Old 01-22-2008, 08:24 PM   #1 (permalink)
Team Taco VP
Default Logo500 3D Build Videos
OK so finally starting my build videos for the Logo500!
Woo hoo!
Still waiting for some things to arrive but I am going to get started anyway.
And here we go!
Kit overview & manual
VIDEO -> Logo500 3D overview (14 Megs)
Frame Build Part 1
VIDEO -> Logo500 Frame Build Part 1 (52 Megs)
Frame Build Part 2
VIDEO -> Logo500 Frame Build Part 2 (55 Megs)
Tail Assembly Part 1 - Tail Shaft
VIDEO -> Logo500 Tail Assembly Part 1 - Tail Shaft (30 Megs)
Tail Assembly Part 2 - Tail Slider
VIDEO -> Logo500 Tail Assembly Part 2 - Tail Slider (36 Megs)
Tail Assembly Part 3 - Thrusted Tail Rotor
VIDEO -> Logo500 Tail Assembly Part 3 - Tail Rotor (42 Megs)
Tail Assembly Part 4 - Tail Assembly
VIDEO -> Logo500 Tail Assembly Part 4 - Final Tail Assembly (44 Megs)
Next step... This is NOT following the manual and I am changing the manual build order for video reasons!
Swash and Washout
VIDEO -> Logo500 Swash and Washout Assembly (49 Megs)
OK trying to get this done but I am waiting on electronics!
Anyway as I have said through out this video I am doing steps differently than how the manual flows for both video reasons and other reasons (like waiting on electronics )...
Head and Main Grips
VIDEO -> Logo500 Head and Main grips (69 Megs)
Seesaw and Flybar
VIDEO -> Logo500 Seesaw and Flybar (76 Megs)
Main Gear and Main shaft
NOTE: I did not show installing the boom and belt in this segment for video reasons. I am showing iinstalling the main gear now as it needs to be in place for head setup! I will show belt and boom install later
VIDEO -> Logo500 Main Gear and Main Shaft Install (36 Megs)
Servo Install and Servo Setup
VIDEO -> Logo500 Servo Install and Setup (80 Megs)
Head and Linkage Setup
VIDEO -> Logo500 Head Setup (69 Megs)
Tail boom and tail servo install
VIDEO -> Logo500 Tailboom and tail servo install (67 Megs)
Landing Gear
VIDEO -> Logo500 Landing Gear (21 Megs)
Motor and Pinion install
VIDEO -> Logo500 Motor and Pinion Install (28 Megs)
Curtis Soild-G gyro and tail servo setup
VIDEO -> Logo500 Tail setup using the Solid-G gyro (49 Megs)
For a complete 100% step by step walk through of the Solid-G please see this link here as well.
Video Link ->Curtis Youngblood Solid-G Gyro - "Stick / Radio" Setup NOT using the G-view (67 Megs)
Video Link ->Curtis Youngblood Solid-G Gyro - Setup "Using the G-View" Setup (43 Megs)
Video Link ->Curtis Youngblood Solid-G Gyro - G-view Advanced Settings (55 Megs)
Kontronik 80-6-18 setup
VIDEO -> Logo500 Setting up the Kontronik Jazz 80-6-18 (41 Megs)
FINAL build step.... Electronics placement overview
VIDEO -> Logo500 Eectronics placement (20 Megs)
FIRST Flight test
VIDEO -> Logo500 First flight demo (20 Megs)
Enjoy,
Bob
Old 01-22-2008, 08:28 PM   #2 (permalink)
Nice Bob, looking good so far!
Mikado Heli
Scorpion Motors
Western Robotics RC,
Youth Generation Electronics
Old 01-22-2008, 11:48 PM   #3 (permalink)
epl
Team Taco Member
Suhweet! I look forward to this Bob as i'm just waiting for W2's to arrive and a Logo500 shortly thereafter. Your timing is perfect.
Logo 500SE Vbar, Jive100LV, BLS451, BLS251, Edge 553
Logo 600SE Vbar,Jive 120, BLS451s, 9254, 5020-450 10S
T 700 Vbar , YS91SR , Hatori SB19 , DS8717 , AR7100R , Radix 710
epl is offline        Reply With Quote Quick reply to this message
Old 01-23-2008, 02:35 AM   #4 (permalink)
Just a guy and his heli....
LITHIUMSTATIC is offline        Reply With Quote Quick reply to this message
Old 01-23-2008, 06:16 AM   #5 (permalink)
Great videos Bob - I found on my second frame assembly that it was worth installing the tail and elevator servos before putting the frames together as screw access is a little tricky later. We also had some concerns about some of the frame bolts not being long enough to engage the nylon locking collar on the nuts - did you find this ? Also what d'ya think about putting a dab of goop on the idler pulley bearings as rotating in this could melt the plastic pulley ?
John
Old 01-23-2008, 08:26 AM   #6 (permalink)
I LOVE the look of this kit and have seriously thought about getting one. Thanks Bob! Now Im gonna have to get one!!! LOL
Currently Flying!
Logo 400 V-Bar: Hacker A40-12S, Jive80, 9650s, BSL241, 6s1p 3300 Lipo
Lepton EX Installed in Airwolf: Hacker A30-12XL, CC80, 3102s, 401/9257, 6s1p 3300 A123
Retired Helis - Blade CX, Blade CPP, TRex450SE,
cybinary is offline        Reply With Quote Quick reply to this message
Old 01-23-2008, 08:26 AM   #7 (permalink)
Yeah, it's a great start! I wish Shawn had mentioned sanding the frames to me My AR7000 satellite wire was neatly snipped off by one of those edges...
As far as the elevator servo, I still don't know a good way around it. If you install it too early, then there's no way to get it centered later. I installed it early, then had to pull it, center it while it was hanging loose, then install it again.
John
Logo 600 3D V-Bar, Jazz 55-10-32, Tango 45-7, 0.7/13T, BLS451/BLS251, JR R921, Maniac623
Logo 500 3D V-Bar, Jive 100+LV, Scorpion HK-4020-1100, 0.7/15T, S9452/S9256, AR7000, RT560
T-Rex 600 CF, Jazz 80-6-18, Neu 1515/2.5D/F/H, 11T, S9451, ds760/S9254, AR7000, Radix600
T-Rex 500 CF, stock ESC/motor/rotors, 13T, HS-5245MG, ds760/S9254, JR R921
th3tick is offline        Reply With Quote Quick reply to this message
Old 01-23-2008, 09:11 AM   #8 (permalink)
Great, Bob!
Will there be a VBar setup video in the near future maybe?
Mathias
Lynx Oxy 3 | JR XG14
Mathias is offline        Reply With Quote Quick reply to this message
Old 01-23-2008, 12:32 PM   #9 (permalink)
Yeah been checking in for this every day for kinda the last 4 weeks.
Getting my logo 500 end of feb so really glad to have the vids..
Daniel
doeni is offline        Reply With Quote Quick reply to this message
Old 01-23-2008, 12:55 PM   #10 (permalink)
Something I've found with my 6003D kit is I couldn't get the main shaft to slide in without a lot of force. I loosened the mainshaft bearings slid the mainshaft in and then tightened the bolts holding the mainshaft bearing. Problem solved.
Some of my frame bolts were to short and didn't protrude through the nylon nuts fare enough. Mainly it was the 4 bolts holding the mainshaft bearing in. I got some longer bolts from my LHS made by Dubro.
Yes I wish I had known to sand the frames as I had a couple of wires get cut. On my second build I sanded them with 400 grit and all is happy.
Old 01-23-2008, 05:42 PM   #11 (permalink)
Team Taco VP
I didn't notice any issues with bolts going into the nylock.... Are you sure the nuts were seated? Some of them don't seat right and you have to fiddle to get them in place. Maybe my kit has longer bolts now?
Bob
Old 01-23-2008, 05:49 PM   #12 (permalink)
A lot of us were seeing the bolts being a little short so maybe Mikado has changed that in the more recent kits. The bolts on mine are just barely touching the nylock but there seems to be enough pressure on the bolt and friction from the plastic to hold it in place so I ended up just leaving it this way. So far after 30+ flights there seems to be no change.
Logo 500 3D /Scorpion HK4020-1100KV (16T)/Jazz80/BLS451/Spartan DS760/BLS251/RT 560mm/AR9000
TRex 450SE
/Scorpion HK-2221-8 (13T)/ AlignESC35(X)/ HS65MG/Spartan DS760/S9650/AR6100
Spektrum DX7
BruceW is offline        Reply With Quote Quick reply to this message
Old 01-23-2008, 06:07 PM   #13 (permalink)
Team Taco VP
Well I do notice some of the bolts do NOT come out the nut completely.... so yea... Some of them might be about 2/3rds way into the nylock... For the frame I think this is good enough based on checking them? Did anyone on you have them back out?
Bob
Old 01-23-2008, 06:24 PM   #14 (permalink)
The Capi
Bob, To Vbar or not to Vbar ? Whats your initial impression of the kit being as its unusual construction.
Old 01-23-2008, 06:53 PM   #15 (permalink)
Team Taco VP
V-bar honestly will be a NEW thing for me... I want to do it myself but it's not in my pocket range right now... I bet I will be getting into it this year for sure! Not sure WHEN right now BUT I will do this. I am sure I will just don;t know when!
Bob
Old 01-23-2008, 07:38 PM   #16 (permalink)
Bob
Danny Jetschin said in the Mikado forum a while back that his are a liitle short too but never had a problem with it being this way. I bought longer ones for peace of mind as I'm sure others did for the same reason.
Nice vids by the way. I wish I had someone walk me through the process, but I got lucky and got to be an early guini pigs for the 6003D....
Old 01-23-2008, 09:10 PM   #17 (permalink)
Well, I suppose it will be a 2 part review, with and without, flybar that is.
Flybarless Bob is offline        Reply With Quote Quick reply to this message
Old 01-23-2008, 11:28 PM   #18 (permalink)
Bob
Mine were definitely seated OK and not into the nyloc at all - DJ commented on this and said don't worry and I haven't had any troubles. See Post # 96 https://www.helifreak.com/showthread.php?t=47241&page=4
John
Old 01-24-2008, 02:54 AM   #19 (permalink)
Team Taco VP
UM Ok I am about to post new vids... but why is my belt BLACK? Do I need to worry about static?
Bob
Old 01-24-2008, 03:07 AM   #20 (permalink)
Bob
The 600 has a yellowish belt.
Static? I wouldn't worry about it unless your running a CC85HV. I run a Jazz 55 and it's the hot ticket on my 600. You may want to try a Jazz 80.
