Old 06-16-2013, 01:00 AM   #1 (permalink)
Question Tail setup? 105mm vbar Protek
Still trying to get this tail figured out
I'm close but still not quite there
I was at
65
65
65
45 collective per comp
10 cyclic
Was ok. but seems like i was still gettin a tail kick. got the precomp up over 50
And knew that was to much. So I took a step back listend to Mr Mel talk about how to setup a tail and he said raise the accelleration and lower the precomp...
I set my aux up to switch threw 3 settings
Now my numbers are
Number 1
75
75
75
15 collective
3 cyclic
Number 2
75
75
75
20 collective
3 cyclic
Number 3
70
75
75
20 collective
3 cyclic
The first one is working the best an
It's holding And it's CLOSE! But there has to be a way to get rid of the kick.
HELP!!!!
):>Team Gaui USA, MKS-Servos USA, Dryfluid, ScorpionPowerSystems, Cyclone Blades"J1S Designs" #Highonhelis
highonhelis is offline        Reply With Quote Quick reply to this message
Old 06-16-2013, 01:02 AM   #2 (permalink)
I've also tried so many up and downs from each setting 5 points at a time... Just over "testing" and i wanna FLY
Thanks guys
Old 06-16-2013, 01:47 AM   #3 (permalink)
What are you using for a gov? This needs to be dialled in before you deal with the tail. It's a long shot but this might be causing the issue.
Logo 700, Logo 600, Protos 380 Evo, Trex 470L, Jeti DS-16, TT Raptor 50 nitro, couple of planks and lots of laughs
Carapau is offline        Reply With Quote Quick reply to this message
Old 06-16-2013, 08:31 AM   #4 (permalink)
this i agree with. also no matter what FBL unit that is dialed in perfect, if you try hard enough you can get the tail to kick. that being said PERFECT i dont think can REALLY be achieved. perfect for YOU can be achieved, but then someone who flies different or harder can make it act up.
the very first this that needs to be tuned in the gov. or turn it off and fly curves till you get the tail figured out. second that needs to be tuned is the overall gain, then precomps, then I & P gains. Mr. Mel, knows his shit when it comes to vbar, but the precomp/accel adjustment is in general and may vary from model to model. you may have to raise both or lower both.
75,75,75, is a general area where most end up. i'm slightly lower, as i told you on the phone. it can be very frustrating to get it right. i got to the point when i almost took the vbar off and put the beastx back on. but i went out with a clear mind and a better understanding of how things work and got it . im going to send you a pm that was sent to me personally. actually its going too be 2 or 3 that was written by someone who i think is a vbar pro. with this info, i was able to understand things better and get it to where i want.
dodgeboy is offline        Reply With Quote Quick reply to this message
Old 06-16-2013, 08:37 AM   #5 (permalink)
also i "think" you tail blade may be on the small size for this model, just my opinion.
Old 06-16-2013, 10:16 AM   #6 (permalink)
+1. Try 115's.
onlyfinehelis.com
mmickels is offline        Reply With Quote Quick reply to this message
Old 06-16-2013, 10:37 AM   #7 (permalink)
+2. 115's/116's on the tail. They will make a world of difference.
Scott
Team Rage-RC USA--Team Pilot
KBDD Team Pilot ):>
Old 06-16-2013, 11:37 AM   #8 (permalink)
I was gonna run 115s but I've head of a hand full or more of people having problem with them..
Thinking about trying 110
Heading to the field to do more testing so I'll see what happend with some different number today.
I need more packs so I have more flight to get this done lol
Old 06-16-2013, 11:47 AM   #9 (permalink)
Default Re: Tail setup? 105mm vbar Protek
115's shine on this bird! For normal putting around 105s are fine, but when you start pushing it, blowouts can follow..
Sent from my XT907 using Tapatalk 2
Kevin Williams
Team OFH
www.onlyfinehelis.com
Cyclone Blades, Scorpion Motors
eagleridge is offline        Reply With Quote Quick reply to this message
Old 06-16-2013, 01:01 PM   #10 (permalink)
yesterday my 115's must of had a weight shift in them or something cause all of a sudden during the flight my canopy started shaking and it was getting drifting issues.
put it on the bench with mains off and spooled it up. you could hear a weird wine noise and feel the boom was not happy at all. took the tail blades off and 0 vibe. putting th radix 110's on till i get some replacements
Old 06-16-2013, 02:29 PM   #11 (permalink)
Were they Edge premium or Edge SE's, Mike? Just wondering because at least one person I know of said the premiums were iffy.
Scott
KBDD Team Pilot ):>
Old 06-16-2013, 02:50 PM   #12 (permalink)
Yes. They were se. Whichh do you use?
Old 06-16-2013, 03:21 PM   #13 (permalink)
I use the SE's, too. It's strange that the blades would go wonky on you. I'd definitely weigh the blades and check their CG's. If there's a problem with them, I'd call RH and let them know.
Tony is the one who noted the problem with the premiums. It may have been an isolated problem, but it's worth noting and taking the steps above for the SE's.
Scott
KBDD Team Pilot ):>
Old 06-16-2013, 05:24 PM   #14 (permalink)
I got them from Cody. I just ordered anoter set. Hopefully these last longer
Old 06-17-2013, 02:40 AM   #15 (permalink)
I got the tail figured out today SUPER locked on now!
Just needed more HS: 2350 its at now!
Today was a good day of flights that were me actually gettin used to the heli
Love it!
Only reason I didnt get 115s is cause Tony told about his problem with them an said to run 105s
I also have a friend here at my local field have the same problem
Old 06-17-2013, 05:05 AM   #16 (permalink)
Tony's problem was with the Premium 115's, not the SE's--just to be clear.
Scott
KBDD Team Pilot ):>
Old 06-17-2013, 01:03 PM   #17 (permalink)
2350 on a 90?! WOW!
Harry
Thunder Tiger Raptor G4 CGY750 | ALEES Rush 700 Spirit FBL | Powered by Futaba 18SZ
PlaneHazza is offline        Reply With Quote Quick reply to this message
Old 06-17-2013, 01:05 PM   #18 (permalink)
I run 2150. Most people are running 2200 or 2250 on the Rush.
Jacob
Rush 700, Synergy N5c tt, MA Fury 55, Trex 450 pro, Blade 130X
jmdanna is offline        Reply With Quote Quick reply to this message
Old 06-17-2013, 01:27 PM   #19 (permalink)
Yeah I was running 2000, but caved in and upped it to 2200 as recommended. I don't need the power but it sounds awesome!
Harry
Old 06-18-2013, 07:38 AM   #20 (permalink)
Originally Posted by PlaneHazza View Post
2350 on a 90?! WOW!
I have seen a Rush turn about 2650 while testing, it was a bit much....
A Main Hobbies/ProTekRC Field Rep
Spartan RC Field Rep
Todd Moriarty is offline        Reply With Quote Quick reply to this message
Tags
105mm, alees, protek, rush, vbar
