Go Back   HeliFreak > Multi Rotor Support > Blade Multirotor Support > 180QX
180QX Blade 180QX Helicopters Information and Help
Old 01-27-2014, 07:54 PM   #21 (permalink)
Originally Posted by JonJet View Post
Not sure but it cannot hurt...
I don't have the DX6i anymore, sold it when I got the DX9...but it should work just fine according to Octane's guide
If the DX6i settings work properly, you should be able to see the indicator switch from blue to red when StaGility is active even with the quad sitting still...Mine does on the DX9
130X(5)*130X-L(6)*180CFX(15)
nanoQX*180QX*DX9*HF180060*AMA 988253
Old 01-27-2014, 08:02 PM   #22 (permalink)
I'll give it another try. This time, I'll rebind. I'll report back with the results.
"Nothing is as constant as changes"
DX9, DX6i, Blade Nano CP X, ZYX "Blade" 130X, Blade 180 CFX, Blade 230S, Blade 300X, Blade 450 3D (about 2 b FBL; have the parts, not the time), Blade 180QX, Blade 230S V2, Convergence, Mini Convergence.
Neunerball is offline        Reply With Quote Quick reply to this message
Old 01-27-2014, 08:10 PM   #23 (permalink)
Default Re: Stagility, Its a new flight mode!
Whoops... mistakenly read you had a dx9.
Dx6 will lose standard agility mode due to the lack of mixes. But that's ok and I'll show why shortly.
Wait for my edit..I never say it right the first time!
indoorheli is offline        Reply With Quote Quick reply to this message
Old 01-27-2014, 08:17 PM   #24 (permalink)
Yes...I think you are right...but you gain StaGility
Old 01-27-2014, 08:27 PM   #25 (permalink)
...Dx6 will lose standard agility mode due to the lack of mixes. But that's ok and I'll show why shortly...
Still doesn't work, even after rebinding. Like I said I'll have to get me a DX9. I might be able to sell my DX6i to a coworker.
Old 01-27-2014, 08:30 PM   #26 (permalink)
NOW YER TALKIN MY LANGUAGE !
The DX9 Rocks, Man...seriously You cannot do better in My opinion !
Old 01-27-2014, 08:30 PM   #27 (permalink)
A couple guys here in Freak looking for DX6i...WTB threads
Old 01-29-2014, 07:52 PM   #28 (permalink)
Default futaba settings?
I've been flying helis for several years. I love this little quad. I'm not having any problems flying in all 3 modes. But I'm intigued by stagility. I fly with a Futaba 9CHP. It has the Spektrum module, so that's how I can bind with the 180. I don't have a Spekrum radio so do you know what mixes I can use on my Futaba to invoke stagility? I would like to give it a try.
Gunner
Fusion 50 FBL, HD Cell 500 FBL, Pantera 50 FBL, Tiger 50 MKII, Trex 450, Blade 350 QX
Futuba 9CHP w/Spektrum module, Scorpion, OS 50 hyper, AR7200BX, IKON
Gunner is offline        Reply With Quote Quick reply to this message
Old 01-29-2014, 07:55 PM   #29 (permalink)
I would suggest you start with the mixes...not sure how many you can do, but you need 3 mixes to make it work...
You'll know if it's successful while the heli is still on the floor, rotors stopped because you can test it there
Old 01-29-2014, 07:57 PM   #30 (permalink)
You might want to make a copy of your 180QX model...and play with it there..
Use the mix instructions for the DX9 as a start point and see how far you can get
Old 01-29-2014, 08:06 PM   #31 (permalink)
I dont need the mode either..actually I made it to help others get into the flippin But I have found it is a nice safety net and doesnt interfere with my normal flying as seen here. So...I tossed agility mode all together
DX9 - 350qx & Full Time Stagility Flight (5 min 19 sec)
As far as mixes I would guess it would be pretty similar unless they are the opposite sides as in, right rudder is negative % movement on spektrum, make sure it is so on Futaba too.
As Jon said, start with a copy and try the aileron to ger mix. Then put the 180 right in front of you add aileron and you will see it hit from agility to stagility..or not. If not try the opposite mix
Old 01-29-2014, 09:07 PM   #32 (permalink)
Jon, Indoor. Ok, my Futaba has 7 programmable mixes. But only 2 that I can set curves on. I have a couple of standard mixes like elev to flap, elevon, ailvator but I can't set curves on those. Only rates. The programmable mixes 1-5 allow me to pick whatever I want to mix, but I can only set 2 rates and 1 offset. Could I use one of these? THanks.
Gunner
Old 01-29-2014, 09:10 PM   #33 (permalink)
You can sure try...it will either work or it won't...maybe Ivan (indoorheli) the mixology master will pop in here with a suggestion for you
Old 01-29-2014, 09:16 PM   #34 (permalink)
Also, I can only go -100 to +100 on the curve. But I can set the endpoints to -125 to +125. So I set up the Ail to Gear curve and the Elev to Gear curve. Switch E, a 3 position switch, is the one I currently use to switch between Stability low and hi and Agility. What switch should I set the mixes to use?
Gunner
Old 01-29-2014, 09:18 PM   #35 (permalink)
You can use any switch you want...it only needs to be a 2-position...
Just make sure all 3 mixes are tied to the same position
Old 01-29-2014, 09:19 PM   #36 (permalink)
Please keep in mind that for StaGility to work, you MUST select Stability Mode (not smart mode) AND the mixes switch
Old 01-29-2014, 11:51 PM   #37 (permalink)
You can use end point or curves, I use curves since that is what I am more used to.
If you have a 3 position switch for stability and agility I would use that switch for stagility as well.
For me it would be stability, stagility, then agility
Old 01-30-2014, 12:33 AM   #38 (permalink)
Gunner is getting closer to being done !
He's got a swapping problem with the switches, but it's properly mixed...he just has to get them linked correctly
Old 01-30-2014, 12:41 AM   #39 (permalink)
Hey Ivan...Octane is gonna do a step-by-step picture tutorial for the DX6i...
I've got one for the DX9/18
We need someone to do the DX7 and the DX8 and I'll make a step-by step thread for all of them
Would be nice if We could get 4-5 guys with the SPM files for the DX7,8,9 to make distribution a lot easier
Old 01-30-2014, 11:14 AM   #40 (permalink)
I added a new .spm file and text to the first post. Let me know if it doesnt download correctly
