350QX Blade 350QX Multirotor Information and Help |
#41 (permalink) |
![]() I am long way from being able to fly in agility mode. I recently purchased the dx9 but I have not set it up to the 350 QX. Can someone share the basic or default setup?
#42 (permalink) |
![]() Join Date: Oct 2007
![]() -------------Heads up--------------
While trying to figure out a mix that works for a dx8 due to user input that it didnt work well on two 3 point curves, I made a new mix. It makes stagility even faster on response from stability to agility for the dx9 and makes it work with a dx8 using a combo of 3 mixes It is now a 3 mix combo for best results. Please check first post with an update to the mixes later today |
#43 (permalink) | |
![]() Quote:
![]() -Shane |
#44 (permalink) | |
![]() Quote:
#45 (permalink) | |
![]() Quote:
#46 (permalink) |
![]() Works great on my 180qx, haven't tried it on my 350qx yet.
Thank you... ![]()
Steve - KT4RJ |
#47 (permalink) |
![]() Does anybody know if this will work on a nano qx? I tried with no luck. However, I am a rookie at this!!!
#48 (permalink) | ||||
![]() Quote:
Try this and test it on the bench, if this works it should work for a dx6i too Quote:
![]() I had to use the sequencer for flight mode on my nano qx instead of mixes. |
#49 (permalink) |
![]() Yep, this worked on the DX8:
Mix 1- ALE-Gear Rate: -125% +125% Offset: 0 Sw: Mix1 (Throttle Hold switch) Mix 2- ELE-Gear Rate: -125% +125% Offset: 0 Sw: Mix 1 Gear SubTrim: -112 (You may need to adjust this a little. Adjust this so that when in stability mode, you are just a couple points away from switching into Agility mode) Gear Travel: (This evens out the sub-trim introduced above as close as is feasible) 65%, 150%
Blade 130X- My cul-del-sac flyer. Blade 450X w/MSH Brain - My Ferrari T-Rex 600 EFL Pro w/SK-720 BE, KDE600XF & SK-GPS - My BMW T-Rex 700 HV DFC w/VBar, Kosmik 200 & KDE700XF - My muscle heli |
#50 (permalink) |
![]() Is there hope for the DX6i with all these new mixes?
#52 (permalink) |
![]() Oh, so the DX7s will work too? Just pop in the DX8 settings? Sorry, barely know how to setup my radio let alone getting into this crazy stuff!
450X, 350 QX (GoPro H3B), 130X, Nano CP X, Nano QX, Hubsan X4, Proto X Nano Spektrum DX7s Phoenix Sim Aerial pics at http://foosyou.imgur.com |
#53 (permalink) | ||
![]() Here is the revised video utilizing the three curve mixes for better adjustability for the center transition of stability/agility
#55 (permalink) |
![]() The DX8 method should also work on the DX6i, if not mistaken.
#56 (permalink) |
![]() I have a DX7s, and I'm don't understand what we're doing here with the mix as well as I would like.
Will someone post up that they have this working with a DX7s once they get it. I'm concerned that we already have to use a mix with the 7s to activate agility mode because it doesn't have the 3 position flight mode switch that the DX8 has. |
#57 (permalink) |
![]() OMG this thread just keeps getting better and better.
#58 (permalink) |
![]() Well, I tried to duplicate the settings in post #1 in My Nano QX, but alas something is not right...Switch H does nothing at all, cant get the red light unless I switch modes as before
Anyone got an idea what might be wrong?
nCPX(3)*mCPX(25)*130X(5)*130X-L(6)*180CFX(12)*300X(2) 450X(3)*470LP*GauiX3*nanoQX*180QX*DX9*HF180060*AMA 988253
#59 (permalink) |
![]() Anyone have the time to accept a phone call and walk Me thru the Nano QX settings on a DX9?
#60 (permalink) | |
![]() Quote:
