Go Back   HeliFreak > R/C Electronics Support > Gryphon Electronics
Gryphon Electronics Gryphon Electronics Factory Support Forum
Old 12-07-2013, 06:07 AM   #1 (permalink)
Default Polaris and capacitator
Dear All,
Can I use a capacitator together with the Polaris BEC or will it damage the BEC at startup?
Just looking for a way to secure the power for the servo and a stress relieve for the BEC. I am using one in my 450 and Gaui X5.
Regards,
Menno
Gaui X3 HW 50A V3 OMG H1/H2 Servo's BL450MX Mini-V (M.I.A.)
Gaui X5 FES Polaris BEC BLS451/251 Silverline V-Bar Formula Swash/Head
JR Forza 700 Scorp 160A opto + 4525 520 JR NX8925/SLG01 Vbar Neo
JR XG14 PL8 v2
mverhorst is offline        Reply With Quote Quick reply to this message
Old 02-24-2015, 04:42 PM   #2 (permalink)
Old thread but good question. I have heard of Capacitors hurting BECs, is that true?
Pard is offline        Reply With Quote Quick reply to this message
Old 02-25-2015, 01:34 AM   #3 (permalink)
Old thread indeed... Nobody seems to knew back than.
I still don't use any caps. I did go from specky sats to JR Xbus and Futaba BLS451/251 on my X5 which made me feel I don't need the caps...
No issues to date.
JR XG14 PL8 v2
Old 02-25-2015, 03:46 AM   #4 (permalink)
No issues to date.
For sure, Vbar and sats are the most common source of trouble. I think caps can damage a BEC. They seem to have done that to my Talon 35 BEC. The solution is just a better setup as you describe, not just adding caps. I think.
Old 02-25-2015, 08:54 AM   #5 (permalink)
I think so to. Empty caps act like a short circuit for a split second as the current rushes in...
The bigger the caps, the bigger the amp spike.
JR XG14 PL8 v2
Old 02-25-2015, 12:36 PM   #6 (permalink)
No exactly clear, but here is what WR responded to my inquiry:
It is not recommended to place large capacitance capacitors near the BEC terminals or any other supply as it does not require it.
Having a certain type of capacitance added or remove can affect ESR, ripple current rating, rated life and current surge.
Western Robotics Information
WR_logo Western Robotics Ltd.
#215-12837 76th Avenue
Surrey, BC V3W2V3
Canada
Phone: 778-565-1332
www.western-robotics.com
[email protected]
Old 02-25-2015, 04:44 PM   #7 (permalink)
Surrey, BC V3W2V3
Canada
Phone: 778-565-1332
[email protected]
With the BEC powered off the caps will loose there charge and become empty in a split second.
The moment you plug your flight pack in the BEC will charge the empty caps (same as the cap in you ESC, some will give quite some spark when pluging in your packs).
An empty cap acts like a short circuit for the split second the cap is empty and your BEC powers on...
JR XG14 PL8 v2
Old 02-25-2015, 04:52 PM   #8 (permalink)
Makes sense.
I wonder why caps have become so recommended in the forums if they can cause the whole BEC to fail.
Not a great solution to brownouts if it can cost you a complete power failure. Mikado even seems to recommend them, which is particularly odd.
http://www.vstabi.info/en/node/1327
My solution is to just use expensive BECs from now on.
Old 02-26-2015, 01:27 AM   #9 (permalink)
I quess it comes down to common sense agian.
If you have trouble a cap vould help but don't go overboard and use to much to big...
Iv'e seen 2S lipo's have voltage errors on a Vbar due to servo back EMF, it could happen to any setup and is IMO more servo related then BEC...
JR XG14 PL8 v2
Old 02-26-2015, 04:05 AM   #10 (permalink)
You are most likely correct, as demonstrated here:
http://www.vstabi.info/en/node/1422
That said, how do you decide if it is the servos or not without special gear? I like the high performance value servos, like KST, which may be the problem. I have to get over that habit ...
Vbar seems to be most sensitive to this effect. I never have problems with Ikon, Vortex, Skookum, just vbar.
Old 02-26-2015, 09:54 AM   #11 (permalink)
I quess try your system, if errors occur, disconnect the servo's and try again...
Vbar indeed seems more sensitive to the these problems...
That being said, there are some servo manufacturers that are known for these problems and there are some known for there low and nice amp draw...
JR XG14 PL8 v2
Old 03-01-2015, 07:00 PM   #12 (permalink)
More from WR:
If you want to use the large capacitors, we recommend you to use our Battery Buffer unit, this will prevent the capacitor from feeding back any power back to the BEC.
http://www.western-robotics.com/battery_buffer_hp.html
Regards,
Surrey, BC V3W2V3
Canada
Phone: 778-565-1332
[email protected]
Old 03-03-2015, 01:29 PM   #13 (permalink)
FWIW on one of my Trex 450 standard 325 baldes, 4 TGY 306HV servos, using mini vbar.
Running the Polaris at the lowest voltage I still need a capacitor or I can brown it out on the bench. So I will keep the capacitor in line. With the capacitor, I still cannot even get 6V without brownouts.
I think the biggest factor is running the BEC off of 6s instead of 3s
Old 03-03-2015, 01:47 PM   #14 (permalink)
I have posted on Aerodynamics, Physics and Engineering for exactly this kind of situation:
https://www.helifreak.com/showthread.php?t=676587
Capacitors can upset a BEC and potentially destroy it. Not all BECs suffer in the same way and your system may be better or worse with the combination of RX, FBL, Servos etc. that you use.
External (to the BEC) capacitor(s) do not just cause problems at start up. They upset the fundamental arrangement inside a switching BEC regulator (sometimes even linear types too). This could make the internals unstable at a high speed (not seen by simply measuring the DC voltage). The inevitable stress and heating in this scenario causes the damage.
The purpose of the inductor in my post is to electrically separate the external capacitors from the control loop in the BEC. That way you can have your capacitors, avoid the brown outs and keep the BEC happy.
helicopters - levity whilst avoiding gravity?
Nano-CPX, MCPX BL, T-rex 450 Sport V2 now FBL, T-rex 600E PRO/Vbar
gorlandheli is offline        Reply With Quote Quick reply to this message
Old 03-03-2015, 01:57 PM   #15 (permalink)
You lost me. So what is safe to use?
Old 03-04-2015, 04:09 PM   #16 (permalink)
I have about the same setup but 3S, works like a charm.
JR XG14 PL8 v2
Old 03-04-2015, 04:53 PM   #17 (permalink)
Short answer is nothing...
You can use capacitors with a risk of malfunction.
If you want capacitors without risk of malfunction you would need to add an inductor between BEC output and capacitors e.g.
RED wire from BEC -> Inductor -> Caps "+" terminal -> rest of circuitry
BLACK wire just as before but include connection to Caps "-" terminal
Adding the inductor is awkward and adds weight but can be done. Otherwise it is a case of buy an appropriately rated BEC from the outset.
Old 03-04-2015, 04:58 PM   #18 (permalink)
