Go Back   HeliFreak > R/C Simulators Support > Other R/C Flight Simulators
Other R/C Flight Simulators Other R/C Flight Simulators
Old 06-10-2013, 08:35 AM   #1 (permalink)
Default Simulator setup
I have seen many questions on how to set up a simulator. Phoenix, RealFlight, Heli-X, ClearView, etc. Each simulator is relatively easy to set up once you understand the basic principles. This is what I will explain. I have also provided details my Heli-X setup with a DX8.
I will try put up more examples in the next few of days (if requested). Possible examples can be Phoenix, ClearView and/or FMS (may also look at neXt).
The Basics:
How a simulator works.
A simulator takes control inputs and manipulates a model on a screen based on those inputs. This much is not hard to understand. The part that confuses people is how does the computer determine what to do with the model based on the control inputs.
Each simulator has a 3D virtual landscape to fly the model in (usually labelled as an airport). Quite often this environment is a photo box (a 360 degree photo that you can look around in). The other environments are full 3D environments. You can only move the pilot in a full 3D environment. In a photo box environment, you can only change the direction you are looking, not the pilot. This is why FPV simulation can only work in a full 3D environment.
Now that we have a virtual flying environment, we need to put things in it, ground, water, trees, buildings, etc.. Each object (including ground) is represented as an object in the environment. Each object must have location and size (and optionally graphics, yes some items may be invisible since the graphic may be part of the photo box). Once an object is defined, a virtual heli can collide with it. Some of these objects are native to the field (like ground and trees), others can be defined separately and used in multiple environments (such as boxes or flags).
Now we have an environment, we need a heli to fly in it. The model must have a shape and a graphic. This way you can see it, control it and collide it with things. Each model will also have a number of flight parameters (usually quite a lot). This enables the simulator to emulate the movement of the heli. Every simulator I have tried enables a user to modify how a heli behaves. Getting a model to behave right is a combination of two things. The first is the accuracy of the model parameters in relation to the simulators physics engine. The second is the physics engine itself.
If the physics engine is good, we can make a heli perform in the sim like real life. If the physics engine is bad, regardless of how we tune the heli parameters, there will be things that do not line up to real life flying. For example, if your simulator under-values heli mass, then it will need reduced thrust to keep it in the air (slower rotor speed, shorter configured blades, etc). We may be able the tune the flight so it works right, but auto-rotations will be too easy and the heli will feel more "floaty". This is why we evaluate the simulator physics.
Physics:
Modelling the physics of a helicopter is very complex. As well as stationary lift and transitional lift, there is ground effect, autorotative states, blade stall, anti-torque compensation and other artefacts to emulate. Good simulators emulate all listed above and more. The more they emulate, the close to reality the simulator feels.
Can you learn to fly on a sim with poor physics? Yes. The basic principals of flying work on even the poorest of sims (like FMS).
Can you hone and tune your flying on a sim with poor physics? Not really. As some aspects will seem far easier than others, and fine tuning responses in a "partially correct" environment.
RealFlight 6.5 and Heli-X both emulate effects such as tumbling in a blade stop autorotation and tail instability when main rotor speed is too slow. The German creators of Heil-X have developed a video series demonstrating an number of helicopter physics principals. If looking for realistic physics, as of June 2013, RealFlight 6.5 is generally recommended. I personally also recommend Heli-X in this area as well.
Controller:
Ideally your controller should be as close to the transmitter you use to fly your helicopter as possible. You can learn the basic reactions with something as simple as and xbox controller, but having a real feeling transmitter is more helpful.
There are two main options for a controller, dedicated 2 stick device (with optional buttons) like RealFlight, or table to link to trainer port on actual transmitter. In either case the input control device must be calibrated so the simulator knows the hich and low values of each input channel.
A dedicated two stick device relies on the simulator to emulate the transmitter programming. Settings such as DR&expo, pitch curve, throttle curve, gyro gain (and others like flight mode and throttle hold) need to configured. These configurations will be done in the simulator. Flight modes may be per helicopter, or overall for the simulator, or a mixture of both.
Using the trainer port on a transmitter, only the resultant output of the channels is sent to the simulator (not the actual switch and button actions). This is important to realise. When you click TH on your TX, the output settings on the throttle channel drop (usually to 0, but whatever you programmed them to). The gyro switch should operate the gyro channel, etc. Correct programming of your transmitter is crucial for calibration to the computer. You may then have to re-calibrate for correct operation. More on that soon.
Controller selection:
If your simulator does not come with a purpose built cable (like Phoenix), or a purpose built transmitter replacement (like RealFlight), you will need a pseudo transmitter (controller) or a way to connect your transmitter to the computer.
I started off with a USB pseudo 4ch transmitter which was for FMS. It was mode 1, but I converted it to mode 2 when I switched to learning mode 2. If you are just starting and selecting a mode, I highly recommend mode 2. For more information see "Transmitter mode" section of "From tail-in to all 8s and funnels in 6 months" - https://www.helifreak.com/showthread...70#post5003370.
if connecting your transmitter to the computer, find a trainer to USB method. Some sites suggest you can use PPJoy or TXPPM. In short do not waste time on these for helicopter simulation. These rely on sampling the PPM audio signal from a trainer port and converting it into a joystick interface signal. I have had little success with these since the PPM signal is very fast (50ms packets with signal bursts 1ms - 2ms long) and it takes computing time to convert the audio signal into the joystick signal which is already being used for the computationally intense simulators and display.
For a list of transmitter to USB or pseudo transmitters, I usually direct people to the Heli-X support site (http://www.heli-x.net/support_e.shtml), other options can be researched by the reader.
Controller Calibration:
As mentioned, calibration is required for control devices. The computer represents and input from an analog device (such as a stick as a digital number. These numbers range from 0 to 2147483648 (2^31) (sometimes even greater if unsigned or 64 bit). The low point of a stick is almost never 0. The high point on a stick in almost never maximum. Consequently the simulator must determine what the low and high points are. The middle is always determined to be the middle of high and the low points. This is why calibration asks you to move the sticks around and centre the sticks. By measuring the endpoints and the centre, the input ranges can be stored by the simulator.
For a dedicated two stick controller device, this calibration process is easy, the input is always linear. With a transmitter this is trickier.
If using a transmitter and feeding from the trainer port, you will need to set the model for calibration to as basic as possible. Easiest way to accomplish this is to create a new heli model in your transmitter. Call this model simcal (short for simulator calibration). Ensure the throttle and pitch curves are both linear (0,25,50,75,100) in normal mode, the gyro switch goes from -100 in low rate to +100 in high rate, and any other switches that control other channels use the linear full range. Use this model for calibration (and simming if using the sim to control the parameters instead of the transmitter programs).
Once you have your transmitter ready, calibrate your sim and save the calibration settings.
After calibration:
If using a dedicated two stick device, or using your transmitter as a dedicated two stick device, you will need to tell the simulator how to emulate your transmitter programming settings.
If you use your programmable transmitter as a 5 or more channel input device, you will need to set up a sim model with the settings you want AND tell the simulator NOT to emulate these settings as if you had a linear controller.
Whichever method you choose, the normal and idle up settings need to be created. Any change to DR, expo and/or travel adjust needs to be made. Gyro settings will also need to be created.
Heli selection:
Temptation is to use the heli you are flying (if that model is available in your sim). If you are flying a heli bigger than a 450 size heli, this is fine. If you are flying a heli 450 size or smaller, go for a 600 or 700 size heli.
If you intend to fly flybarless, choose a large flybarless heli. If you intend to fly flybared, choose a large flybared heli
The reason for sticking with larger helis is twofold. Firstly, the emulation of the physics of small helis is usually so far out that you spend more time training reflexes than flying control (all emulations I have flown of a 130, fly almost nothing like my real 130). Secondly, small helis become hard to see on a sim very fast.
Once you have selected a heli, you may need to adjust it's properties to resemble how yours performs. Adjust roll rate, tail rate, governor speeds, tail sensitivity, mass, blade length, blade chord, air resistance and other parameters. If you do not know how to adjust these parameters, or the effects they will have on the model, just fly the large heli on it's default settings.
Summary:
  • Understand how a sim works.
  • Calibrate your controller.
  • Setup your controller and heli parameters.
  • By preference use appropriate bigger helis.
Example setup 1:
This is taken from my actual setup.
Assumptions:
  • DX8
  • USB interface
  • Heli-X
DX8 model "SimCal" (used for calibration)
  • Type: Heli
  • Swash Type: 1 Servo Normal
  • Switch Select: Gov/Aux2 - Knob/Aux3 - All other Inh
  • Flight Mode: F Mode - Hold: Hold
  • Servo Setup (all): No sub trim, No travel adjust, Speed normal, Normal (not reversed)
  • DR & Expo (all): DR 100 / Expo 0
  • Throttle Cut: Inh
  • Throttle Curve: (N 0,25,50,75,100 - 1 100,100,100,100,100 - 2 100,100,100,100,100 - H 0,0,0,0,0)
  • Pitch Curve (all - N,1,2,H): 0,25,50,75,100
  • Gyro: Ch/Gear - Sw/Gyro - (0,-100.0 / 1,0.0 / 2,100.0)
  • Governor: Inh
  • Tail Curve (all - N,1,2,H): 0,0,0,0,0
  • Mix (no changed settings)
  • Timer: 5:00 min - Count down - Trainer
DX8 model "Sim"
  • Type: Heli
  • DR & Expo (all): DR 100 / Expo 20 (my preference)
  • Throttle Cut: Inh
  • Governor: Inh
  • Mix:
    • Mix1 - Aux2>Thr -30,-50,0 (1 only)
    • Mix2 - Aux2>Thr -10,-20,0 (2 only)
(This setting means for Idle up 2, Aux2 switches throttle from 90,100,80 and Idle up 1, Aux2 switches throttle from 70,100,50. This means I can have flat 100,90,80,70 and 50 throttle curves).
(Heli-X does not use gyro, otherwise would change gyro setting to better reflect throttle speed).
After starting Heli-X in the Controller configuration:
  • Check use 5 channels
  • Check ignore thrust / pitch curves
  • Check ignore dual rate / expo settings
  • Collective pitch is stick S_5_y
  • Cyclic roll is stick S_0_x (inverted)
  • Cyclic nick is stick S_1_y
  • Rudder is stick S_4_rz
  • Engine Speed is stick S_3_slider
In Buttons setting:
  • Trigger (invert) is set to Idle Up 1 (Gyro switch 0 or 1)
  • Top is set to Idle Up 2 (Aux 3)
In Keyboard settings:
  • Toggle Pause Resume is set to SPACE
  • Instant Zoom In is set to F11
  • Instant Zoom Out is set to F12
I edited the files/controller/<controller-name>.xml to match up the ServoPlus, ServoMinus and Offset for all the calibrated channels (for fine tuning).
I edited the start position of the Airport Dietersdorf to -8.2,5,-2.6 (from -5,5,0). This places the heli on the dot in the middle of the road for launch. This was done through the edit button in the Airport Selection menu (edit the selection, press return, then press save button, close edit window, select another airport, then go back to airport selection and select the one you edited). You may want to move the heli launch position further away again so you are not standing inside the hover training circles (-8.2,5,-7.6).
I use mainly the Logo 600. In the Flight Mode configuration, I have the gyro gain set to 95.0/65.0 for Idle up 1 and 2 and 75.0/45.0 for Autorotation. Because I use "5 channel" mode, the DR, expo, throttle and pitch settings are taken from the TX, not the Flight Mode configuration.
If I was not using "5 channel" mode, I would have to emulate the DR, expo, throttle and pitch settings in the Flight Mode configuration for Idle Up 1, 2 and Autorotation. I would also have to set keys for Idle Up 1, Idle Up 2 and Autorotation (usually 1, 2 and A).
Do you want more example setups?
References:
Heli-X support site - http://www.heli-x.net/support_e.shtml
Old 06-24-2013, 06:10 PM   #2 (permalink)
Phoenix please!!
I've just started reading your threads....i'm new...own Phoenix 4, a DX7s, have a real-life mcpx bl for IRL flying, and am building a FBL Logo 500. Because I'm new to tx setup, sim setup, etc, I haven't fully wrapped my head around yet the exact setting for my tx and sim for optimal practice...so any tx-specific or sim-specific posts would be much appreciated!...thanks in advance!!
John
Blade Mcpx BL
[stock]; Logo 500 3D...build in process [Scorpion HK4020-1100KV motor 15T pinion mod 0.7 JR DS8717 cyclic servos [x3] JR DS8900G tail servo Kontronik Jive 100+LV ESC RotorTech 550mm blades Spartan ds760 gyro]
insurroundsound is offline        Reply With Quote Quick reply to this message
Old 06-24-2013, 08:09 PM   #3 (permalink)
Default setups
How about just posting some setups for the dx7s we can import and use. I need mcpx bl, and blade sr. I can't make one that lets me fly upside down for nothing.
kecked is offline        Reply With Quote Quick reply to this message
Old 06-24-2013, 09:42 PM   #4 (permalink)
Originally Posted by insurroundsound View Post
Phoenix please!!
First response since I posted this 2 weeks ago.
Unfortunately you will have to wait for the weekend for me to do the Phoenix setup (as I am away from home right now).
Unfortunately, I don't have a DX7s (or easy access to one). The setup should be similar to a DX8 though.
To make a Blade SR fly inverted, you need mCX blades (lower ones that spin CCW). The SR will then ONLY fly inverted (inverted hand launch required).
Best way to learn inverted is on the sim (zero crash cost, unlimited battery). Don't try to cheat the process of learning inverted (it will catch you out). Do you want to fly or just show off to your friends?
Old 06-25-2013, 06:57 AM   #5 (permalink)
Default flying
I want to learn to fly well. I don't know how to setup my radio so that it will allow any ship to fly upside down. I can't seem to make it work. I tried the mxcp and the align birds but can't setup the radio. I can't seem to get negative pitch.
I was thinking you set the throttle essentially full on and then have the pitch curve change from 0-100 in some way to get from negative pitch to positive pitch with 50 being 0 pitch but that doesn't work either. What is the trick to make it work. IE what basic physics am I missing in the theory?
Old 06-25-2013, 03:25 PM   #6 (permalink)
Does your transmitter represent pitch values from 0 to 100 or -100 to 100. If -100 to 100, then the pitch curve of 0,25,50,75,100 becomes -100,-50,0,50,100. For the DX series of TX's, it's represented as 0 to 100 (0,25,50,75,100).
I will use DX (0 - 100) curves from here on.
In real life.
  1. You need to use idle up (cannot hold invert on normal mode)
  2. 0 pitch should be at centre stick (when you bind, in throttle hold, with pitch curve 0,25,50,75,100, when you put the throttle stick to middle and fold the blade back so both are parallel, the tips should be level).
On the sim (when using Phoenix), you want to re-calibrate. Set up the SimCal model in your TX (All throttle and pitch curves are 0,25,50,75,100). Calibrate in normal mode. Then load your regular TX model (or sim model) and fly the sim in idle up mode.
Idle up throttle curve must be all high (80,80,80,80,80) or (100,100,100,100,100). Some use a V curve (100,90,80,90,100), but I tend to stick to flat.
The basic theory is that the collective pitch allows both positive and negative pitch on the main and tail rotor blades. You can see this on a real model RC heli, but this blade pitch is not visually represented on a simulator. It is represented in the way a model behaves though.
Hope this helps.
Old 06-25-2013, 07:06 PM   #7 (permalink)
Default sim
Almost there. Is F mode 1 idle up and f mode 0 normal?
Old 06-26-2013, 11:14 AM   #8 (permalink)
Yes, those terms are different words for the same thing....
On different transmitters you will see different terminology, but the meaning is the same.
"Normal Mode" is the same as "Flight Mode 0" which is typically set up such that the Throttle Stick in full down position (pulled towards you) is zero throttle, in other words, the motor is shut off (or just idling for nitros or gas). Also the blade pitch at Throttle Stick full down is typically near zero degrees pitch (flat) at this point (sometimes folks will have just a little bit of negative pitch set up).
"Idle Up" also known as "Flight Mode 1" or "Stunt Mode" (or Stunt 1) is typically set up such that full down Throttle Stick is 100% throttle (or near 100%) and blade pitch is full negative pitch, like -8 or -10 or -12 degrees for example. This allows for flying inverted and various advanced maneuvers.
Additionally, some transmitters provide a third flight mode, such as Flight Mode 2, or Stunt 2, which can have an additional customized throttle and blade pitch curve.
So in summary:
- Normal Mode = Flight Mode 0
- Idle Up = Flight Mode 1 = Stunt Mode (or Stunt Mode 1)
...and if transmitter supports it:
- Idle Up 2 = Flight Mode 2 = Stunt Mode 2
Normal Mode will not allow you to fly inverted, but you will be able to shut the motor off.
Stunt / Idle Up / Flight Mode 1 or higher will allow you to fly inverted (skids up, rotor under the heli) and the motor will always be running fast enough to fly the heli in this mode.
rojack is offline        Reply With Quote Quick reply to this message
Old 06-26-2013, 02:39 PM   #9 (permalink)
Yes.
rojack correctly expanded.
Old 06-27-2013, 01:26 AM   #10 (permalink)
I'm a little confused about the gyro settings you posted. And how they apply to the dx7s. (Maybe someone with that tx could chime in). And out of those three settings, which one do I run on the sim? Any danger with just leaving the gyro settings inhibited?
John
Blade Mcpx BL
Old 06-27-2013, 02:34 AM   #11 (permalink)
The gyro settings for the DX8 are to ensure the gyro switch will output a value on the gyro channel.
For Phoenix, it can read the gyro channel and use real values (so use values you would normally - negative for rate mode, positive for heading hold). For Heli-X, it currently can only use the channel as a switch, so the settings ensure the toggle button in the Buttons screen.
In Heli-X, the gyro settings is in the model and have a different rate for Idle-Up 1 and Idle-Up 2. You set the values there.
No danger leaving gyro settings inhibited. Sim will just take the programmed model preferences.
Feel free to explore, and ask more questions or clarifications.
Old 06-28-2013, 12:48 AM   #12 (permalink)
I just realized Heli-X has a "Use 5 channels" option on the controller menu now!!!!
Must have been a 4.2 update? Anyway, after some fiddling I've got my SIM model as "HELI" now on my DX6i, and it uses my throttle curves and throttle hold switch. I'd been practicing my autos with the Flight Mode switch (since before it was either that or gear) mapped to "Autorotation" on the Buttons menu. I will admit I'd hit the wrong button once try to auto my 500 IRL...
Now I'm simmin' like a PRO!
Russell Harding is offline        Reply With Quote Quick reply to this message
Old 08-30-2013, 09:08 PM   #13 (permalink)
Hey guys,
I have things pretty well set up, using the Adv mode settings on my transmitter from Phoenix.
Things work great, but when I switch to idle up mode in both Heli-X and neXt the heli just shoots straight up. Any ideas as to why? I tried all the obvious stuff but its driving me crazy.
Thanks!
Copter X 450 SE V2 DFC (in progress), 130x
LaTraxx Alias, Hubson x4 104L, F450 quad for FPV and AP, Custon 120mm Brushed FPV quad.
Heli-X Sim, Devo 10 (Deviation TX), Spectrum DX6i.
Turnigy Power Systems.
jk6stringer is offline        Reply With Quote Quick reply to this message
Old 08-31-2013, 01:37 AM   #14 (permalink)
Sounds like the sims are calibrated to use your Tx's throttle channel for pitch. Normal mode is 'normal', but in IU, you have 100% constant pitch.
Oxy 3 - MSH Mini Protos - MSH Protos Max 700 - Taranis
Thanks to Oxy Heli and MSH-Direct.com
Former Username: Code3Medic
Old 08-31-2013, 11:26 AM   #15 (permalink)
I do have the transmitter in acro mode. Is it just just not possible to use my transmitters flight mode with these sims? If I leave it it normal flight mode and use the sims idle switches its fine, and I can map those to my gyro switch to.
I was hoping to use my flight mode switch like I ca do in Phoenix.
I have tried the 5 channel settings. I think the issue is that in 5 ch mode it links throttle with collective so when the flight mode is switched the collective goes up to 100% along with the throttle. The actual transmitters curve is not like that, but I have tried both options for ignore throttle and picch curves...
Old 08-31-2013, 01:31 PM   #16 (permalink)
I have DX6i, and heli-x and IU and TH work with the proper switches.
Old 08-31-2013, 02:14 PM   #17 (permalink)
I have the DX6i as well, would you mind posting your settings?
Thanks!
Old 08-31-2013, 10:57 PM   #18 (permalink)
Ok, so I just realized that my USB dongle does see the switched on my transmitter in Mac or windows. My 12 in 1 USB sees them in windows but doesn't work at all in Mac, which is why I got a new FMS USB.
When I load joystick tester it shows 3 buttons, so it looks like they are being seen but there values don't change... Any thoughts?
Old 09-22-2013, 12:57 AM   #19 (permalink)
I am trying to setup DX8 to work with Heli-x. I have problem getting the flight mode switch (normal, idle 1 & idle 2) and throttle hold switch work. The setup seems to be a bit different from the guide originally written.
From the Heli-x scrips run, I believe allt he buttons of DX8 are recognised.
For the stick and button setup, they are like this
Did I miss out anything?
Oxy 3 with Spirit
Blade 130X
Blade nano cpx
Logo 500 with Skookum
phwm is offline        Reply With Quote Quick reply to this message
Old 09-22-2013, 04:22 AM   #20 (permalink)
Attachment 452572
Attachment 452573
Normal, idle 1 & idle 2 will work to change the throttle and pitch curves in the TX which will affect the operation of "YRotation" (pitch/collective) and "XAxis" (throttle). This is what the check box "Ignore thrust and pitch curves" does (Ignores the In-Heli-X model parameters for throttle and pitch/collective).
What are your pitch and throttle curves in your DX8 for Normal, Idle 1 and Idle 2?
Other switches (like gyro, Aux1 and Aux2) should change color (red/black) in the button screen as switches are moved. To check the DX8 transmissions look at "Monitor" in the "Function List" menu on the DX8 and look how the switches movement change the values being sent by the channels to the sim.
You should have keys set for Idle-2 and autorotation (but never use them).
Hope this helps.
