Go Back   HeliFreak > R/C Helicopter Support > Gaui Helicopters > X3
X3 Discussion and support for the Gaui X3
Like Tree3Likes
Old 10-22-2015, 09:39 PM   #481 (permalink)
Originally Posted by mattbeau View Post
Nice flight and cool tunes.
Thank you!
Team GAUI Brazil
Eric Valeriano is offline        Reply With Quote Quick reply to this message
Old 10-23-2015, 02:37 PM   #482 (permalink)
[QUOTE=Eric Valeriano;6701430]I did this one for a local heli shop:
Nice flight!!! Now the only thing you need is a camera man to match your skills.
helicopter1 is offline        Reply With Quote Quick reply to this message
Old 11-22-2015, 02:27 PM   #483 (permalink)
Here is another video of me flying my gaui x3 last week . I did some tuning changes to the geometry of cyclic. I went with the outer hole on the grips and servos and now I am happy with the way it flies.
I also had 7 flights yesterday with some serious winds and I was shocked at how well it handles the wind!
Gaui X3 3D flight at S.E.F (4 min 43 sec)
Old 11-22-2015, 11:39 PM   #484 (permalink)
Nice clean, smooth flight.
- Eric
Compass Atom 6HV, KDE 600XF-530 motor, CC Ice2 HV 80, Torq Servos, BeastX
MSH Protos 500, Scorpion/YGE, Brain
GAUI X3 6S, Xnova 1860, HW 50A V3, MKS DS95, 8910A+, BeastX, Belted Tail.
isogloss3d is offline        Reply With Quote Quick reply to this message
Old 11-23-2015, 04:09 PM   #485 (permalink)
Thanks. Still need a lot of work though with my orientations.
Old 11-25-2015, 06:40 PM   #486 (permalink)
I put my trigger on this x3, I would like to try it if it's what Im looking for. Compared to a 425mm blades running 6s how this gaui will be on a 325mm 3s setup? No 3d, just sport flights and because of the near size (450-500 class) I'm afraid will be too similar to my 500.
andrea_farins is offline        Reply With Quote Quick reply to this message
Old 11-26-2015, 03:45 PM   #487 (permalink)
Been flying the 700 too much now I suck at keeping this heli close. Here it is on 380's QF servos and the all mighty Xnova 1860! 3000 rpms on brain gov
Gaui x3 stretch on 380's xnova 1860 (3 min 5 sec)
Team MSH USA - Cyclone Blades
MSH Prôtos 380 Brain 2
MSH Prôtos Max V2 Brain
vtown nick is offline        Reply With Quote Quick reply to this message
Old 12-06-2015, 10:11 AM   #488 (permalink)
Default Gaui X3 Videos - post your vids here!
Great little heli to pass around with friends!! The jesus bolt on this thing needs replaced often.
Chris Olsen Gaui X3 @ night (2 min 57 sec)
#HighOnHelis
AlarmedBread is offline        Reply With Quote Quick reply to this message
Old 12-06-2015, 11:19 AM   #489 (permalink)
Getting back into it, haven't flown much in the last 6 or 8 months. Just switched out the 350's for 360's, really like the 360's.
Gaui X3 with 360's (3 min 22 sec)
Gaui X5-MiniVbar | Gaui X3-MiniVbar | Gaui X2 SK-540 | 250 Pro DFC |130X 3S GY280 | 300X-Ikon | DX8 | Real Flight 6.5
bmc76 is offline        Reply With Quote Quick reply to this message
Old 12-07-2015, 08:47 AM   #490 (permalink)
Originally Posted by AlarmedBread View Post
Great little heli to pass around with friends!! The jesus bolt on this thing needs replaced often.[/url]
Please explain? I don't have an incredible amount of flights on mine yet, and mine is the CNC gold version. So maybe different? What happens to the jesus bolt?
Ironically I had the nylock nut on my X5 come off in flight. When I landed the bolt flew out as the rotor spooled down. Then when i picked it up the rotor came off. Is it something like this? Or does the bolt actually wear out?
Integrity Handywork is offline        Reply With Quote Quick reply to this message
Old 12-07-2015, 04:48 PM   #491 (permalink)
The jesus bolt bends then breaks in flight. Usually you feel this as minor blade tracking error and zero pitch a bit off. Then it snaps off. Head and nut come off leaving a piece of the bolt in the main shaft. I'm using the hardware that comes with the main shafts and not over tightening. This has happened pretty frequently for me.
Here is one where the head came off in flight leaving the center of the bolt behind. No other damage to the heli. Aside from a break away servo horn.
https://instagram.com/p/1b4ep8inyF/
This is after one flight the bolt is slightly bent. Not sure what to do I like this heli but can't fly it with this problem.
#HighOnHelis
Old 12-07-2015, 05:11 PM   #492 (permalink)
we need to find a bolt without treads all the way down the shaft..just enough so the nut will grab..
tonys-heli is offline        Reply With Quote Quick reply to this message
Old 12-08-2015, 10:15 AM   #493 (permalink)
+1. I had this same problem on my 600. It was the type of bolts I was using. The threads weaken the bolt, so you need to use one with an unthreaded shank, just like Tonys-heli said.
*Spartan Vortex VX1e*
Old 12-22-2015, 04:04 AM   #494 (permalink)
Wow, so this is the first I'm hearing/seeing of this issue with that bolt. Obviously it should be a shoulder bold like you guys are saying. Only problem is, finding one this size isn't easy. But I found some options..
First is a semi threaded shoulder bolt from Gaui. The shoulder doesn't look long enough to pass the whole rotor head. But they might be a little better than the one without a shoulder at all.
http://www.anythingheli.com/gaui-sem...m2-5x12-10pcs/
Second is a bolt from SAB. It's 3mm too long at 15mm compared to the stock 12. However, the nut might still tighten or else a couple washers might fix it up. It's so close to the center that it shouldn't cause much off balance I don't think. If your handy with a dremel and cut the bolt just right. You could cut the 3mm off and this bolt would probably fit just right from the looks of it. I have a pretty good measuring eye, but I could be wrong. Either way, I'm pretty sure this bolt could work one way or the other.
http://www.anythingheli.com/sab-din-...n-380-500-570/
I'll have to take a look at mine. I've only got about 125 flights on my X3 Gold. I'm not sure how quickly this is happening for you. But now I'll have to keep an eye on it. Here is a flight from the other day at the park... and yes the grass is green and it was like 80°... Not sure when the "winter" is going to come for us here.
Gaui X3 Gold - Fun 3D at the park (3 min 28 sec)
Old 01-08-2016, 03:00 AM   #495 (permalink)
Hello helifreaks.Here is me flying this amazing heli.I fly only 2 months so be kind to me.This is my 70th fly.
" frameborder="0" allowfullscreen>
Thespius is offline        Reply With Quote Quick reply to this message
Old 01-08-2016, 03:01 AM   #496 (permalink)
Old 01-08-2016, 03:04 AM   #497 (permalink)
Gaui X3 inverted hover practise. (4 min 27 sec)
Old 01-17-2016, 04:39 PM   #498 (permalink)
Attachment 623493
+1. This should be a semi threaded (shouldered?) bolt as others have suggested. On all my crashes I have had to replace this, and/or, the jesus bolt on the bottom of the shaft which is, I believe, the same bolt... threaded all the way through.
XLP Specter NME | Oxy 5 550, 5 HF 560, 5 HF 610 | Compass Chronos, 7HVU, 550U, Atom | Gaui X3
cyclo is offline        Reply With Quote Quick reply to this message
Old 01-17-2016, 05:20 PM   #499 (permalink)
My kit came with a semi-threaded bolt.
kuroguy is offline        Reply With Quote Quick reply to this message
Old 01-22-2016, 12:28 PM   #500 (permalink)
Looking good!
- Eric
