Some Build Tips - Page 3 - HeliFreak
Go Back   HeliFreak > R/C Helicopter Support > Gaui Helicopters > X3
X3 Discussion and support for the Gaui X3
Like Tree3Likes
Old 09-25-2013, 04:32 PM   #41 (permalink)
Default Pinion lenghts
Beware if you change from Gaui pinion to Scorpion.
The Scorpion is like 2mm shorter. I had grinded a little on the main shaft for the lock screw and now it barely locates good axial-wise. Just edge to edge w main gear, would need to move it 1mm but can't because of the grinded slot (if I don't want to grind some more that is )
Well. Just a notice.
Name:	Gaui X3 - Bygge 910 - Pinion Gaui 12T vs Scorp 11T.jpg
550E, X3 | BeastX, YGE, DX8
http://dannesholk.se/rc.shtml
Danny_Swe is offline        Reply With Quote Quick reply to this message
Old 09-28-2013, 06:43 PM   #42 (permalink)
Those pinions are hard to find. I tried finding them and i got one from innovative designs, they were awesome.
But finding one online,,,what a pita. But i asked for it, early adopter syndrome
fusionsx00 is offline        Reply With Quote Quick reply to this message
Old 09-29-2013, 09:21 PM   #43 (permalink)
All of the Align, ALZRC and Tarot slant pinions for the 450, will work.
Gaui X2 FES ZYX, Gaui X3 MB, Gaui X4 II VBar, Gaui X5 FES MB
250 DFC ZYX, 450 DFC Sport MB, ALZRC 450L Pro VBar, Devil 450 FAST VCTRC FBL
500E DFC Pro VBar, 500E SDC ZYX-S
KDS 550 VBar, 550E DHPS VBar, 550E DFC Pro VBar, 700E DFC HV iKon
beenflying is offline        Reply With Quote Quick reply to this message
Old 09-30-2013, 02:21 AM   #44 (permalink)
Are they full length? Also some of the ones i looked at were mod.5
Old 10-18-2013, 12:14 AM   #45 (permalink)
I am using the scorpion 13t no issues.
Also here is a pic of the new TT bearing position, says edit ** 2cm off center , either direction.
Just not centered, and not as the manual says.
Old 10-18-2013, 12:58 AM   #46 (permalink)
Also here is a pic of the new TT bearing position, says 2" off center , either direction.
2cm
Old 10-18-2013, 01:16 AM   #47 (permalink)
Thanks, edited
Old 10-18-2013, 07:56 PM   #48 (permalink)
JC, can you please ask Gaui to ammend their manual, about the TT bearing position. Doing this has made a big difference to my X3. Thanks.
Old 10-18-2013, 08:12 PM   #49 (permalink)
Default Some Build Tips
Where did you place the bearing
Sent from my iPhone using Tapatalk.
Protos 380 NEO x2
Oxy 2
Goblin Fireball
norstaroption is online now        Reply With Quote Quick reply to this message
Old 10-18-2013, 08:17 PM   #50 (permalink)
20mm forward of center.
Old 10-23-2013, 04:09 PM   #51 (permalink)
new manual V1.02 http://www.gaui.com.tw/html/download.asp
TT support bearing 13,9mm as before?
Lynx Oxy Team Pilot
joseca is offline        Reply With Quote Quick reply to this message
Old 10-23-2013, 08:30 PM   #52 (permalink)
Sweet, they are using rev numbers. Makes stuff alot less confusing.
Old 10-23-2013, 11:17 PM   #53 (permalink)
Thanks. So no change about the TT bearing location and when were they going to tell us about this mod. I'm starting to get annoyed now:
Edit: I see now it's only if you are using the collars on the TT.
Name:	Tail washer mod.jpg
Old 10-24-2013, 05:56 PM   #54 (permalink)
GensAce 1200 6S 40C are in stock
Protos 380 NEO x2
Oxy 2
Goblin Fireball
Old 10-29-2013, 06:42 AM   #55 (permalink)
I just found a easy way to change a TT carrier bearing. Just pulled the boom back, used a L wrench and pushed it back out. Then used tweezers to place the new bearing on the guide pin. And pushed the boom back in, it went really easy.
I thought i would have to remove the lower tray, or a side frame. I dont want to pull cutting screws in and out of plastic alot. Well not anymore that i have too.
Old 11-06-2013, 04:06 PM   #56 (permalink)
I roughed the one way assembly up where you glue the two parts together with 120 sandpaper. Do you think that is ok or should I take it apart and rough it up more. Don't want the oneway to fall me. I have enough troubles keeping these things in the air without the heli being the issue.
Bill
airsiler is offline        Reply With Quote Quick reply to this message
Old 11-06-2013, 04:08 PM   #57 (permalink)
I would buy the threaded OWS for piece of mind.
Protos 380 NEO x2
Oxy 2
Goblin Fireball
Old 11-07-2013, 02:06 AM   #58 (permalink)
Gaui are providing the thread one for free. Contact the store you got your kit from.
Old 11-07-2013, 04:23 AM   #59 (permalink)
Finally started on my X3 kit. I am extremely careful but managed to strip the plastic where a M2 bolt is used. The self-tapping screws are more forgiving. So...a simple tip that has been mentioned before is to use caution.
Second thing...I noticed the mainshaft bearing blocks/servo mounts contact the carbon on the lower rear mounting point. Simple matter of trying to fit a square edged part into a radius in the carbon. Hard to explain in words. Easy fix is to chamfer the edge of the bearing block rather than force the fit.
Third thing...something is making my frame slightly unsquare. With bearing blocks alone, it's square but once I attach the battery tray and ESC tray, it's a little tweaked. Yes, I have an OCD problem. I suspect because the screw holes in the frame are very precise, i.e. somewhat snug fit, there's no wiggle room and this torques the frames. Still working on this...
ScotY is offline        Reply With Quote Quick reply to this message
Old 11-20-2013, 08:55 AM   #60 (permalink)
Originally Posted by B.Ewing View Post
The shim above the main gear is definitely a PITA.
I just finished the installation of the main gear assembly (p.10 of the instructions).
The way I handled the installation of the two thin washers was to invert the heli, insert the main shaft so that it barely emerged through the upper bearing. The two washers could then be slid onto the end of the shaft. The gear assembly could then be slid into place without the two washers moving. It was very easy this way.
(As MinskUK and scoio have already mentioned, the screws holding the lower bearing mount
needed to be loose so that the gear assembly could easily slide into place---then tightened afterwards.)
Blade 450X, Witespy Quad, Gaui X3, Gaui X5, Goblin 570, Goblin Black Thunder
lmcwilli is offline        Reply With Quote Quick reply to this message
Insurance
Human Verification
