Old 02-17-2014, 12:07 PM   #201 (permalink)
Originally Posted by mba83 View Post
So how risky is it to run DS76t with Talon 15 at 5.5V? Do most of them burn out? Or only a few had issues? I wonder if I should add a resistor to mine. If so, which resistor should I use?
It won't fry it, but not good for the lifespan of the servo imo. Lots of people run servo higher than the rated voltage and frequency, I'm not that brave or lucky.
Gaui X5-MiniVbar | Gaui X3-MiniVbar | Gaui X2 SK-540 | 250 Pro DFC |130X 3S GY280 | 300X-Ikon | DX8 | Real Flight 6.5
bmc76 is offline        Reply With Quote Quick reply to this message
Old 02-17-2014, 12:10 PM   #202 (permalink)
Originally Posted by vtown nick View Post
Ok, I was wondering if it was a voltage thing I just didn't look into the specs yet. Stock default voltage on the blue esc is also 5.5v so that would be much needed.
By the looks of it in your video that thing is really happy with the less weight. I'm surprised the plastic servo gears held up in your crash. But the 250 blades are quite small.
you have a 5v option on the align blue/yellow as well, no need for a diode if you are ok running 5v.
Old 02-17-2014, 02:17 PM   #203 (permalink)
Thanks guys. I can't adjust the voltage on Talon15, so I'll just keep it at 5.5V and hope the 76t won't fry. Don't want to spend time and money to add more weight to my heli
mba83 is offline        Reply With Quote Quick reply to this message
Old 02-17-2014, 02:20 PM   #204 (permalink)
go to radioshack, look in the diode bin, and get a 3a barrel diode, they come 2 to a package for about $3. Solder it inline with the red servo wire, painted ring towards the servo. That will give you a .7ish voltage drop to the tail servo and keep it right in line with it's operating specs.
Old 02-17-2014, 03:37 PM   #205 (permalink)
I already have a few of these around the house:
http://www.digchip.com/datasheets/pa...139/HER105.php
They are 1A diodes. Would it work fine?
Old 02-18-2014, 10:24 AM   #206 (permalink)
Yeah, I'd think 1a would be ok for just one servo, but I only have first hand experience with the 3a barrel diode, these are very commonly installed on the ds76t by the 450x guys, that esc can be switched to 6v, people install the diode to drop the voltage to the tail servo. That still puts it at around 5.2 or 5.3, so apparently people are running the ds76t above the recommended voltage with success. For me running it at 4.8 gives me a little more peace of mind. I know there is a user on here (can't remember his name) that has been running the 76t right off of his talon at 5.5v.
Old 02-23-2014, 09:38 AM   #207 (permalink)
no, and the 300x horns don't work with the 250 balls, so you need 3 packs of s60 horns. I used 10.5/11mm from center with the longer balls on the front of the lower swash
Hi BMC76,
I'm trying to get my servo horns set up for my 76's on the cyclic, but I'm finding that the long balls on the servo horns (on the two front servos) are hitting the gear casing when using 11mm from center.
Did you swap the long balls on the servo horns with the short balls on the lower swashplate to get clearance? It's hard to tell in the pic on the first page.
If so, does that not effect the swashplate geometry, using the longer balls on the swashplate? I wish I had some spare long and short balls to try, but I don't.
Thanks!!
MB
Nano CPX x 3, mCPX-BL x 3,130X, 180CFX, Lynx 450X-L, T-Rex 250 DFC, T-Rex 450L, T-Rex 500, KDS Chase 360, SAB G380, G500 Spt, BT650, BT700-T, BT700 Spt, XLP500
"More the Knowledge Lesser the Ego, Lesser the Knowledge More the Ego" Albert Einstein
Miracle Boy is offline        Reply With Quote Quick reply to this message
Old 02-23-2014, 03:48 PM   #208 (permalink)
I just left them as is and angled out the loops, contacts the case a bit but doesn't cause any problems that I noticed, no wear that I see yet. I know some people put short balls on the horns and the long balls on the swash if it bothers you.
Old 02-23-2014, 04:43 PM   #209 (permalink)
O.K. thanks I don't like the idea of the links rubbing the casing, so I'll try swapping the balls over and see how the geometry looks.
Cheers!!
Old 03-09-2014, 06:45 PM   #210 (permalink)
Upped the collective to +-13, feels like the gov holds head speed better.
Align TREX 250 Pro DFC (4 min 19 sec)
Old 03-09-2014, 07:14 PM   #211 (permalink)
very nice. 309 grams? Is the one piece plastic landing gear heavier than the SE landing gear?
helicray is offline        Reply With Quote Quick reply to this message
Old 03-09-2014, 09:28 PM   #212 (permalink)
the one piece plus skids are only a tenth of a gram lighter than the standard set according to my scale.
Old 03-09-2014, 09:33 PM   #213 (permalink)
Thank you bmc, my 250 weight is very heavy, I'm looking for ways to cut down the weight.
Old 03-09-2014, 10:09 PM   #214 (permalink)
I know the feeling bud. Mine was a tank before the diet. It's good now though, one of my favorite helis.
Old 03-09-2014, 10:14 PM   #215 (permalink)
last flight of the day.
250 Pro DFC evening flight (4 min 6 sec)
Old 04-06-2014, 08:22 PM   #216 (permalink)
Originally Posted by grumpy42 View Post
I plan on using Hyperion DS09SMDs for the cyclic and a DS09GMD for the tail . They are light, have metal gears, and seem reliable, but the SMDs are slower than ds76s. They are currently 50% off, so they may be worth trying.
I ordered a DS09GMD on Friday, should get delivered Monday. I'll see how it does compared to ds76t. I really like Hyerion lipos so I'm optimistic.
Old 04-29-2014, 08:17 AM   #217 (permalink)
Just wondering how the DS09GMD worked out for you. I'm using the DS76t, but not sure if I trust it.
Murph_d is offline        Reply With Quote Quick reply to this message
Old 04-29-2014, 08:32 AM   #218 (permalink)
I just finished rebuilding one of my 250's. It started out as a CopterX kit but as I was chasing down vibes, used a lot of Align parts. It would seem the CopterX frame is several grams lighter than the Align as my AUW is 289.50 grams. My other 250 is a DFC plus with a nearly identical setup except for tt tail, and weighs 298 grams. It's been crazy windy here so no test flight yet.
Old 04-29-2014, 09:14 AM   #219 (permalink)
Originally Posted by rodo1268 View Post
They are NOT better, but thay are a lot lighter (and smoother in my opinion). But they are WEAK! ESPECIALLY in a dfc application. Theres a reason eflite/horizon runs all levered flybarless heads. They LOVE to fail w/o notice.
My $.02 worth
Has anyone had the D76 servos fail in mid air without notice?
150DFC - 180CFX - 300CFX - DX6
JSP816 is offline        Reply With Quote Quick reply to this message
Old 04-29-2014, 09:32 AM   #220 (permalink)
I have not, but I have read about it happening on the 300x/ 450x forum. It's not a common complaint but it does seem to happen at times. I'm going to keep on running them on cyclic until they fail. Most common complaint is the gears strip easily in a crash, but I had a nasty crash on the 250 and the gears survived. The gears are cheap too so that doesn't concern me.
