Go Back   HeliFreak > Multi Rotor Support > Blade Multirotor Support > nano QX
nano QX Blade nano QX Information and Help
Old 07-17-2015, 05:41 PM   #101 (permalink)
I realize this is old thread, but I haven't been able to find the answer to this question.
TLR - I want to be in HI rate stability and LO rate Agility.
I am not trying to switch from Stability to Agility so much as switch from LO Rate to Hi Rate. Is there a switch with these setting to switch them?
I like to run HI Rate in stability mode and LO Rate in Agility mode while warming up before going HI Rate in Agility mode.
joshtbuff is offline        Reply With Quote Quick reply to this message
Old 07-20-2015, 01:01 PM   #102 (permalink)
One way to switch between LO and HI rates is to use the D/R (dual rate) switch(es), putting the LO rates on one switch setting and HI rates on the other switch setting (web browser searches on "spektrum dx6i dual rate settings" seems to get videos on how to do this).
Another way to switch is to use "IDLE-UP" switch in helicopter mode: have the LO rates in not IDLE-UP and HI rates on IDLE-UP (or vice-versa).
flying-llama is offline        Reply With Quote Quick reply to this message
Old 07-20-2015, 02:44 PM   #103 (permalink)
I got that part figured out nicely. I just now cannot get it into agility mode. I can't get the red light to come on even after flipping the Flap/Gyro switch down and then up again. It just stays blue all the time.
Old 07-21-2015, 02:24 AM   #104 (permalink)
... I just now cannot get it into agility mode. I can't get the red light to come on even after flipping the Flap/Gyro switch down and then up again. It just stays blue all the time.
Depending on how you set the Flap/Gyro switch, you may need to flip it up and then down for the mode to change to agility.
Old 07-21-2015, 06:15 AM   #105 (permalink)
I don't know what I need to set up to make this the case. I followed the steps on page one of this thread, but that switch has no effect on my quad. The light just stays blue all the time.
Old 07-21-2015, 02:54 PM   #106 (permalink)
Post 1 says that with its settings use the F Mode/IU switch to change modes, NOT the Gyro/Flap switch. From Post 1:
"With these settings, toggling the F.Mode / IU switch is what changes between "stability" and "agility" mode, rather than the Gyro/Flap switch per the instructions in the manual. The reason for this is that receiver channel 6 on an airplane is used for Flaps on wings, and on a heli, it's used for Pitch on the main blades.
While flying, the F Mode switch should remain in the "0" position, and flipping to "1" and back to "0" will perform the mode change."
Old 07-21-2015, 05:46 PM   #107 (permalink)
FIipping the F mode switch also doesn't change to agility mode. None of the switches when flipped from 0 to 1 changes it to agility.
Old 07-21-2015, 11:03 PM   #108 (permalink)
Did you switch it from 0 to 1 and then back to 0 again?
The nano QX is weird in that way: changing modes involves flipping some channel from off to on and then back to off again (or vice-versa, I forget which): just switching from off to on (or vice-versa) by itself will not switch modes (and from what I have read, will also sometimes even cause a loss of aileron and elevator control).
I believe that this weirdness stems from that little RTF Tx that a nano Qx can come with: on that Tx, channel 6 is controlled by a spring loaded momentary contact switch.
Old 07-22-2015, 06:52 AM   #109 (permalink)
I did flip it on the off again. I flipped every switch on then off again. Somehow it's not a switch when I'm in this helicopter mode. It's slightly frustrating. I guess I'll go back to acro (plane) mode
Old 07-22-2015, 08:43 AM   #110 (permalink)
Did you go into the REVERSE menu and set pitch or R?
Syma S107-Syma S109-Syma X8C-Syma X8G-Syma X5HC-Syma X5HW-Mini Orion-ProtoX-Syma X5C-1
USAF RETIRED 1968-1988 Vietnam Veteran
Pfloyd is offline        Reply With Quote Quick reply to this message
Old 07-29-2015, 08:07 PM   #111 (permalink)
Yes it is set to R. If I flip the TH hold switch it kills the throttle. That may be the case for everyone, but didn't know if it would help somehow.
Old 07-29-2015, 08:39 PM   #112 (permalink)
Don't use the TH switch. Use the flap/gyro switch.
Old 08-17-2015, 11:39 PM   #113 (permalink)
In the pitch curve menu set the STUNT pitch to 90% across all throttle ranges. When mine was at 80% I was unable to get it into agility mode. Just had to boost the AUX signal a bit.
Stranger25 is offline        Reply With Quote Quick reply to this message
Old 09-10-2015, 01:29 AM   #114 (permalink)
Just set up my Nano using the setting in the first post but could not get the F Mode switch working to change between stability and normal modes.
Changed the Pitch channel back to N and it's all working great now.
Mine is a stock Nano QX (not the FPV version).
Thanks for posting the settings.
mattltm is offline        Reply With Quote Quick reply to this message
Old 10-22-2015, 08:27 PM   #115 (permalink)
Default Agility mode setup on jr 9303
How do I setup Agiliry mode on my jr 9303 for my Nano QX FPV. The manual says to use aux1 but I can't find aux 1 on any menus in the JR 9303.
Anyone??
johnnyo7 is offline        Reply With Quote Quick reply to this message
Old 10-23-2015, 01:42 PM   #116 (permalink)
My memory is that the Nano QX uses channel 6 to switch modes.
And you need to toggle that channel (off-on-off or on-off-on, I forget which) to change modes.
Also, if you toggle the wrong way, you can lock out cyclic control, so be careful when trying things.
Old 01-21-2016, 11:15 PM   #117 (permalink)
I had the same issue with a Jan. 2016 Nano QX. After trying the settings here and several others shown on the web, I went back to Acro mode and watched what Chan. 6 does in the TX 'monitor' mode. On my DX6i in Acro mode, where the gyro switch successfully switches stability/agility, the Chan. 6 slider moves from 60% to 50% when switching to on. I then set up a heli profile as shown in this thread (switching to agility doesn't work as shown), then set the pitch curve to be constant at 60% at F0 and to be constant at 50% at F1. I then found that setting the TH pitch curve to be constant at 60% makes TH not affect stability/agility, and the Flight Mode switch switches between stability/agility as described here.
I also noticed that if I set the F0 pitch to be 65% instead of 60%, switching between stability/agility doesn't work. This seems much more sensitive than using 0% and 80% for pitch settings as shown here. For some reason my setup is different than others. In any case, the solution was to watch what happens on Ch. 6 in Acro mode, then make the same thing happen on Ch. 6 in Heli mode.
helifixing is offline        Reply With Quote Quick reply to this message
Old 01-06-2017, 05:22 AM   #118 (permalink)
Why would you want to use toggling the f-mode over using the push button to switch from stability to agility mode?
Richiejm3 is offline        Reply With Quote Quick reply to this message
Old 01-09-2017, 02:35 PM   #119 (permalink)
For those flying multiple models, using F MODE on a DX6i is the typical way to select between an easy mode and an aggressive mode.
If by "push button" you are referring to the spring loaded momentary switch that flying_lama mentioned in his 2015 post, note that he's referring to the low-end TX that comes with the RTF version of the nano TX. The only push button switch on a DX6i is Throttle Cut, and I doubt using it is an option. So, on the DX6i some toggle switch has to be made to look like a momentary switch by changing its position and then flipping it back.
My NanoQX hasn't arrived yet, but if it works I'd far prefer using FMODE over Blade's suggestion of the FLAP/GYRO toggle switch.
Kevin B.
"Fun, Learning, Friendship and Mutual Respect" - good words to live by
RC: 300x, 130x, DX6i, iCharger 106b+, Phoenix Sim
Other: Atmel AVR microcontrollers, electronics, 3D printing
helibus is offline        Reply With Quote Quick reply to this message
Old 01-09-2017, 02:48 PM   #120 (permalink)
Exactly helibus. I had not flown mine since 2015. I had previously used the small low end to that I got with one of my mcpx's. I switched over to a dx6i I had around over the holidays to fly it again. The setup in the sticky works great and f-mode does control the stability/agility functions. The things are a blast inside in the winter.
stablehover is offline        Reply With Quote Quick reply to this message
Human Verification
