Go Back   HeliFreak > R/C Helicopter Support > KDS Helicopters General Discussion > KDS Agile 5.5
KDS Agile 5.5 KDS Agile 5.5 Discussion
Like Tree1Likes
Old 05-29-2014, 02:48 PM   #21 (permalink)
My setups changed now
Heidrive 4956-550kv
Hw 70hv & rpm sensor
2x6s 2700 zippys lipo
Promodeler cyc
Outrage tail
Skookum sk540
Align 550 & v blade 95
3.7kg all up porker !!
Sent from my A210 using Tapatalk
Synergy N5c,OS55HZr, Opti fuel, Msh Brain
Gaui X3, sk720, gensace power
Lynx team pilot
pugdavey is offline        Reply With Quote Quick reply to this message
Old 05-29-2014, 02:51 PM   #22 (permalink)
Nobody can to measure the height, lenght and width of the battery compartment ?
I want to be sure then my lipo GenAces 5300/30C are not too wide.
Outrage 550: DS610, DS650, Xera 4020/1000, YGE-100, Spartan Vortex VX1N
HDX HC500, Goblin 380, Vortex VX1E
Gaui X7 Formula,
Vortex VX1N
jacquesjb is offline        Reply With Quote Quick reply to this message
Old 05-29-2014, 03:05 PM   #23 (permalink)
I can't measure mine right now. Those should fit, but they'll probably be a pain to get in and out. I run Pulse 6S 5000mAh 65C in mine and the dimensions for those are 160mm x 45mm x 51mm. Your battery dimensions are 138.59mm x 42.78mm x 63.2mm so yours 'should' fit if you lay them down on the short side. I don't think they will fit the other way, though, because my Pulse batteries are pretty tight.
| Agile 5.5 | Goblin 500 | T-Rex 450 Pro DFC | 130X | mCP X BL | Nano CP X | Nano QX |
(and a ton of planes)
{}{steve}{} is offline        Reply With Quote Quick reply to this message
Old 05-30-2014, 03:42 PM   #24 (permalink)
Finally flew mine...
Stock airframe and blades.
AR7200BX + satellite
Spektrum 6200's on cyclic
Spektrum 6210 on tail
Castle Ice 120HV
EFlite 600 heli motor
EFlite 2S 1300 for receiver
Pulse 6S 5000 45C
Flew nicely for the first 4:45 then the tail broke loose... Landed no problem, but had to clean and re-loctite the tail control slider... Can't wait to get it back in the air, I really like the sound this heli makes.
Mike
Logo 400SE - Logo 500 - Logo 690SX
Prôtos - Mini, 500, & Max V2
VBar Control
Smash McCrash is offline        Reply With Quote Quick reply to this message
Old 06-07-2014, 06:05 AM   #25 (permalink)
I've been thinking of getting an agile 5.5. I have a scorpion hk3 4025 650 laying around for it on 12 or 10s, don't know yet.
I was thinking of running a yge 90 hv on that. You guys think it would do the job? Or better go with a 120?
Sent from my Nexus5 using Tapatalk
Mikado Logo 600 mini Vbar - Outrage fusion50 ar7200bx - goblin 700 mini Vbar - dx7s - powerlab6
-kenny- is offline        Reply With Quote Quick reply to this message
Old 06-07-2014, 01:09 PM   #26 (permalink)
On 12s you can go with an 90 Amps ESC and you are even save for 600mm blades.
Carbon Fred is offline        Reply With Quote Quick reply to this message
Old 06-07-2014, 03:17 PM   #27 (permalink)
Ever since i had a few shutdowns on my goblin i'd rather overdo on esc's
Old 06-29-2014, 11:18 PM   #28 (permalink)
CC Edge 120HV
Ikon
Stock: motor, blades servos
Powering electrons with 2s
This heli is awesome and service is second to none. Big UPS to KDS USA
kdfi is online now        Reply With Quote Quick reply to this message
Old 11-21-2014, 09:54 PM   #29 (permalink)
My setup.
Stock combo kit.
Stock KDS motor
20 tooth pinion
Castel Edge 100
8s 4000 Sky Lipo
2s 800 receiver pack
Stock KDS EBAR v2
Stock RJX 550 main blades
Stock KDS 92 tail blades
Idle up 1 2450
Idle up 2 2750
I get about 4- 4.5 minutes
I fly a combination of 3D and Big Air.
This 550 is a little beasty. I love the way it flys. It autos great.
Keith Smith, RCHN #231
Spartan, Synergy E7, Legend FBL, Goblin 700, Whiplash E, Furion 6s,GAUI R5, Furion 450s, Xcell 60 , T-REX 600s, T-REX 450s, 300X, 130X, MCPXs. I'll fly what I want to fly. You do the same.
flyul1 is offline        Reply With Quote Quick reply to this message
Old 12-17-2014, 06:47 PM   #30 (permalink)
UPDATE: After 2 shutdowns I have changed my setup.
Combo kit.
Stock KDS motor changed to Scorpion 4025 890 kv
20 tooth pinion changed to 21 tooth pinion
Castel Edge 100
8s 4000 Sky Lipo
Stock KDS EBAR v2
Idle up 1 2450
Idle up 2 2750 changed to 2650
The machine is now not bogable. It has insane power. I have said it before this heli does not need an esc bigger than 100 amps using 8 or more cells..
Old 12-23-2014, 10:13 AM   #31 (permalink)
Mine will be somewhat revised as well from post #15
New 5.5 I'll be building in about a months time will be running:
Pyro 650 10+9YY (535Kv)
Jive Pro 80Hv
Futaba S-Bus / BLS451/256
BeastX
12S 3000
Zeal 570/95
GimpyGolden is offline        Reply With Quote Quick reply to this message
Old 03-17-2015, 01:07 PM   #32 (permalink)
I made the pluge to KDS after looking at either the Agile 5.5 or the 550L Dominator.
My setup:
Savox BSM4750 for the motor
Align DS615 on cyclic DS655 on tail
6s 5000 mAh packs
AR7200BX
HobbyWing 100A Plat. V3
Edge 553s on main, 95mm KBDD on tail
Align 550L, Thunder Tiger E700 V2, SAB: 420, 570, Thunder Sport 700. All controlled through Vcontrol/NEO
-Ideals are peaceful - history is violent.
Skeezix is online now        Reply With Quote Quick reply to this message
Old 03-17-2015, 02:31 PM   #33 (permalink)
my setup
yep120 esc with heat sink
xnova 4025-560
12s2x3300
rail 606 blades 96 tail blades
mks 1240 hv servos
mks 669 on tail
fbl dampers
bobbyra is offline        Reply With Quote Quick reply to this message
Old 03-24-2015, 04:02 PM   #34 (permalink)
Agile5.5
Torq mini hv servos
Kds 4020-1100kv
Mini vbar pro
Kontronik jive 120
Cyclone 555mm and 95mm tails
1x6s 5000mah
acwise32 is offline        Reply With Quote Quick reply to this message
Old 03-24-2015, 06:34 PM   #35 (permalink)
Mini servo's? Interesting. Got any pics of the adapter plates you made up?
Old 03-24-2015, 07:00 PM   #36 (permalink)
My setup
Scorpion 4025 1100kV
YEP 120HV
KST HVs on both cyclic and tail
WR Super Robotics BEC
Mini vbar
Zeal 570s on main
Running on 7s
Logo 800xx 14s / Logo 753xx 12s / Logo 700xx 12s / Logo 700 12s / Logo 690sx 12s / Urukay HPS3 14s / Rush 753 12s / Protos Max V2 800 12s / Shape S8 14s / Specter 700 12s
ah_liang is offline        Reply With Quote Quick reply to this message
Old 05-27-2015, 08:57 AM   #37 (permalink)
My new setup:
Kontronik Pyro 700-52
Kontronik Jive 80Hv
12S 3300 35C Pusle and Gens Ace 12S 3300 45C, both as stick packs
Futaba BLS 451's and BLS256
BeastX MicroBeast
Switch 603/105mm
Old 07-19-2015, 12:10 PM   #38 (permalink)
Setup for my first 5.5(now sold to a friend)
Mini vbar ( mounted on top of the boom mounts on a carbon plate)
Mks servos 6v servos ( can't remember exactly which ones)
Futaba bls 251 tail servo
Gryphon bec
Ice2 hv 120 esc
Quantum 560kv 12s motor
2x zippy 6s 2650's
Rail 556s
Got about 3:30 of decent 3d, unboggable power! HS at 2500
New 5.5 ( realized I really missed this Heli, and should have kept my previous one on 6s so I could share packs with my 7.2, nothing worse than when the 7.2 shreds a belt and I'm stuck with big charged packs!)
Full size blue line Vbar ( sensor up front, and main unit on a carbon tray above the tail boom - man, I wish KDS made this mod to the kits!! Gives such a better set of mounting options.)
Jr 8717hv servos
Align HV tail servo
stock kds motor
Castle talon 120hv esc (using its BEC)
6s 5000 gens ace 65c
Stock blades ( for now really like rails!)
Should make a good back up and second Heli. Once Im sure the belt issues are done with on the 7.2 ( did the big belt upgrade and have been having good luck since) I'll probably convert this one to 12s and really thinking about stretching it .
AndyHe is offline        Reply With Quote Quick reply to this message
Old 08-17-2015, 11:25 PM   #39 (permalink)
They will fit just fine.. Just place them in width wise.. I have some that I fly in my 5.5... My bottom plate is not screwed down and I treat it like a battory tray.. getting the 5300Mah pack in and out are not a problem
FuzzzMan is offline        Reply With Quote Quick reply to this message
Old 09-18-2015, 08:59 PM   #40 (permalink)
My set up:
Castle Ice 100 esc with BEC Pro
Quantum 4125-1100
JR 8917HV on the cyclic
Torq 9188 on the tail
TotalG FBL unit
Edge 553s and KBDD 95s
Normal - 2100
IU1 - 2250
IU2 - 2350
Paul
Agile 5.5 - Q 4125-1100, YEP 120, Brain2 HD FBL / Outrage 550 - HK4020-1390, Edge 120, Brain2 HD
Rave Ballistic FSO - Q 4530-500, Edge 160HV, Brain2 HD / Protos Max V2 - MSH 4530-500, Edge 160HV, Brain2 HD
pctomlin is offline        Reply With Quote Quick reply to this message
Human Verification
