Like Tree2Likes
Old 09-20-2013, 06:47 PM   #21 (permalink)
Stickied,
Ricky
Helifreak, the place to be!
rdlohr is online now        Reply With Quote Quick reply to this message
Old 09-21-2013, 04:17 PM   #22 (permalink)
Thanks!
xioxia is offline        Reply With Quote Quick reply to this message
Old 09-23-2013, 03:35 AM   #23 (permalink)
Originally Posted by Seasick78 View Post
That is correct. Since you are using the cable loom, the master lead will go straight to the throttle port on the RX. No need to go to BD first.
I experienced that my beastx did not pick up a signal / did not want to initialize some times while connecting power...My original setup had the master and slave connected to the RX. I then changed it by having the master in the RX and the slave feeding the Beastx...never had that problem again.
William Blake Team Kontronik
TDR1, Banshee 850 # 22
Diabolo 700
wblombard is online now        Reply With Quote Quick reply to this message
Old 09-23-2013, 10:21 AM   #24 (permalink)
Default Re: Kosmik FAQ's
That's how I will run it as well. Master to receiver throttle and slave to BD3SX.
Primal is offline        Reply With Quote Quick reply to this message
Old 09-25-2013, 05:11 PM   #25 (permalink)
I got my kosmik today and I have a question.
Would it be OK to solder the supplied ring terminals directly to the motor wires? It would clean up my wiring considerably.
Old 09-25-2013, 08:48 PM   #26 (permalink)
I would say yeas some are connecting the motor wires straight to the kosmik!!!
Helicopters Don't Fly - They Beat The Air Into Submission
Logo 500SE
Minicopter Diabolo 700
Banshee # 45 700 LE and 850
jcflyer is offline        Reply With Quote Quick reply to this message
Old 09-25-2013, 10:20 PM   #27 (permalink)
Cheers, thanks for the info
Old 09-26-2013, 03:57 AM   #28 (permalink)
Yes, I have motor Pyro 800 soldered directly to the ring terminals. I placed the wire inside them then crimped them around the wire and then flowed some solder inside. dont forget to put heatshrink on the wires before you put them on the the Kosmik otherwise you'll be taking them off again when you realise lol.
The difference between knowing your s**t and knowing you're s**t!
Optipower - Kontronik Drives
jamin_00 is offline        Reply With Quote Quick reply to this message
Old 09-26-2013, 07:35 AM   #29 (permalink)
I would not crimp them solder only. you only crimp wires that have lots of strands. the wire guage and small number of strands (2) is VERY bad for crimping.
Richard Zappe
Team Kontronik USA PeakAircraft
Wh1teAfr1can is offline        Reply With Quote Quick reply to this message
Old 09-26-2013, 07:52 AM   #30 (permalink)
Can someone post a picture? Thinking of connecting my motor wires directly to the kosmik...much neater
Diabolo 700
Old 09-26-2013, 08:20 AM   #31 (permalink)
OK, thanks, looks like Im redoing mine tonight then lol
Old 10-18-2013, 03:22 AM   #32 (permalink)
Hmm, why is the "Edit" button not here for me now on post 1?
Old 10-18-2013, 06:42 AM   #33 (permalink)
Default Kosmik FAQ's
After a period of time the posts cannot be edited.
Team - "Self Interests" -
Old 10-18-2013, 11:29 AM   #34 (permalink)
Ah, I need to edit that post as time goes on
Old 10-18-2013, 09:33 PM   #35 (permalink)
14 day's Edit is gone.
Contact Mods and they will fix you up.
GimpyGolden is offline        Reply With Quote Quick reply to this message
Old 10-21-2013, 11:01 AM   #36 (permalink)
20. With V4 when you open the file on the SD card it will give you an error log file. Simply open this with any text editor and it will now detail any errors and on what number log so you will see what is happening and when.
See the pic below of where to find this and an example from one I have been sent.
Mine does not have an error log file. Does this mean that no errors have posted?
William
Synergy N5C, 130x, Mini Protos 6s
wbefield is offline        Reply With Quote Quick reply to this message
Old 10-21-2013, 02:46 PM   #37 (permalink)
The error log should be present regardless of any errors being reported.
Are you on a MAC? On my MAC for some reason it does not list the root menu but on a Windows machine it does.
Old 10-21-2013, 04:49 PM   #38 (permalink)
I'm on a PC. Did find the file though. It was hidden. Was able to unhide it in the Folder options.
William
Old 03-18-2014, 11:16 AM   #39 (permalink)
Dumb question, but I'm getting ready to order my first Kosmik. What does it come with and what do I need? I'm assuming I will need the Progdisc, but what about wiring, terminals, etc? Thanks.
_____________________
JRAY is offline        Reply With Quote Quick reply to this message
Old 03-18-2014, 11:18 AM   #40 (permalink)
It'll come with everything except prog disc and whatever connector type you decide to use for the batteries (EC5, bullets, etc.).
