Go Back   HeliFreak > R/C Electronics Support > MSH Brain FBL Unit
MSH Brain FBL Unit MSH Brain Support Forum
Like Tree2Likes
Old 08-20-2013, 06:36 AM   #1 (permalink)
Default iKON Setup and Tuning Video Series
Hello! Chris Sexton with Team iKON here. I am building a small library of setup and tuning video tutorials for the iKON FBL System. I will be adding more videos as I complete them, if you don't see a video that covers something you have questions about, feel free to PM me with questions or post here on this forum. There are several of us active on the forums as well as the main firmware team checks these forums regularly.
Videos:
Castle ESC Setup for use with iKON Gov
Team iKON - Castle ESC Setup for iKON Gov (17 min 11 sec)
MSH Brain / iKON basic setup
Synergy E6 Build Video - Part 6 - MSH Brain Basic Setup (27 min 46 sec)
MSH Brain / iKON Basic Electric Gov Setup
Synergy E6 Build Video - Part 7 - MSH Brain Gov Programming (10 min 40 sec)
MSH Brain / iKON Nitro Gov Basic Setup
Team iKON - Nitro Gov Basic Setup (26 min 12 sec)
Synergy Factory Specialist / Rail Blades / Team Scorpion
Chris Sexton is offline        Reply With Quote Quick reply to this message
Old 08-20-2013, 11:40 AM   #2 (permalink)
Sticky!!!!!!!!
Screw It, I'm gonna fly.
In search of a 500-600 sized heli.
Preferably rtf with vbar.
povern is offline        Reply With Quote Quick reply to this message
Old 08-20-2013, 11:47 AM   #3 (permalink)
I really think a video is needed that explains how to get gov throttle min set close enough to where a castle esc will arm and gov throttle max close enough where only fine tuning will be needed. Kind of belongs between castle video and gov programming video.
Scenario:
User has plugged esc into the aux port since it said bec on the diagram :-). Gov throttle min and max set to 800 and 2200 respectively.
Probably an an extreme example of ikon setup gone astray, but a real life scenario nonetheless.
Field rep for Discover Card and team Visa.
MSH Brain super fan and crash test dummy.
kthane is offline        Reply With Quote Quick reply to this message
Old 08-20-2013, 12:13 PM   #4 (permalink)
Sorry, I know this is a bit off topic.
I'm just setting up my ikon; can someone tell me what the "sys/IO" port is for?
DWill is offline        Reply With Quote Quick reply to this message
Old 08-20-2013, 12:16 PM   #5 (permalink)
Default Re: iKON Setup and Tuning Video Series
Its where the optional bluetooth module plugs in.
sent from my Verizon Samsung Galaxy Note 2
Old 08-20-2013, 01:07 PM   #6 (permalink)
Ah... thanks...
Now I have to find this optional bluetooth module; being able to set up via bluetooth would make my life much easier and solve my mounting issue easier.
Assuming of course, a: I can set up by bluetooth, and, b: I can access the iKon by bluetooth from either my PC laptop or my iPhone.
Where can one find this bluetooth module?
Then I promise no more derailing this thread...
Old 08-20-2013, 01:11 PM   #7 (permalink)
Ah... thanks...
HeliDirect has the modules
http://www.helidirect.com/crius-mult...on-p-31759.hdx
Unfortunantly there is no iPhone support at this time. But you can access and setup the iKON entirely through bluetooth once you program the bluetooth the first time.
This video might help:
Brain / iKon / TracX Flybarless System - Bluetooth Connection and Android App (7 min 16 sec)
Old 08-20-2013, 01:27 PM   #8 (permalink)
Thanks Chris! Already ordered the BT module now I have to go buy something to run Android until or if there is iOS support.
Old 08-20-2013, 09:30 PM   #9 (permalink)
YES! What a timely thread/sticky!!!
Just finishing up the setup of my Trex 550 with iKon & Talon 90 - never used either before, only YGE & vBars so far. I thought I had the gov & esc setup properly but could not get any response from the motor when I selected "use gov" in the iKon. Thought maybe I mis-wired PS but was getting rpm in the iKon gov window and also in my tm1000 data. So I decided to come look here for some info and found this post. Now, just from watching the first few minutes of this vid I can see I dont have the ESC setup correctly to use external gov! Need to go back to watching but wanted to say YES- THANK YOU FOR POSTING THIS!
Will probably be back soon with a few 'DOH questions' of my own!
trippledigitss is offline        Reply With Quote Quick reply to this message
Old 08-20-2013, 10:18 PM   #10 (permalink)
Well shoot - I reprogrammed my Talon per the video to use multi-rotor, checked my gov settings in the ikon and throttle curve and I thought everything looked good. It spooled up with a smooth slow start (on the bench, pinion loose (mistake)) to the 30% Speed 1 RPM according to the gov info in the iKon but it was really quiet. Then when I brought the stick down ( I have the N curve at 0-30-30-30-30) below 30 the motor got loud like it got alot more power but the RPM was reading correct. Then in Idle 1 & 2 kinda the same thing, it would spool up slow and stay quiet then as I moved the stick or IU switch it would get really loud & fast again.
Long story short, I fiddled with the N curve to 30-30-30-30 and was playing with some other stuff and then all the sudden the motor takes off like a freaking 14s pack was connected to it, pinion catches motor shaft and in turn the main gear and eats out about 10 teeth in two different places and now I need to order parts and fix a heli I havent even flown... Damn good thing I didnt have mains on it.... I wont do that again even if the pinion is loose, its coming off from now on!
A bit more than the DOH questions I was thinking I would need to ask... Dang it, and I still have no idea why the throttle response was all over the place. I am pretty darn sure I have all ESC, iKon, and TX settings correct but apparently I have an issue somewhere....
Old 08-20-2013, 11:33 PM   #11 (permalink)
Futaba radio by chance?
Old 08-20-2013, 11:48 PM   #12 (permalink)
DX8
Man I really screwed myself. The pinion is now stuck on the motor shaft and I think I see two hairline cracks in the pinion too. I heated it up but it wont come off. Just ordered a new pinion and main gear and now I'm about ready to toss this 600mx in the trash and order a new motor too. Really irritated at myself cuz I thought I was so close to getting it in the air and now I have to rebuild the darn thing to get back where I was an hour or two ago before I can even go back to figuring out what the heck happened with my throttle issue. Goshdangitalltoheck
Old 08-21-2013, 12:03 PM   #13 (permalink)
Go with external gov mode on the talon, it won't do the crazy spool up.
Bailout won't work though, just to warn you.
XLPower 520 - Spirit
XK K110 - BLheli
TX: Fr-Sky X9 Lite
P.I.Engineer is offline        Reply With Quote Quick reply to this message
Old 08-21-2013, 06:15 PM   #14 (permalink)
Thanks for the tip. I have it in multi-rotor right now but Chris is going to help me sort thru it.
Old 08-21-2013, 06:24 PM   #15 (permalink)
There where a few things that jumped out at me when we traded pms about his setup. We may very well end up in external gov mode. But for now we are looking at it one piece at a time.
Old 08-25-2013, 07:09 PM   #16 (permalink)
Rock & roll daddy! Thanks to your vids and personalized help I think I got it all figured out now! Thanks again!
Old 08-25-2013, 07:21 PM   #17 (permalink)
Nice! Glad to have been able to help.
Old 08-25-2013, 10:36 PM   #18 (permalink)
Finally! Nitro Gov Basic Setup is processing! should be uploaded by the morning. I will post as soon as I proof the YouTube version.
Up next, Advanced menus !
Old 08-26-2013, 01:18 AM   #19 (permalink)
Chris, thank you for taking the time to do this.
The info that comes with the iKon is pretty sparse to sat the say the least. I just got the electronics on my Trex 450 DFC today and will be setting up my iKon in the next couple days.
Your videos have been and will be a huge help.
Old 08-26-2013, 06:08 AM   #20 (permalink)
Nitro Basic setup posted. Added to first post.
Tags
save
