Go Back   HeliFreak > R/C Helicopter Support > Compass Helicopters > Atom 6HV, 6HVU and 550 Ultimate
Atom 6HV, 6HVU and 550 Ultimate Compass Atom 6HV, 6HVU and 550 Ultimate Model Helicopter Discussion
Like Tree11Likes
Old 02-18-2016, 02:24 PM   #481 (permalink)
This is one sweet photo spread! Thanks for sharing! Looking to pick up a 6HVU asap!
Originally Posted by cyclo View Post
A few pics of the 550U in action... Some I already posted in the 550U build thread.
Team Pilot: Hitec USA~ KBDD Blades~ XOAR Propellers (media and team pilot)~Scorpion Power
volcomsnows2k is offline        Reply With Quote Quick reply to this message
Old 02-20-2016, 12:44 PM   #482 (permalink)
Thanks volcomsnows2k! I am pretty sure you will love the 6HVU. I might convert my 550U to a 6HVU in the distant future but I like it the way it is right now.
A few pics from this morning... I installed Chronos CF struts on the 550U and this paid off this morning after a botched mini-auto (it was very windy) that caused the 550U to bounce twice before landing on its side. No damage whatsoever though except for scratches on the tip of the main blades.
ID:	636430   Click image for larger version
ID:	636431   Click image for larger version
KBDD Team Pilot
Compass Chronos | 7HVU | 550U | Atom 500 | Oxy 5 HF | Gaui X3 #1 | X3 #2
cyclo is offline        Reply With Quote Quick reply to this message
Old 02-23-2016, 04:39 PM   #483 (permalink)
Compass Model - MTTEC - MKS - Spartan RC
My Compass online store: www.helicoach-shop.de
Keven Schauz is offline        Reply With Quote Quick reply to this message
Old 02-23-2016, 06:26 PM   #484 (permalink)
Wow Kevin that pic should be on the cover of Compass magazine
Your is my Bread and Butter.
Compass Field Rep/KBDD Team pilot/Experiencrc.com
sewerfly is offline        Reply With Quote Quick reply to this message
Old 02-24-2016, 04:01 AM   #485 (permalink)
Just rebuilt a 6hvu from a 550...
Insane config to make speed with :
Scorpion 4235 nickmaxwell
YGE 120hv
14s 3300mah 35c (turnigy compact)
RJX servos
Brain
Rail 626mm
Ms composit 96mm
4380g RTF (with lipos)
OXY rep/Lynx team pilot
T700EDFC-RAPTORE700-GOB570-550ULTIMATE-PROTOS500-OXY3
Stoparach is offline        Reply With Quote Quick reply to this message
Old 02-26-2016, 12:12 AM   #486 (permalink)
RAM
Talking
Here's almost the whole family. My helis are on the left and right and Ah Clem's are in the middle.
ID:	637339   Click image for larger version
Goblin 700C || Logo 500 & 550 SE || Compass Chronos || Compass 550U || VBar Control
Rage RC Field Rep
RAM is offline        Reply With Quote Quick reply to this message
Old 02-27-2016, 08:23 PM   #487 (permalink)
YGE 120hv
RJX servos
Brain
Rail 626mm
Ms composit 96mm
Wow. I wanted to do something similar. I competed in the rchn speed cup with my 6hvu and took 1st in class 2 but that was just with a 4225 on 12s. I ran 2800 headspeed. What do you plan on running? I bet that power system would push it to 3200 or so. Not sure what the heli can handle. Definitely put some tiny tail blades on it so the tail doesn't explode. You could also put the 7hvu rear pulley on it to slow the tail ratio down.
Q700
RCHN #232
quinn is offline        Reply With Quote Quick reply to this message
Old 03-01-2016, 03:41 AM   #488 (permalink)
Default THE 6HV ULTIMATE PICTURE THREAD
I see your results in rchn speed cup.
This motor is insane for this model.
Lipos turnigy compact do the job but these are weakness of the setup... The only alternative is Thunder power 3300 7s, but not the same price!
I run 2800 too @80% gov store with 12T pinion.
I can reach 3300 @ 100% but I don't what an explosion... 2800 is a good enough for training and for these blades. I think limits are the blades not mechanic.
Currently I have to cure a cyclic shaking problem on elevators when I start curves at the end of the run.
I'm thinking about reducing Integral gain on elevators on the brain... P gain reducing doesn't work.
Old 03-01-2016, 04:09 PM   #489 (permalink)
Yeah even though I took 1st, my speed wasn't really all that impressive. Somewhere around 110mph I think. Fast for a 600 but there was definitely room to go faster. I decided to compete the day of the competition so all I really did was swap a pinion and tape up the canopy a bit. Also the only decentvspeed blades i found at the funfly were rail 606's, so 626's will definitely make a big difference. I was also using really tired packs. Even though I was running 2800, I'm sure it was sagging down to at least 2400. The only part that would really worry me at higher headspeeds (above 3000) would be the main pitch links popping off. Make sure you have the updated beefier link ends and only pop them on once. As soon as you pop them back off, they don't feel quite as tight. When you set tracking, just use a really good digital guage and hold the link against the ball without popping it on to check the angle. As for the spindle bolts holding up, I'm sure it's not an issue since the 7hv uses the same design and it can handle 700 blades overspeeding to 2800 or so.
Also, just so you know, justin runs the r5 with rail 626's as high as 3400 or so I think so I wouldn't worry about the blades. I really think the only 2 weak points are gonna be pitch links and the tail assembly. Just use really small tail blades. You don't need alot for speed. I think I ran 76mm or something. Also testing the limit of the pitch links should be easy. Just remove the blades and spool up to your max speed and work the collective and cyclic. Of course stand back while you do it.
Q700
RCHN #232
Old 03-02-2016, 02:18 AM   #490 (permalink)
In fact I don't use my 6hv to make pure speed, It's more for "dynamic speed flying" with a lot of curves and loops at high speed. So I don't search super high rotor speed. 2800-2900 is already very impressive for this use. This needs a lot of gov room and not too little tail blades to avoid tail stall with fast and hard motor loading, especially in the bottom of hard loops.
A video of "dynamic speed flying" with my oxy 8s (I would like to do this style of flying in 600 size...), sorry for a little out of subject...
Oxy 3+ cube stretched triblabe 8s @4350 rpm (3 min 57 sec)
Old 03-02-2016, 10:27 AM   #491 (permalink)
Ah, ok. I thought you were just doing speed runs.
Q700
RCHN #232
Old 03-06-2016, 03:16 PM   #492 (permalink)
Red and blue canopy! Funny how different colors and lines makes the canopy look like it changed to a more streamlined shape but in reality it hasn't. Same shape as the lime green canopy.
ID:	639118   Click image for larger version
ID:	639119   Click image for larger version
Rush fan is offline        Reply With Quote Quick reply to this message
Old 04-22-2016, 06:33 PM   #493 (permalink)
550U build
[IMG][/IMG]
[IMG][/IMG]
Protos Max 700-800 / Mikado 690SX-550SX-480XX / Goblin 500-380 / Compass 550U / Trex 550L, 500L / Oxy 3
-- Lynx Heli Team Pilot --
Jeti -- Kontronik -- VControl/Neo -- Pulse
rcompton is offline        Reply With Quote Quick reply to this message
Old 04-23-2016, 03:41 PM   #494 (permalink)
FreerideDD is offline        Reply With Quote Quick reply to this message
Old 04-23-2016, 03:55 PM   #495 (permalink)
Nice pics gentlemen! rccompton, it appears I found the long lost brother of my 550U
KBDD Team Pilot
Old 04-23-2016, 10:49 PM   #496 (permalink)
Agreed! Gotta love those KBDD blades with the 550 canopy.
Old 05-07-2016, 02:55 PM   #497 (permalink)
Spring is here.
KBDD Team Pilot
Old 05-09-2016, 08:51 AM   #498 (permalink)
Awesome photos man!
Rapid Helis Australia
Lighty is offline        Reply With Quote Quick reply to this message
Old 05-09-2016, 05:15 PM   #499 (permalink)
Originally Posted by Lighty View Post
Awesome photos man!
Thanks! I am eagerly awaiting pics from your new camera
KBDD Team Pilot
Old 05-13-2016, 10:06 AM   #500 (permalink)
Wanted to show off my 6HV U
3869g flying weight, of which
- 157g canopy (why so big?)
- 1043g battery (Nanotech 3300 35C 6s 2)
The battery packs are placed about 1cm forward from the back of the tray, so I may try bigger next time (will Turnigy 3600 30C work?).
Futaba BLS272 servos, Xpert 2202T on tail
HobbyWing 100HV and 10A UBEC
Savox BSM 4760 530kV
R2 50F cap buffer
UniSens-E
Spirit Pro
Really pleased with the electronics. The ESC is probably slightly over-rated for my current flight style, but I'd prefer that to under-rated. The Savox motor is performing excellently; plenty enough power so far and quite a bit lighter than the Scorpion 4035.
You may notice how I've installed the reciever antennas on the rear strut. Seems good. According to the logs the telemetry signal is a little weak and drops out sometimes but the control reception is excellent.
Only negatives:
- I've had a couple of issues programming the UniSens-E and MZ-24, but got it working eventually
- The canopy is humongous... I may try the 550 version at some point, even with a 12s battery
- My bird's nest of wires under the battery tray (I may remove the anti-spark since the XT90-S anti-spark is working fine)
Bonus pic
ID:	651938   Click image for larger version
ID:	651939   Click image for larger version
ID:	651965   Click image for larger version
ID:	651966   Click image for larger version
Compass 6HVU, XLPower 520, Chase 380
cycled is offline        Reply With Quote Quick reply to this message
