I've found a major online Esky parts distributor! - HeliFreak
Go Back   HeliFreak > R/C Helicopter Support > Antique Out of Production and Vintage Helicopters > E-Sky Helicopters
E-Sky Helicopters E-Sky Line - Help each other out!!
Old 08-16-2013, 01:52 AM   #1 (permalink)
Thumbs up I've found a major online Esky parts distributor!
http://www.rchelicopterbox.com/esky-...are-parts.html
I've already ordered an Esky servo tester from them. My next order will be for a couple of aluminum cases for my Twinstar 3G and D700 3Gs.
They do wholesale too so they have a lot of stock.
TheKingPhisher is offline        Reply With Quote Quick reply to this message
Old 08-18-2013, 05:20 PM   #2 (permalink)
Good findd now maybei can get the twinstar back in the air. They dont have the tx though
TEAM FLYBAR
Dynam Erazor 450 Gaui 200 V2 Blade Nano Cpx
Dx6i
Kevinfly is offline        Reply With Quote Quick reply to this message
Old 08-18-2013, 05:40 PM   #3 (permalink)
Unfortunately they don't seem to carry parts for the new helis. Maybe if you contact them for specific parts they could special order for you? Heliguy.com carries the new transmitter and parts for some of the new helis but I don't think they have parts for the Twinstar.
Old 08-18-2013, 06:22 PM   #4 (permalink)
That stinks. The only place I have found for parts is in Japan and even with the translator its hard to understand the pricing and descriptions. Back to the drawing board
TEAM FLYBAR
Dx6i
Old 08-18-2013, 08:59 PM   #5 (permalink)
Yeah it does suck because I'm not sure how long my Twinstar's belt will last either. I'm only doing scale and sport flying at the moment so I don't have to worry about broken parts from crashes but the belt will eventually wear out.
Old 08-19-2013, 07:21 PM   #6 (permalink)
Yeah same here but when my tx screwed up it went in hard and bent the feathering shaft and main shaft. To bad because I loved flying it and it was a smoking deal.
TEAM FLYBAR
Dx6i
Old 08-19-2013, 09:01 PM   #7 (permalink)
Maybe you could make your own feathering shaft on a lathe?
Old 08-21-2013, 05:40 PM   #8 (permalink)
Dont have a lathe. Im going to bring it with me to HeliDirect and maybe Brian can find something that will work for me.
TEAM FLYBAR
Dx6i
Old 08-24-2013, 07:18 PM   #9 (permalink)
Good news I found a vendor in France that sells parts for the Twinstar..free shipping too...just don't buy up all the supply ok?
http://www.ckado.com/esky-twinstar-t...42_505_en.html
Old 08-25-2013, 05:39 PM   #10 (permalink)
Sweet find. I was gonna send the site I found to Brian at helidirect and see if he could translate and give me prices. I still might since it looked like it had every part. I have to find it again. I will post it up here when I do.
No worries about me buying up all their stock. We can split it 50/50
Quick question about your blade grips. I noticed mine are real wobbly up and down but they dont tighten down anymore. Are yours the same way?
TEAM FLYBAR
Dx6i
Old 08-25-2013, 05:53 PM   #11 (permalink)
The up/down play of the blades are by design since it's a 3 blade "flapping" setup. It's a floating type head common with multi-blade setups. That said..I've noticed that the plastic blades are not very good as they make the rotor head on my heli vibrate a lot. I've switched to Walkera MasterCP blades to experiment and they work a lot better, much less vibration. I plan on trying out the triple blade sets from the Walkera 4F200 since they're wider and closer to the stock width. The MasterCP blades are narrower.
Old 02-15-2014, 06:30 PM   #12 (permalink)
Default Help
Does anyone know where I can get blades, main blade grips, tail blade control arm and, tail blades all in one place lol or new metal components that will fit
noideawhatimdoing is offline        Reply With Quote Quick reply to this message
Old 03-13-2014, 04:15 PM   #13 (permalink)
Not yet. I put mine on hold for now. Im starting to look again though
TEAM FLYBAR
Dx6i
Old 03-14-2014, 03:47 PM   #14 (permalink)
What model helicopter are you referring to?
Old 03-16-2014, 08:00 AM   #15 (permalink)
Has anyone had any luck with finding any parts for the FBL D700? A local flyer helped MW set mine up and he said it looked just like a blade 450 x. Maybe parts are blade parts will fit it
TC_N992V is offline        Reply With Quote Quick reply to this message
Old 03-17-2014, 03:58 PM   #16 (permalink)
That is correct some parts are interchangeable with the 450X. I know for a fact the feathering shafts are interchangeable because I had to replace my bent one and I wanted to find out if the 450X ones fit and it does.
Esky's Zonda Hobby online site has parts...though shipping is very expensive. I tried adding a few parts into my cart and shipping to US is about $50...
http://www.zondahobby.com/product-de...ssid=5&pid=421
Heliguy in the UK and Ckado in FR has some D700 3G parts to.
Old 07-07-2014, 10:59 PM   #17 (permalink)
Seems like http://www.rchelicopterbox.com/
is no longer up and running? Anyone know were to get the main gear and tail drive for Belt CP?
actionscript is offline        Reply With Quote Quick reply to this message
Old 11-21-2014, 08:46 AM   #18 (permalink)
Try Bangood they have some.
Blade 500x, 450x, 300x, 200srx, MCPX BL, DX7
Courtesy Clerk at Safeway, Lonetree!
Varc is offline        Reply With Quote Quick reply to this message
Human Verification
