Go Back   HeliFreak > R/C Helicopters > Newbies: Tips and Information
Newbies: Tips and Information Section of HF, specifically for Passing along info to newcomers to the hobby. Setup, tweaking, orientation practice, etc.
Old 11-22-2013, 10:33 PM   #1 (permalink)
Default Newbies guide to the DX6i for RC helicopters
* Yet another ArchmageAU epic *
This is being posted in the Newbies: Tips and Information area as a lot of new fliers start with a DX6i as their first programmable TX to go with BNF Blade helicopters (or with the Phoenix simulator).
If you follow the quick start, you should be able to successfully program the DX6i and get it working with your heli or sim with a minimum of fuss. If you want to know all there is to know about this unit, read on at your peril
This is a follow on from:
About the guide:
This guide is to help the first time DX6i user get up and running with the Spectrum DX6i transmitter.
It is geared towards the FBL helicopter pilot, but will be expanded to cover other helicopters (planes will need to be a separate guide).
To most newcomers to RC, they DX6i may as well be written in sanskrit.
The DX6i manual assumes a level of knowledge of RC operation that the novice user just will not have. Concepts such as travel adjust, dual rate, channel mixes etc... mean nothing. Without a thorough grounding in RC concepts most of the manual makes no sense.
Table of Contents
  • Quick Start (Just get my mCPX flying, I'll read the rest later)
  • Transmitter and RC basic concepts
  • Transmitter handling (thumbs vs pinch)
  • Why acro and heli modes (and why to never use acro for helis, even for simulators)
  • Known bugs / Quirks (Timer, Throttle hold)
  • DR, Expo and Travel Adjust, how it works and what you need to know
  • Trim vs Sub Trim, why two modes of trim
  • Monitor, your best friend for TX problems
  • Understanding Throttle and Pitch curves
  • Stunt mode, not only for the advanced pilot
  • Throttle hold, why you need it
  • The secret life of "gyro"
  • Mixing, mysteries revealed
  • What on earth is "revo mix"
  • Swash types, who invents this stuff?
  • Buddy boxing, just the facts
  • Range checking, why and how
  • Using you DX6i with a sim
  • Adjusting stick tension
  • Recalibration (the hidden menu)
  • Changing modes between Mode 1 and Mode 2 (Yes it is possible to do this properly)
Most users that I encounter start with a DX6i to work with a FBL helicopter. This is their first TX and they want to set up up with their Blade BNF or RTF helicopter.
Faced with the mass of switches and options, the hapless beginner is left to try sort out the DX6i manual on their own.
I've chosen the mCPX as the example heli to show the setup of, but this can be applied to any Blade BNF helicopter. (** I don't own an mCPX, just a couple of nanos and a 130x **)
For example, the mCPX manual setup for a DX6i is:
Setup List:
  • Model Type: Heli
  • Reverse: THRO-N, AILE-N, ELEV-N, RUDD-N, GYRO-N, PITC-R
  • Swash Type: 1 Servo 90
  • Timer: 4:00 Basic flying, 3:00 Advanced Flying
Adjust List:
  • DR&EXPO:
    • 0-AILE 70% 30%
    • 0-ELEV 70% 30%
    • 0-RUDD 100% INH
    • 1-AILE 100% 30%
    • 1-ELEV 100% 30%
    • 1-RUDD 100% INH
  • Thro Curve
    • Norm 0% 40% 60% 80% 100%
    • Stunt 100% 100% 100% 100% 100%
    • Hold 0% 0% 0% 0% 0%
  • Pitc Curve
    • Norm 30% 40% 50% 75% 100%
    • Stunt 0% 25% 50% 75% 100%
    • Hold 0% 25% 50% 75% 100%
  • Travel Adjust
    • THRO 100%, AILE 100%, ELEV 100%, RUDD 100%, GYRO 100%, PITC 75%
(see Sanskrit to the beginner )
This is a quick start of how to program this in on a brand new DX6i. (I will go into detail as to what each of these are later). I am assuming you have already put batteries n the DX6i (or changed the internal rechargeable battery).
Real Basic Terms
*** PLEASE READ as it is the KEY to the INSTRUCTIONS below ***
First some basic instructions (to make writing this easier). I've limited it to 4 as most people can hold 4 things in short term memory without problems.
  • <select> - push the scroll wheel in like a button (press and release).
  • <highlight> - scroll the scroll wheel till the highlight on the LCD shows a letter, word or phrase.
  • <return> - <highlight> “List” in the upper right corner and <select>
  • <main> - <highlight> “Main” in the upper right corner and <select> (If “Main” is not in the upper right corner, <return> first, then <highlight> “Main” and <select>)
If you see a number in brackets after quoted text (like “MODEL SELECT” (1) ), this means it is a menu selection and the number is the number of the option in the menu which will be shown on the right hand side of the DX6i screen.
Lets go
OK. Lets just straight in. First lets do:
Setup List:
  • Model Type: Heli
(ensure you are in a well lit area, but not bright sunshine as the DX6i's LCD is not backlit).
Steps:
  • Turn on transmitter
  • Go to “ADJUST LIST” menu
    • <select> - Screen changes to “ADJUST LIST” menu
  • Select a model to use for the mCPX
    • <highlight> “MODEL SELECT” (1) then <select>
    • <highlight> A blank model or a model you wish to overwrite
    • <select> - Transmitter will show “LOADING....” then return to “ADJUST LIST” menu screen
  • Go to “SETUP LIST” menu
    • <highlight> “SETUP LIST” (12) then <select>
  • Reset the model to ensure it is at it's defaults
    • <highlight> “ COPY/RESET” (13) then <select>
    • <highlight> “RESET” then <select>
    • <highlight> “YES” then <select> - DX6i will beep 3 times
    • <return>
  • Set the model to HELI mode
    • <highlight> “MODEL TYPE” (1) then <select>
    • <highlight> “HELI” icon then <select> - DX6i will beep 6 times
    • <return>
  • Set a name for the model
    • <highlight> “MODEL NAME” (2) then <select>
    • <highlight> The models name (should be blank after reset) then <select>
    • <highlight> a blank character of the name then <select>
    • Scroll the highlight with the roller till the character you want appears. (Order: " !~#$%&'()*+,-./0123456789:;<=>[email protected]") and <select>
    • Repeat the above 2 steps till the name you want is on the screen. (You only have 8 characters)
    • <highlight> “OK !” then <select>
    • <return>
  • Ensure the swash type (to "1 Servo 90")
    • <highlight> “SWASH TYPE” (5) then <select>
    • (should be showing “1SERVO90”, if so <return> and skip to next step)
    • <highlight> “CCPM 120” then <select>
    • <highlight> “1SERVO90” then <select>
    • <return>
  • Set the channel reversals (to "THRO-N, AILE-N, ELEV-N, RUDD-N, GYRO-N, PITC-R")
    • <highlight> “SWASH TYPE” (4) then <select>
    • Since PITC is the one we must reverse, <highlight> the “N” next to “PITC-” then <select>
    • <highlight> “R” then <select>
    • <return>
  • Set the timer (to "4:00 min" for basic flying)
    • <highlight> “TIMER” (8) then <select>
    • Ensure the first highlight space shows “DOWN” (if not change to “DOWN”, <highlight> “UP”, <select>, <highlight> “DOWN”, <select>)
    • Change next highlight (minutes) from “06” to “04” (<highlight> “06”, <select>, <highlight> “04”, <select>)
    • Ensure next highlight (seconds) shows “00” (if not change to “00”, <highlight> seconds, <select>, <highlight> “00”, <select>)
    • Ensure next highlight (switch) shows “TRAINER” (if not change to “TRAINER”, <highlight> switch type, <select>, <highlight> “TRAINER”, <select>)
    • <return>
  • Almost there for this part: (What is not specified, but needed are as follows)
  • Set D/R COMBI switch to "RUDD"
    • <highlight> “D/R COMBI” (7) then <select>
    • <highlight> “Inh” then <select>
    • <highlight> “RUDD” then <select>
    • <return>
  • <main>
  • Turn DX6i off to save setting. (Yes! Turn it off).
Setup bit done.
That last bit enables the DR & expo to be changed on a single switch. You may not understand it yet if new to RC helis and programmable TX's, but it makes DR & expo makes flying easier and the next bit of programming easier too. I will discuss DR & expo later in the piece.
Ready for round 2?
Lets do:
Adjust List:
  • DR&EXPO:
    • 0-AILE 70% 30%
    • 0-ELEV 70% 30%
    • 0-RUDD 100% INH
    • 1-AILE 100% 30%
    • 1-ELEV 100% 30%
    • 1-RUDD 100% INH
  • Thro Curve
  • Pitc Curve
  • Travel Adjust
I will explain DR&Expo, Throttle Curves, Pitch Curves and Travel Adjust later. Right now, they just need programming.
Steps:
  • Turn on transmitter (Should be on the model we are programming)
    • (If not on correct model, use “MODEL SELECT” (1), select model, then back to menu)
  • Set DR and Expo for mCPX
    • <highlight> “DR&EXPO” (2) then <select>
    • Ensure Rudd D/R switch is in position 0
    • <highlight> “100”% next to AILE 0 then <select>
    • <highlight> “70” then <select> to store value
    • <highlight> “INH” on same line as AILE 0 then <select>
    • <highlight> “+ 30%” then <select> to store value
    • Do the same 4 steps for ELEV 0
    • Leave RUDD 0 at “100%” and INH
    • Change Rudd D/R switch is in position 1 (All 3 values will change from AILE 0, ELEV 0 and RUDD 0 to AILE 1, ELEV 1 and RUDD 1)
    • <highlight> “INH” on same line as AILE 1 then <select>
    • Do the above 2 steps for ELEV 1
    • You should now be finished DR&EXPO, Change Rudd D/R switch is in position 0 for first flight (softer DR).
    • <return>
  • Set Throttle Curve for mCPX
    • <highlight> “THRO CUR” (6) then <select>
    • (This will be: 0, 40, 60, 80,100 - 100, 100, 100, 100, 100 - 10)
    • <highlight> “NORM” then <select>
    • <highlight> “2” then <select> - this is programming pos 2 on the normal curve
    • <highlight> “40.0%” then <select> - pos 2 on the normal curve is 40, notice the graph changes - “NORM” should be illuminated again.
    • <highlight> “3” then <select> - this is programming pos 3 on the normal curve
    • <highlight> “60.0%” then <select> - pos 3 on the normal curve is 60 - “NORM” should be illuminated again.
    • Do the same for “NORM” “4” and set to “80.0%”
    • (“NORM” “H” should already be at “100.0%” - Note not “NORM” “5”)
    • (Now we do Stunt)
    • <highlight> “STUNT” then <select>
    • <highlight> “L” then <select> - this is programming pos 1 (or low) on the stunt/idle up curve
    • <highlight> “100.0%” then <select> - pos 1 on the stunt/idle up curve is 100, notice the graph changes - “STUNT” should be illuminated again.
    • <highlight> “2” then <select> - this is programming pos 2 on the stunt/idle up curve
    • <highlight> “100.0%” then <select> - pos 2 on the stunt/idle up curve is 100
    • Do the same for “STUNT” “3” and set to “100.0%”
    • Do the same for “STUNT” “4” and set to “100.0%”
    • (“STUNT” “H” should already be at “100.0%”)
    • (Now we do Hold – set to 10, this will be explained later)
    • <highlight> “HOLD” then <select>
    • <highlight> “10.0%” then <select> - notice the line for hold on the graph changes.
    • <return>
  • Set Pitch Curve for mCPX
    • (as most of these are close to the model defaults, only 2 values need to change)
    • <highlight> “PITC CUR” (7) then <select>
    • <highlight> “L” then <select> - this is programming pos 1 (or low) on the normal curve
    • <highlight> “30.0%” then <select> - pos 1 on the normal curve is 30, notice the graph changes - “NORM” should be illuminated again.
    • <highlight> “40.0%” then <select> - pos 2 on the normal curve is 40 - “NORM” should be illuminated again.
    • *** Insert pic of Throttle Curve screen at this stage? ***
    • (This should be all we need to do here – default curve for each is 0,25,50,75,100 only normal curve is 30,40,50,75,100)
    • <return>
  • Set Travel Adjust for mCPX
    • <highlight> “TRAVEL ADJ” (3) then <select>
    • (Fortunately only the pitch needs to change)
    • <highlight> “+100”% next to PITC *** (DO NOT <select> YET) ***
    • Pull the throttle stick full down and <select> while throttle stick full down
    • <highlight> “+75”% then <select>
    • Push the throttle stick full up. Pitch value will change to “+100”% ! (under the highlight). I will explain later.
    • <select> (to allow change to “+100” value
    • <return>
  • <menu>
  • Turn DX6i off to save setting. (Yes! Turn it off - again).
Congratulations, you have just programmed your DX6i Transmitter.
If you want to check transmitter settings, you can go back through the menus, or use the monitor screen. The following is how to view the monitor screen.
Steps:
  • Go to “MONITOR” screen
    • <highlight> “MONITOR” (3) then <select>
    • (<return> will get you out to menu, <menu> will get you to to the main screen)
The monitor screen shows the output of all 6 channels. This is what is being sent to the helicopter.
Switch F.Mode switch to 0. T.Hold to 0.
  • Low throttle stick will be Thr 0, Aux 35 (TA 75% turns Pitch 30 into Pitch 35)
  • High throttle stick will be Thr 100, Aux 75 (TA 75% turns Pitch 100 into Pitch 87.5)
TH Hold to 1
  • High throttle stick will be Thr 0, Aux 75 (TA 75% turns Pitch 100 into Pitch 87.5)
  • Low throttle stick will be Thr 0, Aux 25 (TA 75% turns Pitch 0 into Pitch 12.5)
F.Mode switch to 1. TH Hold to 0.
  • Low throttle stick will be Thr 100, Aux 25 (TA 75% turns Pitch 0 into Pitch 12.5)
With RUDD D/R in 0 position, elevator and aileron should only move between to 15% and 85% (70% of full range). Rudder will move between to 0% and 100% (full range)
With RUDD D/R in 1 position, elevator and aileron should move between to 0% and 100%. Rudder will move between to 0% and 100% (full range)
In both cases elevator and aileron should move slower round mid stick and faster at the edges.
Do not worry if aileron and rudder appear to move backwards from what is expected. This is normal.
Finally we need to bind to your heli.
  • READ THROUGH ALL THE FOLLOWING INSTRUCTIONS BEFORE FOLLOWING (so you know what to do in advance - particularly the rudder right bit)
  • Ensure DX6i is off.
  • Ensure "MIX/TH HOLD" switch is off (0).
  • Ensure Throttle stick is low.
  • Ensure all switches are at 0.
  • Connect battery to heli (heli LED will flash).
  • Hold trainer switch up on TX.
  • Hold rudder to the right (This is specific for the mCPX and nano).
  • Turn on the DX6i (still holding trainer and rudder - The DX6i will show "BIND" on the screen).
  • Wait a full 3 seconds before releasing only the "trainer" switch.
  • The heli LED should go solid (which means bound - If heli LED is still flashing after 15 seconds remove heli battery and retry he bind steps from start).
  • If bound, release the rudder stick, disconnect the battery from the heli and turn off the DX6i.
You should need to bind again (but can repeat this process any time to re-bind).
To fly (or attempt to )
  • Turn on the DX6i. (clear any warnings like F.Mode and T.Hold).
  • Engage T.Hold.
  • Ensure correct model is selected on the DX6i screen (this is why you gave it a name ).
  • Connect battery to heli.
  • Ensure heli's LED goes solid (bound/connected).
  • Hit trainer button to start timer. (It will let out TWO beeps first time engaged if counting down. LISTEN for the beeps).
  • Unclick T.Hold and fly.
  • If you land (scheduled or unscheduled), Hit trainer button to pause timer.
  • Remember to hit trainer button to re-start timer before flying.
  • Before takeoff (or timer), I check the collective is responding, you should see the blades twist and the swash move up and down level.
ALWAYS turn off the DX6i IMMEDIATELY AFTER disconnecting the heli battery, EVEN if about to fly again. This avoids the DX6i timer bug.
A little about RC Transmitters
This helps explain why things work (or don't). It gets a little complex (OK a lot complex), and it's completely OPTIONAL. Read on if you are curious, or like me NEED to know.
** You have been warned **
A transmitter/receiver combination is a method for remote controlling a number of servos (hence RC). So all the electrics are designed around transmitting a number of control signals to the receiver repeatedly and reliably. The signals are driven by inputs from sticks, switches, buttons and knobs.
Before we control a servo, we must first understand what a servo is and how it works.
A servo is a control motor which will move a connection point to a specified location dictated by a signal. Servos can be linear or swing arm. In RC, we tend to use swing arm. (micros like the mCPX use linear servos, but they are in the minority primarily due to speed and power constraints).
When we use a swing arm servo, the push-rods connected to the swing arm tends to be near 90 degrees to the centre of the swing. This is a normal part of model design. As such, the focus for the transmitter is to define a mid-point and the maximum and minimum swing distances. This is what the settings of sub-trim (centre) and travel adjust (maximum and minimum) are about. Almost all RC is about variation of position from centre (either + or -).
For a servo to work, it needs the position (or channel signal) continuously sent to it. The position is not sent by varying a voltage, but by a pulse signal. The pulse signal repeats over and over. The length on the pulse is the determination of how far through the control range the servo needs to hold it's connection point. (This is Pulse Position Modulation or PPM). If the pulse width changes the servo must move. If the servo detects that the connection point has moved outside of the motors control, it must use the motor to bring it back to the point. The more force pulling or pushing the servo out of position, the more the servo motor has to work to keep it in position. This is the main draw of servo current (and the quickest way to destroy servos).
A servo knows where it's connection point is because of a sensory potentiometer. The control circuit of the servo tries to move or retain the the connection point position. From the potentiometer, it knows if it need to move forwards or backwards.
Since a servo needs a continuous signal, it is the receivers job to provide this signal. A receiver reads all the channel signals coming in from the transmitter and ensures it outputs the continuous signals to the servos. If the receiver loses connection with the transmitter, it will fall back to its fail safe programming for the servos.
With 2.4ghz RC, the signal is sent from the transmitter to the receiver as encoded digital frames (or packets). The encoding allows multiple channel values per frame to be sent. These frames, or packets of channel positions, are sent continuously by the transmitter. Packets are sent at a rate of over 40 frames per second. When the receiver misses or cannot decipher a frame, it considers the frame dropped. If a frame is dropped, the channels maintain the values they last received. If the receiver “drops” a large enough number of these frames it believe the signal is lost (and invokes failsafe).
DX6i sends channel values from 0-1023 (1024 possible values). This is termed resolution. The value for a channel of 511 is considered “0” (centre), 0 is considered “-150” (min) and 1023 is considered “+150” (max). The DX8 and beyond use values 0-2048 (centre, min and max adjusted accordingly). Better resolution = finer control. This should be the last I need to talk about real channel values till stick calibration.
DX6i only uses a 22ms frame rate. The DX8 and beyond can use 11ms frame rates as well as long as the receiver can handle this). Lower frame rate ms, more packets sent, less chance for long outage.
Getting back to the individual servos and control channels. Remember, the control channels tell the servo where to move and keep the connection point.
The control for a channel in the TX should be first an ideal (0 being centre, -100 being lowest and +100 being highest) should be set. Ie. Minimum collective should be -100, max collective +100. This is independent of flying hard 3D, mild 3D, big air or scale.
Next this ideal is mapped through sub-trim and travel adjust to actual servo movement. Ie. min collective is made so the servos move the models collective to the desired blade angle, be that -5 degrees or -13 degrees.
In essence we control a virtual model with the sticks and switches, and the TX mapping setting transfer these virtual controls into real signals the servos and understand.
Since rotary swing arm servos are measured from the middle. Travel adjust needs to be varied on the +side of 0 and the - side of 0 separately (this is why in the instructions it seemed like we set the pitch TA twice, we just had to do both the + and - sides separately).
Helicopters are quite complex in the control systems, so we have other mappings like swash type and revo mix but I will discuss these at other stages.
Old 11-22-2013, 10:41 PM   #2 (permalink)
Default Part 2
As the DX6i is usually the first programmable transmitter an RC pilot starts with, they usually have not considered how to hold the transmitter. Before you get too comfortable flying RC is the BEST time to work out what feels best for you.
The two main methods of holding a transmitter are thumbs and pinch. Third, less common, method is tray but this is least common.
Thumbs is what seems most logical to most the first time they pick up a transmitter and twiddle the sticks. Just wrap fingers round the back of the DX6i, place thumbs on top of the sticks and twiddle away. Often the index fingers rest on the hold and trainer switches on the back of the transmitter. Long live Playstation and Xbox.
Pinch is using the pad of the index finger resting around the top of the stick and thumb guiding the stick from underneath. This means the index finger helps guide the thumb in making fine movements (beneficial for control). To allow immediate access to buttons, the ring finger now rests on the hold and trainer switches. Because the bulk of the hand is above (or beside) the transmitter, it will feel less supported. For this reason a lot of pinchers use a strap to help support the transmitter.
Tray is using a platform to support the transmitter. The platform may be secured to the ground (tripod, etc), or the operator (wearable). The sticks are usually held like two pencils. The hands can “float” above the transmitter, or rest on pads on the tray to the left and right of the transmitter on the tray. The fingers are also free to this switches.
My preferred method is to use pinch without using a strap. To do this, you grip the transmitter with the sides of the hand and support on the little fingers. This does require some flexibility in the hands to reach all corners of the transmitter. The advantage of this method is that the hands will not move around the transmitter, and you get the fine control of the index finger with the power and quickness of the thumb. I found when I started using pinch, I found it easier to do finer controlled movements with the sticks.
This is discussed in greater detail in “1st U.S. R/C Flight School – Transmitter Handling” (http://www.rcflightschool.com/TransmitterHandling.pdf).
In the end, the choice of how to hold the transmitter is yours. If you are just starting out. This is the best time to experiment. Find out what is most comfortable to you.
Last point is “transmitter english”. This is trying to steer the helicopter by moving the transmitter body, moving your body or your feet. You want to AVOID this. If you find yourself doing the “transmitter hustle”, stop, land, and try again without body and foot movement. The reason why this is bad is because it will limit the style of flying you can do and the place you can fly. Practice with a simulator will help this too.
The DX6i allows programming of model type to be HELI or ACRO. If you are flying a helicopter, use HELI.
ACRO is for fixed wing aircraft. It eliminates the pitch curve. The “ADJUST LIST” menu options are changed, even some of the “SETUP LIST” menu options change. Gyro and Pitch are replaced by Gear and Flaps.
Without the pitch curve, no collective pitch helicopter can be flown (or properly emulated). You are familiarizing yourself with the wrong options.
When used to control a simulator, the DX6i is attached by the trainer cable. The only signals sent to the computer are the PPM channel signals (6 channels every 22ms). The switch positions are not sent, only the results those switches make on the channel signals (as seen by the monitor screen). Consequently, there is no reason to use ACRO mode for emulating a helicopter.
If you are using a helicopter in a sim, set up a SIMHELI model. If also wanting to fly a plane in the simulator, create a separate SIMPLANE model.
If the heli simulator only takes 4 stick channels and 2 switches, the normal switches wanting to emulated are flight mode and throttle hold. To do this, set up the throttle curves for Normal AND Stunt modes to be 100,100,100,100,100, Hold to be 10 and Gyro to switch on f.mode and have normal as gyro 10% and stunt as gyro 90% (this maps Gyro channel to -100 for Normal and +100 for stunt). Pitch curve for Normal AND Stunt modes should be 0,25,50,75,100. DR for all channels should be 100 during calibration. Also during calibration with the sim, flick the Flight Mode and Throttle Hold switches to ensure those channel values are recorded for sim switches. Once calibration is complete, DR and Expo can be altered according to taste (see “DR, Expo and Travel Adjust, how it works and what you need to know” in this guide) for more details on DR and Expo.
To put this in Manual terms (as used to configure the mCPX in the quick start.
Setup List:
  • Model Type: Heli
  • Reverse: THRO-N, AILE-N, ELEV-N, RUDD-N, GYRO-N, PITC-N
  • Timer: 4:00
Adjust List:
  • DR&EXPO:
    • 0-AILE 100% 20%
    • 0-ELEV 100% 20%
    • 0-RUDD 100% INH
    • 1-AILE 100% 20%
    • 1-ELEV 100% 20%
    • 1-RUDD 100% INH
  • Thro Curve
    • Norm 100% 100% 100% 100% 100%
    • Hold 10% 10% 10% 10% 10%
  • Pitc Curve
    • Norm 0% 25% 50% 75% 100%
  • Gyro
    • Switch: F-Mode
    • Norm 10%
    • Stunt 90%
  • Travel Adjust
    • THRO 100%, AILE 100%, ELEV 100%, RUDD 100%, GYRO 100%, PITC 100%
By doing this, you control the sim EXACTLY the same was as you control a real heli.
So no more ACRO mode for controlling sim helis with a DX6i please.
Known Bugs / Quirks (Timer, Throttle hold)
There are a couple of known quirks with the DX6i. First involves the throttle hold, second involves the timer.
With the throttle hold, 0 is not 0. Spectrum decided that for the DX6i, 10 should be 0 (sounds like dodgy accounting to me ). It's really not a bug, but a feature (that is never explained in any manual). Set hold to 10 on a DX6i and it will output the same of throttle a 0 in normal or stunt modes. That is all you NEED know. (There is a deeper explanation, but that is for another time)
With the timer, there is a case where it can switch from count down to count up. This is real annoying and can kill batteries (or at worst aircraft).
When the timer expires in count down mode, it starts counting UP (to tell you how long you have overshot). Even stopping the timer, it remains in count up mode. IF YOU CHANGE MODELS IN THE ADJUST MENU, THE COUNT UP ON TIMER REMAINS (even if you switch back to the model later). If you turn off the transmitter and only switch models from a newly switched on transmitter, this problem does not occur.
If using trainer to start timer. Holding trainer for 3 seconds when the timer is stopped resets the timer.
DX6i throttle hold quirk for those who must know
* Read this section if you really must know what is going on with T.Hold 10 = 0 *
Spectrum RC channels tend to go from -150% to +150% (all channels 1-6). Remember channels control servos, servos usually have swing arms with push rods 90 degrees from center. 0% is a reliable middle so variances either side are consistent.
A DX6i takes an input (stick, switch, etc), transforms that into an output, filters the output through sub-trim and travel-adjust and sends it to the transmitter (this transmitter signal can be intercepted by the trainer port too).
Now for ease of understanding, throttle is always positive (how can you have negative throttle ), so throttle 0 becomes output -100 on throttle channel, throttle 50 becomes output 0 on throttle channel, 100 becomes output 100 on throttle channel.
By convention the 0 on the throttle channel is -100%. By setting hold to 0 on a DX6i, the throttle channel outputs -125%. So in hold, the throttle channel has a pre travel adjust of -125%/+125% (this is not the same as actual travel adjust). In math terms, out = (2.5in) - 125. So to output -100, we need an input of 10.
This automatic pre-travel adjust alteration ONLY affects throttle throttle when on hold.
(Travel adjust intercepts the output signal and varies it prior to transmission, monitor show the "to transmitter values").
btw, the optional throttle cut (if enabled) outputs -150% on the throttle channel and cannot be altered.
Only reason I can think of is for combustion engines where hold is idle, cut is off. Hold will keep the engine at an idle state, cut pulls the throttle channel to full negative to stop the engine.
Other note: The pre-travel adjust alteration also applies to Gyro. So Gyro 10 = Gyro channel output -100 and Gyro 90 = Gyro channel output +100.
If you are new to RC flight, you will be new to the terms of DR and expo.
DR is short for Dual Rate. What this means is that the rate the stick moves from end to end does not match the speed the servo moves from end to end. In short it is a limit on how far the servo is supposed to move at maximum stick defelction. A DR of 50 means at full stick deflection, the servo moves half the distance from middle to end.
Expo is short for exponential. Exponential describes the type of deflection from a linear curve you want the movement of the servo to have.
All you really need to know is that for Spektrum transmitters (like the DX6i), positive expo makes the servo have smaller defections round centre stick but accelerates till it meets full throw at maximum stick deflection. Negative expo has the reverse affect (more sensitive round centre stick and still slows near maximum stick deflection).
** Warning mathematical explanation following **
An exponential is a “to the power of” curve (ie. To the power of 1 (^1) a curve is linear 0=0, 1=1, 2=2, 3=3, 4=4 ... 9=9, 10=10, to the power of 2 (^2) a curve is exponential 0=0, 1=1, 2=4, 3=9, 4=16 ... 9=81, 10=100).
One curious thing is that we work in percentages. So the previous example becomes (Linear (^1) becomes 0.0=0.0, 0.1=0.1, 0.2=0.2, 0.3=0.3, 0.4=0.4, ... 0.9=0.9, 1.0=1.0. Exponential (^2) 0.0=0.0, 0.1=0.01, 0.2=0.04, 0.3=0.09, 0.4=0.16, ... 0.9 =0.81, 1.0=1.0 ). Note that 0.0 and 1.0 is the same for linear and exponential curves.
When we add an exponential percentage, the curve from 0% to 100% changes closer to the (^2) curve. 50% expo is the same as a squared (^2) curve. 100% is the same as to the power 4 curve (squared square).
I did an explanation of this in another thread on helifreak called “DR expo graphs” (https://www.helifreak.com/showthread...84#post4693084). The thread goes into the mathematics behind the exponential curve.
The curious thing about this is that it is easy to implement in electronics as it is the same as a gamma correction function (like contrast on a TV set).
** End mathematical explanation **
Expo is applied OVER DR. What this means is that softening to full speed happens over the DR range.
To make a heli easier to fly, first reduce DR on the cyclics. This reduces the maximum speed at which the helicopter will flip and roll. Once this is done, then increase expo to taste. The goal is to make the controls natural enough that the helicopter moves as much as you expect based on the stick inputs you give. This will change for each different sized helicopter.
Too much expo, a heli feels mushy. You have to chase the corrections around with the stick, then all of a sudden they rush in. Too little expo and the heli feels twitchy, it's hard to get it to stabilize properly.
Too many new people equate expo with experience. It is just not so. Bert Kammerer uses 20% expo on most helis. Few have more experience with RC helicopters than Bert. Expo is a personal preference thing, nothing more.
For the mCPX, some may like to start with 100% DR and 0 expo, others may start with 70% DR and 30% expo, others may start with 40% DR and 20% expo. Until you get a good feel for flying helis start with a low DR and work up.
For a beginner thumb flyer start with 40% expo and DR to suit level (40 - 70).
For a beginner pinch flyer start with 20% expo and DR to suit level (40 - 70).
As you get more comfortable, increase the DR.
Some higher end transmitters (like the DX8) allow DR values as large as 150. Until you are trying advanced 3D smack moves, a DR of 100 should be fine.
Travel Adjust
What you NEED to know about Travel Adjust is do not touch it unless told to.
Some experienced fliers use Travel Adjust on a flybarless system to command the flybarless system to pitch or roll faster. This works, but should not be tried unless you have a good idea of what you are trying to achieve.
If you must know how Travel Adjust works, if you have not read through the “A little about RC Transmitters” section earlier, do so before continuing on here.
As mentioned in the “A little about RC Transmitters” section, servos vary from a mid-point. Travel Adjust is to alter the outgoing signal from the DX6i to the receiver so that it accurately represents the travel expected of the servo. Sub-Trim represents adjustment to the 0 (or centre point) of the servo, Travel Adjust alters the point the servo is to move to when a move to +100% or a -100% command is received. Consequently we need to adjust both sides, the “-” side and the “+” side.
In the DX6i the adjustment of “-” side and the “+” side travel adjust for a channel is done separately. In order to adjust one side, you move the channel to the side that needs adjusting (move a stick, or with gyro, flick a switch). Once the switch or stick is on the side to adjust, select the channel it is affecting and adjust it's travel. If you move the switch or stick to the other side, the adjustment should be replaced with the other side adjustment that can then be altered.
In the mCPX setup, the setup had a travel adjust for the collective of +/-75%. This could also have been achieved by altering the pitch curve, (but then your could overdrive the 3-in-1 pitch maximums, which is not good).
This travel adjust is applied in combination with sub trim BEFORE any servo reversing, but AFTER all the control adjustments are taken into account.
If tuning a physical model it is best to do sub-trim and travel adjust alterations on the default model BEFORE adding pitch and throttle curves and DR and expo.
When reading forum, some people say adjust trim to solve some problems, others say adjust sub-trim to solve issues. Some say do not alter sub-trim, etc.. The following paragraphs are to explain the difference between the two and when each should be used.
To be brief, trim affects perceived input from the sticks, sub-trim affects centre point of an output channel.
The best way I can describe this with an analogy to shooting a gun (I am not a shooter, but you don't need to be to understand this). You are shooting at a target on an inside range, barrel, bullets, etc.. between shots are identical. The gun is on an adjustable rack and the trigger is pulled mechanically, so there is no variance (heartbeat, etc) to worry about. You line up the shot through the sight and pull the trigger. The bullet hits the target 1cm to the left. How do you correct the gun? Move the gun to aim 1cm to the right (trim) or correct the sight to move the aim 1cm left (sub-trim). Both have a similar effect in the current situation when the gun is re-fired, but moving the sight (sub-trim) mechanically aligns the machine so that if the target is twice as far, the left-right aim balance is still the same.
Why should you care?
When you are using mixes (like swash mixes) to control a helicopter, adjusting elevator trim changes output values on all 3 cyclic channels. Adjusting elevator sub-trim only affects the elevator servo.
In short. When hovering a perfectly balanced helicopter in still conditions you should not need trim. If the helicopter is unbalanced (incorrect load distribution), battery too light/heavy/mounted wrong, trim provides a constant stick input to counteract the imbalance.
Sub-Trim affects the centre point of the servo ravel for a channel (ie, When the DX6i's control signal believes the servo should be at it's centre point). This is used in conjunction with travel adjust. Travel adjust is used to set the position signals when the DX6i believes the servo should be at +100% and -100% of it's control path.
Trim affects the stick input signals. Trim is signal the gimbal (stick) should supply when it is centred.
I rarely use trim.
With digital signals to Blade RTF and BNF helicopters (and most FBL units), sub-trim (and travel adjust) should not be used. The exception to this is the Blade 130x if the main board has a drift problem. This is outlined in “How to zero out pitch/roll/yaw rates at center sticks for the bad mainboards” (https://www.helifreak.com/showthread.php?t=462484) and the Horizon Hobby 130X Addendum on “Calibration and Troubleshooting” (www.horizonhobby.com/pdf/BLH3780-Manual_Addendum.pdf).
Apart from the main screen, this is/was the most used screen on my DX6i.
The monitor screen shows the output of the channels. These are the values for each channel being transmitted to the receiver.
From the “Quick Start”
Steps:
I use this screen to check that the output values being sent on each channel are as expected.
The values include all changes travel-adjust, sub-trim and reverse apply.
If there are no alterations in any of the settings of travel-adjust, sub-trim and reverse, the output is the result of mixing of all the control inputs.
As you move sticks and switches, the triangular arrow pointer on each channel will move. The marking for each channel represent -150 (end-point), -100, -50, 0, +50, +100, +150 (end-point).
By watching the monitor screen you can see the effects of DR&expo, confirm pitch and throttle curves and verify switch settings (like gyro).
The biggest problem I found with monitor on the DX6i is that is does not show exact numbers. This makes it hard to see if calibration is out or fine-tune mixes. However, this is an entry level programmable transmitter.
Imzzaudae did a great post on this “Pitch & Throttle Curves Explained” (https://www.helifreak.com/showthread...30#post3909330)
I'll just expand on this here.
For an RC helicopter perspective, throttle and collective are controlled by the same stick. For an RC plane, only the throttle is controlled by the stick used for helicopter throttle and collective.
In a real helicopter, the collective is controlled by a pull arm (like a handbrake in a car - usually on the left side of the pilot's chair), throttle is by a twist grip on the collective arm. Cyclics are on a single control stick (usually controlled by the right hand) and rudder (or counter-torque) is done by foot pedals.
When flying a helicopter, often the main rotor is brought up to speed and collective is controlled to perform lift and descent. When flying a plane, throttle tends to be a set and forget style of affair. Most of the time, there is no hand on the throttle (apart from when it needs changing).
What has this to do with throttle and pitch curves.
To fly a collective pitch RC helicopter, there are two methods of flying “Normal” (which ironically is rare) and “Idle Up” (which is most common). In Normal, the pitch and throttle values BOTH change as the throttle stick is moved, altitude is determined by both engine speed and collective pitch value. In Idle Up, throttle is always on (unless held) and collective controls altitude. Most real world helicopters are flown “Idle Up”.
In order to facilitate both modes on the one stick, the output values for both throttle and collective must be varied as the stick moves from bottom to top. Since the values may be non-linear (or describable by travel-adjust and sub-trim), we need a way to convert the throttle/collective stick position into values for both throttle and collective.
Say we are setting up a fixed pitch helicopter. For this, we set the collective to a constant value as the throttle/collective stick moves from bottom to top. We also ensure the output of throttle is linear (from 0 to 100) as the throttle/collective stick increases.
When we are setting up a collective pitch helicopter, we need to specify what we want the collective pitch to do as the stick changes. Ideally we want below mid stick to push the heli down and above mid stick to push the heli up. In normal mode, we usually only want slight negative to allow the blades to get up to speed without much blade resistance, but without launching skyward and above mid stick the pitch is greater to allow much greater lift (to fight gravity). In Idle Up mode, we want the negative and positive pitch to be equal above and below mid stick to allow inverted hovering.
The DX6i allows a 5 point curve for throttle and collective output. Each point corresponds to a percentage travel on the throttle/collective stick. Low (or 1) is -100, 2 is -50, 3 is 0, 4 is +50, High (or 5) is +100. (I use the -100 to +100 nomenclature as this is what the servos, rudder, elevator and aileron use, the DX6i uses 0 to 100 nomenclature for presentation of throttle collective for ease of user understanding, but this maps directly onto the servo values. When describing input values I will use 0 to 100 nomenclature, but for stick positions -100 to +100).
An example normal throttle curve from the mCPX was 30, 40, 50, 75, 100. This means the the lowest position (-100) on the throttle/collective stick output a collective signal of -40. (-40 = (30-50)*2 ie. The conversion from 0 to 100 to -100 to +100 nomenclature: ((x-50)*2)). A negative collective signal will push the heli downward. Mid stick (0) has a collective signal of 0 ((50-50)*2), which is level so the helcopter will not lift until over mid stick. Mid up stick (+50) has a collective signal of +50 ((75-50)*2), half maximum positive pitch. Full stick has full collective signal.
You will notice with the mCPX the Idle Up throttle curve is 100, 100, 100, 100, 100. This equates to always full throttle (+100) regardless of throttle/collective stick position. To allow the mCPX to be flyable with this, the pitch curve is linear 0, 25, 50, 75, 100 (collective channel -100, -50, 0, +50, +100). If you have the skill to flip the mCPX upside-down while flying. The engine will not cut off when the throttle/collective stick is below mid-stick. As negative collective pushes the heli in the direction of it's skids (which are upwards in out example), this allows the helicopter to hover inverted.
Throttle and pitch curves are only available in Heli mode on the DX6i.
When flying a heli with the DX6i (even if it is a fixed pitch helicopter), to stop the helicopters engine quickly, ALWAYS use throttle hold. The habit of “chopping” throttle (usually learned with “mall” helicopters - often fixed pitch to make them cheap and easy to fly), will force a collective pitch helicopter into the ground at high speed. This will all but destroy a large collective pitch helicopter. Even most micro “crash resilient” collective pitch helicopters will not survive this treatment long.
What is a V curve for throttle (and why would I use it)?
Before ESC or FBL governors, when RC helicopters had less power to weight, a V curve was quite common. A V curve would try to maintain rotor speed when collective is applied (up or down) in Idle Up mode, by requesting more power to the engine when collective was likely to add load.
A flat curve is like what was in the mCPX stunt mode (100, 100, 100, 100, 100). A V curve would be (100, 90, 80, 90, 100). This way, at mid collective, the speed is lower and easier to handle, but at full collective (when pitch makes the blades encounter more air resistance), the motor works harder (at this point you are usually doing forward flight and need the extra power to overcome winde resistance as well).
With a governor (a device to keep the motor at a certain speed), a V curve is not necessary. For a brushed motor, a V curve is also not usually a good idea. Only on a non-governed combustion system (nitro or gas), should you consider a V curve for throttle.
Programming Throttle and Pitch curves
I assume at this point, you have the curve values you want for the 5 points on the curve.
I also assume you have the mode for which you wish to program the curves. (normal or stunt).
To program a curve:
Steps:
  • Go to “ ADJUST LIST” menu
    • <select> - Screen changes to “ ADJUST LIST” menu
  • To Set Throttle Curve Values
    • (Note: You can only set curves for Normal and Stunt, Hold will be a single number)
    • <highlight> mode (“NORM”, “STUNT” or “HOLD”) then <select>
    • (If “NORM” or “STUNT”)
    • <highlight> the position to change (“L”, “2”, “3”, “4” or “H”) then <select>
    • <highlight> the value you want on that part of the curve (“0.0%” - “100.0%” in “0.5%” increments) then <select> - Notice the graph changes dynamically as you change the value, and once you select the value is stored and you return to mode selection. Remember throttle channel output value is ((VALUE*2)-50), ie. 25 = -50 throttle channel output.
    • (If “HOLD”)
    • <highlight> The value you want for hold (usually “10.0%”) then <select> - Notice the line for hold on the graph changes as you change the value. Due to “Hold” properties, the channel output value of hold is ((HOLD*2.5)-75) (ie. 10 becomes throttle output of -100).
    • (Once all throttle point wanted are entered, then exit).
    • <return>
  • To Set Pitch Curve Values
    • (Note: You can set curves for Normal, Stunt and Hold)
    • <highlight> the value you want on that part of the curve (“0.0%” - “100.0%” in “0.5%” increments) then <select> - Notice the graph changes dynamically as you change the value, and once you select the value is stored and you return to mode selection. Remember pitch channel output value is ((VALUE*2)-50), ie. 25 = -50 pitch channel output.
    • <return>
Turning off the DX6i will save changes.
Stunt mode is not just for 3D smackers. It's for all pilots.
All stunt mode is another programmable flight mode. It has another set of pitch and throttle curves. It can be used to switch gyro settings. It can be used to switch DR and expo settings.
In other transmitters, the flight modes are call f.mode, so you would have FM1, FM2 (and FM3, etc... if more than 2).
The printed recommended configurations for helicopters using the DX6i usually have a normal mode and an idle up mode. For normal mode, the throttle curve varies from 0 to 100 (or so) becoming greater as the throttle stick is raised. The collective usually starts around 30 or 40, raises to 50 at mid stick and then rises to 100. For stunt mode, the throttle curve is usually flat 100, 100, 100, 100, 100, the collective is usually linear and starts around 0 raises to 100 at full stick.
YOU DO NOT HAVE TO USE THE RECOMMENDED CONFIGURATIONS. They are a guide. A start point for those who do not fully understand what is going on. As you are reading this (and have some idea of how it all works now), you can decide what you would like to vary.
On a number of my models, I have no normal curve. I fly Idle Up all the time (does not mean I am in STUNT mode, just that there is no point where the throttle is off unless hold is engaged. I use the ESC soft start to start the motor (if the model detects the throttle channel leaps from -100 to -20 (or greater), the motor starts a timed spool up taking a few seconds to climb to the desired setting. When I fly, I turn on the DX6i, engage hold, switch to flight mode I want, connect the model battery, toggle trainer (to start timer), then disengage hold to fly. My nano uses normal 75% throttle (flat) and stunt 100% (flat).
As mentioned earlier in “Programming Throttle and Pitch curves”, “Most real world helicopters are flown “Idle Up”.”. If you want to fly like a real helicopter, or you want to fly aerobatics, learn to fly “Idle Up”. After a little practice, you will find this far easier than normal mode and you will have more control.
Throttle hold is the preferred method to bringing the speed of an RC helicopters engine to 0.
I don't say stopping as this has different meaning for electric vs combustion heli (gas/nitro). For a combustion heli, throttle cut should be used to stop the engine, throttle hold just brings it to idle.
When learning on coaxial helis, or fixed pitch helis (usually prior to having a programmable transmitter like a DX6i), the normal way to stop the heli's blades rotating was to bring the throttle stick to it's lowest point (sometimes rapidly, known as “chop throttle”). Do this “chop throttle” when flying idle up on a collective pitch heli and you will perform a rapid powered descent (possibly destroying the helicopter if driven into the ground). Helicopter pancake anyone?
Therefore, even if flying a coaxial, or a fixed pitch with the DX6i, please get used to using the hold switch to rapidly remove power from the main blades. You want to completely eradicate this “chop throttle” response.
On the DX6i, hold takes precedence over any other flight mode. If you are in normal or sport, engage hold and the throttle channel is set to the hold value (regardless of where the throttle stick is positioned).
On the DX6i, you can set the value of the throttle output channel value when hold is engaged in the throttle curves menu. Set HOLD to the value you want, BUT THERE IS A CATCH.
The HOLD value does not match the throttle curve values. 0 hold does not equal -100 throttle channel output.
HOLD value of 10 is equal to -100 throttle channel output.
For the NORM and STUNT throttle curves, throttle values = to channel output values; 0 = -100, 25 = -50, 50 = 0, 75 = +50 and 100 = +100.
For the HOLD throttle values, throttle values = to channel output values; 0 = -125, 10 = -100, 30 = -50, 50 = 0, 70 = +50, 90 = +100, 100 = +125.
(This is assuming travel adjust is 100% for + and – throttle).
TO MATCH NORMAL AND STUNT THROTTLE VALUES OF 0, SET HOLD TO 10.
*** The actual math is <channel output> = (<set value> – 50) * 2.5 ***
Old 11-22-2013, 11:01 PM   #3 (permalink)
Default Part 3
Gyro is short for gyroscope. But in a helicopter it is really short for gyroscopic counter-torque stabilization (or gyroscopic tail stabilization).
As a single main rotor helicopter's rotor spins, it produces a torque on the main body. The tail (counter-torque rotor) exerts a sideways push to prevent the main body rotating. As the main rotor speeds up, slows down adds collective or reduces collective, this changes the torque the rotor places on the main body. The tail must vary it's push to exactly counter the main rotor torque to stop the helicopter body spinning.
A gyroscope exerts a force when twisted from the axis of rotation. This force can be measured and applied to adjust the counter torques force from provided by the tail to slow or stop the main body spinning.
The gyro setting is how aggressively to apply this counter force when rotation is sensed by the on-board gyroscope.
Old helicopter gyros were heavy spinning gyroscopes (extra weight is bad in flying models). Modern gyros use electric mems gyros which are much lighter and easier to integrate into electric control circuits.
There are two main types of RC helicopter gyros. Rate mode and heading hold gyros.
Rate mode gyros limit the amount of instantaneous drift that can be felt by the gyroscope (hence rate, what is the limiting allowable rate of drift from one moment to the next). Rate mode is mainly used for scale or speed flying. In rate mode, a helicopter tends to weather-vein with the tail tracking in behind the line of flight. Great for forward flight. Rate mode makes hovering hard as the helicopter will also track nose-in to wind (which may not be a convenient orientation for landing).
Heading hold gyros accumulate the amount of drift felt over an extended time period and correct the heading of the helicopter to try always face in the same direction. Hence heading hold. Most RC helicopter pilots use heading hold 100% of the time.
One thing to be careful of with heading hold is that the helicopter remembers the heading the gyro was activated in. If you connect the battery in one orientation, then turn the heli as you walk it out to the field to another orientation, this can confuse takeoff. One trick I have found that works well to counter this is to move the rudder before takeoff while the heli is on the launch spot to ensure the tail pitch slider is in the middle of the tail pitch slider range. This way the helicopter “thinks” it is facing the heading you have told it, not the heading it had when the battery was connected.
Helicopter gyros work by utilizing a PID controller (proportional-integral-derivative controller - http://en.wik%69pedia.org/wiki/PID_controller). Should this controller have modifyable parameters, normally the P (proportional) gain is adjustable by the gyro channel.
Too much proportional gain, the tail wags as it overshoots on each correction. The gyro instructs the tail to adjust too aggressively, it overshoots, and has to correct again, which overshoots and so on.
Too little proportional gain, the tail drifts and corrects as it undershoots on a correction, then accumulates too much error before having to correct again. It seems like the tail hunts for it's place instead of just finding it and sticking to it.
As the gyro gain channel goes from -100 to +100, often gyro manufacturers allow a heading hold gyro to adjust heading hold gain when using positive values, but work in rate mode for negative values. So +60 gyro channel is 60 gain in heading hold, and -60 gyro channel is 60 gain but in rate mode.
In the DX6i, the gyro values suffer the same problem as HOLD values in the throttle curve. 50 is the middle gyro channel value of 0, 10 is the gyro channel value of -100, 90 is the gyro channel value of +100. This means 50 is the mid point, > 50 is normally heading hold, < 50 is normally rate mode. The actual numerical value for gyro is less important as it is usually tuned on each helicopter based on main rotor size, tail rotor size, tail rotor pitch and other variables.
Mixing is one of the most mus-understood aspects of programmable transmitters and the DX6i is no exception.
Mixing allows you to vary a channels input value based on the output value of another channel. These changes are applied in sequence on the output values and accumulated. You cannot accumulate the mixes in series (eg. Mix 1 gyro -> throttle, Mix 2 throttle -> rudder. The changes to throttle in mix 1 will not be used as part of the input for mix 2).
Mixing work by altering the output channel based on the input channel. If the input channel is 0, no alteration to the output channel is made. The offset used on the DX8 is not available on the DX6i. Offset is ALWAYS 0.
If you put in a mix of aileron -> elevator of -50, -30 and the elevator channel is at an input value 0, what is the elevator output when as you vary aileron by increments of 20 from -100 to +100. Aileron Inputs (-100, -80, -60, -40, -20, 0, 20, 40, 60, 80, 100), Elevator outputs (-50, -40, -30, -20, -10, 0, -6, -12, -18, -24, -30).
A mix I have seen used is to compensate for the lack of a piro-compensation mode for a n mSRX. Look to the reference setups for different helis at the end of this guide for more information.
Reference: “Solving the DX8 spectrum mix setting mystery” (https://www.helifreak.com/showthread...51#post5370251)
Revo mix is short for revolution mix.
Revo mix is used on helis with only rate mode gyroscopes. As torque from the main rotor increases or decreases, this can cause tail deviations. Revo mix allows you adjust rudder trim based on collective adjustments. Ideally, you start small and work up till the tail stays put when you pitch up and down.
Revo mix is of no use in a helicopter with a heading hold gyro. The heading hold gyro automatically compensates for main rotor torque variances.
Swash types changes channel output on rudder, aileron and elevator. The DX6i only offers 2 swash mixes “1 Servo 90” and “CCPM 120”
So what is CCPM I hear you ask. CCPM stands for Cyclic Collective Pitch Mixing. In an RC helicopter, like a real heli, we have a swash plate that controls both the rotor pitch and the lift applied during flight. The helicopter basically follows the tilt directions of the swash plate (tip swash forward, heli goes forward). To control this swash plate, we connect at least 3 servos (either directly or by bellcrank levers). CCPM controls the signal to these three (or four) servos.
If we look at a “1 Servo 90”, elevator controls the elevator channel, aileron controls the elevator channel, collective controls pitch channel. If we were to link the channels directly to a swash plate, the result would be catastrophic.
In a direct connection, for full level collective, all three channels must lift. For an aileron roll one side of the swash plate must lift and the other side must fall, but the overall level remains the same.
The output channels for a transmitter CCPM mixed connection must be thought of as servo 1, servo 2 and servo 3 (not elevator, aileron and pitch despite them being labelled as such). The inputs are elevator, aileron and pitch, but movement on each affect all 3 cyclic servos.
The actual formula for CCPM mixing is based on the placement of the connections to the swash plate. The most common configuration is 120 degree connection points (equal distance between all points). One point is usually in direct line with travel and the other 2 are offset from that connection by 120 degrees.
The basic mix matrix used by the DX6i for CCPM120 is:
  • Output Servo1 (Aile) = <input aileron>*<aile mix>*44.6 + <input elevator>*<elev mix>*-25.75 + <input collective>*<pitch mix>*88.33
  • Output Servo2 (Elev) = <input aileron>*<aile mix>*0 + <input elevator>*<elev mix>*-51.5 + <input collective>*<pitch mix>*-88.33
  • Output Servo3 (Pitch) = <input aileron>*<aile mix>*-44.6 + <input elevator>*<elev mix>*-25.75 + <input collective>*<pitch mix>*88.33
As with any output channel, this value is then passed thought sub-trim, travel adjust and reversing before final transmission to the receiver.
(As with anything, the TX makes slight shortcuts. By using set values instead of cos and sin values, the in-transmitter math is GREATLY simplified. I could put in the full math proof, but that would bore most people to tears).
* How does this help me. It's too confusing. *
Assume Servo 2 output (elev) is for the servo in direct line with travel. This way roll left/roll right at a stable collective will not change this servo.
Attach the other two servos either way around. By changing the aileron mix setting is swash mixing you can make your model's swash plate tip the correct way for roll left/roll right. More on this later.
Next ensure collective up moves the swash up and collective down moves the swash down. Use servo reversing on the output channels to ensure this.
Next middle the collective. And push nose forward on cyclic, the swash should tip forward. If it does not, change the elevator mix from + to – in the swash mix.
Lastly pull left on the cyclic and ensure the swash tilts to the left. If it does not, change the aileron mix from + to – in the swash mix.
Now the CCPM swash should move correctly. You may want to tune the pitch, roll and collective limits. For most models, you want to ensure the full range of swash movement is available with no binding. This way you can “tame” the models cyclic agility with DR & expo. Collective “taming” should be done with collective swash mix adjustment (this way Pitch curves can still vary from 0 to 100 and not be too aggressive).
Man this is poorly covered out on the net.
Buddy boxing allows two controllers to control the same model, but not at the same time. One is the master, the other is the slave. The master can let the slave take over, but can take control again at a moments notice.
For Spektrum a mono audio cable (3.5mm male headphone jack) is recommended, but a stereo audio cable can do. JR cables can be purchased, but a male to male audio cable is sufficient.
The main questions people have with buddy boxing:
  • How do I make buddy boxing work.
  • Does the slave need to have the same programming as the master.
  • Are there any restrictions to DX6i as master.
  • How does buddy boxing actually work.
Order of operations:
  • Set up the programming for the model in the master transmitter.
  • Set up the same programming for the model in the slave transmitter.
  • Turn both transmitters off.
  • Connect the bind cable to both transmitters.
  • Turn the master transmitter on only.
  • Test model control.
  • Pull the trainer switch on the master transmitter.
  • Test the model control on the slave transmitter.
There are some nuances (like setting trim on the slave), but these are the essential steps.
Yes.
When the master hands over to the slave, the slave PPM signal is decoded and sent directly to the transmitter on the master unit. Reversing, DR, expo, travel adjust, sub-trim and mixes are all ignored. If the slave programming is incorrect, the wrong signal will be sent to the model.
DX6i can only interpret PPM signals that contain less channels then the DX6i is transmitting. You can not use a DX6i master with a DX7 slave or a DX8 slave for example.
For Spektrum transmitters, buddy boxing allows the signal from a slave transmitter to be passed directly on to the transmitter module in the master transmitter bound to the model. This signal is only passed through while the trainer button is held.
The trainer PPM signal is sent though the audio cable when the transmitter is turned OFF and the audio cable is connected. If the transmitter is turned ON, the DX6i assumes it is the master and will read the audio cable IF and only IF the trainer button is pulled.
One problem is that the trainer signal needs to be interpreted by the master before sending it to the transmitter. As this is an analog signal, there is often a slight discrepancy between the PPM signal sent and the actual digital value transmitted. This is why a slave transmitter may need to be trimmed to prevent drift in the model being controlled.
Another problem is that you are relying on the master to interpret a PPM signal. A PPM signal mixes all channels into a frame that is regularly sent. Each channel is represented by a pulse from 1ms to 2ms in length within a set length frame. The DX6i can only interpret a maximum of 6 channels in the PPM frame, so transmitters with more channels confuse it. When confused, the DX6i does nothing (assumes the signal is faulty and does nothing).
The master is the only transmitter that should be sending a signal. Some people disconnect the slave from the transmitter module inside the case, this is not necessary.
Range checking, why and how
Range check is to ensure your model will not lose connection with the transmitter in the normal flying range.
As the antenna mounting on a model affects it's reception, it is wise to do a range test whenever the electronics in the model are altered.
Similarly, if you have to replace or alter the antenna in the DX6i, it is wise to redo a range check.
A range check reduces the signal power from the DX6i. During the reduced signal power, you should check the models responsiveness from a
The instructions for a range check are:
  1. With the model resting on the ground, stand 30 paces (approx. 90 feet) away from the model.
  2. Face the model with the transmitter in your normal flying position. Place the transmitter in the range test screen (“Setup List” Option 9 “Range check”) and pull and hold the trainer switch on the top of the transmitter. This causes reduced power output from the transmitter. (and the display to change “Check” from “INH” at “ACT”)
  3. You should have total control of the model with the trainer switch pulled at 30 paces (90 feet).
If the model does not respond, then you will need to diagnose the issue. Most common problem is antenna positions on the model. Another thing could be power to the receiver.
Seeing deflections on small models (such as a 450) at 30 paces can be difficult. Either have a closer spotter, or align the main blades so that you can see them easily (side on, not end on). Move from full positive collective to full negative collective, you should be able to easily see the main blades twist as their profile should change dramatically.
This takes less than a minute to do, so no excuses. (Better than a heli falling unexpectedly from signal failure - Fly-away should not occur. You set and tested your receiver fail-safe right!!)
Using you DX6i with a sim
I am not going to go into a lot of detail here.
I have two other works that cover Transmitter sim usage.
In short:
  • ALWAYS use HELI for the transmitter mode to a heli simulator.
  • Set up a separate DX6i model for the sim (and possibly a separate one for sim calibration).
  • Calibrate the sim to the DX6i BEFORE customizing the DX6i settings.
  • Recognise that all the DX6i can send to the simulator is the channel values (not the switch positions).
You are flying a simulator, best ones allow you to use the actual channels (so you can set throttle and pitch curves in the transmitter). Be in control of your DR and expo. Be in control of your pitch AND throttle curves. Let TH cut the throttle channel and real that.
Every function you could do in acro mode, you can do in HELI mode. You are flying a heli, best configure the control to be like a heli. If you then fly a plane, switch to a plane TX model. Allow your DX6i to be more than a dual joystick input, use the gyro channel for a switch. Let flight modes change the collective and throttle values.
You should not use your actual model parameters on the sim. The sim models have perfect setups. They do not need trim, sub-trim, travel adjust, CCPM mixing, etc. You could use your standard model setups (if your standard model is FBL, no sub-trim, travel adjust, etc...), but best not to.
Calibration allow the computer to “hone in” on the transmitter signals (minimum and maximum). For Calibration, the model should be completely default (all channels vary from -100 to +100). Once calibration is complete, then start altering channel values, curves, DR, etc. to you liking on the sim model.
Like the real model, the sim model does not see the switch positions on the transmitter. When to click TH or change flight mode, how does the model know these switches are thrown? By how the signals are changed (TH, drops throttle channel to a defined value. Flight mode changes the rates of change of throttle and collective, and possibly cyclic DR and/or gyro). The simulator is no different in this regard. Only by inspecting the values transmitted does it know what you are asking the model to do.
My other works cover all this in MUCH more detail.
Reference: “Simulator setup” (https://www.helifreak.com/showthread.php?t=538755)
Reference: “Phoenix Setup with DX6i step-by-step guide” (https://www.helifreak.com/showthread.php?t=561059)
See also “Why acro and heli modes (and why to never use acro for helis, even for simulators)” in this guide.
Learn to fly reference: “From tail-in to all 8s and funnels in 6 months” (https://www.helifreak.com/showthread.php?t=531380)
Adjusting stick tension
I found the default stick tension on the DX6i too loose. I like a more positive feel so I know where centre is.
To adjust stick tension, take the back off the DX6i and adjust the screws holding the springs on the back of the gimbals. This will alter how firm or loose the centre returns are.
You can also switch the throttle from ratchet to smooth (or vice-versa). I prefer smooth, some like ratchet (especially plane flyers).
Recalibration (the hidden menu)
Sometimes the sticks may not centre properly (especially after service). Or spring tension alteration. The video shows where to find the hidden menu to allow you to re-calibrate the DX6i's stick positions.
In short (if the video disappears). Turn off the DX6i, ensure all switches are at 0 and TH is ON. Squeeze the horizontal trims together (left pulled right and right pulled left) and while squeezed, turn on the DX6i. This enteres the calibrate mode. The three switches (elevator DR, flap, aileron DR) control the lower middle and upper values for each stick. Flick the elevator DR to 1, move both sticks to all extreems, then flick elevator DR to 0 (low set). Center the sticks and then flick the flap to 0, then back to 1 (middle set). Flick the aileron DR to 1, move both sticks to all extreems, then flick aileron DR to 1 (high set). TH off, then press the scroll wheel and the process is complete. Power off the DX6i.
Reference: “DX6i throttle problem?”(https://www.helifreak.com/showthread...51#post5367351)
Changing modes between Mode 1 and Mode 2 (Yes it is possible to do this properly)
The process involves telling the radio that the input signals for the gimbals has swapped. This is done though a hidden config menu. Follow the referenced videos to find where this menu is.
Next you will want to swap the auto-centre from one side to another. This is the most fiddly part of the operation.
As well as changing stick mode and auto-centre, you may need to change switch positions. “Mix/Throttle Hold” should swap with “Trainer/Bind”. “Gear/Flight Mode” should swap with “Rudder Dual Rate”. This can be done as there is enough slack in the cables to allow the switches to be unscrewed, swapped and re-screwed without any soldering required.
Reference: “Spektrum DX6i Change Mode 2 - to Mode 1 Procedure” (https://www.helifreak.com/showthread...034#post717034)
Reference: “Change Mode for your Spectrum DX6i Radio From MODE 2 to MODE 1” (http://storage.vuzit.com/public/5qp/...ode_change.pdf)
In case the reference PDF gets lost, to set the mode of the DX6i, go into the COPY/RESET in the SETUP MENU. Highlight and select reset. When the DX6i asks are you sure (no/yes), highlight "List" and switch the Aileron DR switch (front right) from 0 to 1 and back a few times. This will enter the Mode menu. You can select either Mode1 or Mode2 here. After selecting a mode, turn off the DX6i.
After changing a mode, you will need to change the spring from the newly selected throttle stick to the newly selected elevator stick and swapping the friction tensioner for the throttle. This requires taking the back of the transmitter. Screwdriver and bent nosed pliers should be enough to accomplish this.
References:
"1st U.S. R/C Flight School - Transmitter Handling” (http://www.rcflightschool.com/TransmitterHandling.pdf)
"From tail-in to all 8s and funnels in 6 months” (https://www.helifreak.com/showthread.php?t=531380)
"Simulator setup” (https://www.helifreak.com/showthread.php?t=538755)
"Phoenix Setup with DX6i step-by-step guide” (https://www.helifreak.com/showthread.php?t=561059)
"DR expo graphs” (https://www.helifreak.com/showthread...84#post4693084)
"Solving the DX8 spectrum mix setting mystery” (https://www.helifreak.com/showthread...51#post5370251)
"DX6i throttle problem?” (https://www.helifreak.com/showthread...51#post5367351)
"How to zero out pitch/roll/yaw rates at center sticks for the bad mainboards” (https://www.helifreak.com/showthread.php?t=462484)
"Horizon Hobby 130X Addendum on “Calibration and Troubleshooting” (http://www.horizonhobby.com/pdf/BLH3...l_Addendum.pdf)
"Pitch & Throttle Curves Explained” (https://www.helifreak.com/showthread...30#post3909330)
120SR setup, service and flying link for Newbies (https://www.helifreak.com/showthread.php?t=496890)
mCPX setup, service and flying links for newbies (https://www.helifreak.com/showthread.php?t=506789)
Old 11-22-2013, 11:02 PM   #4 (permalink)
Default Part 4
My Suggested Beginner Setups on the DX6i for Blade Helis
(Thank you to Imzzaudae for providing some setups)
MCX2 (coax)
  • Model Type: HELI
  • Model Name: MCX2
  • Swash: 1 SERVO 90°
  • D/R Combi: D/R SW: FM
  • Timer: 4:00 Trainer
  • ThroCur: (0,15,50,75,100 - 0,15,50,75,100 - 10)
  • PitcCur: (0,25,50,75,100 - 0,25,50,75,100 - 0,25,50,75,100)
  • Aile/Elev DR&expo: (80/20 - 100/20)
  • Rudd DR&expo: (100/0 - 100/0)
120SR(fixed pitch)
  • Model Type: HELI
  • Model Name: SR120
  • Mix1: Rudd Elev Act D-35% U-25% Sw:Gyro
  • Mix2: Rudd Aile Act L-40% R-10% Sw:Gyro
(note: See note on mSRX for mixes)
MSR (fixed pitch)
  • Model Type: HELI
  • Model Name: MSR
mSRX (fixed pitch - source: http://ganninger.de/DX6i-mSRX.pdf for mixes)
  • Model Type: HELI
  • Model Name: MSRX
  • ThroCur: (0,25,50,75,100 - 0,25,50,75,100 - 10)
  • Aile/Elev DR&expo: (70/15 - 100/0)
(note: Mixes only work when gyro switch in pos 1, Mixes provide a piro-compensation type affect in a stable hover.
With this setting, mixes only work when gyro switch in pos 1.
The mixes provide a piro-compensation type affect in a stable hover.
The way to test this is to get into a stable hover and push rudder momentarily full right (turn nose right) then adjust mix 1 first number and mix 2 first number till the heli does not travel when the rudder is momentarily pushed right.
Do the same again for pulling the rudder left and and adjusting the second numbers in the mixes.
Do over carpet in room with still air (no drafts, fans or air-con). Don't want to do damage while tuning this.
Normal for a FP heli to go forward and right with nose-right turn (and backward and left with nose-left turn)).
Nano CPX
  • Model Type: HELI
  • Model Name: NANO
  • D/R Combi: D/R SW: Rudd DR
  • Reverse: Pitch
  • ThroCur: (0, 40, 60, 80, 100 - 100, 100, 100, 100, 100 - 10)
  • PitcCur: (30, 40, 50, 75, 100 - 0, 25, 50, 75, 100 - 0, 25, 50, 75, 100)
  • Aile/Elev DR&expo: (60/30 - 85/30)
  • Rudd DR&expo: (85/0 - 100/0)
(When comfortable on DR 85, move to DR 100)
mCPX v1 or v2
  • Model Type: HELI
  • Model Name: MCPX
  • Reverse: Pitch
  • Aile/Elev DR&expo: (70/30 - 100/30)
  • Rudd DR&expo: (70/0 - 100/0)
  • Travel Adjust: Pitch 70% (up and down)
(You could remove pitch travel adjust and put in a pitch curve of (35, 42.5, 50, 69.0, 87.5 - 12.5, 31 ,50, 69, 87.5 - 12.5, 31 ,50, 69, 87.5). This has the same affect as pitch travel adjust, but allows the DX6i to over-drive the pitch settings if re-configured. I would recommend leaving the pitch travel adjustment).
mCPX BL
  • Model Type: HELI
  • Model Name: MCPX BL
  • Reverse: Pitch
  • Rudd DR&expo: (83/0 - 85/0)
130X
  • Model Type: HELI
  • Model Name: 130X
  • Reverse: Pitch
  • ThroCur: (0, 40, 60, 68, 75 - 100, 100, 100, 100, 100 - 10)
(When comfortable on DR 85, move to DR 100. Manual suggests 40 expo, but I am reluctant to advise more than 30 lest you lose the “feel” for corrections. If you need greater expo, I would suggest reducing DR unless you know what you are doing. ie. “extreme thumber” in which case you may be looking at a better transmitter as well)
(Only use sub-trim to alter main-board drift as outlined in “How to zero out pitch/roll/yaw rates at center sticks for the bad mainboards” (https://www.helifreak.com/showthread.php?t=462484) and the Horizon Hobby 130X Addendum on “Calibration and Troubleshooting” (URL="http://www.horizonhobby.com/pdf/BLH3780-Manual_Addendum.pdf).
450 3D (intermediate)
  • Model Type: HELI
  • Model Name: 4503DINT
  • Swash: CCPM 120
  • Swash Mix: A -100%, E -95%, P +85%
  • Reverse: Aile, Rudd
  • Travel Adjust: Rudd 90% (left and right)
  • Timer: 6:00 Trainer
  • ThroCur: (0, 56.5, 72.5, 72.5, 72.5 - 72.5, 72.5, 72.5, 72.5, 72.5 - 10)
  • PitcCur: (45, 51, 60, 73.5, 91 - 0, 25, 50, 75, 100 - 42, 46, 50, 75, 100)
  • Aile/Elev DR&expo: (50/7 - 75/15)
  • Rudd DR&expo: (77/0 - 77/0)
  • Gyro: 77.5% (norm), 76.0% (stunt) Sw:F.Mode
450 3D (advanced)
  • Model Type: HELI
  • Model Name: 4503DADV
  • Swash: CCPM 120
  • Swash Mix: A -100%, E -95%, P +92%
  • Timer: 5:00 Trainer
  • ThroCur: (0, 56.5, 72.5, 72.5, 72.5 - 100, 100, 100, 100, 100 - 10)
  • PitcCur: (45, 51, 60, 73.5, 91 - 0, 25, 50, 75, 100 - 0, 25, 50, 75, 100)
  • Aile/Elev DR&expo: (75/15 - 100/15)
  • Rudd DR&expo: (87/0 - 87/0)
(450 3D uses CCPM mixing. Be sure to check swash plate movement before flying).
300X
  • Model Type: HELI
  • Model Name: 300X
  • Reverse: Rudd, Pitch
  • ThroCur: (0, 50, 80, 80, 80 - 100, 100, 100, 100, 100 - 10)
  • Aile/Elev DR&expo: (75/0 - 100/0)
  • Rudd DR&expo: (75/0 - 100/0)
  • Gyro: 77.0% (norm), 77.0% (stunt) Sw:F.Mode
(300X uses the AR7200BX FBL unit. Sub trim should be 0, Travel adjust 0, expo settings can be done in the AR7200BX unit. My preference is to have expo in the TX and disable expo in the FBL unit (B. Control Behavior - default is Transmitter (Blue Solid)) as this can be adjusted easier as skills progress or as the need calls for it. In this case use 15 for expo as a start point on Aile/Elev (ie. (75/20 - 100/20) ).
450X
  • Model Type: HELI
  • Model Name: 450X
(450X uses the AR7200BX FBL unit. Sub trim should be 0, Travel adjust 0, expo settings can be done in the AR7200BX unit. My preference is to have expo in the TX and disable expo in the FBL unit (B. Control Behavior - default is Transmitter (Blue Solid)) as this can be adjusted easier as skills progress or as the need calls for it. In this case use 15 for expo as a start point on Aile/Elev (ie. (75/20 - 100/20) ).
500X
  • Model Type: HELI
  • Model Name: 500X
(500X uses the AR7200BX FBL unit. Sub trim should be 0, Travel adjust 0, expo settings can be done in the AR7200BX unit. My preference is to have expo in the TX and disable expo in the FBL unit (B. Control Behavior - default is Transmitter (Blue Solid)) as this can be adjusted easier as skills progress or as the need calls for it. In this case use 15 for expo as a start point on Aile/Elev (ie. (75/20 - 100/20) ).
Old 11-27-2013, 03:13 AM   #5 (permalink)
Epic! Great information
John
Old 11-27-2013, 08:19 AM   #6 (permalink)
+1
Thanks for taking the time to compile this!
Rick
Helifreak, the place to be!
rdlohr is online now        Reply With Quote Quick reply to this message
Old 01-01-2014, 10:43 AM   #7 (permalink)
Thumbs up Thanks
this is a great step by step exactly what i was looking for
tfast500 is offline        Reply With Quote Quick reply to this message
Old 01-02-2014, 05:59 PM   #8 (permalink)
this is awesome, thank you. I think I may have found a problem with my DX6I though. On the monitor screen, I do not get any Elevator movement? I dont get any movement on the servo either. It is set up on a Blade 300x. Any ideas? Do I have a dead radio?
Thanks!
Babies dad is offline        Reply With Quote Quick reply to this message
Old 01-03-2014, 03:39 AM   #9 (permalink)
Thanks!
If Elevator DR is not 0 (and swash type 1Servo90 - for 300x), could be a dead pot inside the transmitter (for the gimbal), or the wire from the pot to the circuit board is disconnected/broken/damaged.
Easiest test for pot / connection is make a new heli model, set swash type to ccpm120 and move the elevator while looking at the monitor screen. pitch aileron and elevator should all move. If none do, then it's a pot / circuit board connection issue.
Another test would be to re-calibrate the sticks. If the elevator values even for top, middle, bottom, then it is definitely a pot / connection issue.
My best advice is to have the DX6i serviced (or looked at by the LHS).
Old 01-05-2014, 02:10 PM   #10 (permalink)
This was extremely helpful! Thanks for taking the time to put this guide for us noobs together. Much appreciated.
envy662 is offline        Reply With Quote Quick reply to this message
Old 01-05-2014, 11:26 PM   #11 (permalink)
Default very helpful, thanks
Yah, I figured out to program my Dx6i on my own, then found this thread. Would have saved me a couple hours.......
danbob is offline        Reply With Quote Quick reply to this message
Old 01-11-2014, 09:59 AM   #12 (permalink)
Default Dx6i / 300X Settings
Hello,
Need to ask about your listing "Pitch Reversed" for the 300X settings in the Nubie guide for the DX6i as the manual states "No" for Pitch reverse.
Thanks and Regards
Jeff
DrumDog is offline        Reply With Quote Quick reply to this message
Old 01-11-2014, 06:49 PM   #13 (permalink)
Originally Posted by DrumDog View Post
Hello,
Thanks and Regards
Jeff
You are correct. It should be Reverse for Elevator and Rudder (not Pitch). I also corrected the throttle curve (as it was a direct copy of the 450X settings).
Hope this helps people.
300X (as it should be)
  • Reverse: Rudd, Elev
  • ThroCur: (0, 25 ,50 ,60 ,70 - 75, 75, 75, 75, 75 - 10)
Originally Posted by ArchmageAU View Post
300X
  • Model Type: HELI
  • Model Name: 300X
  • Aile/Elev DR&expo: (85/0 - 100/0)
(300X uses the AR7200BX FBL unit. Sub trim should be 0, Travel adjust 0, expo settings can be done in the AR7200BX unit. My preference is to have expo in the TX and disable expo in the FBL unit (B. Control Behavior - default is Sport (Red Flasing), I would recommend Transmitter (Blue Solid)) as this can be adjusted easier as skills progress or as the need calls for it. In this case use 15 for expo as a start point on Aile/Elev (ie. (85/15 - 100/15) ).
Old 01-22-2014, 04:26 PM   #14 (permalink)
I'll just add my name to the "thinks this is an AWESOME thread" list.
This, and all your other posts have been a tremendous help with my new DX6i and my helis.
Thanks!
Blade 450x V2, Nano CPx, 120SR, mCX2, Scout, DX6i. Just assume I have others, I probably won't update this every time I get a new heli... ;-)
jbrandt is offline        Reply With Quote Quick reply to this message
Old 01-26-2014, 04:19 PM   #15 (permalink)
Default THX
Thanks I was just looking for this kind off info.
Sali is offline        Reply With Quote Quick reply to this message
Old 01-28-2014, 09:41 AM   #16 (permalink)
Definitely awesome thread thank you
Sent from my SCH-I535 using Tapatalk
BigBlue2012 is offline        Reply With Quote Quick reply to this message
Old 01-28-2014, 11:23 PM   #17 (permalink)
TLDR
Bubba
Goblin 700
Jeti DS-16
Bubbasanjohn is offline        Reply With Quote Quick reply to this message
Old 01-28-2014, 11:24 PM   #18 (permalink)
Seriously that is really a great job
Bubba
Goblin 700
Jeti DS-16
Old 02-05-2014, 04:27 PM   #19 (permalink)
Default Thank You
MCX2 (coax)
  • Model Type: HELI
  • Model Name: MCX2
120SR(fixed pitch)
  • Model Type: HELI
  • Model Name: SR120
MSR (fixed pitch)
  • Model Type: HELI
  • Model Name: MSR
  • Model Type: HELI
  • Model Name: MSRX
Nano CPX
  • Model Type: HELI
  • Model Name: NANO
  • Reverse: Pitch
mCPX v1 or v2
  • Model Type: HELI
  • Model Name: MCPX
  • Reverse: Pitch
mCPX BL
  • Model Type: HELI
  • Reverse: Pitch
130X
  • Model Type: HELI
  • Model Name: 130X
  • Reverse: Pitch
  • Model Type: HELI
  • Swash: CCPM 120
450 3D (advanced)
  • Model Type: HELI
  • Swash: CCPM 120
300X
  • Model Type: HELI
  • Model Name: 300X
  • ThroCur: (0, 30, 60, 60, 60 - 100, 100, 100, 100, 100 - 10)
450X
  • Model Type: HELI
  • Model Name: 450X
(450X uses the AR7200BX FBL unit. Sub trim should be 0, Travel adjust 0, expo settings can be done in the AR7200BX unit. My preference is to have expo in the TX and disable expo in the FBL unit (B. Control Behavior - default is Sport (Red Flasing), I would recommend Transmitter (Blue Solid)) as this can be adjusted easier as skills progress or as the need calls for it. In this case use 15 for expo as a start point on Aile/Elev (ie. (85/15 - 100/15) ).
500X
  • Model Type: HELI
  • Model Name: 500X
(500X uses the AR7200BX FBL unit. Sub trim should be 0, Travel adjust 0, expo settings can be done in the AR7200BX unit. My preference is to have expo in the TX and disable expo in the FBL unit (B. Control Behavior - default is Sport (Red Flasing), I would recommend Transmitter (Blue Solid)) as this can be adjusted easier as skills progress or as the need calls for it. In this case use 15 for expo as a start point on Aile/Elev (ie. (85/15 - 100/15) ).
The fact that you put all that out there for new to helicopters is awesome and I thank you very much. I am in the process of trying to get a Dx6i now and hope to have it soon. This is almost overwhelming the information but I am slowly digesting it.
Thank you again.
I used to live in Templestowe when I was a kid. I miss it. Vic is a great place. Brother live s in Glenelg SA
Scott
swells is offline        Reply With Quote Quick reply to this message
Old 02-06-2014, 01:17 PM   #20 (permalink)
okay this is great work and Thank you so much! but its a little tech heavy and i need some clarification.
Assume that all variables are the same and 0 is stick center and servo center.
I need clarification on throttle throw and DR. NOT EXPO! so expo at 0 or INH
so if Throw for any given channel is set at 100%, and DR is set at 80%, then you get 80% movement of the servo
you can produce the same exact result by:
Throw @ 80%, and Dr at 100%, getting again 80% movement of the servo.
Is this true?
don't talk about expo. i get it. i just want a clear simple answer to this. not all the technical of whats doing what. Will this give you the same desired result? KISS
Katstrike is offline        Reply With Quote Quick reply to this message
