Go Back   HeliFreak > Multi Rotor Support > Blade Multirotor Support > 180QX
180QX Blade 180QX Helicopters Information and Help
Old 12-14-2013, 01:16 AM   #21 (permalink)
Blade Forum Support
Default Re: How to calibrate the 180QX with video
Originally Posted by flying-llama View Post
In posts 477 and 478 of the large RCGroups thread on the 180QX,
http://www.rcgroups.com/forums/showt...2#post26894074
the posters mention receiving a similar but slightly different set of calibration instructions from Horizon Hobby. They were asked NOT to post the instructions (that they received) in forums (I think that Horizon Hobby is still working on finalizing the instructions). The instructions that they received may be better at dealing with drifting.
One possibility for these slightly different sets of instructions: Horizon Hobby support may have given different people (at different times) slightly different sets of instructions as they try to figure out which set of instructions will both work and be easy to follow.
I did notice that. That is why I said in the video I didn't think that Horizon hasnt really release anything yet.
Be blessed
Isaac
Sent from my Galaxy Nexus using Tapatalk
Jesus Rep Its all Good,Its all GOD
FPV Everything Now
GOD BLESS
tntburnett is offline        Reply With Quote Quick reply to this message
Old 12-20-2013, 01:35 AM   #22 (permalink)
Originally Posted by angeliak View Post
I just spoke to HH about the calibration of 180QX. There is indeed a procedure to follow so as to make the calibration. Here it is folks :
BLADE 180QX CALIBRATION PROCEDURE :
(a) SWITCH ON TRANSMITTER
(b) PUT THROTTLE TO "FULL"
(c) PUSH RIGHT STICK "FORWARD" AND KEEP HOLDING IT THERE
(d) CONNECT BATTERY TO 180QX - LED WILL FLASH BLUE-RED-BLUE-RED
(e) LET GO OF RIGHT STICK
(f) LEAVE FOR ABOUT 15-25 SECONDS AND THEN THE LED WILL FLASH AGAIN : solid RED-BLUE-RED-BLUE...
(g) CALIBRATION FINISHED!!!
Hi,
i got this from Horizon : http://www.bladehelis.com/ProdInfo/F...bration_EN.pdf
But i don t understand for the up and down elevator, because if you look at the picture, down is stick up and up is down stick.
Is is right ?
Pascandrea is offline        Reply With Quote Quick reply to this message
Old 12-20-2013, 02:50 AM   #23 (permalink)
Blade has released calibration instructions (actually 2 types of calibration):
Looking at it explains why the instructions here are not the same as the instructions mentioned in the RCGroups thread:
*the instructions here resemble the agility mode calibration instructions from Blade.
*the instructions mentioned in the RCGroups thread resemble the stability mode calibration instructions from Blade.
flying-llama is offline        Reply With Quote Quick reply to this message
Old 12-20-2013, 02:56 AM   #24 (permalink)
Originally Posted by Pascandrea View Post
Hi,
Is is right ?
Long history, but the picture is correct (page 12 of the English manual shows the same thing) and standard aircraft terminology: the term "up" elevator refers to the elevator stick being moved backward (or "down" if viewing the Tx vertically) because it will move the nose up on an upright aircraft. Vice-versa with "down" elevator.
Here is a more long winded explanation:
http://www.rcgroups.com/forums/showp...&postcount=609
Old 12-20-2013, 12:39 PM   #25 (permalink)
in the instruction for calibration for stability mode says to hold camera triger switch for 5 seconds.
does this mean we have to mount the camera s well?
angeliak is offline        Reply With Quote Quick reply to this message
Old 12-20-2013, 04:44 PM   #26 (permalink)
No you do not have to have the camera on the quad to do the calibration.when the 180 is in "safe" calibration it is looking at the camera channel to know when to start recording data. I should also add that this should be done out of ground effect and in little to no wind. No wind "inside" would be best.
The calibrations will not remove "all" drift some trim may still be necessary. But should help in occasions where with the RTF you have run out of trim or when the is an extreme difference in trim between flight modes.
sean
Sean
www.BladeHelis.com
Horizon Hobby, Inc.
turtle is offline        Reply With Quote Quick reply to this message
Old 12-20-2013, 09:26 PM   #27 (permalink)
Question:
Ok. I have my 180QX HD bound to the stock tx and have it calibrated with that tx.
If I rebind it to my DX6i, do I need to recalibrate it to the DX6i or is it good to go?
Syma S107-Syma S109-Syma X8C-Syma X8G-Syma X5HC-Syma X5HW-Mini Orion-ProtoX-Syma X5C-1
USAF RETIRED 1968-1988 Vietnam Veteran
Pfloyd is offline        Reply With Quote Quick reply to this message
Old 12-20-2013, 09:43 PM   #28 (permalink)
Blade Forum Support
Originally Posted by Pfloyd View Post
Question:
I wouldn't think so because the calibration is in the board nothing dealing with the tx ( transmitter).
It will be OK you will be good to go :-)
Be blessed
Isaac
Sent from my SM-N900V using Tapatalk
FPV Everything Now
GOD BLESS
Old 12-21-2013, 07:05 PM   #29 (permalink)
i try to cslibrate in stability mode with my dx7se. the camera toggle switch is the flight mode switch. however when i move flight mode switch to position 1 for 5 seconds and then back to 0 and then land the 180qx , the blue light is still on and nothing seems to happen..
Old 12-21-2013, 07:35 PM   #30 (permalink)
If it solid blue it is calibrated. You have to unhook the battery and shut off the DX7s and then turn everything on again and you should be good to go.
Old 12-22-2013, 08:26 AM   #31 (permalink)
but the mannual says :
Release the camera trigger and land the quadcopter. Upon landing, the LEDs should fl ash red then blue. When the
LEDs repeat with one blink per color, the calibration is complete
mine is solid blue...
Old 12-22-2013, 05:24 PM   #32 (permalink)
I had the same problem than you with my DX7, nothing happen after 5 secondes, but what i did, when you are in hover, (if you can because on mine it s was not so easy) you put up the camera trigger for 5 sec, after you put it down, you land the copter and after again you put up and down the camera trigger, and there the led will flash red and blue, but for me they never change to one blink per color ...
Hope it will work for you ...for me it s a bit better than before, the worst is when i fix the camera, in this case the copter is very unstable ...have you the same ?
Old 12-25-2013, 06:53 AM   #33 (permalink)
Adding the camera for me, did not change how it flies, I think its stable either way, however the first time I try some rolls and flips Ill do it with out the camera first
Gaui X5 FES, Gaui X2 Formula, Align 470 LP, Blade 450X,Hanger 9 P-51, Dynam Waco . DX9, PL8
jetskier416 is offline        Reply With Quote Quick reply to this message
Old 01-01-2014, 11:28 AM   #34 (permalink)
(radio = DX8)
Bought a 180QX new from the local hobby shop n' it had this mean right/forward drift.. it was bad.
Was impossible to fly.
Found the calibration video on UToob.. didn't work. After the double blue/red flash => quick alternating blue/red (as if it had lost connection with the DX8. Couldn't get it to go solid blue at all.
Found this thread and got the .pdf instructions from Blade.. still no worky in "stability mode/low angle".
I believe the calibration was successful in the other two modes.. which I don't intend to use.. this is stricly a video capture effort.
Troubleshooting phone session with HH, still couldn't get the LEDs to the solid blue state and beyond.. still went straight to quick blue/red/blue/red. still no 180QX love.
So exchanged it for a new one and Aaahhh.. all is better. No drift problems.. Trimmed it out.. works great. Nice to fly.
HOWEVER, just cuz - decided to try an ddo the calibration anyway.
Still can't complete the cal. process. After the double blue/red flash.. this new one goes to solid red..
Seems like there still may be some issues with the cal. process as written. Maybe just a DX8 thing..
Still flying real nice though, so happy to be moving on.
tomasino is offline        Reply With Quote Quick reply to this message
Old 01-01-2014, 02:39 PM   #35 (permalink)
yeah the calibration is pretty strange, even for me with the Dx7 i never had the solid light ...maybe it works only with their tx ?
Old 01-07-2014, 08:25 PM   #36 (permalink)
I have a nassssty left drift today after a pretty good thump onto the ground. Structurally its fine....
Calibrated in full agility- red/blue
Calibrated in full stable- red blue
calibrated in medium agility- solid red
But it flies great with just a bit of trim.
Doom Buggy is offline        Reply With Quote Quick reply to this message
Old 02-09-2014, 02:35 AM   #37 (permalink)
Issues trying to calibrate for me too...
I followed the stability mode calibration instructions Blade has posted on their own website to the letter: http://www.bladehelis.com/ProdInfo/F...bration_EN.pdf
(Except for step 13, as I don't think the RTF radio allows the trims to center afterwards.)
After landing, the LEDs flash red and blue alternately as expected.
I then disconnect the battery and switch off the radio.
Next time I turn on the radio and connect the battery in stability mode, the trim is just off as much as it was prior to the calibration.
Interestingly, when I put the 180QX back into calibration mode, it seems to remember the previous calibration settings, and is absolutely stable whilst in calibration mode.
Any ideas?
chemoul is offline        Reply With Quote Quick reply to this message
Old 02-09-2014, 11:19 AM   #38 (permalink)
Call HH. They will walk you thought the calibration and if your equipment is defective will assist you in the repair or replacement.
Jim1946 is offline        Reply With Quote Quick reply to this message
Old 02-25-2014, 09:14 AM   #39 (permalink)
Default A couple questions
I have calibrated and still have a right back drift which I trimmed out with the switches on the front og DX8. 15 clicks left 10 forward for solid hover. I try doing the hold the trainer/bind button to finalize calibration with no affect, the lights just keep flashing back and forth.
When I go in to adjust the trim in the tx all surfaces show 5 trim. Why? and would that not just cancel it's self out? 5 R and 5 L = 0 right?
mCX, mCPX X3, Blade CX4, Blade 400, Blade 400FBL Upgraded, NANO QX, mQX, 180QX.
DX6i DSMX, DX8
Phoenix 4
Dano59 is offline        Reply With Quote Quick reply to this message
Old 12-30-2014, 03:09 PM   #40 (permalink)
Default Fear of flying!!!!
Apologies from an oldie in years but very much a newbie in experience. I think I might be caught in a catch 22 situation. I have just treated myself to an early retirement present of a 180 QX and Spektrum DX6. On starting up 3 rotors spin up on throttle setting 6 but to get the fourth to start (rear left standing behind the quad) the throttle setting has to be around 40. On lift off, there is a fairly fast drift to the left which induces a bit of pilot panic and immediate shutdown. I figure that a bit of trim is required and have consulted the HH web site for details which are part listed below. In order to get this trimming procedure to work I need to be able to achieve steps 8, 9 and 10. For someone who has never flown before, how much of a challenge will this be and how big a space do I need to risk it. Any advice gratefully accepted
Jim
Stability Mode Calibration
1. Ensure all trims are centered.
2. Power on the transmitter and move the throttle stick to full throttle.
3. Ensure the transmitter is in Stability High or Low Angle Mode.
4. Hold full up elevator.
5. Connect the fully charged flight battery in the quadcopter.
6. Both LEDs will flash red twice, then blue twice for a few seconds.
7. When the LED turns solid blue, lower the throttle and return the elevator to center.
8. Raise the throttle to bring the quadcopter to a hover.
9. Use the trims on the transmitter to eliminate any drifting, allowing for a stable hover.
10. While in a stable hover, press and hold the camera trigger on the transmitter for 5 seconds. The quadcopter is now calibrating input from the sensors and transmitter. Full down elevator Full up elevator
11. Release the camera trigger and land the quadcopter.
dimbojimbo is offline        Reply With Quote Quick reply to this message
