Go Back   HeliFreak > R/C Helicopter Support > 600 Class Electric Helicopters > 600/600 PRO Aftermarket Upgrades and Mods
600/600 PRO Aftermarket Upgrades and Mods Align T-REX 600/600 PRO Aftermarket Upgrades and Mods Support
Old 12-21-2013, 07:39 PM   #1 (permalink)
Default 700 class 530KV motor in a 600 EFL Pro
Hey guys,
Trying to figure out if a 530KV motor will fit in my 600 EFL Pro..Had a little motor blow out and want a suitable substitute over the Christmas holidays until I can find a 510 Kv to put it in it. I know KDE makes a kit for this mod..I have the adjustable motor mount and the upgraded KDE gear so I think the 530 should fit...But just wondering that if I should get it to fit were there any other gotchas I should be aware of? Thanks for the help.
TRex 450L, TRex 500 EFL, TRex 600 EFL, Synergy E7/SE, AS350, Bell 222, Bell 206, Jayhawk, Tiger EC-665, Vbar, Beastx
erospawn is offline        Reply With Quote Quick reply to this message
Old 12-21-2013, 09:37 PM   #2 (permalink)
Align do an upgrade kit, cause I got one today , it's 49 euro . It comes with all you need .
700 pro hv, dominator, (v bar)...G4 nitro hv, v bar, 600 pro, 500 dfc, , 2x 130 , mcpx bl.
sean1098 is offline        Reply With Quote Quick reply to this message
Old 12-21-2013, 11:24 PM   #3 (permalink)
The Align upgrade will allow many large motor options without the need for shimming servos or other tricks to keep the motor from rubbing the front servos. If you do not plan on using the upgrade kit, some of the larger motors can become an issue. I ran a Scorpion 4035-500 and Quantum 4135-530 in my EFL. Both of them rubbed during hard flying. I had to shim one side of the servos quite a bit to angle them enough to prevent the motor from rubbing in flight. I haven't personally tried the Align upgrade kit, but I have heard it solves this issue when flying big motors in the EFL.
More helis than brains
Funky is offline        Reply With Quote Quick reply to this message
Old 02-09-2014, 03:54 PM   #4 (permalink)
What size motor is good for a 600 PRO DFC? Sorry to hijack the thread but I don't want to start a new one and still have trouble finding a current thread on this. I am flip flopping with a 550E or 600E. I still want to be able to do autos which is why I am heavily considering 600 PRO DFC. I am a custom builder and am looking for a scorpion motor and Castle ESC combo. Any suggestions? I don't need it to run like a raped ape but good power similar if not better than align is plenty.
Air goes in and out, Blood goes round and around. Any deviation of the two requires EMS.
WV_Medic is offline        Reply With Quote Quick reply to this message
Old 02-10-2014, 08:33 AM   #5 (permalink)
I believe the KDE 600XF-530 motor was the first after market motor of appropriate size to be a direct replacement for the Align motor on this bird. However, due to the higher torque, some folks recommend bracing the front cyclic servos to prevent the motor can from contacting the servos. There are currently more motor choices.
Goblin 700 KSE/380 KSE, Logo 700/550SX V2, Synergy E5; Spirit Pro;Jeti DS-24/DX8 Gen 2
Simulators (on Mac computer): neXt, Heli-X, AccuRC, RF8, AeroFly RC7 Ultimate
Citizen 259
curmudgeon is offline        Reply With Quote Quick reply to this message
Old 02-10-2014, 12:37 PM   #6 (permalink)
If I were to go with lets say a Scorpion HK-4035-560. Would I need a special mounting plate or something?
Old 02-11-2014, 01:03 PM   #7 (permalink)
I put a HKIII-4035-530kv in my 600pro. I used the performance booster kit to create the required clearance between motor and servos, You may be able to squeeze it in by shimming the servos but i couldn't say for sure.
I had to slot two of the holes in the mount plate to suit the Scorpion bolt pattern, luckily i know a friendly machine shop.
here it is:
Gob 700 Speed | Gob 770 Comp | Gob 630 Comp | Trex 700X | KDS Agile 7.2 | Compass 7HV U | Trex 600Pro (626 stretch) | Kasama Dune 600 | KDS Chase 360 | Devil 420 | XLPower 520
Grumpy_Old_Man is online now        Reply With Quote Quick reply to this message
Old 02-11-2014, 02:45 PM   #8 (permalink)
here it is:
Thanks the for the picture bud! Thats a nice set up there. What gears are you running and Whats the power like? What kinda flight times are you seeing with head speeds? Shortly before I got out of the heli scene the last time I was just learning electrics. I was a nitro guy myself. Eventually I got tired of lugging nitro supplies to and from the field. Plus it sucks spilling it in the car.
Old 02-11-2014, 04:39 PM   #9 (permalink)
Thanks!
It's the standard 'performance booster kit' gearing, so 118 main gear and 14t pinion.
I'm a relative nubie on helis, my flying is limited to loops and rolls, but on 2000RPM head speed I'm getting 7 minutes easy. I've got max head speed set at 2200 but it would run higher if I wanted.
Old 07-16-2014, 11:12 AM   #10 (permalink)
I am not familiar with the "Booster kit"
I have the KDE Direct adjustble motor mount and the red frame braces.
Is the "last step" the 118t main & 14t pinion? That would add some space between the servos and the motor can and make a minor change to the gear ratio (from 8.61:1 to 8.42:1)
Old 11-09-2014, 09:57 PM   #11 (permalink)
I have run everything from what I consider a wimpy older Align 750MX up to the KDS 495kv older version, and the newer gen Kds 505kv, then the Scorp 4035-630. And am now running the Scorp 4025-520 Ultimate Mikado version on mine. Which is what is staying in there.
Old 08-24-2016, 02:41 PM   #12 (permalink)
Gonna put a rewound 1.5mm wire with 505KV in my Pro.
No idea what i can do with my 600MX though..? Rewind to maybe 6S, combi wind so i can fly 6/12S?
apper001 is offline        Reply With Quote Quick reply to this message
Human Verification
