Old 10-01-2013, 08:55 PM   #1 (permalink)
Default Trex 450 L wiring pictures
Show your wiring on the new trex 450 L
Josh S is offline        Reply With Quote Quick reply to this message
Old 10-02-2013, 12:01 AM   #2 (permalink)
+1 I wanna see where others put wires.
Weird this one was even harder to route wire nicely then my 250.
Chopper Crew: T-Rex 250 DFC, T-Rex 550e DFC, Goblin Black Thunder 700 T-Line
Multi Chop Crew: Nano QX, E010S, 200 QX, Martian II 250, Scratch V-Tail 355
Planks: Too Dayam Many
QueadlunnRau is offline        Reply With Quote Quick reply to this message
Old 10-02-2013, 08:36 AM   #3 (permalink)
my wires turned out ok, most of them are hidden and safe from being eaten.. but my heli is currently in pieces so once its back together I can post some pics
michael88997 is offline        Reply With Quote Quick reply to this message
Old 10-02-2013, 09:50 PM   #4 (permalink)
After messing around with it on and off for 2 nights I come up with the following. I think it is pretty clean and there is no external wires except for esc/battery and the rudder servo. There is the ikon fbl controller inside the frame as well as the hobbywing phase sensor.
ID:	455082   Click image for larger version
ID:	455083   Click image for larger version
ID:	455084   Click image for larger version
jprochnow is offline        Reply With Quote Quick reply to this message
Old 10-02-2013, 09:54 PM   #5 (permalink)
The Capi
Mine.
Old 03-07-2014, 06:01 PM   #6 (permalink)
Default Just finished 450L wiring
Finally finished 450L wiring. It's quite different machine from the DFC so takes some time to make neat wiring.
I put two satellite receiver inside the frame and mount 3mm fomax under the V-bar to get satellite receiver wiring clearance. I've been flying 450DFC long time. This machine very different scheme from the DFC.
Battery mount,servo mount, motor mount is revolutionally. Very good machine and eager to fly.
But, IMO have some complaints compared to DFC.
1. Battery size important because battery go inside the frame so large batt. impossible
and mounting scheme is not easy. I like just velcroing DFC scheme more.
2. Servo mounting is very good but I have to detach whole servo wire from the RX to replace servo gear.
for DFC I just unscrewed the servo and replaced the gear without unpluging the wire.
3. Most complaint is tail boom mount. It's latched the frame so very difficult to replace the front tail gear.
Overall 450L is very revolutionary machine from the DFC but doubt repair easiness after crash.
ID:	492970   Click image for larger version
ID:	492971   Click image for larger version
ID:	492972   Click image for larger version
ID:	492973   Click image for larger version
ID:	492975   Click image for larger version
ID:	492976   Click image for larger version
ID:	492977   Click image for larger version
ID:	492978   Click image for larger version
chan is offline        Reply With Quote Quick reply to this message
Old 03-07-2014, 09:52 PM   #7 (permalink)
Thanks for the review about the serviceability of this frame vs the Pro frame.
Please let us know any differences in flight characteristics also!
Sent from my HTC One X using Tapatalk
sharkfin is offline        Reply With Quote Quick reply to this message
Old 03-08-2014, 08:41 AM   #8 (permalink)
The Capi
Chan you have mounted the rx inside the frame, but I don't see where the antennas have come out of the frame.
Old 03-08-2014, 09:49 PM   #9 (permalink)
Yes, first I tried antennas out. But, looks not good and also gap exist between the mounting plate.
So, I rotated 90 degrees. so antennas pararell to the frame. It's just fit.
Looks good. and hopes no side effect becase I mounted dual satellite inside the frame
Old 03-08-2014, 09:53 PM   #10 (permalink)
The Capi
The antennas inside the frames drastically reduces the radio link performance.
Old 03-08-2014, 11:13 PM   #11 (permalink)
Thanks for the comment. I searched some information about antenna placement and found this.
http://www.archeli.com.au/forums/sho...d.php?t=136223
Good info. for Rx installation.
I've been flying 450 for a long time without concerning satellite placement and no issues until now.
But I don't want jeoperdize my new bird. So, I'll replace satts. soon.
Old 03-09-2014, 06:04 AM   #12 (permalink)
Default Re: Trex 450 L wiring pictures
Here is mine. Nothing special, though. A small S-bus receiver is under the mast on the lower mount.
ID:	493336Click image for larger version
ID:	493337Click image for larger version
Tapatalk ISW11F
Akira Taniguchi from Osaka, JP___Compass 6HV , Atom550, JR Forza EX
akiyoshinosato is offline        Reply With Quote Quick reply to this message
Old 03-11-2014, 12:21 AM   #13 (permalink)
5packs flown today. I've been flying DFC for a long time so I can celarly feel the differences.
Simply say its stable and agile than DFC. Because it has larger span blades than DFC other than that its similar performance to DFC. Overall, good machine but not night and day difference between two.
someone likes 450 325mm quick feeling may feel this machine dumb stable sometimes. Just IMO.
Old 03-11-2014, 09:24 AM   #14 (permalink)
Bro the mks servos how much you bought? For x3 cyclic and x1 rudder... And price in your place it's USD or EUR? Pls update ASAP to me thanks...
HeliKing84 is offline        Reply With Quote Quick reply to this message
Old 03-20-2014, 03:39 PM   #15 (permalink)
here is mine:
I tried to get a good compromise between an easy serviceable heli, and a nice clean look.
most of the wires are hidden, Heli is stock except for a CC talon ESC, and an Ikon fbl (i have tried the 3GX, but it was crap)
running 1 sat receiver on the lower electronics tray.
had to shave off a little from the frame so the sat wire won't touch it and transmit vibrations to the fbk unit
eesc to motor wires were left exposed so i can easily disconnect them when setting up the heli.
all in all it is a pretty easy heli to wire up neatly, way easier than the 450 pro, lots of room to run wires, and the wide frames help as well.
i am flying mine gove'd at 3250RPM and it is insanely powerful. when you tell it to go it goes fast! and shoots up in to the air like a rocket.
this is one fun little heli
ID:	496022   Click image for larger version
ID:	496023   Click image for larger version
ID:	496024   Click image for larger version
ID:	496025   Click image for larger version
Greetings from Israel
Trex 700e dfc pro HV\Ikon FBL\CC Edge 160
Trex 450L\Ikon FBL\CC talon 35
Gaui X3\Ikon\Talon 35\460MX
bendisar is offline        Reply With Quote Quick reply to this message
Old 03-21-2014, 01:52 AM   #16 (permalink)
How do you guys program / tune the iKON / Brain mounted there? Bluetooth, or does a USB cable fit somehow?
DiceK is online now        Reply With Quote Quick reply to this message
Old 03-21-2014, 02:47 AM   #17 (permalink)
I just use the bluetooth connection.
Very cheap and makes field tuning an ease
Sent from my GT-I9300 using Tapatalk 2
Old 03-21-2014, 05:25 AM   #18 (permalink)
I use bluetooth, too. With my PC at home, too. It is so convenient that it has been quite a while since I last used the USB cable.
Tapatalk ISW11F
Old 03-21-2014, 06:20 PM   #19 (permalink)
I am thinking about the Talon 35 vs the EDGE light 50
is the talon up to the challenge ?
how is it with 3D flying
I am thinking it's twice the voltage so the current should be low on a 6 cell setup
right now I am running the 3 cell set up with 450mx 3400kv
T-REX 500X, T-REX 600 PRO DFC,T-REX 550 DFC, T-REX 470L, T-REX 500L, T-REX 700X, DX9
atlny is offline        Reply With Quote Quick reply to this message
Old 03-22-2014, 04:25 PM   #20 (permalink)
i fly it with the talon on 6S, with the stock 1800KV motor.
gove'd at 3250rpm on stock pinion, i throw everything i got at this heli and it just begs for more .
i do both hard smack and big air with it, but i have never gotten the motor nor the esc to come down hot. if it is a really hot day (and it gets really hot where i live) than the esc might come down barely warm.
so for a 6S setup i am sure that the Talon will do just fine.
on 3S tough i bet it will come down hot, because 35A on a 3S machine for 3D is pretty marginal
