BATTERIES!!! Let's get a which battery thread going - Page 2 - HeliFreak
Go Back   HeliFreak > R/C Helicopter Support > Gaui Helicopters > X3
X3 Discussion and support for the Gaui X3
Old 11-02-2013, 04:13 PM   #21 (permalink)
You have installed your washout arms incorrectly. The washout arms linking to the swash should be parallel to the main shaft. If you were to move your arms 180 degrees they would be in the correct position.
DX8 - Gaui X7 - Gaui X5 - Gaui X3 - Mini PRTOS
Blade 130 X - mCP X BL - Blade nCP X
grovey is offline        Reply With Quote Quick reply to this message
Old 11-02-2013, 06:29 PM   #22 (permalink)
No kidding... I have 10 flights on this bird so far...CrAZY that it has done so well.... back to the book to correct this..Thanks for the heads up. . . . P.s... Damn good eye !!
Dejavu*Xion is offline        Reply With Quote Quick reply to this message
Old 11-02-2013, 06:38 PM   #23 (permalink)
Default BATTERIES!!! Let's get a which battery thread going
No worries! It is an easy thing to miss. I think I may also have gotten that wrong IIRC and had to fix while building mine.
Old 11-02-2013, 07:30 PM   #24 (permalink)
Ok..All set now..Wow, I totally had that set backwards... A page I should have taken more time on. . . . . . Thank god nothing came undone during flights... Went back thru the 7200BX and had a little tweaking to do as well... Again HUGE thanks.. And good eye.
Update.....So ya know I just had to check my Gaui X4II as well..... And what-da ya know....Backwards as well... Talk about Dyslexia..ha
Old 11-02-2013, 07:58 PM   #25 (permalink)
That still does not look 100% correct?
My long links, the ones from swash to grip are perfectly vertical, it may be a optical illusion but yours look on an angle?
Fly... crash... rebuild... repeat... Fly hard my friends! Team Lynx Mini Protos
Trexwilly is offline        Reply With Quote Quick reply to this message
Old 11-02-2013, 08:30 PM   #26 (permalink)
yeah, it does look like angled. mine looks in line with my head block center
fusionsx00 is offline        Reply With Quote Quick reply to this message
Old 11-02-2013, 08:37 PM   #27 (permalink)
Take note of the grips...Did not have them installed yet. Ya came close to wining a prize however..lol
Old 11-03-2013, 04:29 AM   #28 (permalink)
Sorry, missed the posts on this page.
Gaui X2 FES ZYX, Gaui X3 MB, Gaui X4 II VBar, Gaui X5 FES MB
250 DFC ZYX, 450 DFC Sport MB, ALZRC 450L Pro VBar, Devil 450 FAST VCTRC FBL
500E DFC Pro VBar, 500E SDC ZYX-S
KDS 550 VBar, 550E DHPS VBar, 550E DFC Pro VBar, 700E DFC HV iKon
beenflying is offline        Reply With Quote Quick reply to this message
Old 11-03-2013, 01:44 PM   #29 (permalink)
I ordered some gensace 1200, also emailed glacier and they said it is already in the works to make a 6s packs for the new 450's that came out
Old 11-09-2013, 03:39 PM   #30 (permalink)
Wow the gensace 1200mah 40c are a tight fit. I cant believe they are 1200, more like 1400 by the weight and size alone. The only way i got them in was to find thin velcro , and i still have to manuver them in. I rather ditch the tray, it supposed to make battery mounting easy.
My idea of easy is the x5, slap it on and velcro. Done.
Just seems like extra work , for less space and i can put packs in faster without the tray
Old 11-09-2013, 05:04 PM   #31 (permalink)
I just got two more of the Gens Ace 1200 40C and another set of the battery tray things, so now I have all 4 Gens Ace mounted on the plates. My plan is to keep the Gens for the Gaui, and cycle the rest though my other 6S 450s
Out of my 3 other 6S machines, the Gaui is the most power hungry, so I think it deserves the larger packs
Old 11-09-2013, 06:10 PM   #32 (permalink)
How do you keep the velcro from getting stuck when putting the tray in. I keep on getting caught on the frame
Old 11-09-2013, 07:12 PM   #33 (permalink)
Yup that happens, I just press it in with my thumb as I slide it in or out... took a bit, but now I am kind of programed to do it!
I have very thin Velcro...
Old 11-18-2013, 02:47 PM   #34 (permalink)
What flight time are you guys getting on GenAce 1200mah?
cRash_landing is offline        Reply With Quote Quick reply to this message
Old 11-18-2013, 03:22 PM   #35 (permalink)
4 minutes for me
Old 11-18-2013, 11:27 PM   #36 (permalink)
On the GenAce 1200mah.
Can you just face the battery down? What I mean is, the power wire is on the bottom instead of the side.
Will it still fit and no mods on the frame?
Could not find any batteries other than Align ones. And the HK ones are out of stock.
Old 11-19-2013, 01:41 AM   #37 (permalink)
Platinum 1300 65c perfect fit $39 at prostarhobby.com
BLACKOUT MINI,ZMR 250,TBS Discovery ,Zephyr 2
TARANIS X9D + ,ez-uhf jr mod
GauiX5 Gauix3
kachur779 is offline        Reply With Quote Quick reply to this message
Old 11-19-2013, 03:36 AM   #38 (permalink)
my gens 40c 1200 fit with zero mods. pretty tight, you have to coax the straps in as you push the pack in. im getting 5 minutes of flight time at 2700 rpm.
nothing crazy, just chasing my tail around tuning. i finally gave up trying to get it right again. really need those head upgrade bearings made of unobtainium
but they only go in one way, they are bigger in width on one side, so the lead end up on the sides, left or right. it cant fit in the frame with the leads facing down or up
Old 11-19-2013, 09:55 AM   #39 (permalink)
I just got a reply for the Glacier battery
They would not have them until by next year.
I am tempting to get the Genace 1200, I may have a hard time putting this on and may regret the purchase later.
I'm afraid that it is a tight fit and might put some stress on the frame since it is only holding by screws on a plastic battery mount.
Old 11-22-2013, 03:27 PM   #40 (permalink)
I just opened a box from the AlignTrexStore.com A pair of their new 1250 45C. They look nice, and will fit with no issues at all, lots of extra room from thick lush velcro! LOL
213g and come with a clone T plug soldered on! jst balance plug
Insurance
Human Verification
