Go Back   HeliFreak > R/C Helicopter Support > Other Makes and Models Helicopters
Other Makes and Models Helicopters Other makes and model Helicopters
Old 07-11-2013, 07:39 AM   #21 (permalink)
Next up....swash plate links........The voodoo's plastic links have flat top which makes measuring the length quite easy. 94mm from flat top to flat top.
Minicopter Diabolo-14s-Pyro 800-Kosmik-Vbar
Voodoo 400 SK540
ChadL is offline        Reply With Quote Quick reply to this message
Old 07-11-2013, 07:40 AM   #22 (permalink)
Pitch arms....same links as the swashplate links. 54mm long.
Voodoo 400 SK540
Old 07-11-2013, 07:41 AM   #23 (permalink)
Will you be running it 4S or 6S, as I see the basic combo is for 4S with the 1400KV motor?
Gaui R5, Henseleit TDR, TDR2, TDF, Banshee
Kontronik, Scorpion ESC, iChargers, VBar, VControl, JR XG11
Old hand at Planks
Vinger is online now        Reply With Quote Quick reply to this message
Old 07-11-2013, 07:43 AM   #24 (permalink)
The swash plate comes with the balls installed. The manual calls for 5w40 oil to be placed on the shaft. I used tri-flow I had on hand. The voodoo comes with a block to ensure square swash while setting up the servos.
Voodoo 400 SK540
Old 07-11-2013, 07:46 AM   #25 (permalink)
Sorry for the crappy pic of the head. Like other critical assemblies, the head comes assembled. You need to secure the pitch control arms to the blade grips.
head installed....note the swash drivers are at 90 degrees. No need to make any adjustments to the head that came assembled.
Also, please note the correct location for the canopy mount. The anti rotation bracket secures into two holes on the frame sides...one of which I originally had the canopy mounts located in.
Voodoo 400 SK540
Old 07-11-2013, 08:02 AM   #26 (permalink)
Nice build so far Chad...
Are all of the pre-assembled bits have thread lock on them... I assume so but wanted to confirm.
Synergy N5c TT | JR Forza 700 | Bell 430 Turbine
rdavis is offline        Reply With Quote Quick reply to this message
Old 07-11-2013, 08:15 AM   #27 (permalink)
Indeed they do...I confirmed on a couple of assemblies.
Chad
Voodoo 400 SK540
Old 07-11-2013, 08:19 AM   #28 (permalink)
Perfect... many thanks.
Old 07-11-2013, 08:20 AM   #29 (permalink)
I decided to go 4s power. The overlying theme of this heli is weight, or lack thereof. I almost went with the Protos motor on 6s power, but opted for the pyro 400-14 on 4s per Stefan's recommendation. Lighter motor and lighter batteries than 6s.
Voodoo 400 SK540
Old 07-27-2013, 04:36 AM   #30 (permalink)
Thanks for the thread Chad.
Very quiet around here - how many are flying this bird in the rest of the world other than Germany?
How do you like the Edge blades on this bird?
Mini Protos, Voodoo 400, Gob 500 stretch x 3, BT650, Thunder T 700, Protos Leggero 700,Diabolo 700
Chris Nifty is offline        Reply With Quote Quick reply to this message
Old 07-30-2013, 09:46 AM   #31 (permalink)
Not too many people outside of Germany....that I'm aware of.
Maiden flight is today, so I don't have any feedback to date regarding the blades. marcosp has a voodoo 400 and flies the Edge 473 main blades. I bought edge blades after speaking with him and hearing his feedback.
Voodoo 400 SK540
Old 07-30-2013, 10:23 AM   #32 (permalink)
Chad, You could try some spin 465's, bet they are super light. SAB makes some 465's too...
Old 07-30-2013, 03:27 PM   #33 (permalink)
Damn you Ray Those spin blades look good
The maiden today was rather boring (which is good). My gov decided not to work. I'm using the gov in the SK540 and it wouldn't work....which is odd as I had it working on the bench. Since the gov wasn't functioning properly I didn't bother making any adjustments to the FBL parameters.......just tootled around the flight line. This heli is whisper quiet.....can't wait to fly again once I get the gov sorted.
Voodoo 400 SK540
Old 07-30-2013, 03:30 PM   #34 (permalink)
Default Re: Acrobat Voodoo 400 build thread
[fly a Voodoo 600. It's great!
-TT E700 V2-vbar-mks950-980-Kosmik 160HV-Pyro 700 rewound by PD / Voodoo 600 -PD-MX700-470kv--BLS255hv-VBAR 5.3+- Gaui X3+Spirit Pro
velocity90 is offline        Reply With Quote Quick reply to this message
Old 07-30-2013, 03:31 PM   #35 (permalink)
The red tips are on top of my list but did not see them in 465's.... Glad the flight went well, other than gov problem. Post some pics of that done bird.
Old 07-30-2013, 03:33 PM   #36 (permalink)
I saw those red tips in 350mm......my stretched mini protos would like those I'm sure.
Voodoo 400 SK540
Old 07-30-2013, 03:37 PM   #37 (permalink)
Are you offering to send me your Voodoo 600 I accept! Seriously though...I would love to fly a Voodoo 600.
Voodoo 400 SK540
Old 07-30-2013, 03:38 PM   #38 (permalink)
Had a set on my Warp before I got rid of it and loved them... Seemed quicker yet more stable than the edge I had on it...
Old 07-31-2013, 01:21 AM   #39 (permalink)
Does the Voodoo 400 kit come with any main blades? Looks like it has some black carbon tails is that right? What length and root thickness are they?
How would a Voodoo 600 be on 6s with 4400 packs?
Old 08-10-2013, 05:26 PM   #40 (permalink)
How is it going ? looking forward to an update on test flying and a report !
I am very interested as one of these will be my next build
laserfish is offline        Reply With Quote Quick reply to this message
Human Verification
