Go Back   HeliFreak > R/C Simulators Support > Phoenix Flight Sim
Phoenix Flight Sim Phoenix Flight Sim
Old 10-27-2010, 05:52 AM   #81 (permalink)
Originally Posted by pitchp View Post
anyone have any Trex 250 variants please? Something with more power? I've got a 250 with 5500 HS in real life, and I'm looking for something similar ? TIA
Just edit the model and adjust the head speed up in the settings.
D
devens is offline        Reply With Quote Quick reply to this message
Old 10-27-2010, 06:07 AM   #82 (permalink)
D
Yeah where do I adjust the HS? I go to Model>Edit>Main Rotor> Rotor Governor>
And I try to set 5500 HS, and it wouldn't let me. Why? What am I suppossed to do? My real 250 is 5500 HS
Just how deep does the rabbit hole go?
pitchp is offline        Reply With Quote Quick reply to this message
Old 10-27-2010, 10:30 AM   #83 (permalink)
How high does it let you go to? Maybe 5500 on a 250 isn't a good idea? What is the typical headspeed?
Old 10-27-2010, 12:13 PM   #84 (permalink)
3500
Old 11-02-2010, 12:48 PM   #85 (permalink)
Not a heli but I'm working on a few. I recently picked up a 30% MX2 in the Gary Ward scheme so I made a variant for Phoenix. Will post up the helis as they get done.
ID:	188237   Click image for larger version
ID:	188238   Click image for larger version
-TREX600NSP - TREX500ESP -TREX450FBL - TREX250 - CHP GAUI 550 - OXY3 - 30% EG Aircraft MX2 DLE55 -
JaggedEdge is offline        Reply With Quote Quick reply to this message
Old 11-02-2010, 10:28 PM   #86 (permalink)
Old 11-03-2010, 04:44 PM   #87 (permalink)
Thanks Jagged. Any idea what's going on with the floor/canopy on the extra#MX2?
Here's a recent pic of the 100% reference kicking into a side slide.
xspare is offline        Reply With Quote Quick reply to this message
Old 11-05-2010, 08:45 PM   #88 (permalink)
Shimmering floor boards work around: edit moedl to use another color scheme such as default and then load the "MX2-GW" scheme. I think you need to do this every time you load the model.
Old 11-16-2010, 07:56 AM   #89 (permalink)
Hey pitchp, switch off the governor and set the headspeed by upping the motor RPM and adjusting the gear ratio on the main gear, by doing this you can get higher headspeeds, but obviously they'll be ungoverned so you might need to play with your throttle and pitch curves a bit to get an even headspeed across your pitch range.
jagsta is offline        Reply With Quote Quick reply to this message
Old 11-16-2010, 01:17 PM   #90 (permalink)
thank you jagsta, what would you recommend for the settings?
Old 11-17-2010, 07:47 AM   #91 (permalink)
I haven't flown a 250 model so can't say specifically what you'll need. The Phoenix default motor rpm is 36000 rpm I think, this is equivalent to around a 3400kv motor on 3s I think. Up the RPM value to reflect your motor kv and adjust the gear ratio to match your main to pinion gear ratio, this should get you the same headspeed as your 250. Since the gov is off you'll need to set appropriate throttle curves to maintain the HS across your pitch range.
Hope this helps, i'm no expert!
Old 11-17-2010, 07:52 AM   #92 (permalink)
yeah that's what I did, I just want to make sure I got it right. thanks jagsta
Old 12-20-2010, 08:04 AM   #93 (permalink)
Here is my 250 variant, it's quite close to real thing in FF/circuits. Hover, I don't think Phoenix is capable of simulating realistic hover when it comes to small helis, they always drift too much and have some sort of "low gravity" lag.
If someone has any tips, let me know (my tx, weather, sim etc. are set up properly)
TDR/VBar
Logo 600SX 12s VBar
MSH MINI PROTOS/CGY750
AcidDrink is offline        Reply With Quote Quick reply to this message
Old 12-23-2010, 02:23 AM   #94 (permalink)
did you set the expo and d/r on your tx or on the software?
Old 12-24-2010, 06:10 AM   #95 (permalink)
15% expo on tx only.
TDR/VBar
Logo 600SX 12s VBar
Old 01-25-2011, 11:11 AM   #96 (permalink)
Originally Posted by Finskeeper View Post
Just received my Phoenix Sim yesterday (3 days direct from the UK!!!) and started playing with the default mSR model. For those that are interested, the flight characteristics are pretty far off. Three hours later and a bit of tinkering, Iíve got the simulated mSR back in the ballpark of my real flyer.
For those that are interested, hereís what I changed in the Model Edit variables:
Front Cyclic Response = .005
Lateral Cyclic Response = .005
Control Expo = (all 0, controlled on my DX6i)
Cyclic Tuning = 150%
Tail Power Tuning = 100%
Knife Edge Tuning = 110%
Hovering Stability = 200%
I think these settings better reflect the built-in auto stabilization.
Variant attached below---
Hi, I copied the attached file in the variants\helicopters folder and changed the extension to pxv. I see the heli on the menu, but Phoenix quits when I select it and hit the 'Finished' button. (Phoenix V3.0p)
Any ideas? Thanks.
https://www.helifreak.com/attachment...5&d=1267297507
Jazzjohn is offline        Reply With Quote Quick reply to this message
Old 02-19-2011, 05:27 AM   #97 (permalink)
V2 of my 250 variant. I must say I am quite happy with it, it's very close to my real 250.
I fly it with 10% aile/elev expo on the radio.
It's for 3.0p
If someone could make a proper 250 sound...
TDR/VBar
Logo 600SX 12s VBar
Old 03-03-2011, 06:42 AM   #98 (permalink)
I've had 8 different kinds of 250s, and they all had a distinct sound. I'm guessing the one who made the 250 sound for the current phoenix was similar to his 250?? I had a 250 with plastic blades, and that one came close to the sound of the 250 model in phoenix. You may need to make a new one with the 205d blades.
Old 03-05-2011, 12:54 AM   #99 (permalink)
I'll get pro mic and good recorder and sample it when it gets warmer. 250 on sim doesn't sound anywhere close to my 250.
TDR/VBar
Logo 600SX 12s VBar
Old 03-09-2011, 10:12 PM   #100 (permalink)
Guys, Anyone have a variant for an Align 450 V2 or Sport. I want to make sure I know what to expect before taking my new bird out...
Any help would be greatly appreciated.
David
djborden is offline        Reply With Quote Quick reply to this message
