Go Back   HeliFreak > Multi Rotor Support > Blade Multirotor Support > 350QX
350QX Blade 350QX Multirotor Information and Help
Old 01-23-2014, 03:38 PM   #1 (permalink)
Lightbulb Stagility, it's a new flight mode - For dx6i radios and up!
Have you ever wanted to be able to flip the 350qx but were worried you would over or under input?
Or have you wanted agility to fly like agility but corrected like stability when you needed it most?
Well if you have,there are a few mixes below that will let you do just that Flight videos and instructions on various radios are below.
Stagility, it's a new flight mode! 180qx, 200qx and the 350qx (9 min 54 sec)
FOR ANY RADIO YOU MUST ALREADY BE IN STANDARD STABILITY MODE TO BE ABLE TO PROPERLY ACCESS STAGILTY!
Dx9/18
Set all as 3 point curves.
AlL/GER and ELE/GER
1)-125
2)0
3)-125
Make GER/GER
1)0
2)-50 or less (suggested -45)
3)0
To make the transition larger, lower the GER/GER towards 0. To make it smaller increase the negative number up to -50%
IF YOU WANT ALL VOICE COMMANDS AND AUTO START/STOP FEATURE PLEASE SEE THE DOWNLOAD LINK AT THE BOTTOM OF THIS POST.
Here is a demo of the auto start feature and all the voice commands (minus the newly added on/throttle cut voices to the momentary start switch)
DX9 - 350qx & Full Time Stagility Flight (5 min 19 sec)
350qx Out in the Cold W/Stagility (4 min 26 sec)
This is a different way to program Stagility on the dx9 to different switch layouts than in my video, though shows how easy it is to setup anyway you want
DX9 Program Guide For 350QX & 180QX StaGility Mode (1 min 21 sec)
__________________________________________________ __________________________________________________ __________________________________________________ __________________________________________________
Dx8 mix - These mixes can be used on the dx9/18 if wanted as well --Thanks to HFman (RJBishop on rcgroups) for a great start on using mixes without curves for ALL the lower channel radios.
Mix 1- ALE-Gear
Rate: -125%
+125%
Offset: 0
Sw: Mix1 (Throttle Hold switch)
Mix 2- ELE-Gear
Rate: -125%
+125%
Offset: 0
Sw: Mix 1
Mix 3 - Gear-Gear
Rate: 0%
+100%
Offset: 50% or less (suggested 45%)
Sw: Mix 1
Gear to gear will give you adjustability of stability to agility transition. As you lower the offset below 45% it will make the center of the stick less sensitive.
DX7s - Thanks to FoosYou for dialing it in
*suggestion permanently toss standard agility mode and use THold toggle as the SW
Mix 2- ALE-Gear
Rate: -125%
+125%
Offset: 0
Sw:
Mix 3- ELE-Gear
Rate: -125%
+125%
Offset: 0
Sw:
Mix 4 - Gear-Gear THIS IS AN ADDITIONAL GEAR MIX! Leave the stock mix 1 Ger/Ger alone!
Rate: 0%
+100%
Offset: -50% or less (suggested -45%)
Sw:
DX7s Stagility mode setup for 350QX (4 min 38 sec)
Dx6i - Thanks to Highoctane22 for help dialing it in in
Travel Adj
Gear (up) 100%
Gear (down) 45%
Mix 1
Aile -> Gear
Rate D -125% U + 125%
SW MIX Trim Inh
Mix 2
ELEV -> Gear
SW MIX Trim Inh
Gear down can be adjusted 1-2% for higher or lower sensitivity
* NOTE-You will lose Standard Agility Mode-
Blade 350 QX Stagility Mode how to set up For DX6I radio. (3 min 8 sec)
DOWNLOAD FOR STAGILITY SPM FILES
Mixing the 6th channel for tilt gimbal or servo use
Many do not realize that the 6th channel on the Blade 350qx is only used at 85% to activate RTH. This means you have almost an entire channel to use if you use a simple mix.
R Knob (or any other switch) to aux1
rate 100% and 123%
Offset 50%
Switch- RTH toggle (off position)
indoorheli is offline        Reply With Quote Quick reply to this message
Old 01-23-2014, 03:54 PM   #2 (permalink)
RZR007 is offline        Reply With Quote Quick reply to this message
Old 01-23-2014, 03:55 PM   #3 (permalink)
You are such a tease!
HIGHOCTANE22 is offline        Reply With Quote Quick reply to this message
Old 01-23-2014, 03:56 PM   #4 (permalink)
TBS Discovery Naza V2 900KV T-Motor/ESC Combo
Blade 350QX-DX6i Tarot Gimbal + Fatshark Attitude Set
Couple of Nano QX's
http://www.youtube.com/armenian
Armenian is offline        Reply With Quote Quick reply to this message
Old 01-23-2014, 04:08 PM   #5 (permalink)
Originally Posted by Armenian View Post
Replace " PICS!" with "set up instructions"...
Old 01-23-2014, 04:08 PM   #6 (permalink)
Stop teasing.
Quadflyer is offline        Reply With Quote Quick reply to this message
Old 01-23-2014, 04:48 PM   #7 (permalink)
I got all the time till spring
Thanks IndoorHeli...
I am sure this will be a new challenge to all, that try it and a very interesting topic indeed. keep th great work on!
Never a Pro, but always try to be helpful. that is me. Happy flying!
fishycomics is offline        Reply With Quote Quick reply to this message
Old 01-23-2014, 05:18 PM   #8 (permalink)
It's TRUE guys, I JUST watched a video! The guy is a flippin' genius (pun intended).
I'll be programming my radio tonight.
-Shane
ShaneXman is offline        Reply With Quote Quick reply to this message
Old 01-23-2014, 05:39 PM   #9 (permalink)
-Shane
I believe it...NOW WHAT ARE THE SETTINGS
Old 01-23-2014, 05:51 PM   #10 (permalink)
does anyone have the link to the video?
LayzTexan is offline        Reply With Quote Quick reply to this message
Old 01-23-2014, 06:13 PM   #11 (permalink)
Oh heck ya! I'm afraid to put it into agility mode for fear of not being able to
recover before the dreaded crash! Would love to put it into my TX!!!!!
bnexpress is offline        Reply With Quote Quick reply to this message
Old 01-23-2014, 06:22 PM   #12 (permalink)
There isn't one YET. Indoorheli is a good buddy of mine, so he sent it off to me as soon as he got back from the park. I'm sure he'll post it though, just hang tight.
-Shane
Old 01-23-2014, 06:23 PM   #13 (permalink)
Dude not funny its been clearly to long and my blades are turning blue with anticipation
hotrodhawk is offline        Reply With Quote Quick reply to this message
Old 01-23-2014, 06:24 PM   #14 (permalink)
He just went BACK to the park for a bit more testing, but he should have something pretty awesome for you guys in a few.
-Shane
Old 01-23-2014, 06:28 PM   #15 (permalink)
Let me take a guess here. Moving the aileron or elevator to an extreme (say past 75%), changes the mode to agility. And as soon as you release the aileron or elevator back to center (or less than 75%), mode changes back to stability. Grandma will be flying loops and rolls in the backyard!
P@reez is online now        Reply With Quote Quick reply to this message
Old 01-23-2014, 06:33 PM   #16 (permalink)
Shane got a vid via skype earlier today, no video online yet.
Sorry, guys I am at the park testing lower rates aka 100% rates to makes sure it works as it did at max ( i fly at EPA150% and rates at 125% =max possible)
[email protected] - no it does not take an extreme movement, it is very quick and close to center
Old 01-23-2014, 08:24 PM   #17 (permalink)
450X, 350 QX (GoPro H3B), 130X, Nano CP X, Nano QX, Hubsan X4, Proto X Nano
Spektrum DX7s
Phoenix Sim
Aerial pics at http://foosyou.imgur.com
FoosYou is offline        Reply With Quote Quick reply to this message
Old 01-23-2014, 08:31 PM   #18 (permalink)
edin508 is offline        Reply With Quote Quick reply to this message
Old 01-24-2014, 12:45 AM   #19 (permalink)
i cant wait for this
blader is offline        Reply With Quote Quick reply to this message
Old 01-24-2014, 05:39 AM   #20 (permalink)
Video shows as unavailable
Edit: Now it shows as processing so I assume the tubes are slow.
Spektrum DX7s
Phoenix Sim
