Go Back   HeliFreak > R/C Helicopter Support > Scale Helicopters > Power Systems
Power Systems Power Systems Discussion
Old 10-20-2013, 12:00 PM   #1 (permalink)
Default Agusta a109 motor?
Hello,
First time i make scale heli from trex 500 with 4 blade head on a109 fuselage. Is it ok to put this motor http://www.hobbyking.com/hobbyking/s...00_class_.html , because align 500mx is very hot (untouchable) with this configuration :
YGE 100A LV
2650 nanotech 65-130c 6s
ds510x3 and tail RJX FS0391THV?
and
Does anybody knows which is the upper limit for the mass of scale heli based on trex 500
laza is offline        Reply With Quote Quick reply to this message
Old 10-21-2013, 01:21 AM   #2 (permalink)
No. You cannot use that motor. That motor is for a 600 class Heli, with a 6mm rotor head shaft.
You need a 500 class motor, with a 5mm rotor head shaft.
I would suggest the HYPERION HS3026 1210 KV motor.
Use a 12T pinion and run the head speed at 1700 rpm.
When the wife asks "How many helicopters do you need?"
The answer is always "Just one more!"
BlackTitanium is offline        Reply With Quote Quick reply to this message
Old 10-21-2013, 02:42 AM   #3 (permalink)
Thanks for reply,
But I was thinking this one http://www.hobbyking.com/hobbyking/s...00_class_.html
5mm shaft with 12t or 13t .
Old 10-21-2013, 03:11 AM   #4 (permalink)
Originally Posted by laza View Post
Hello,
I don't have a figure for maximum mass, but I believe it is MUCH more than the mass of a painted fuselage. RC helicopters and their components are engineered for very strong g-forces in 3D manouvers, which is probably 3 - 4 times the basic mass (pod and boom). But a heavy helicopter will be less agile and have a shorter flight duration than a light one of course. Even so, in my experience where the fuselage has added 30% of the mechanics weight by reducing head speed I get flight times at least twice of those that 3D fliers get.
Nelson JR DSX9 II; Stretched Atom 500 in Bell 222 body , Stretched TRex550 in 600 size AS350 - . Trex 450 S and 550E for sport . practice.SK720 all round..
npomeroy is offline        Reply With Quote Quick reply to this message
Old 10-21-2013, 04:12 AM   #5 (permalink)
You don't need a lot of power for scale flight - any appropriately sized heli motor will have more than enough power for scale because they are almost always designed for 3D.
My 500 sized UH-1N weighs about 8lbs I think, and it uses about 400W for scale circuits. Using 50W / lb of weight is a good rule of thumb, with slightly more for either 4 blade (like the A109) or hovering.
As said above, that is a 600 sized motor (and a fairly weak one at that), so it is probably a bit large to fit in the 500 frames.
Scorpion motors are not the best for scale because of the need to oil regularly. Look at the Savox 1200kV motor. I have bought a used Savox 1300kV for my UH-1N but I have not used it yet, but apparently they are quite good, and not too pricey.
I would have thought you might run a bit slower than 1700rpm for a 4 blade. I run 1700rpm in my UH-1N and it flies quite well at that (2x 465mm Spin asymmetrical wide chord blades).
Colin
Vario Long Ranger 700e
Seahawk 600
UH-1N 500
Baumann EC-145 800+ (coming soon )
Andy01 is offline        Reply With Quote Quick reply to this message
Old 10-21-2013, 09:04 AM   #6 (permalink)
Originally Posted by Andy01 View Post
"...I would have thought you might run a bit slower than 1700rpm for a 4 blade. I run 1700rpm in my UH-1N and it flies quite well at that (2x 465mm Spin asymmetrical wide chord blades)."
Colin
I use the thin chord Carbon Fiber scale blades.
Four of those seem to be nearly equal to using a pair of wide chord blades.
7-8 minute flight times, on 6S 3300mah packs, and the motor is barely warmer than ambient after the flight.
Old 10-21-2013, 09:43 AM   #7 (permalink)
Thank You guys for replies,
Ordered Savox BSM 3750 1200KV Pro Spec 500.
For blades I will use symmetrical http://www.hobbyking.com/hobbyking/s...in_Blades.html is it ok for test flight?
Old 10-22-2013, 03:57 AM   #8 (permalink)
The blades should be OK. Just check that the two pairs are not too far apart in weight. With 4 blades the opposing pairs can be a bit different, but not too far out.
Colin
Seahawk 600
UH-1N 500
Old 10-23-2013, 02:40 AM   #9 (permalink)
Believe it or not, even though were purchased at HobbyKing all are in balance
Old 11-05-2013, 02:08 AM   #10 (permalink)
Until the motor arrive, I do a paint job.
No more Nemo fish http://www.imdb.com/media/rm38551577...ef_=tt_pv_md_1
Old 11-05-2013, 02:24 AM   #11 (permalink)
Very nice paint job!
Old 12-01-2013, 11:03 AM   #12 (permalink)
....almost done....
[IMG][/IMG]
[IMG][/IMG]
And lights..
[ame]http://youtu.be/hRbuGXjNMLE[/ame]
