Go Back   HeliFreak > R/C Helicopter Support > Blade Helicopters (eFlite) > Blade 450X
Blade 450X Blade 450X Helicopters Information and Help
Old 08-28-2013, 02:59 PM   #1 (permalink)
Cool Tail freewheeling mod
Hello Warp
Hello Dominator
let me introduce another freewheeling tail on a 450 (with 350mm blades)
the build was easy and done in about 15 min without extra parts
I will document it soon.
full 2s/3s mcpx , 450x 4s BLHeli, Rex500/550 stretch BLHeli TARANIS
Diablol is offline        Reply With Quote Quick reply to this message
Old 08-28-2013, 09:43 PM   #2 (permalink)
Default Re: Tail freewheeling mod
Ok. Forgive my complete ignorance, but wht would you want a freewheeling tail?
Doesnt this cause control issues during an auto if you tail stops rotating (not that a 450 is very well suited to doing autos)? Or does this help maintain headspeed during an auto due to decreased drivetrain losses?
Again, just trying to understand the benefits of this (but it does look cool)!
Sent from my Galaxy Note 2 - pardon the typos...
MCPX BL, 130X, 450X, Nano QX, ProtoX
Spektrum DX7S
spiff72 is offline        Reply With Quote Quick reply to this message
Old 08-28-2013, 09:59 PM   #3 (permalink)
Are you using a centrifugal force clutch for this? If so, auto's should work as long as the head speed stays up and keeps the clutch engaged, otherwise the tail and main need to be mechanically linked to have tail control in an auto.
TheQuixote is offline        Reply With Quote Quick reply to this message
Old 08-28-2013, 10:05 PM   #4 (permalink)
... or hooked the tail up to the main gear before the one way bearing, the way the tail stops looks like it's attached to a motor.
Old 08-28-2013, 10:46 PM   #5 (permalink)
My ancient nitro Shuttle had a non-driven tail when the engine wasn't running. It sucked. There's a reason they moved away from that design.
Fairbain is offline        Reply With Quote Quick reply to this message
Old 08-28-2013, 11:36 PM   #6 (permalink)
fwiw..
I took the warp off my wish list simply because it does not have a driven tail..450 helis auto fine if set up correctly.....
John.
bmlasater is offline        Reply With Quote Quick reply to this message
Old 08-29-2013, 01:57 AM   #7 (permalink)
The main reason actually was to get better autorotations. I have those very very light warp blades on it and for me I find it not easy to do perfect auto. You can flare nice but you have nearly no time to land save because the energy dissipates fast.
Maybe it ist better with a TT or heavier blades but I wanted to get rid of thoes huge belt losses.
A Warp actually rotates fine...
On the other hand there is actually no reason to drive the tail in an auto with a 450!
You cant use it either. If you have a 600 or 700 you need it if you want to do stunts during autos.
If your tail servo fails you could theoretical land in an auto.
Well I actually tried to build it because I have fun to try things out. Dont say you all need that. I tell that it is possilble..easy.
I am now going out to test some autos
Old 08-30-2013, 07:20 AM   #8 (permalink)
Autorotations Blade 450 X M freewheeling tail (6 min 27 sec)
Old 08-30-2013, 11:22 AM   #9 (permalink)
Well I'll be, would have thought that flaring would cause the tail to kick out more than that.
Learn something new every day I guess.
Old 08-30-2013, 11:42 AM   #10 (permalink)
Why? There's zero torque on the head. The only thing you might see is a little CW rotation in the direction of the head due to the slight drag of the bearings. But, a 450 has absolutely no hang time at the bottom, so you don't see it because there just isn't time for any rotation to build.
Old 08-30-2013, 11:47 AM   #11 (permalink)
Pretty helifreakin' cool if you ask me. I'm really interested how this works mechanically. Looking forward to your documentation.
Gaui X5F 6S (VBar), Lynx 450X-L 6S (Ikon), Lynx 300X-L 4S (Ikon), Blade 180CFX 3S (Ikon)
Lumenier QAV400 4S (Vector), Lumenier QAV250 3S (Naze32/CleanFlight), CYE Stingray 500 4S (TG Multi)
AMA Member, HCAM Member
Nelsonisms is offline        Reply With Quote Quick reply to this message
Old 08-30-2013, 12:33 PM   #12 (permalink)
Awesome work, looking forward to seeing mechanics behind it.
Noticed your coming in pretty hot for your autos. Do you think you've gained much extra flare time?
Trex 700E FBL V1 - Align 700MX 510kV, CC Edge 120 HV, AR7200BX
Trex 550E FBL V2 - Align 600MX 1220kV, CC Edge 100, AR7200BX
Blade 450X - Scorpion 2221-8, Lynx Slant Gear (13T/136T), AR7200BX
Spektrum DX9
hoody_s13 is offline        Reply With Quote Quick reply to this message
Old 08-30-2013, 01:07 PM   #13 (permalink)
thanks guys!
yes I did, thats the reason why I did that mod. Show me such autos with a 450 belt driven
Absolutely right.
If you get a high headspeed and flare a lot with heavy blades and use long hangtimes you get a rotation. Most I got is about a 180 . It depends on how you flare or your auto style.
But mostly then you have no ground speed anymore and it doesnt matter.
Old 08-30-2013, 01:29 PM   #14 (permalink)
Lightbulb How is it done now...
  1. drill at least two fitting holes
  2. cut at this point
  3. those longer screws you will find used in the tail case. If you have none I ll be sure there are alternatives
  4. kind of critical is the distance between the main and tail gears. It depends on where you cut. I wouldnt cut flush again but it should be even. Else you can use 1-3 washers (used from the feathering shaft) to fit it
  5. screw both gears
  6. the glide shim is used as shown
  7. done
Thats the story behind that actually works well.
Standart handworks as grinding etc. should be used according to ones need.
My work isnt perfect at all, but I got no issues till now.
I hope you got the point because that is important
It is easy to do and brings a lot of fun - trust me!!!
ID:	447206   Click image for larger version
ID:	447207   Click image for larger version
ID:	447208   Click image for larger version
ID:	447209   Click image for larger version
Old 10-17-2013, 12:55 AM   #15 (permalink)
Someone (n)ever tried?
Old 10-19-2013, 07:52 PM   #16 (permalink)
Cool mod. Thanks for the info.
What lights do you have on your heli?
Warp 360 - MCPX BL - Skookum 720 - Dx7s
WoodyzArt.com - Custom Painted RC Bodies
Resqnu is offline        Reply With Quote Quick reply to this message
Old 10-19-2013, 08:18 PM   #17 (permalink)
Well done driven tail on a 450 is about as useful as teets on a boar hog
Centurian is offline        Reply With Quote Quick reply to this message
Old 10-21-2013, 08:09 AM   #18 (permalink)
Man that is just GENIOUS!
Very long flare time, awesome!
Micro: XK K110, Mini: Gaui X2 Formula
Medium: 330X 6S, G380
Big: G500, Align 700E
DX8, Phoenix
Old 10-21-2013, 09:23 AM   #19 (permalink)
did you really tried it? If so you are the first
I am pleased
Old 10-21-2013, 02:21 PM   #20 (permalink)
I am pleased
No, just saw the vid - but will try for sure!
DX8, Phoenix
Tags
autorotation, freewheeling tail
