be different to yours
Just to be sure in your explorer you got to "show file extension". To check this setting; use explorer, find Tools menu, Folder Options, pick Views tab, and uncheck Hide extension for known file types to show whole file name included extension.
Old 01-01-2008, 09:32 PM   #12 (permalink)
Man you don't know how long I've wanted to know how to show the extensions! That worked perfectly!
Once again THANKS!
Old 01-02-2008, 05:19 PM   #13 (permalink)
hey devindh,
i run my phoenix at 100 to 105% depending on what i'm doing. My graphics card is pretty low spec though, so maybe that makes it more docile for me! i can usually only get 40 to 50 fps.
i'm still fiddling with the cyclic response and damper values so i'll let you know if i get a better combination.
ben
Old 01-03-2008, 06:19 AM   #14 (permalink)
Ok Ben, ,........................
It is a new issue now,.....................
"The variant cant be shared as easy like this",
cause in my system with 100% speed, full 60 fps, your variant so twitchy. Its character different in yours,....
Some parameters from your GPU-VGA, RAM setting (maybe), is the key. I hope your understand my bad english.
Cheers.
Old 01-04-2008, 01:11 AM   #15 (permalink)
It's not a helicopter... but here is my Variable Pitch ShiftRotor. It's alot of fun and gets rid of stress after a session of training.
You have to make sure your 3 pos switch is set to control the tilt, and set your throttle curve to a V under System_yourcontrols
All I did was just make the pitch range like a helicopter (+10/0/-10) and lightened it to 25lbs.
Uhhh not sure how to make the screenshot come up without clicking it... but oh well.
Old 01-05-2008, 12:39 PM   #16 (permalink)
Default Honey Bee King2 - tailfix - 3d setup
Here is mine,..........................try.
Unzip ???recording (*.rec) to C:\Documents and Settings\(your login)\My Documents\PhoenixRC\Recordings
Rename ???.txt to ???.fly to C:\Documents and Settings\(your login)\My Documents\PhoenixRC\Variants\helicopters
Cheers.
Old 02-05-2008, 10:29 AM   #17 (permalink)
Default Trex 500 Drift Fix and variant
For those flying the 500 on Phoenix, in case you have not noticed, and I dont see how you couldn't, the left drift effect is way overboard. See image below of angle held for steady hover. The red is the 500. Thats more like hovering it a 10 mph wind from the right. Anyway below the image is a link to a variant I did, which to me is more lifelike. I also added some vortex lift loss effect so the heli actually drops after settling. This one autos more like mine as well.
http://www.socalsurfs.com/trex500/trex500_socal500.fly
Socal500 is offline        Reply With Quote Quick reply to this message
Old 02-05-2008, 06:04 PM   #18 (permalink)
Now you put it on helifreaks...it would have been easier yesterday for me to find it . Good job on the variant though. I also look forward to practicing my autos with you guys later.
have a good one
helidude123 is offline        Reply With Quote Quick reply to this message
Old 02-05-2008, 08:41 PM   #19 (permalink)
Sorry... I had only visited the 500 forum and was not aware this variant sticky was here.
Old 02-09-2008, 11:39 AM   #20 (permalink)
Hi, Socal
Thanks for the 500 variant!!
I'm building my 500 now, and I'm about to setup pitch range on it.
If your variant feels like your 500. What are your collective and cyclic pitch range? Do you know?
I'm aiming for something like +12/-12 collective and 7 cyclic. Would that be something like your variant?
rostad
rostad is offline        Reply With Quote Quick reply to this message
