Go Back   HeliFreak > Multi Rotor Support > NextD - Stingray 500
NextD - Stingray 500 CJY Stingray 500 Quad Discussions
Old 11-25-2013, 02:51 PM   #61 (permalink)
Default Re: Next-D Stingray 500
Originally Posted by Luisito View Post
Any idea why the motor cut off?
Don't know yet. My guess is either LVC set to hard cutoff or brown out. Need to do more test to find out.
Sent from my SGH-M919 using Tapatalk
HD750, TDR II, TDR, Logo 700, Logo 700 XXtreme, Logo 550SX V2, KDE motors on all helis
taoY is offline        Reply With Quote Quick reply to this message
Old 11-26-2013, 02:37 PM   #62 (permalink)
Hi taoY,
do you have a lot of damage after the crash ?
Grtz,
Dirk
The heli virus has infected me and i hope that there is NO CURE !! Compass Support Team
__________________________________________________ _____
Warp 360 / 6HVU / CY Stingray / Invertix 400 / SH Little Spyder
Dflyer is offline        Reply With Quote Quick reply to this message
Old 11-27-2013, 09:23 PM   #63 (permalink)
Originally Posted by Dflyer View Post
Hi taoY,
Grtz,
Dirk
Every crash is different.
I had 5 crashes so far. All of them are on short grass field. Two of the crashes were just pick up, check, and fly - both were not light crashes. So far I went through two shafts and 3 sets of landing skids ( they are brittle in my book). Fitted landing skid from Trex450 (some girding required). It's more durable than the stock one.
Old 11-27-2013, 10:02 PM   #64 (permalink)
I have had 2 crashes so far with mine. The first was hard onto rocks, flat at the bottom of a loop and it bent the main drive shaft, centre boom, rear boom and landing gear was smashed. The main pulley at the back got marked up but survived ok with a little file work.
The second one cause by high vibrations from making my own main shaft as I couldn't find any in stock, it was a roll from 5 meters into a sports field when the TG multi freaked out, so very short grass but hard packed soil, looks like front and back boom, one pitch slider and 2 vertical shafts but I am waiting for parts to be available before I pull it apart. The booms can probably be re-bent and used again as they only need to be straight, not perfectly formed like a tail boom.
The LG is a weak point, they seem to shatter. I used an old trick of boiling the LG in a pot of water for 20 minutes that usually reduces the stress in plastic and lets them flex rather than breaking. It looks like it has worked well so far but I need to get some more hard landings on them to say if it has fixed the problem.
//Dennis.
SOXOS DB7 : SOXOS 600 : SOXOS 550 : SOXOS F3C
Protos 380 : SAB Goblin 700 nightflyer : Jeti DS-16 : Mini Protos FBL Stretch : Logo 600
www.soxosaustralia.com.au & VTX blades
Thunder Fighter is offline        Reply With Quote Quick reply to this message
Old 11-28-2013, 09:08 AM   #65 (permalink)
I find the Stingray is quite easy to repair. I like the simple, self aligning design that makes reassembly very easy.
Sky Dancer is offline        Reply With Quote Quick reply to this message
Old 11-28-2013, 05:02 PM   #66 (permalink)
Yep, the repairs have been quite fast, I managed to find all the parts I needed last night at Esprit and 10% off as a nice gift seeing we don't even have thanksgiving out here.
//Dennis.
Old 11-28-2013, 08:11 PM   #67 (permalink)
Default Sweet flight!!!
If it cant be bought...It can be built!
Wildkat450 is offline        Reply With Quote Quick reply to this message
Old 11-28-2013, 11:30 PM   #68 (permalink)
Cool flight !! Great video.
Synergy 766, E7SE, E5SS, E5S, 516, Protos 770 Evo, V Control, Neo, Tribunus
Freeskiken is online now        Reply With Quote Quick reply to this message
Old 11-29-2013, 08:52 PM   #69 (permalink)
Default Max Battery Size
Can someone please let me know the maximum battery size? I just ordered the combo kit today and would like to get some batteries on order. Searched for about an hour but all I could come up with was capacity but not any dimensions.
MarkAllen is offline        Reply With Quote Quick reply to this message
Old 11-30-2013, 05:22 AM   #70 (permalink)
Hi MarkAllen,
Curtis mentionned in one of his video"s that you can go up to 3600 mah. I'm currently using 4S 2200 and 2800 lipo's. Works great.
Grtz,
Dirk
Old 11-30-2013, 07:34 AM   #71 (permalink)
Hi i have tried 2200, 2700, 3700 and 4000mah 4S
4000mah great for fpv
2700 is a better option to start of with
viper66 is offline        Reply With Quote Quick reply to this message
Old 12-01-2013, 12:31 AM   #72 (permalink)
Thanks for the feedback. I was hoping for dimensions rather than capacity although most manufactures sizes are similar for a given capacity. I have plenty 2650mAH 6 cell batteries and I was wondering if it would be possible to limit the throttle curve to 66% with the stock motor and use them. If the PWM duty cycle is limited to the input value it should work as the average voltage would be the same as 4 cells at 100% duty cycle. The only downsides would be higher power in the BEC if it's linear and switching losses compared to running 100% with 4 cells.
Once again, thanks for the help. I'm looking forward to picking up the kit on Monday. This will be my first quad, watching people fly fixed pitch just didn't do much for me. As soon as I saw the first videos for the Stingray I knew it was just a matter of time and with the sale over the holiday I couldn't resist.
Old 12-01-2013, 08:45 AM   #73 (permalink)
If you want to go 6 cell, there is a motor for sale my Depche_Mode, that will work to convert your Stingray.
That is the route I'm going...
Paul
PS Found it: https://www.helifreak.com/showthread.php?t=581392
Screw It, I'm gonna fly.
Synergy E5, Synergy E5s
Couple planks, couple quads
vControl and Neo
povern is offline        Reply With Quote Quick reply to this message
Old 12-05-2013, 07:58 PM   #74 (permalink)
Cool review video of the stingray with Curtis in the manufacturers section.
Old 12-05-2013, 08:54 PM   #75 (permalink)
How about a link.
John R. is offline        Reply With Quote Quick reply to this message
Old 12-05-2013, 09:32 PM   #76 (permalink)
Flite Test - Stingray 500 - OVERVIEW (8 min 53 sec)
KDS Agile 7.2/5.5 Chase 360 - SkyHero Spyder/Spy/Little Spyder
BrainDrain_dx is offline        Reply With Quote Quick reply to this message
Old 12-05-2013, 09:36 PM   #77 (permalink)
Yes, That's the video. Sure would like to get one. Maybe in March. Right now I am building a Ballistic. I should say rebuilding.
Old 12-07-2013, 02:12 PM   #78 (permalink)
The landing gear are extremely brittle. I took a set of Mini Protos landing gear and re-drilled them. They are made by Gorilla gear and flex, plus they come in black.
John
Team Synergy, Rail Blades, Lynx Heli
Citizen #396
jmiceli11 is offline        Reply With Quote Quick reply to this message
Old 12-07-2013, 09:06 PM   #79 (permalink)
I think boiling the LG has helped, they feel a little more flexible than the first set which I broke.
//Dennsi.
Old 12-14-2013, 08:26 AM   #80 (permalink)
So for those of you guys flying this model on say 2500 to 2700 mah 4S packs, what flight times are you getting? Are the packs light enough to do smooth 3D flying for 4 min? Seems like the 3D flights I've seen on 2200 packs last about 3.5 min.
Team Synergy
Kinger is offline        Reply With Quote Quick reply to this message
Human Verification
