Go Back   HeliFreak > R/C Helicopter Support > KDS Helicopters General Discussion > KDS Agile 5.5
KDS Agile 5.5 KDS Agile 5.5 Discussion
Like Tree1Likes
Old 12-15-2013, 10:22 AM   #1 (permalink)
Default Whats your 5.5 set up?
Mine is as follows but still in the build.
Kontronik Pyro 650-103LS
Kontronik Jive 100LV
Futaba BLS255 x3
Savox SB-2275MG tail (on test)
Ebar V2
Optipower Ultra 6s 5000
553 Edge blades and 92 tails.
Think thats it. Not sure what headspeed to run either, what you running?
The difference between knowing your s**t and knowing you're s**t!
Optipower - Kontronik Drives
jamin_00 is offline        Reply With Quote Quick reply to this message
Old 12-15-2013, 11:21 AM   #2 (permalink)
ESC HIMODEL ICE SERIES 150A
BEC CCBEC PRO
Motor KDS BL 4020-1100KV - stock pinion
Futaba S9255 (cyclic)
Savox 1290MG (tail)
BRAIN + BT modul + RPM senzor
stock blades and tails
battery GENS ACE 5300Mah 30c 6s - on the way
MSH Miniprotos > MSH Protos> Goblin 500> Agile 5.5>chase360>logo480xx>devil420>HD502cell
seltino is offline        Reply With Quote Quick reply to this message
Old 12-15-2013, 02:25 PM   #3 (permalink)
KDS 4020- 1100 motor
Castle Creation ICE2 120
KDS Servos
KDS EBAR v2
Castle Creations BEC Pro
Revolution 550mm and 95mm Blades
OptiPower Ultra (Of Course)
Futaba RX
Fast-Lad Performance, SAB Heli Division, Kontronik, OptiPower, BK Designs LLC, Jeti USA
Alex Hawtin is offline        Reply With Quote Quick reply to this message
Old 12-16-2013, 12:19 PM   #4 (permalink)
Motor KDS BL5052-1200Kv
ESC KDS 120A-HV
3 x KDS Servos N680
Xbar + KDS N690
UBEC KDS
KDS 550mm CF and 92mm Blades
Vant Battery 5000 6S 45C
Lds1968 is offline        Reply With Quote Quick reply to this message
Old 05-04-2014, 02:53 AM   #5 (permalink)
Scorpion 4020-1100 motor
Yep120lv with power bec
Promodeler hv cyc
Outrage HV tail
Sk 540
Align 550
Blades
Haiyian 5000
Sent from my XT1052 using Tapatalk
Synergy N5c,OS55HZr, Opti fuel, Msh Brain
Gaui X3, sk720, gensace power
Lynx team pilot
pugdavey is offline        Reply With Quote Quick reply to this message
Old 05-04-2014, 12:41 PM   #6 (permalink)
KDS BL4020-1100kv
Mini Vbar pro
Hyperion 2200mah 2s
Futaba BL255Hv x3
KDS N650Hv
Yep 120Hv
Pûlse 5000mah 45C
Kds blades
lorenb is offline        Reply With Quote Quick reply to this message
Old 05-04-2014, 02:23 PM   #7 (permalink)
Hello,
I have found a low RPM set up that works very good for me:
Pyro 650-65 Compettition
Jive 80 HV
Motor Pinion 16 T from Voodoo 600
Belt from Voodoo 600
Lipo, 10S mit 2200mah !!
MKS BLS 650, BLS 251
Mini V-Bari
Pro Carbon Skid
Blades: 550mm and110mm for the tail
Flight weight with Lipo is 3140 gramm this is 110,76oz
So I can run for 8-9 minutes with1500 RPM. Not only Crusing...
The Agile is really a great and very versatile machine!
and this is how it looks like:
Aleusius is offline        Reply With Quote Quick reply to this message
Old 05-04-2014, 08:09 PM   #8 (permalink)
Originally Posted by Aleusius View Post
Hello,
Jive 80 HV
Mini V-Bari
Pro Carbon Skid
What is the weight whitout the Lipo ?
Do you use the original tail blade?
Outrage 550: DS610, DS650, Xera 4020/1000, YGE-100, Spartan Vortex VX1N
HDX HC500, Goblin 380, Vortex VX1E
Gaui X7 Formula,
Vortex VX1N
jacquesjb is offline        Reply With Quote Quick reply to this message
Old 05-05-2014, 01:21 AM   #9 (permalink)
Hi jacquesjb,
the weight without the Lipo is 2590 gramm.
Because of the 1500RPM I have to use 110mm tail blades. On the Agile5.5 I use Radix.
Caren
Old 05-05-2014, 03:45 PM   #10 (permalink)
12S 5.5 with 2600s jive 80hv gov at 2600 ish headspeed
Sent from my HTC6525LVW using Tapatalk
Team Empire Hobby Team HobbyWing
Gaui X7F, Gaui X7 FZ, Gaui NX7
Bubba Gump is offline        Reply With Quote Quick reply to this message
Old 05-05-2014, 08:16 PM   #11 (permalink)
Hi jacquesjb,
Caren
How is the ground fin clearance with the 110mm tail blade with the original landing gear?
Gaui X7 Formula,
Vortex VX1N
Old 05-05-2014, 08:19 PM   #12 (permalink)
Fine. I run 107s on mine at higher headspeeds because I had trouble getting the stock 92s to hold. Tail fin is long enough and there's enough clearance with 550mm blades.
Lots of X-Cells and little sense.
SamIAm is offline        Reply With Quote Quick reply to this message
Old 05-06-2014, 12:50 AM   #13 (permalink)
right, absolutly no problems with 110mm tail blades. Even the fin is long enough.
Old 05-06-2014, 08:46 AM   #14 (permalink)
Thank's a lot
Gaui X7 Formula,
Vortex VX1N
Old 05-07-2014, 09:01 AM   #15 (permalink)
My setup:
-Pyro 650 10+9 YY (535Kv), 21 tooth pulley.
-Jive 80Hv
-12S 3300, waiting for stretch but surprised how quick it is o 550 w/ 3300's.
-HeliCommand HC-3X, Ver 201.
-Futaba BLS451 and BLS251
-Edge 553mm and 92mm
GimpyGolden is online now        Reply With Quote Quick reply to this message
Old 05-27-2014, 09:41 PM   #16 (permalink)
What is the height, lenght and width of the battery compartment ?
Is the X-Nova 4020-1000kv will be enough for sport flying at 2150 rpm?
Gaui X7 Formula,
Vortex VX1N
Old 05-28-2014, 09:21 AM   #17 (permalink)
KDE 550XF-1200-G3 Motor
Castle EDGE 120HV
Western Robotics Hercules Super Mini G2 BEC
iKon FBL Controller w/2 Spektrum DSMX Satellites
Spektrum H6200 for Cyclic
Spektrum H6210 for Tail
Stock Agile kit main and tail blades
Running the iKon governor (white wire from 120HV providing RPM) with 3 head speeds:
Normal Mode: 2100 RPM
Idle Up 1: 2400 RPM
Idle Up 2: 2650 RPM
| Agile 5.5 | Goblin 500 | T-Rex 450 Pro DFC | 130X | mCP X BL | Nano CP X | Nano QX |
(and a ton of planes)
{}{steve}{} is offline        Reply With Quote Quick reply to this message
Old 05-28-2014, 11:18 AM   #18 (permalink)
Yes that motor would work for that.
Team aircapitalheli.com
Travis(twill)
Aircapitalheli.com
Xnova motors and kbdd blades
Twill is offline        Reply With Quote Quick reply to this message
Old 05-28-2014, 03:50 PM   #19 (permalink)
Kds agile 5.5 combo kit with motor, servos, rjx 550 blades and ebar v2 fbl controller
Castle edge 120hv esc
Kds agile 6s 5000mah batteries
Futaba 6008hs receiver
Castle bec pro
Futaba 8fg transmitter
Where are we going, and why am I in this hand basket?
RCHN Citizen 30
Squid628 is offline        Reply With Quote Quick reply to this message
Old 05-29-2014, 04:24 AM   #20 (permalink)
AGile 5.5
KDE DIRECT 600xf G3 530kv
Bavarian demon 3x
RJX HV SERVOS
NANO TECHS x2
YEP 120HV
livedemon is offline        Reply With Quote Quick reply to this message
Human Verification
