Old 11-22-2013, 08:01 AM   #1 (permalink)
Default Does the MiniP require anti static strapping?
My experience with most of my belted helis is that they required anti static strapping to avoid static build up in the tail section.
Silicon on the belt is an option but I would prefer not to do that unless it is required for belt maintenance anyhow.
Rick
Helifreak, the place to be!
rdlohr is offline        Reply With Quote Quick reply to this message
Old 11-22-2013, 08:21 AM   #2 (permalink)
Rick, the Mini P has conductive carbon frames and boom blocks, and 'naked' spots on the boom. I've been flying mine forever with no anti-static mods with no issue.
That said, I always soak my belts overnight in silicone RC car shock oil before installation just to make them more pliable. I'm sure that also helps remove static tendencies.
Chris Boultinghouse
JustPlaneChris is offline        Reply With Quote Quick reply to this message
Old 11-22-2013, 11:02 AM   #3 (permalink)
Cool, thanks. Have you ever tried to measure conductivity from the frame to the tail pulley? I'll try that when I get mine. Hopefully someone will chime in if they have had problems.
Rick
Old 11-22-2013, 02:53 PM   #4 (permalink)
Honestly I can't remember if I've checked it on the Mini P or not. I know I did on the Logo after installing the anti-static wiring!
Chris Boultinghouse
Old 11-22-2013, 02:56 PM   #5 (permalink)
I had to do it on my Logo 400 because the VBAR was logging hits.
Rick
Old 11-23-2013, 02:37 AM   #6 (permalink)
No trouble with Mini P due to conductive tail boom parts.
SAB Goblin 380 / Xnova 2820-890kv / Yep 90Lv / Beastx v3 / Tgy 306g Hv / BK DS-5005HV
Blade Nano CP-X BL
Rcx 250
Spektrum DX9
michalss is offline        Reply With Quote Quick reply to this message
Old 11-23-2013, 02:45 AM   #7 (permalink)
Default Re: Does the MiniP require anti static strapping?
No issues here, I lube the bearings (especially the idler pulley bearings) with trinity royal oil before every session, and hit the belt around the main gear with it as well. Use trex 500 grommets on the canopy CA'd on, with a bit of synthetic plastic and rubber safe grease (superlube from ace hardware) on the pins to make it easy to take the canopy off and on. Still on the original canopy after tons of flights and 2 crashes, barely a scratch or crack on it.
Dylan ~ www.AstroidDesigns.com
Dylwad is offline        Reply With Quote Quick reply to this message
Old 11-23-2013, 07:58 AM   #8 (permalink)
Thanks. Sounds like static is not an issue here. I was lulled into a sense of security with the Logo 400 since the Logo 600 came with strapping. I assumed if the 400 needed strapping it would have come with it as well. I was a bit annoyed at Mikado for that one.
Rick
Old 04-07-2014, 07:36 AM   #9 (permalink)
Does the oil weight make any difference?
DX6i, Jeti DS-16
MCPX BL, Mini Protos 6S, Stingray 500, SG704 post-maiden tuneup, SG381 in the making
Brain, SK 720, Spirit Pro, Brain2; HW, Kosmik
Heli-X, AccuRC, RF 7.5 Transmitter Interface Edition
madeye is offline        Reply With Quote Quick reply to this message
Old 04-07-2014, 08:18 AM   #10 (permalink)
Probably not, but mine is 80 weight.
Chris Boultinghouse
Old 04-07-2014, 04:53 PM   #11 (permalink)
The miniP will require a ground wire if you use the cheap aftermarket fiberglass frames
maarset is offline        Reply With Quote Quick reply to this message
