Go Back   HeliFreak > R/C Simulators Support > Phoenix Flight Sim
Phoenix Flight Sim Phoenix Flight Sim
Old 11-01-2011, 05:34 PM   #121 (permalink)
I have no .fly in neither of my Phoenix-folders. Wonder what that is?
550E, X3 | BeastX, YGE, DX8
http://dannesholk.se/rc.shtml
Danny_Swe is offline        Reply With Quote Quick reply to this message
Old 12-10-2011, 08:02 PM   #122 (permalink)
Default mCPX variants
My mCPx variants:
BBB -- stock battery, bullet blades
HiPerf -- stock battery, hi-perf blades
BBN -- stock battery, bullet blades with lead weights removed (my fav blades)
BBN_300mAh -- like BBN above but with 300mAh battery
BBN_M5 -- like BBN_300mAh but with M5 (C05m v2) motor 8T, (my current setup)
Tell me what you think!
EDIT: Forgot to mention that these variants assume you calibrate Phoenix to run 100% pitch channel signal and then turn down max pitch travel to whatever you run the real thing. I do it this way because I run the same model memory for Phoenix and the real thing. If you calibrate Phoenix pitch channel to your entire stick travel (like with stock RTF radio DX4e), you'll need to turn down pitch range to +/-10 like in the original.
Old 12-19-2011, 11:52 AM   #123 (permalink)
Originally Posted by andrewv28 View Post
I'm also looking for an easy to fly 450 variant. Any help would be greatly appreciated.
Post #55
Chris20 is offline        Reply With Quote Quick reply to this message
Old 12-28-2011, 05:24 AM   #124 (permalink)
Originally Posted by AcidDrink View Post
Here is my 250 variant, it's quite close to real thing in FF/circuits. Hover, I don't think Phoenix is capable of simulating realistic hover when it comes to small helis, they always drift too much and have some sort of "low gravity" lag.
If someone has any tips, let me know (my tx, weather, sim etc. are set up properly)
Have you tried adjusting rotor stability in the Main Rotor section. If you set it too high the Heli will try to right itself while knife edge. Somewhere around 103.00 seems to be right on most models except the Blade SR. I used about 85 on that one. You have to set it high as you can without it trying to right itself knife edge.
If its fixed don't break it!
Bladecpnitro is online now        Reply With Quote Quick reply to this message
Old 02-18-2012, 07:05 AM   #125 (permalink)
Default CopterX Black Angel
Google translation from french to english.
I am the Black Angel from Protos 500 I scaled. Then I change several settings for that flight as my Black Angel with FBL BeastX. Even if you see the flybar in the parameter is well Flybarless. Too bad we can remove the visual. Then I painted the canopy with the colors of Black Angel.
Help me:
Monetarily to help me a simple little click on the ads to the left of my web page bring me a little money and it costs nothing in you except the click of a few seconds
Thank you!
You can download at:
https://sites.google.com/site/lapage...ome/phoenix-rc
Drop pxv file in: ..\Documents\PhoenixRC\Variants\helicopters\
Drop bmp file in: ..\Documents\PhoenixRC\Schemes\
FredyCP is offline        Reply With Quote Quick reply to this message
Old 02-20-2012, 01:31 PM   #126 (permalink)
700e scaled down and setup to run at 2350 HS to replicate 600 pro.
DaveHolland is offline        Reply With Quote Quick reply to this message
Old 03-12-2012, 03:22 AM   #127 (permalink)
Awesome, Thanks
Logo 400SE - Chase 360
Synergy E7SE - Chronos
JR XG8
Hardsy is offline        Reply With Quote Quick reply to this message
Old 03-22-2012, 09:27 AM   #128 (permalink)
I dont know how to post my varient.
Blade 500x, 450x, 300x, 200srx, MCPX BL, DX7
Courtesy Clerk at Safeway, Lonetree!
Varc is offline        Reply With Quote Quick reply to this message
Old 05-17-2012, 10:45 AM   #129 (permalink)
I posted my Protos 500 FBL variant(I got rid of the drift too) T-Rex 600N 3G and 700N variant
NOTE:None of the models I made fly like the real ones,they are just tweaked to my likings.
-juroxzg3
Align T-Rex 550 DFC SELLING
AccuRC
Spektrum Dx7s
Jurica is offline        Reply With Quote Quick reply to this message
Old 05-27-2012, 03:56 PM   #130 (permalink)
Originally Posted by DoubleCH View Post
My mCPx variants:
I don't understand what your saying to turn down the pitch ? I really want to use your co5 variant but all it does is roll left on me in IU.
LokiNexus is offline        Reply With Quote Quick reply to this message
Old 08-19-2012, 08:13 AM   #131 (permalink)
Question
Seeing quite a few Blade mCPx variants, but sense they tend to be for modified/upgraded mCPX's. Which variant seems closest to the mCPx V2, right out of the box?
Oh, and how should I set up the Dx6i for it? Just use a basic heli setup with no adjustments?
BrettOssman is offline        Reply With Quote Quick reply to this message
Old 09-07-2012, 03:32 PM   #132 (permalink)
Anyone feel like trying my variants of the R22 and Cierva and tell me how they fly
(the R22 should be good for 3D, just a little bouncy chassi, the Cierva just a little more power)
Old 11-20-2012, 03:34 PM   #133 (permalink)
Default Green Goblin Scheme
Heres a Green/yellow Goblin scheme I created. Hope you like it. Put in your Documents/Phoenix/Scheme folder
SAB GOBLIN 700, MKS HV Servos all round, Vbar Silverline Pro, Quantum 500KV "Goblin Edition" motor, Kontronik Kosmik 160HV, Giant Power Lipos.
discoferret is offline        Reply With Quote Quick reply to this message
Old 11-20-2012, 04:34 PM   #134 (permalink)
maybe im colour blind, but isnt your goblin scheme yellow.
neverland is offline        Reply With Quote Quick reply to this message
Old 11-20-2012, 05:00 PM   #135 (permalink)
I made a green and a red scheme if anyone wants them... The red one is probably a bit dark but I'll I'll have another go at it tomorrow.
http://www.busaboost.com/pictures/SAB_Goblin(green).bmp
http://www.busaboost.com/pictures/SAB_Goblin(red).bmp
GSXR is offline        Reply With Quote Quick reply to this message
Old 11-21-2012, 01:19 AM   #136 (permalink)
Sorry it's the green/yellow version.
Sent from my Galaxy S2
Old 11-21-2012, 04:08 AM   #137 (permalink)
Default Angry Bird Canopy
.bmp file here.... http://www.busaboost.com/pictures/SAB_Goblin(angry).bmp
Old 01-07-2013, 07:29 PM   #138 (permalink)
Originally Posted by Socal500 View Post
For those flying the 500 on Phoenix, in case you have not noticed, and I dont see how you couldn't, the left drift effect is way overboard. See image below of angle held for steady hover. The red is the 500. Thats more like hovering it a 10 mph wind from the right. Anyway below the image is a link to a variant I did, which to me is more lifelike. I also added some vortex lift loss effect so the heli actually drops after settling. This one autos more like mine as well.
http://www.socalsurfs.com/trex500/trex500_socal500.fly
Hi socal I can't find link for 500 variant
lastofthefew is offline        Reply With Quote Quick reply to this message
Old 01-26-2014, 04:46 PM   #139 (permalink)
how do these schemes get loaded into the sim?
Atom500(FBL)., Gaui x4II (FBL) ;Trex450 sport (FBL). All with Ikon fbl gyro. AMA#1019423.
Tony .
tony521 is offline        Reply With Quote Quick reply to this message
Old 02-07-2014, 04:39 AM   #140 (permalink)
Made this one in Photoshop today….
Name:	phoenixRC 2014-02-07 11-27-20-64.jpg
Gerard
GerardHCH is offline        Reply With Quote Quick reply to this message
