Old 10-14-2013, 07:37 PM   #1 (permalink)
Default mini vbar gov soft start problem
Hello fellow enthusiasts. I have a goblin 700 with mini vbar blue pro( bank switching and gov), hobbywing platinum pro 120 ESC with hobbywing phase sensor, align 750MX motor, align DS610 and 650. The heli flies fine on 1820 headspeed (idle 1 in dx7), and 2040 (idle 2). The problem is the soft start will work when switching from normal mode(I don't believe in running gov in norm mode for safety reasons and setup) with the blades off. but with blades on, if I switch from norm to idle 1 or 2, the motor does two turns and stops. Because I have a norm mode for testing, I have to have soft start in the hobbywing esc, otherwise I'll strip everything. the only way I can get it to spool up into idle (idle 1 and 2 have gov enabled) is if I start the soft start in norm mode half way, and then click over into the idles. Also, the motor likes to come to a dead stop when I go from high speed idle 2 over to low idle 1, the heli just quits and falls outta the sky, and it sounds like its trying to do a soft start all over again, but takes too long. I tried different gov run up times like 3 and 4, no difference. I can't set the hobbywing softg start to the faster setting cuz then it starts way too fast. I suspect this may be a motor timing problem or ESC gov cutoff issue. My HW 120 is set to 15 degrees and 12 hertz switching freq, nobody recommends setting any lower with this esc, even with scorpion motors. I'm running 21T pinion, max rpm is set to 2200, flat curve of 96% in radio(2040 rpm), phase count is set to 5 as instructed, and motor "off) gov range is -98 to 94%. this is really bugging me because one day I'll switch rpms in mid air and it will quite on me again, and I won't be so fortunate. I have the same ESC with a scorpion on a logo 500 and switch between idles all the time in mid air, with soft start enabled, no problem!!
Any suggestions will be dearly appreciated.
NGC1672 is offline        Reply With Quote Quick reply to this message
Old 10-14-2013, 08:34 PM   #2 (permalink)
How is your Normal throttle curve set?
AMA 373608
K2Freak is offline        Reply With Quote Quick reply to this message
Old 10-15-2013, 12:49 PM   #3 (permalink)
thanks
Old 10-15-2013, 12:53 PM   #4 (permalink)
It could be the two soft starts not working with eachother and the esc or the vbar stopping the motor because it does not get the result it is asking for. You only need to run one of the soft start or spool up programs. Just use the one on the vbar and disable the one on the esc and see if that solves the issue. The vbar will smoothly switch between idle speeds. One other thought is it could be the curve you are using and the transition points. The dropoff in RPM can be really steep with small percentage changes in the vbar software. It might be triggering some failure mode or possibly even a respool and softstart sequence.
jgrog76 is offline        Reply With Quote Quick reply to this message
Old 10-15-2013, 01:02 PM   #5 (permalink)
yeah that makes sense. Norm is 0 80 flat, idle 1 is 91 flat, and 2 is 96% flat curve. I tired disabling the soft start in the esc, but vbar soft start is extremely rough even with run up time at 2 or 3. Norm mode has vbar gov disabled since its a test mode, so you would need esc soft start for norm. No soft start in norm is disaster lol. Everyone at the field says vbar soft start is kinda shitty with some setups and motor combs.
Old 10-15-2013, 11:28 PM   #6 (permalink)
Interesting. I used the same setup and curves but never disabled gov in normal. Worked ok, but i found soft worked better than very soft hw startup speed.
AMA 373608
Old 10-16-2013, 02:48 AM   #7 (permalink)
Never heard of this problem before.
How did you disable the gov in normal, via bankswitching?
Gaui X3 HW 50A V3 OMG H1/H2 Servo's BL450MX Mini-V (M.I.A.)
Gaui X5 FES Polaris BEC BLS451/251 Silverline V-Bar Formula Swash/Head
JR Forza 700 Scorp 160A opto + 4525 520 JR NX8925/SLG01 Vbar Neo
JR XG14 PL8 v2
mverhorst is offline        Reply With Quote Quick reply to this message
Old 10-16-2013, 03:04 AM   #8 (permalink)
yup turned off vbar gov in that norm bank. I'll try to turn on gov on all banks and turn off HW soft start see if that solves it
Old 10-16-2013, 04:05 AM   #9 (permalink)
Seems like a good starting pointm but keep in mind, the initial kick with the HW 120 could be a bit harsh. Check the HW forums for some fixes with the HW firmware...
JR XG14 PL8 v2
Tags
goblin 700, vbar, wtf!
